path: root/arch/arm/mach-bcm
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-04Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "SoC platform changes (arch/arm/mach-*). This merge window, the bulk is for a few platforms: - Andres Färber adds initial support for the Actions Semi S500 (aka 'owl') platform, a close relative of the S900 platform he adds for arm64. - in mach-omap2, we remove more legacy code - Rockchips gains support for the RV1108 SoC designed for camera applications. - For Atmel, we gain support for MMU-less SoCs (SAME70/V71/S70/V70) - Minor updates for other platforms, including davinci, s3c64xx, prima2, stm32, broadcom nsp, amlogic, pxa, imx and renesas" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (74 commits) ARM: owl: smp: Drop bogus holding pen ARM: owl: Drop custom machine ARM: owl: smp: Implement SPS power-gating for CPU2 and CPU3 soc: actions: owl-sps: Factor out owl_sps_set_pg() for power-gating soc: actions: Add Owl SPS dt-bindings: power: Add Owl SPS power domains MAINTAINERS: Update Actions Semi section with SPS ARM: owl: Implement CPU enable-method for S500 MAINTAINERS: Add Actions Semi Owl section ARM: Prepare Actions Semi S500 ARM: socfpga: Increase max number of GPIOs ARM: stm32: Introduce MACH_STM32F469 flag ARM: prima2: remove redundant select CPU_V7 ARM: davinci: fix const warnings ARM: shmobile: pm-rmobile: Use GENPD_FLAG_ALWAYS_ON ARM: OMAP4: hwmod_data: add SHAM crypto accelerator ARM: OMAP4: hwmod data: add des ARM: OMAP4: hwmod data: add aes2 ARM: OMAP4: hwmod data: add aes1 ARM: pxa: Delete an error message for a failed memory allocation in pxa3xx_u2d_probe() ...
2017-06-18Merge tag 'arm-soc/for-4.13/soc' of http://github.com/Broadcom/stblinux into ↵Olof Johansson
next/soc This pull request contains Broadcom ARM-based SoCs (non Device Tree) changes: - Jon updates the Kconfig entry for Northstar Plus to have THERMAL and THERMAL_OF selected in order to get the NS/NSP thermal driver dependencies to be satistfied * tag 'arm-soc/for-4.13/soc' of http://github.com/Broadcom/stblinux: ARM: BCM: Enable thermal support for NSP SoCs Signed-off-by: Olof Johansson <olof@lixom.net>
2017-06-14clocksource/drivers: Rename CLKSRC_OF to TIMER_OFDaniel Lezcano
The config option name is now renamed to 'TIMER_OF' for consistency with the CLOCKSOURCE_OF_DECLARE => TIMER_OF_DECLARE change. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2017-05-19ARM: BCM: Enable thermal support for NSP SoCsJon Mason
Change the Northstar Plus Kconfig to select THERMAL and THERMAL_OF, which allows the ns-thermal driver to be selected via menuconfig. Signed-off-by: Jon Mason <jon.mason@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-05-19ARM: remove duplicate 'const' annotations'Arnd Bergmann
gcc-7 warns about some declarations that are more 'const' than necessary: arch/arm/mach-at91/pm.c:338:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier] static const struct of_device_id const ramc_ids[] __initconst = { arch/arm/mach-bcm/bcm_kona_smc.c:36:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier] static const struct of_device_id const bcm_kona_smc_ids[] __initconst = { arch/arm/mach-spear/time.c:207:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier] static const struct of_device_id const timer_of_match[] __initconst = { arch/arm/mach-omap2/prm_common.c:714:34: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier] static const struct of_device_id const omap_prcm_dt_match_table[] __initconst = { arch/arm/mach-omap2/vc.c:562:35: error: duplicate 'const' declaration specifier [-Werror=duplicate-decl-specifier] static const struct i2c_init_data const omap4_i2c_timing_data[] __initconst = { The ones in arch/arm were apparently all introduced accidentally by one commit that correctly marked a lot of variables as __initconst. Fixes: 19c233b79d1a ("ARM: appropriate __init annotation for const data") Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Krzysztof Hałasa <khalasa@piap.pl> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2017-03-15ARM: brcmstb: Enable ARCH_HAS_HOLES_MEMORYMODELDanesh Petigara
Due to the brcmstb SoC's memory map, we may have holes in the memory if we don't populate the maximum amount of memory supported by e.g: the first memory controller which spans either the first 1GiB or first 2GiB of memory. We need to select ARCH_HAS_HOLES_MEMORYMODEL in order to enable CONFIG_HAVE_ARCH_PFN_VALID on platforms that have CONFIG_SPARSEMEM enabled. Signed-off-by: Danesh Petigara <danesh.petigara@broadcom.com> [florian: Detailed commit message] Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-03-15ARM: brcmstb: Enable ZONE_DMA for non 64-bit capable peripheralsAl Cooper
