<linux/sched/clock.h>
We are going to split <linux/sched/clock.h> out of <linux/sched.h>, which
will have to be picked up from other headers and .c files.
Create a trivial placeholder <linux/sched/clock.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
All low-level PM/SMP code using virt_to_phys() should actually use
__pa_symbol() against kernel symbols. Update code where relevant to move
away from virt_to_phys().
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Reviewed-by: Laura Abbott <labbott@redhat.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Pull ARM DT updates from Olof Johansson:
"Device tree contents continue to be the largest branches we submit.
This time around, some of the contents worth pointing out is:
New SoC platforms:
- Freescale i.MX 7Solo
- Broadcom BCM23550
- Cirrus Logic EP7209 and EP7211 (clps711x platforms)_
- Hisilicon HI3519
- Renesas R8A7792
Some of the other delta that is sticking out, line-count wise:
- Exynos moves of IP blocks under an SoC bus, which causes a large
delta due to indentation changes
- a new Tegra K1 board: Apalis
- a bunch of small updates to many Allwinner platforms; new hardware
support, some cleanup, etc"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (426 commits)
ARM: dts: sun8i: Add dts file for inet86dz board
ARM: dts: sun8i: Add dts file for Polaroid MID2407PXE03 tablet
ARM: dts: sun8i: Use sun8i-reference-design-tablet for ga10h dts
ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04
ARM: dts: sun8i: reference-design-tablet: Add drivevbus-supply
ARM: dts: Copy sun8i-q8-common.dtsi sun8i-reference-design-tablet.dtsi
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for utoo p66 dts
ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for dit4350 dts
ARM: dts: sun5i: reference-design-tablet: Remove mention of q8
ARM: dts: sun5i: reference-design-tablet: Set lradc vref to avcc
ARM: dts: sun5i: Rename sun5i-q8-common.dtsi sun5i-reference-design-tablet.dtsi
ARM: dts: sun5i: Move q8 display bits to sun5i-a13-q8-tablet.dts
ARM: dts: sunxi: Rename sunxi-q8-common.dtsi sunxi-reference-design-tablet.dtsi
ARM: dts: at91: Don't build unnecessary dtbs
ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitions
ARM: dts: at91: at91sam9g25ek: fix isi endpoint node
ARM: dts: at91: move isi definition to at91sam9g25ek
ARM: dts: at91: fix i2c-gpio node name
ARM: dts: at91: vinco: fix regulator name
ARM: dts: at91: ariag25 : fix onewire node
BCM23550 has a Cluster Dormant Control IP block that holds cores
in an idle state. Support a new CPU enable method in which the CDC is
accessed to bring the core online.
Signed-off-by: Raymond Ngun <raymond.ngun@broadcom.com>
Signed-off-by: Chris Brand <chris.brand@broadcom.com>
Commit 84320e1a635fcf90cff4185f029ce9e31bf1d4a7
("ARM: BCM: Clean up SMP support for Broadcom Kona") moved the
"secondary-boot-reg" property from the "cpus" node to the individual "cpu"
nodes but negelected to actually support multiple "secondary-boot-reg"
properties.
This patchset rectifies that omission. Note that the behaviour is changed
slightly in that the "secondary-boot-reg" property is now read in
smp_boot_secondary() rather than smp_prepare_cpus(). This means that any
omissions will now only be reported when and if the cpu in question is being
brought up. It also means that an omission for one cpu will not force
uniprocessor mode.
Reviewed-and-Tested-by: Jon Mason <jon.mason@broadcom.com>
This newly added code missed the global fixup by commit 75305275a721
("ARM: use const and __initconst for smp_operations"). So fix it now.
Also, add missing "static" qualifier.
Reviewed-by: Ray Jui <rjui@broadcom.com>
Merge in cleanup to avoid internal conflicts with newly added code.
* treewide/cleanup:
ARM: use "depends on" for SoC configs instead of "if" after prompt
ARM/clocksource: use automatic DT probing for ux500 PRCMU
ARM: hisi: do not export smp_operations structures
Add SMP support for Broadcom's Northstar Plus SoC
cpu enable method. This changes also consolidates
iProc family's - BCM NSP and BCM Kona, platform
SMP handling in a common file.
Northstar Plus SoC is based on ARM Cortex-A9
revision r3p0 which requires configuration for ARM
Errata 764369 for SMP. This change adds the needed
configuration option.
Signed-off-by: Kapil Hali <kapilh@broadcom.com>
