path: root/arch/arm/mach-at91
2011-12-21ARM: at91: fix clock conid for atmel_tcb.1 on 9260/9g20Jean-Christophe PLAGNIOL-VILLARD
commit 1808958d27b1250295f01dff4997d8a8814adaab upstream. The conid is supposed to be t0/t1/t2_clk. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-04AT91: Change nand buswidth logic to match hardware default configurationNicolas Ferre
The recently modified nand buswitth configuration is not aligned with board reality: the double footprint on boards is always populated with 8bits buswidth nand flashes. So we have to consider that without particular configuration the 8bits buswidth is selected by default. Moreover, the previous logic was always using !board_have_nand_8bit(), we change it to a simpler: board_have_nand_16bit(). Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Tested-by: Ludovic Desroches <ludovic.desroches@atmel.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-06-25at91: Use "pclk" as con_id on at91cap9 and at91rm9200Joachim Eastwood
Hello, I am not 100% sure this is the right thing to do, but it makes the atmel-ssc driver happy on my at91rm9200 board. This unifies the con_id across all at91 machines. The atmel-ssc driver expects the con_id to be "pclk" or it will fail probing. Signed-off-by: Joachim Eastwood <joachim.eastwood@jotron.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2011-06-25at91: fix udc, ehci and mmc clock device name for cap9/9g45/9rlJean-Christophe PLAGNIOL-VILLARD
2011-06-25at91: fix at91_set_serial_console: use platform device idJean-Christophe PLAGNIOL-VILLARD
2011-05-25at91: drop at572d940hf supportJean-Christophe PLAGNIOL-VILLARD
no-one use it and it's nearly impossible get a board to work on it and the Mainline implementation was never finished Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Cc: Andrew Victor <linux@maxim.org.za>
2011-05-25at91rm9200: introduce at91rm9200_set_type to specficy cpu packageJean-Christophe PLAGNIOL-VILLARD
as we can not detect it by defaut the type will be bga introduce cpu_is_at91rm9200_bga and cpu_is_at91rm9200_pqfp Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-05-25at91: drop boot_params and PLAT_PHYS_OFFSETJean-Christophe PLAGNIOL-VILLARD
select ARM_PATCH_PHYS_VIRT as with ARM_PATCH_PHYS_VIRT you can patch boot_params at runtime or any recent bootloader will provide a valid atags pointer in r2 as point out by Russell on AT91 we never use XIP so se do not need PLAT_PHYS_OFFSET Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Cc: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-25at91: factorize common irq IDJean-Christophe PLAGNIOL-VILLARD
2011-05-25at91: switch to CLKDEV_LOOKUPJean-Christophe PLAGNIOL-VILLARD
we do not change the clock naming convention so does not need to switch the AVR32 yet Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-05-25at91: fix map_io init usageJean-Christophe PLAGNIOL-VILLARD
switch early init to init_early and introduce soc map_io with this Patch we will not do any more early device setup during the map io tks to Russell to point the new call back Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Andrew Victor <linux@maxim.org.za>
2011-05-25at91/board-eco920: remove at91_beeper ressource as no driver at91_beeper existJean-Christophe PLAGNIOL-VILLARD
2011-05-25atmel_serial: keep the platform_device unchangedJean-Christophe PLAGNIOL-VILLARD
specify the port num via platform_data this will allow to match the clock with the plaform_dev staticaly Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Alan Cox <alan@linux.intel.com> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-25at91: remove MTD_NAND_ATMEL_BUSWIDTH_16 optionJean-Christophe PLAGNIOL-VILLARD
no board configure it as 'n' and it's an issue to merge all defconfigs in one On AT91SAM926x boards both types of NAND flash can be present (8 and 16 bit data bus width). so will pass it via system_rev Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-23at91: Add ARCH_ID and basic cpu macros definition for 5series chips family.Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-04-23arm: at91: fix compiler warning for eb01 board buildGreg Ungerer
Fix compiler warning when building for AT91EB01 board: arch/arm/mach-at91/board-eb01.c:41: warning: initialisation from incompatible pointer type Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2011-04-23ARM: at91: AT91CAP9 has a macb deviceUwe Kleine-König
commit ee621dd (net: atmel_macb Kconfig: remove long dependency line) replaced a list of several explicit machines in the dependencies of MACB by a single symbol that is selected by the respective machines. ee621dd missed to let ARCH_AT91CAP9 select HAVE_NET_MACB though which is fixed here. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2011-04-10treewide: remove extra semicolonsJustin P. Mattock
Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: at91: Cleanup irq chipThomas Gleixner
Avoid the whole lazy disable dance in the demux handler by providing a irq_disable() callback. Use the proper accessor functions and tidy up gpio_irq_handler() Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Use genirq lockdep helper to set lock classThomas Gleixner
Remove the open coded access to irq_desc which will fail on sparse irq and use the proper wrappers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: at91: at572d940hf: Fix SDRAMC defineThomas Gleixner
That wants to be AT91_SDRAMC0 Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-16Merge branch 'p2v' into develRussell King
Conflicts: arch/arm/kernel/module.c arch/arm/mach-s5pv210/sleep.S
2011-02-19ARM: 6665/1: Add Snapper9260 rtc wakeup interrupt pinRyan Mallon
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-19ARM: 6664/1: AT91: Use macros for gpio_to_irq/irq_to_gpioRyan Mallon
Replace the static inline functions for gpio_to_irq/irq_to_gpio so that they can be used in static initialisers. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-15Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (161 commits) ARM: pxa: fix building issue of missing physmap.h ARM: mmp: PXA910 drive strength FAST using wrong value ARM: mmp: MMP2 drive strength FAST using wrong value ARM: pxa: fix recursive calls in pxa_low_gpio_chip AT91: Support for gsia18s board AT91: Acme Systems FOX Board G20 board files AT91: board-sam9m10g45ek.c: Remove duplicate inclusion of mach/hardware.h ARM: pxa: fix suspend/resume array index miscalculation ARM: pxa: use cpu_has_ipr() consistently in irq.c ARM: pxa: remove unused variable in clock-pxa3xx.c ARM: pxa: fix warning in zeus.c ARM: sa1111: fix typo in sa1111_retrigger_lowirq() ARM mxs: clkdev related compile fixes ARM i.MX mx31_3ds: Fix MC13783 regulator names ARM: plat-stmp3xxx: irq_data conversion. ARM: plat-spear: irq_data conversion. ARM: plat-orion: irq_data conversion. ARM: plat-omap: irq_data conversion. ARM: plat-nomadik: irq_data conversion. ARM: plat-mxc: irq_data conversion. ... Fix up trivial conflict in arch/arm/plat-omap/gpio.c (Lennert Buytenhek's irq_data conversion clashing with some omap irq updates)
2011-01-14Merge branch 'for_rmk' of git://github.com/at91linux/linux-2.6-at91 into ↵Russell King
devel-stable
2011-01-14AT91: Support for gsia18s boardIgor Plyatov
The GS_IA18_S (GMS) is a carrier board from GeoSIG Ltd used with the Stamp9G20 SoM from Taskit company. It operate as an internet accelerometer. Signed-off-by: Igor Plyatov <plyatov@gmail.com> [nicolas.ferre@atmel.com: rm Kconfig, whitespace fixes, change machine name] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-01-14AT91: Acme Systems FOX Board G20 board filesSergio Tanzilli
Signed-off-by: Sergio Tanzilli <tanzilli@acmesystems.it> [nicolas.ferre@atmel.com: whitespace fixes, change machine name] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-01-14AT91: board-sam9m10g45ek.c: Remove duplicate inclusion of mach/hardware.hJesper Juhl
Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2011-01-13Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) Documentation/trace/events.txt: Remove obsolete sched_signal_send. writeback: fix global_dirty_limits comment runtime -> real-time ppc: fix comment typo singal -> signal drivers: fix comment typo diable -> disable. m68k: fix comment typo diable -> disable. wireless: comment typo fix diable -> disable. media: comment typo fix diable -> disable. remove doc for obsolete dynamic-printk kernel-parameter remove extraneous 'is' from Documentation/iostats.txt Fix spelling milisec -> ms in snd_ps3 module parameter description Fix spelling mistakes in comments Revert conflicting V4L changes i7core_edac: fix typos in comments mm/rmap.c: fix comment sound, ca0106: Fix assignment to 'channel'. hrtimer: fix a typo in comment init/Kconfig: fix typo anon_inodes: fix wrong function name in comment fix comment typos concerning "consistent" poll: fix a typo in comment ... Fix up trivial conflicts in: - drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c) - fs/ext4/ext4.h Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
2011-01-13ARM: at91: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
2011-01-05Merge branch 'clksrc' into develRussell King
Conflicts: arch/arm/mach-vexpress/v2m.c arch/arm/plat-omap/counter_32k.c arch/arm/plat-versatile/Makefile
2010-12-22Merge branch 'master' into for-nextJiri Kosina
Conflicts: MAINTAINERS arch/arm/mach-omap2/pm24xx.c drivers/scsi/bfa/bfa_fcpim.c Needed to update to apply fixes for which the old branch was too outdated.