Some Host Controller hardware blocks, like the OHCI, EHCI and SDIO controllers, have hardware blocks that are not capable of doing 64 bit DMA. These host controllers fail on boards with >3GB of memory because the memory above 3GB is located physically >= 0x100000000 and can only be accessed using 64 DMA. The way Linux is currently configured for BRCMSTB systems, the memory given to drivers for DMA through functions like dma_alloc_coherent() comes from CMA memory and CMA memory is taken from the top of physical memory. When these drivers get a DMA buffer with an address >=0x100000000, they end up dropping the upper 32 bit of the address causing the hardware to DMA to incorrect memory, typically BMEM (custom memory carveout). This issue was discovered on a BCM97449SSV_DDR4 system with 4GB or memory. The fix is to enable CONFIG_ZONE_DMA. On ARM systems this makes sure that all DMA memory is located within the first 32 bits of address space. Signed-off-by: Al Cooper <alcooperx@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2017-03-02sched/headers: Prepare for new header dependencies before moving code to ↵Ingo Molnar
<linux/sched/clock.h> We are going to split <linux/sched/clock.h> out of <linux/sched.h>, which will have to be picked up from other headers and .c files. Create a trivial placeholder <linux/sched/clock.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-28ARM: 8641/1: treewide: Replace uses of virt_to_phys with __pa_symbolFlorian Fainelli
All low-level PM/SMP code using virt_to_phys() should actually use __pa_symbol() against kernel symbols. Update code where relevant to move away from virt_to_phys(). Acked-by: Russell King <rmk+kernel@armlinux.org.uk> Reviewed-by: Laura Abbott <labbott@redhat.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2016-11-16ARM: BCM5301X: Add back handler ignoring external imprecise abortsRafał Miłecki
Since early BCM5301X days we got abort handler that was removed by commit 937b12306ea79 ("ARM: BCM5301X: remove workaround imprecise abort fault handler"). It assumed we need to deal only with pending aborts left by the bootloader. Unfortunately this isn't true for BCM5301X. When probing PCI config space (device enumeration) it is expected to have master aborts on the PCI bus. Most bridges don't forward (or they allow disabling it) these errors onto the AXI/AMBA bus but not the Northstar (BCM5301X) one. iProc PCIe controller on Northstar seems to be some older one, without a control register for errors forwarding. It means we need to workaround this at platform level. All newer platforms are not affected by this issue. Signed-off-by: Rafał Miłecki <rafal@milecki.pl> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-10-07Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Arnd Bergmann: "These are updates for platform specific code on 32-bit ARM machines, essentially anything that can not (yet) be expressed using DT files. Noteworthy changes include: - We get support for running in big-endian mode on two platforms: sunxi (Allwinner) and s3c24xx (old Samsung). - The recently added Uniphier platform now uses standard PSCI methods for SMP booting and we remove support for old bootloader versions that did not support it yet. - In sunxi, we gain support for the "Nextthing GR8" SoC, which is a close relative of the Allwinner A13 and R8 chips. - PXA completes its move over to the generic dmaengine framework and removes its old private API - mach-bcm gains support for BCM47189/BCM53573, their first ARM SoC with integrated 802.11ac wireless networking" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits) ARM: imx legacy: pca100: move peripheral initialization to .init_late ARM: imx legacy: mx27ads: move peripheral initialization to .init_late ARM: imx legacy: mx21ads: move peripheral initialization to .init_late ARM: imx legacy: pcm043: move peripheral initialization to .init_late ARM: imx legacy: mx35-3ds: move peripheral initialization to .init_late ARM: imx legacy: mx27-3ds: move peripheral initialization to .init_late ARM: imx legacy: imx27-visstrim-m10: move peripheral initialization to .init_late ARM: imx legacy: vpr200: move peripheral initialization to .init_late ARM: imx legacy: mx31moboard: move peripheral initialization to .init_late ARM: imx legacy: armadillo5x0: move peripheral initialization to .init_late ARM: imx legacy: qong: move peripheral initialization to .init_late ARM: imx legacy: mx31-3ds: move peripheral initialization to .init_late ARM: imx legacy: pcm037: move peripheral initialization to .init_late ARM: imx legacy: mx31lilly: move peripheral initialization to .init_late ARM: imx legacy: mx31ads: move peripheral initialization to .init_late ARM: imx legacy: mx31lite: move peripheral initialization to .init_late ARM: imx legacy: kzm: move peripheral initialization to .init_late MAINTAINERS: update list of Oxnas maintainers ARM: orion5x: remove extraneous NO_IRQ ARM: orion: simplify orion_ge00_switch_init ...
