path: root/arch/arm/mach-clps711x/include
2011-03-16Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (91 commits) ARM: 6806/1: irq: introduce entry and exit functions for chained handlers ARM: 6781/1: Thumb-2: Work around buggy Thumb-2 short branch relocations in gas ARM: 6747/1: P2V: Thumb2 support ARM: 6798/1: aout-core: zero thread debug registers in a.out core dump ARM: 6796/1: Footbridge: Fix I/O mappings for NOMMU mode ARM: 6784/1: errata: no automatic Store Buffer drain on Cortex-A9 ARM: 6772/1: errata: possible fault MMU translations following an ASID switch ARM: 6776/1: mach-ux500: activate fix for errata 753970 ARM: 6794/1: SPEAr: Append UL to device address macros. ARM: 6793/1: SPEAr: Remove unused *_SIZE macros from spear*.h files ARM: 6792/1: SPEAr: Replace SIZE macro's with SZ_4K macros ARM: 6791/1: SPEAr3xx: Declare device structures after shirq code ARM: 6790/1: SPEAr: Clock Framework: Rename usbd clock and align apb_clk entry ARM: 6789/1: SPEAr3xx: Rename sdio to sdhci ARM: 6788/1: SPEAr: Include mach/hardware.h instead of mach/spear.h ARM: 6787/1: SPEAr: Reorder #includes in .h & .c files. ARM: 6681/1: SPEAr: add debugfs support to clk API ARM: 6703/1: SPEAr: update clk API support ARM: 6679/1: SPEAr: make clk API functions more generic ARM: 6737/1: SPEAr: formalized timer support ...
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-31arm/mach-clps711x: Switch do_timer() to xtime_update()Torben Hohn
do_timer() requires holding the xtime_lock, which this code did not do. Use the safe version xtime_update() Signed-off-by: Torben Hohn <torbenh@gmx.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Peter Zijlstra <peterz@infradead.org> Cc: johnstul@us.ibm.com Cc: hch@infradead.org Cc: yong.zhang0@gmail.com LKML-Reference: <20110127145926.23248.56369.stgit@localhost> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-11-21ARM: 6484/1: fix compile warning in mm/init.cAnand Gadiyar
Commit 7c63984b86 (ARM: do not define VMALLOC_END relative to PAGE_OFFSET) changed VMALLOC_END to be an explicit value. Before this, it was relative to PAGE_OFFSET and therefore converted to unsigned long as PAGE_OFFSET is an unsigned long. This introduced the following build warning. Fix this by changing the explicit defines of VMALLOC_END to be unsigned long. CC arch/arm/mm/init.o arch/arm/mm/init.c: In function 'mem_init': arch/arm/mm/init.c:606: warning: format '%08lx' expects type 'long unsigned int', but argument 12 has type 'unsigned int' Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Acked-by: Uwe Kleine-K <u.kleine-koenig@pengutronix.dee> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-10-01ARM: do not define VMALLOC_END relative to PAGE_OFFSETNicolas Pitre
VMALLOC_END is supposed to be an absolute value, while PAGE_OFFSET may vary depending on the selected user:kernel memory split mode through CONFIG_VMSPLIT_*. In fact, the goal of moving PAGE_OFFSET down is to accommodate more directly addressed RAM by the kernel below the vmalloc area, and having VMALLOC_END move along PAGE_OFFSET is rather against the very reason why PAGE_OFFSET can be moved in the first place. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2010-08-05ARM: 6283/1: Remove useless PCIO_BASE definitionseric miao
Signed-off-by: Eric Miao <eric.miao@canonical.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-31Merge branches 'at91', 'ep93xx', 'kexec', 'iop', 'lmb', 'nomadik', 'nuc', ↵Russell King
'pl', 'spear' and 'versatile' into devel
2010-07-26ARM: 6262/1: arm/clps711x: fix debug macro compilation failureJeremy Kerr
We need mach/hardware.h for CLPS7111_VIRT_BASE. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-16ARM: Remove DISCONTIGMEM supportRussell King
Everything should now be using sparsemem rather than discontigmem, so remove the code supporting discontigmem from ARM. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-13ARM: fix clps711x, footbridge, integrator, ixp2000, ixp2300 and s3c build bugRussell King
Anders Grafström reports that footbridge fails to build after 1c4a4f4. Fix this by adding the necessary definitions for __pfn_to_bus and __bus_to_pfn. Reported-by: Anders Grafström <anders.grafstrom@netinsight.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-30[ARM] Add a common typesafe __io implementationRussell King
As Al did for Versatile in 2ad4f86b60b649fd7428265c08d73a3bd360c81b, add a typesafe __io implementation for platforms to use. Convert platforms to use this new simple typesafe implementation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] Hide ISA DMA API when ISA_DMA_API is unsetRussell King
When ISA_DMA_API is unset, we're not implementing the ISA DMA API, so there's no point in publishing the prototypes via asm/dma.h, nor including the machine dependent parts of that API. This allows us to remove a lot of mach/dma.h files which don't contain any useful code. Unfortunately though, some platforms put their own private non-ISA definitions into mach/dma.h, so we leave these behind and fix the appropriate #include statments. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] clps711x: avoid polluting the kernel's namespaceRussell King
Avoid unnecessarily pollution of the kernel's namespace by avoiding mach/hardware.h in mach/io.h. Include this header file where necessary. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] remove a common set of __virt_to_bus definitionsNicolas Pitre
Let's provide an overridable default instead of having every machine class define __virt_to_bus and __bus_to_virt to the same thing. What most platforms are using is bus_addr == phys_addr so such is the default. One exception is ebsa110 which has no DMA what so ever, so the actual definition is not important except only for proper compilation. Also added a comment about the special footbridge bus translation. Let's also remove comments alluding to set_dma_addr which is not (and should not) be commonly used. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-13[ARM] cdb89712: avoid namespace clashes with SRAM_ and BOOTROM_ constantsRussell King
2008-11-13[ARM] cdb89712,clps7500,h720x: avoid namespace clash for FLASH_* constantsRussell King
2008-10-21[ARM] clps711x: add sparsemem definitionsRussell King
Fix the edb7211_defconfig build errors. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
