path: root/arch/arm/mach-bcm/platsmp.c
2017-03-02sched/headers: Prepare for new header dependencies before moving code to ↵Ingo Molnar
<linux/sched/clock.h> We are going to split <linux/sched/clock.h> out of <linux/sched.h>, which will have to be picked up from other headers and .c files. Create a trivial placeholder <linux/sched/clock.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-28ARM: 8641/1: treewide: Replace uses of virt_to_phys with __pa_symbolFlorian Fainelli
All low-level PM/SMP code using virt_to_phys() should actually use __pa_symbol() against kernel symbols. Update code where relevant to move away from virt_to_phys(). Acked-by: Russell King <rmk+kernel@armlinux.org.uk> Reviewed-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2016-08-01Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Olof Johansson: "Device tree contents continue to be the largest branches we submit. This time around, some of the contents worth pointing out is: New SoC platforms: - Freescale i.MX 7Solo - Broadcom BCM23550 - Cirrus Logic EP7209 and EP7211 (clps711x platforms)_ - Hisilicon HI3519 - Renesas R8A7792 Some of the other delta that is sticking out, line-count wise: - Exynos moves of IP blocks under an SoC bus, which causes a large delta due to indentation changes - a new Tegra K1 board: Apalis - a bunch of small updates to many Allwinner platforms; new hardware support, some cleanup, etc" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (426 commits) ARM: dts: sun8i: Add dts file for inet86dz board ARM: dts: sun8i: Add dts file for Polaroid MID2407PXE03 tablet ARM: dts: sun8i: Use sun8i-reference-design-tablet for ga10h dts ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04 ARM: dts: sun8i: reference-design-tablet: Add drivevbus-supply ARM: dts: Copy sun8i-q8-common.dtsi sun8i-reference-design-tablet.dtsi ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for utoo p66 dts ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for dit4350 dts ARM: dts: sun5i: reference-design-tablet: Remove mention of q8 ARM: dts: sun5i: reference-design-tablet: Set lradc vref to avcc ARM: dts: sun5i: Rename sun5i-q8-common.dtsi sun5i-reference-design-tablet.dtsi ARM: dts: sun5i: Move q8 display bits to sun5i-a13-q8-tablet.dts ARM: dts: sunxi: Rename sunxi-q8-common.dtsi sunxi-reference-design-tablet.dtsi ARM: dts: at91: Don't build unnecessary dtbs ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitions ARM: dts: at91: at91sam9g25ek: fix isi endpoint node ARM: dts: at91: move isi definition to at91sam9g25ek ARM: dts: at91: fix i2c-gpio node name ARM: dts: at91: vinco: fix regulator name ARM: dts: at91: ariag25 : fix onewire node ...
2016-06-06ARM: BCM23550 SMP supportChris Brand
BCM23550 has a Cluster Dormant Control IP block that holds cores in an idle state. Support a new CPU enable method in which the CDC is accessed to bring the core online. Signed-off-by: Raymond Ngun <raymond.ngun@broadcom.com> Signed-off-by: Chris Brand <chris.brand@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-05-31ARM: BCM: modify Broadcom CPU enable methodChris Brand
Commit 84320e1a635fcf90cff4185f029ce9e31bf1d4a7 ("ARM: BCM: Clean up SMP support for Broadcom Kona") moved the "secondary-boot-reg" property from the "cpus" node to the individual "cpu" nodes but negelected to actually support multiple "secondary-boot-reg" properties. This patchset rectifies that omission. Note that the behaviour is changed slightly in that the "secondary-boot-reg" property is now read in smp_boot_secondary() rather than smp_prepare_cpus(). This means that any omissions will now only be reported when and if the cpu in question is being brought up. It also means that an omission for one cpu will not force uniprocessor mode. Signed-off-by: Chris Brand <chris.brand@broadcom.com> Reviewed-and-Tested-by: Jon Mason <jon.mason@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-02-01ARM: bcm: use const and __initconst for smp_operationsMasahiro Yamada
This newly added code missed the global fixup by commit 75305275a721 ("ARM: use const and __initconst for smp_operations"). So fix it now. Also, add missing "static" qualifier. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Ray Jui <rjui@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-12-22Merge branch 'treewide/cleanup' into next/socOlof Johansson
Merge in cleanup to avoid internal conflicts with newly added code. * treewide/cleanup: ARM: use "depends on" for SoC configs instead of "if" after prompt ARM/clocksource: use automatic DT probing for ux500 PRCMU ARM: use const and __initconst for smp_operations ARM: hisi: do not export smp_operations structures Signed-off-by: Olof Johansson <olof@lixom.net>
2015-12-07ARM: BCM: Add SMP support for Broadcom NSPKapil Hali
Add SMP support for Broadcom's Northstar Plus SoC cpu enable method. This changes also consolidates iProc family's - BCM NSP and BCM Kona, platform SMP handling in a common file. Northstar Plus SoC is based on ARM Cortex-A9 revision r3p0 which requires configuration for ARM Errata 764369 for SMP. This change adds the needed configuration option. Signed-off-by: Kapil Hali <kapilh@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