2016-09-14clk: iproc: Make clocks visible optionsJon Mason
Make the clocks visible options that can be selected by anyone. This avoids the problems of: 1) Select is a reverse dependency and is hard for people to understand and can sometimes be a pain to track down 2) Build coverage goes down because configs are hidden 3) Code bloat Patch suggested by Stephen Boyd Signed-off-by: Jon Mason <jonmason@broadcom.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2016-08-22ARM: BCM53573: Initial support for Broadcom BCM53573 SoCsRafał Miłecki
BCM53573 series is a new family with embedded wireless. By marketing people it's sometimes called Northstar but it uses different CPU and has different architecture so we need a new symbol for it. Fortunately it shares some peripherals with other iProc based SoCs so we will be able to reuse some drivers/bindings. Signed-off-by: Rafał Miłecki <rafal@milecki.pl> Acked-by: Jon Mason <jon.mason@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-08-08ARM: brcmstb: Add earlyprintk support using run-time checksFlorian Fainelli
The SUN_TOP_CTRL_FAMILY_ID register is at a fixed absolute address for all of our supported chips, so utilize its value to determine what the UARTA base address should be based on the value we read. Since the code is called both during decompressor when the MMU is off, and after the MMU has been turned on in the kernel, and we want to do the lookup only once, we use the same technique as tegra.S and have a shared storage location between the decompressor and the kernel. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-08-01Merge tag 'armsoc-dt' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM DT updates from Olof Johansson: "Device tree contents continue to be the largest branches we submit. This time around, some of the contents worth pointing out is: New SoC platforms: - Freescale i.MX 7Solo - Broadcom BCM23550 - Cirrus Logic EP7209 and EP7211 (clps711x platforms)_ - Hisilicon HI3519 - Renesas R8A7792 Some of the other delta that is sticking out, line-count wise: - Exynos moves of IP blocks under an SoC bus, which causes a large delta due to indentation changes - a new Tegra K1 board: Apalis - a bunch of small updates to many Allwinner platforms; new hardware support, some cleanup, etc" * tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (426 commits) ARM: dts: sun8i: Add dts file for inet86dz board ARM: dts: sun8i: Add dts file for Polaroid MID2407PXE03 tablet ARM: dts: sun8i: Use sun8i-reference-design-tablet for ga10h dts ARM: dts: sun8i: Use sun8i-reference-design-tablet for polaroid mid2809pxe04 ARM: dts: sun8i: reference-design-tablet: Add drivevbus-supply ARM: dts: Copy sun8i-q8-common.dtsi sun8i-reference-design-tablet.dtsi ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for utoo p66 dts ARM: dts: sun5i: Use sun5i-reference-design-tablet.dtsi for dit4350 dts ARM: dts: sun5i: reference-design-tablet: Remove mention of q8 ARM: dts: sun5i: reference-design-tablet: Set lradc vref to avcc ARM: dts: sun5i: Rename sun5i-q8-common.dtsi sun5i-reference-design-tablet.dtsi ARM: dts: sun5i: Move q8 display bits to sun5i-a13-q8-tablet.dts ARM: dts: sunxi: Rename sunxi-q8-common.dtsi sunxi-reference-design-tablet.dtsi ARM: dts: at91: Don't build unnecessary dtbs ARM: dts: at91: sama5d3x: separate motherboard gmac and emac definitions ARM: dts: at91: at91sam9g25ek: fix isi endpoint node ARM: dts: at91: move isi definition to at91sam9g25ek ARM: dts: at91: fix i2c-gpio node name ARM: dts: at91: vinco: fix regulator name ARM: dts: at91: ariag25 : fix onewire node ...