2010-12-21mmc: at91_mci: fix multiblock SDIO transfersYauhen Kharuzhy
The AT91 MCI has special SDIO transfer types: SDIO block and SDIO byte transfers, but at91_mci driver doesn't use them and handles all SDIO transfers as ordinary MMC block transfers. This causes problems for multiple-block SDIO transfers (in particular for 256-bytes blocks). Fix this situation by checking the opcode for SDIO CMD53 and setting the transfer type in the AT91_MCI_CMDR register properly. This patch was tested with libertas SDIO driver: problem with TX timeouts on big packets was eliminated. Signed-off-by: Yauhen Kharuzhy <yauhen.kharuzhy@promwad.com> Cc: <stable@kernel.org> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-12-19ARM: AT91: update clock source registrationRussell King
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new interfaces were added which simplify (and optimize) the selection of the divisor shift/mult constants. Switch over to using this new interface. Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-17at91: Refactor Stamp9G20 and PControl G20 board fileChristian Glindkamp
As PControl G20 is a carrier board for the Stamp9G20 SoM, some code can be shared. Therefore board-stamp9g20.c is refactored to allow reusing the SoM initialization and board-pcontrol-g20.c is modified to use it. Signed-off-by: Christian Glindkamp <christian.glindkamp@taskit.de> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-12-17at91: Fix uhpck clock rate in upll caseRyan Mallon
The uhpck clock should be divided from the utmi clock, not its parent (main). This change is mostly cosmetic as the uhpck rate value is not used anywhere except for the debugfs clock output. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-11-30at91/board-yl-9200: fix typo in video supportJean-Christophe PLAGNIOL-VILLARD
for the epson frambuffer support it's CONFIG_FB_S1D13XXX not CONFIG_FB_S1D135XX Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-11-30at91/picotux200: remove commenting usb device and dataflash supportJean-Christophe PLAGNIOL-VILLARD
as based on http://www.picotux.com/pt200/picotux200.pdf these board does not have such I/O Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-11-30at91: rename rm9200ek and rm9200dk board file nameJean-Christophe PLAGNIOL-VILLARD
to be a few more concistant with the other boards as ek is for evaluation kit and dk for development kit Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Andrew Victor <linux@maxim.org.za>
2010-11-30at91rm9200ek: fix warning: 'ek_mmc_data' defined but not usedJean-Christophe PLAGNIOL-VILLARD
2010-11-30at91rm9200dk: fix warning: 'dk_mmc_data' defined but not usedJean-Christophe PLAGNIOL-VILLARD
2010-11-30at91: Convert remaining boards to new-style UART initializationJean-Christophe PLAGNIOL-VILLARD
Convert the following AT91RM9200-based boards to the new-style UART initialization: - Ajeco 1ARM Single Board Computer - Sperry-Sun KAFA board - picotux 200 Remove the deprecated at91_init_serial Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Andrew Victor <linux@maxim.org.za>
2010-11-16suspend: constify platform_suspend_opsLionel Debroux
While at it, fix two checkpatch errors. Several non-const struct instances constified by this patch were added after the introduction of platform_suspend_ops in checkpatch.pl's list of "should be const" structs (79404849e90a41ea2109bd0e2f7c7164b0c4ce73). Patch against mainline. Inspired by hunks of the grsecurity patch, updated for newer kernels. Signed-off-by: Lionel Debroux <lionel_debroux@yahoo.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