2016-08-01Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Olof Johansson: "Improved and new platform support for various SoCs: New SoC support: - Broadcom BCM23550 - Freescale i.MX7Solo - Qualcomm MDM9615 - Renesas r8a7792 Improvements: - convert clps711x to multiplatform - debug uart improvements for Atmel platforms - Tango platform improvements: HOTPLUG_CPU, Suspend-to-ram - OMAP tweaks and improvements to hwmod - OMAP support for kexec on SMP" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits) ARM: davinci: fix build break because of undeclared dm365_evm_snd_data ARM: s3c64xx: smartq: Avoid sparse warnings ARM: sti: Implement dummy L2 cache's write_sec ARM: STi: Update machine _namestr to be more generic. arm: meson: explicitly select clk drivers ARM: tango: add Suspend-to-RAM support ARM: hisi: consolidate the hisilicon machine entries ARM: tango: fix CONFIG_HOTPLUG_CPU=n build MAINTAINERS: Update BCM281XX/BCM11XXX/BCM216XX entry MAINTAINERS: Update BCM63XX entry MAINTAINERS: Add NS2 entry MAINTAINERS: Fix nsp false-positives MAINTAINERS: Change L to M for Broadcom ARM/ARM64 SoC entries ARM: debug: Enable DEBUG_BCM_5301X for Northstar Plus SoCs ARM: clps711x: Switch to MULTIPLATFORM ARM: clps711x: Remove boards support ARM: clps711x: Add basic DT support ARM: clps711x: Reduce static map size ARM: SAMSUNG: Constify iomem address passed to s5p_init_cpu ARM: oxnas: Change OX810SE default driver config ...
2016-08-01Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "The cleanup branch keeps going down in size as we've completed a lot of the major legacy platform removals and conversions. A handful of changes this time around, some of the themes or larger sets are: - A bunch of i.MX cleanups around platform detection, init call cleanups - Misc fixes of missing/implicit includes - Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB" * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits) ARM: mps2: fix typo ARM: s3c64xx: avoid warning about 'struct device_node' bus: mvebu-mbus: make mvebu_mbus_syscore_ops static bus: mvebu-mbus: fix __iomem on register pointers ARM: tegra: Remove board_init_funcs array ARM: iop: Fix indentation ARM: imx: remove cpu_is_mx*() ARM: imx: remove last call to cpu_is_mx5* ARM: imx: rework mx27_pm_init() call ARM: imx: deconstruct mx3_idle ARM: imx: deconstruct mxc_rnga initialization ARM: imx: remove cpu_is_mx1 check ARM: i.MX: Do not explicitly call l2x0_of_init() ARM: i.MX: system.c: Tweak prefetch settings for performance ARM: i.MX: system.c: Replace magic numbers ARM: i.MX: system.c: Remove redundant errata 752271 code ARM: i.MX: system.c: Convert goto to if statement ARM: Kirkwood: fix kirkwood_pm_init() declaration/type ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static ARM: orion5x: make orion5x_legacy_handle_irq static ...
2016-07-30Merge tag 'devicetree-for-4.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux Pull DeviceTree updates from Rob Herring: - remove most of_platform_populate() calls in arch code. Now the DT core code calls it in the default case and platforms only need to call it if they have special needs - use pr_fmt on all the DT core print statements - CoreSight binding doc improvements to block name descriptions - add dt_to_config script which can parse dts files and list corresponding kernel config options - fix memory leak hit with a PowerMac DT - correct a bunch of STMicro compatible strings to use the correct vendor prefix - fix DA9052 PMIC binding doc to match what is actually used in dts files * tag 'devicetree-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (35 commits) documentation: da9052: Update regulator bindings names to match DA9052/53 DTS expectations xtensa: Partially Revert "xtensa: Remove unnecessary of_platform_populate with default match table" xtensa: Fix build error due to missing include file MIPS: ath79: Add missing include file Fix spelling errors in Documentation/devicetree ARM: dts: fix STMicroelectronics compatible strings powerpc/dts: fix STMicroelectronics compatible strings Documentation: dt: i2c: use correct STMicroelectronics vendor prefix scripts/dtc: dt_to_config - kernel config options for a devicetree of: fdt: mark unflattened tree as detached of: overlay: add resolver error prints coresight: document binding acronyms Documentation/devicetree: document cavium-pip rx-delay/tx-delay properties of: use pr_fmt prefix for all console printing of/irq: Mark initialised interrupt controllers as populated of: fix memory leak related to safe_name() Revert "of/platform: export of_default_bus_match_table" of: unittest: use of_platform_default_populate() to populate default bus memory: omap-gpmc: use of_platform_default_populate() to populate default bus bus: uniphier-system-bus: use of_platform_default_populate() to populate default bus ...
2016-07-06Merge ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB changes into next/socArnd Bergmann
* commit '5c34a4e89c743339f78cafb2f2a826a010f0746a': ARM: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB ARM: uniphier: drop code for old DT binding These cause a harmless conflict with the clps711x multiplatform support, and it's easy to resolve. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2016-06-28clocksource/drivers/bcm_kona: Add the COMPILE_TEST optionDaniel Lezcano
Change the Kconfig option logic to fullfil with the current approach. A new Kconfig option is added, CONFIG_BCM_KONA_TIMER and is selected by the platform. Then the clocksource's Kconfig is changed to make this option selectable by the user if the COMPILE_TEST option is set. Otherwise, it is up to the platform's Kconfig to select the timer. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2016-06-28clocksource/drivers/bcm2835: Add the COMPILE_TEST optionDaniel Lezcano
Change the Kconfig option logic to fullfil with the current approach. A new Kconfig option is added, CONFIG_BCM2835_TIMER and is selected by the platform. Then the clocksource's Kconfig is changed to make this option selectable by the user if the COMPILE_TEST option is set. Otherwise, it is up to the platform's Kconfig to select the timer. Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2016-06-23arm: Remove unnecessary of_platform_populate with default match tableKefeng Wang
After patch "of/platform: Add common method to populate default bus", it is possible for arch code to remove unnecessary callers of of_platform_populate with default match table. Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Ray Jui <rjui@broadcom.com> Cc: Lee Jones <lee@kernel.org> Cc: Krzysztof Halasa <khalasa@piap.pl> Cc: Kukjin Kim <kgene@kernel.org> Cc: Rob Herring <robh@kernel.org> Cc: Shawn Guo <shawnguo@kernel.org> Cc: Santosh Shilimkar <ssantosh@kernel.org> Cc: Roland Stigge <stigge@antcom.de> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Heiko Stuebner <heiko@sntech.de> Cc: Viresh Kumar <vireshk@kernel.org> Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com> Cc: Tony Prisk <linux@prisktech.co.nz> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com> Signed-off-by: Rob Herring <robh@kernel.org>
2016-06-08ARM: bcm: fix missing include of kona_l2_cache.hBen Dooks
Fix a warning of kona_l2_cache_init() not being declared by including the header file kona_l2_cache.h which defines it thus fixing: arch/arm/mach-bcm/kona_l2_cache.c:21:13: warning: symbol 'kona_l2_cache_init' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk> Acked-by: Ray Jui <ray.jui@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-06-06ARM: BCM23550 SMP supportChris Brand
BCM23550 has a Cluster Dormant Control IP block that holds cores in an idle state. Support a new CPU enable method in which the CDC is accessed to bring the core online. Signed-off-by: Raymond Ngun <raymond.ngun@broadcom.com> Signed-off-by: Chris Brand <chris.brand@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-06-06ARM: Add support for Broadcom BCM23550 SoCChris Brand
BCM23550 is a quad-A7 SoC used on the Broadcom "Sparrow" board. It shares many IP blocks with other Broadcom Kona chips. Signed-off-by: Chris Brand <chris.brand@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-06-06ARM: bcm21664: Remove reset codeChris Brand
The kona reset driver now provides this functionality. Signed-off-by: Chris Brand <chris.brand@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-06-03ARM: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIBLinus Walleij
This replaces: - "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can now be selected directly. - "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB is now selectable by everyone, so we need not declare our intent to select it. When ordering the symbols the following rationale was used: if the selects were in alphabetical order, I moved select GPIOLIB to be in alphabetical order, but if the selects were not maintained in alphabetical order, I just replaced "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB". Cc: Michael Büsch <m@bues.ch> Cc: arm@kernel.org Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2016-05-31ARM: BCM: modify Broadcom CPU enable methodChris Brand
Commit 84320e1a635fcf90cff4185f029ce9e31bf1d4a7 ("ARM: BCM: Clean up SMP support for Broadcom Kona") moved the "secondary-boot-reg" property from the "cpus" node to the individual "cpu" nodes but negelected to actually support multiple "secondary-boot-reg" properties. This patchset rectifies that omission. Note that the behaviour is changed slightly in that the "secondary-boot-reg" property is now read in smp_boot_secondary() rather than smp_prepare_cpus(). This means that any omissions will now only be reported when and if the cpu in question is being brought up. It also means that an omission for one cpu will not force uniprocessor mode. Signed-off-by: Chris Brand <chris.brand@broadcom.com> Reviewed-and-Tested-by: Jon Mason <jon.mason@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-04-18bus: brcmstb_gisb: Rework dependenciesFlorian Fainelli
Do not have the machine Kconfig entry point need to select BRCMSTB_GISB_ARB, instead, just let it be default ARCH_BRCMSTB which is a better way to deal with this. While at it, also make it default BMIPS_GENERIC so the legacy MIPS-based STB platforms can benefit from the same thing. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-04-18soc: brcmstb: add SoC driver to brcmstbJustin Chen
Value of soc_dev_attributes: * family = chip family id * soc_id = product id * revision = product revision Signed-off-by: Justin Chen <justin.chen@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-02-02ARM: BCM63xx: Remove unused pmb_dn variableFlorian Fainelli
Introduced in commit 3f2a43c98d72b ("ARM: BCM63xx: Add secondary CPU PMB initialization sequence"), but not used by the code. Reported-by: David Binderman <dcb314@hotmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2016-02-01ARM: bcm: use const and __initconst for smp_operationsMasahiro Yamada
This newly added code missed the global fixup by commit 75305275a721 ("ARM: use const and __initconst for smp_operations"). So fix it now. Also, add missing "static" qualifier. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Ray Jui <rjui@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-12-31Merge tag 'bcm2835-soc-next-2015-12-28' of http://github.com/anholt/linux ↵Arnd Bergmann
into next/soc Merge "BCM2835 SOC changes for 4.5" from Eric Anholt: This pull request includes the bcm2835 changes for 4.5 targeting the arm-soc next/soc branch. * tag 'bcm2835-soc-next-2015-12-28' of http://github.com/anholt/linux: ARM: bcm2835: Add Kconfig support for bcm2836 ARM: bcm2835: Add a compat string for bcm2836 machine probe dt-bindings: Add root properties for Raspberry Pi 2 Conflicts: arch/arm/mach-bcm/Kconfig
2015-12-26ARM: bcm2835: Add Kconfig support for bcm2836Eric Anholt
This should be a complete port of bcm2835 functionality to bcm2836 (Raspberry Pi 2). Signed-off-by: Eric Anholt <eric@anholt.net>
2015-12-22Merge branch 'treewide/cleanup' into next/socOlof Johansson
Merge in cleanup to avoid internal conflicts with newly added code. * treewide/cleanup: ARM: use "depends on" for SoC configs instead of "if" after prompt ARM/clocksource: use automatic DT probing for ux500 PRCMU ARM: use const and __initconst for smp_operations ARM: hisi: do not export smp_operations structures Signed-off-by: Olof Johansson <olof@lixom.net>
2015-12-22ARM: bcm2835: Add a compat string for bcm2836 machine probeEric Anholt
Supporting the 2836 requires using the new interrupt controller, which we have support for. Signed-off-by: Eric Anholt <eric@anholt.net>
2015-12-07ARM: BCM: Add SMP support for Broadcom 4708Jon Mason
Add SMP support for Broadcom's 4708 SoCs. Signed-off-by: Jon Mason <jonmason@broadcom.com> Acked-by: Hauke Mehrtens <hauke@hauke-m.de> Tested-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Kapil Hali <kapilh@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-12-07ARM: BCM: Add SMP support for Broadcom NSPKapil Hali
Add SMP support for Broadcom's Northstar Plus SoC cpu enable method. This changes also consolidates iProc family's - BCM NSP and BCM Kona, platform SMP handling in a common file. Northstar Plus SoC is based on ARM Cortex-A9 revision r3p0 which requires configuration for ARM Errata 764369 for SMP. This change adds the needed configuration option. Signed-off-by: Kapil Hali <kapilh@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-12-07ARM: BCM: Clean up SMP support for Broadcom KonaKapil Hali
These changes cleans up SMP implementaion for Broadcom's Kona SoC which are required for handling SMP for iProc family of SoCs at a single place for BCM NSP and BCM Kona. Signed-off-by: Kapil Hali <kapilh@broadcom.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-12-01ARM: use "depends on" for SoC configs instead of "if" after promptMasahiro Yamada
Many ARM sub-architectures use prompts followed by "if" conditional, but it is wrong. Please notice the difference between config ARCH_FOO bool "Foo SoCs" if ARCH_MULTI_V7 and config ARCH_FOO bool "Foo SoCs" depends on ARCH_MULTI_V7 These two are *not* equivalent! In the former statement, it is not ARCH_FOO, but its prompt that depends on ARCH_MULTI_V7. So, it is completely valid that ARCH_FOO is selected by another, but ARCH_MULTI_V7 is still disabled. As it is not unmet dependency, Kconfig never warns. This is probably not what you want. The former should be used only when you need to do so, and you really understand what you are doing. (In most cases, it should be wrong!) For enabling/disabling sub-architectures, the latter is always correct. As a good side effect, this commit fixes some entries over 80 columns (mach-imx, mach-integrator, mach-mbevu). [Arnd: I note that there is not really a bug here, according to the discussion that followed, but I can see value in being consistent and in making the lines shorter] Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Patrice Chotard <patrice.chotard@st.com> Acked-by: Liviu Dudau <Liviu.Dudau@arm.com> Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Jun Nie <jun.nie@linaro.org> Acked-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Simon Horman <horms+renesas@verge.net.au> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Thierry Reding <treding@nvidia.com> Acked-by: Krzysztof Halasa <khc@piap.pl> Acked-by: Maxime Coquelin <maxime.coquelin@st.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-12-01ARM: use const and __initconst for smp_operationsMasahiro Yamada
These smp_operations structures are not over-written, so add "const" qualifier and replace __initdata with __initconst. Also, add "static" where it is possible. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Moritz Fischer <moritz.fischer@ettus.com> Acked-by: Stephen Boyd <sboyd@codeaurora.org> # qcom part Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Patrice Chotard <patrice.chotard@st.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Wei Xu <xuwei5@hisilicon.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Acked-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Thierry Reding <treding@nvidia.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Liviu Dudau <Liviu.Dudau@arm.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2015-11-24ARM: BCM5310X: activate erratas needed for SoCHauke Mehrtens
The BCM4708 I have, which is probably the first generation which got to the consumer market, is using a ARM Cortex-A9 rev r3p0 and a L2C-310 rev r3p2 L2 cache controller. There are 3 workarounds for known erratas in the Linux kernel which could be activated and will be in this patch. There are currently no workarounds which have to be activated for the L2C-310 rev r3p2 in Linux. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-11-24ARM: BCM5301X: remove workaround imprecise abort fault handlerLucas Stach
This is not needed anymore. Handling a potentially pending imprecise external abort left behind by the bootloader is now done in a slightly safer way inside the common ARM startup code. Signed-off-by: Lucas Stach <l.stach@pengutronix.de> Acked-by: Hauke Mehrtens <hauke@hauke-m.de> Tested-by: Tyler Baker <tyler.baker@linaro.org> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-11-10Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Olof Johansson: "New and/or improved SoC support for this release: Marvell Berlin: - Enable standard DT-based cpufreq - Add CPU hotplug support Freescale: - Ethernet init for i.MX7D - Suspend/resume support for i.MX6UL Allwinner: - Support for R8 chipset (used on NTC's $9 C.H.I.P board) Mediatek: - SMP support for some platforms Uniphier: - L2 support - Cleaned up SMP support, etc. plus a handful of other patches around above functionality, and a few other smaller changes" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (42 commits) ARM: uniphier: rework SMP operations to use trampoline code ARM: uniphier: add outer cache support Documentation: EXYNOS: Update bootloader interface on exynos542x ARM: mvebu: add broken-idle option ARM: orion5x: use mac_pton() helper ARM: at91: pm: at91_pm_suspend_in_sram() must be 8-byte aligned ARM: sunxi: Add R8 support ARM: digicolor: select pinctrl/gpio driver arm: berlin: add CPU hotplug support arm: berlin: use non-self-cleared reset register to reset cpu ARM: mediatek: add smp bringup code ARM: mediatek: enable gpt6 on boot up to make arch timer working soc: mediatek: Fix random hang up issue while kernel init soc: ti: qmss: make acc queue support optional in the driver soc: ti: add firmware file name as part of the driver Documentation: dt: soc: Add description for knav qmss driver ARM: S3C64XX: Use PWM lookup table for mach-smartq ARM: S3C64XX: Use PWM lookup table for mach-hmt ARM: S3C64XX: Use PWM lookup table for mach-crag6410 ARM: S3C64XX: Use PWM lookup table for smdk6410 ...
2015-10-21ARM: cygnus: fix link failures when CONFIG_COMMON_CLK_IPROC is disabledArnd Bergmann
When CONFIG_CYGNUS is set but CONFIG_COMMON_CLK_IPROC is disabled, the following link failures are caused: drivers/built-in.o: In function `cygnus_armpll_init': :(.init.text+0x1d290): undefined reference to `iproc_armpll_setup' drivers/built-in.o: In function `cygnus_genpll_clk_init': :(.init.text+0x1d2c4): undefined reference to `iproc_pll_clk_setup' drivers/built-in.o: In function `cygnus_lcpll0_clk_init': :(.init.text+0x1d304): undefined reference to `iproc_pll_clk_setup' drivers/built-in.o: In function `cygnus_mipipll_clk_init': :(.init.text+0x1d344): undefined reference to `iproc_pll_clk_setup' drivers/built-in.o: In function `cygnus_asiu_init': :(.init.text+0x1d370): undefined reference to `iproc_asiu_setup' It is fixed it by always selecting COMMON_CLK_IPROC from ARCH_BCM_IPROC, and making COMMON_CLK_IPROC a silent option (thus preventing it from being erroneously disabled by a user). Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jon Mason <jonmason@broadcom.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
2015-10-09ARM: brcmstb: Setup BIU control registers during bootFlorian Fainelli
Call brcmstb_biuctrl_init() in brcmstb's init_irq machine descriptor callback since we need to setup the Bus Interface Unit before SMP in particular, but we also need to be able to remap registers. Acked-by: Gregory Fong <gregory.0xf0@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-09-14soc: add stubs for brcmstb SoC'sBrian Norris
Used on BCM7xxx Set-Top Box chips (e.g., BCM7445). Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-09-14ARM: NSP: Add basic support for Broadcom Northstar Plus SoCJon Mason
Broadcom Northstar Plus family of SoCs are used for switching control and management applications as well as residential router/gateway applications. The SoC features dual core Cortex A9 ARM CPUs, integrating several peripheral interfaces including multiple Gigabit Ethernet PHYs, DDR3 memory, PCIE Gen-2, USB 2.0 and USB 3.0, serial and NAND flash, SATA and several other IO controllers. Signed-off-by: Kapil Hali <kapilh@broadcom.com> Signed-off-by: Jon Mason <jonmason@broadcom.com> Acked-by: Scott Branden <sbranden@broadcom.com> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
2015-09-01Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Olof Johansson: "New or improved SoC support: - add support for Atmel's SAMA5D2 SoC - add support for Freescale i.MX6UL - improved support for TI's DM814x platform - misc fixes and improvements for RockChip platforms - Marvell MVEBU suspend/resume support A few driver changes that ideally would belong in the drivers branch are also here (acked by appropriate maintainers): - power key input driver for Freescale platforms (svns) - RTC driver updates for Freescale platforms (svns/mxc) - clk fixes for TI DM814/816X + a bunch of other changes for various platforms" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits) ARM: rockchip: pm: Fix PTR_ERR() argument ARM: imx: mach-imx6ul: Fix allmodconfig build clk: ti: fix for definition movement ARM: uniphier: drop v7_invalidate_l1 call at secondary entry memory: kill off set_irq_flags usage rtc: snvs: select option REGMAP_MMIO ARM: brcmstb: select ARCH_DMA_ADDR_T_64BIT for LPAE ARM: BCM: Enable ARM erratum 798181 for BRCMSTB ARM: OMAP2+: Fix power domain operations regression caused by 81xx ARM: rockchip: enable PMU_GPIOINT_WAKEUP_EN when entering shallow suspend ARM: rockchip: set correct stabilization thresholds in suspend ARM: rockchip: rename osc_switch_to_32k variable ARM: imx6ul: add fec MAC refrence clock and phy fixup init ARM: imx6ul: add fec bits to GPR syscon definition rtc: mxc: add support of device tree dt-binding: document the binding for mxc rtc rtc: mxc: use a second rtc clock ARM: davinci: cp_intc: use IRQCHIP_SKIP_SET_WAKE instead of irq_set_wake callback soc: mediatek: Fix SCPSYS compilation ARM: at91/soc: add basic support for new sama5d2 SoC ...
