path: root/arch/arm/mach-clps711x
2015-09-08Merge tag 'libnvdimm-for-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dan Williams: "This update has successfully completed a 0day-kbuild run and has appeared in a linux-next release. The changes outside of the typical drivers/nvdimm/ and drivers/acpi/nfit.[ch] paths are related to the removal of IORESOURCE_CACHEABLE, the introduction of memremap(), and the introduction of ZONE_DEVICE + devm_memremap_pages(). Summary: - Introduce ZONE_DEVICE and devm_memremap_pages() as a generic mechanism for adding device-driver-discovered memory regions to the kernel's direct map. This facility is used by the pmem driver to enable pfn_to_page() operations on the page frames returned by DAX ('direct_access' in 'struct block_device_operations'). For now, the 'memmap' allocation for these "device" pages comes from "System RAM". Support for allocating the memmap from device memory will arrive in a later kernel. - Introduce memremap() to replace usages of ioremap_cache() and ioremap_wt(). memremap() drops the __iomem annotation for these mappings to memory that do not have i/o side effects. The replacement of ioremap_cache() with memremap() is limited to the pmem driver to ease merging the api change in v4.3. Completion of the conversion is targeted for v4.4. - Similar to the usage of memcpy_to_pmem() + wmb_pmem() in the pmem driver, update the VFS DAX implementation and PMEM api to provide persistence guarantees for kernel operations on a DAX mapping. - Convert the ACPI NFIT 'BLK' driver to map the block apertures as cacheable to improve performance. - Miscellaneous updates and fixes to libnvdimm including support for issuing "address range scrub" commands, clarifying the optimal 'sector size' of pmem devices, a clarification of the usage of the ACPI '_STA' (status) property for DIMM devices, and other minor fixes" * tag 'libnvdimm-for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (34 commits) libnvdimm, pmem: direct map legacy pmem by default libnvdimm, pmem: 'struct page' for pmem libnvdimm, pfn: 'struct page' provider infrastructure x86, pmem: clarify that ARCH_HAS_PMEM_API implies PMEM mapped WB add devm_memremap_pages mm: ZONE_DEVICE for "device memory" mm: move __phys_to_pfn and __pfn_to_phys to asm/generic/memory_model.h dax: drop size parameter to ->direct_access() nd_blk: change aperture mapping from WC to WB nvdimm: change to use generic kvfree() pmem, dax: have direct_access use __pmem annotation dax: update I/O path to do proper PMEM flushing pmem: add copy_from_iter_pmem() and clear_pmem() pmem, x86: clean up conditional pmem includes pmem: remove layer when calling arch_has_wmb_pmem() pmem, x86: move x86 PMEM API to new pmem.h header libnvdimm, e820: make CONFIG_X86_PMEM_LEGACY a tristate option pmem: switch to devm_ allocations devres: add devm_memremap libnvdimm, btt: write and validate parent_uuid ...
2015-08-10cleanup IORESOURCE_CACHEABLE vs ioremap()Dan Williams
Quoting Arnd: I was thinking the opposite approach and basically removing all uses of IORESOURCE_CACHEABLE from the kernel. There are only a handful of them.and we can probably replace them all with hardcoded ioremap_cached() calls in the cases they are actually useful. All existing usages of IORESOURCE_CACHEABLE call ioremap() instead of ioremap_nocache() if the resource is cacheable, however ioremap() is uncached by default. Clearly none of the existing usages care about the cacheability. Particularly devm_ioremap_resource() never worked as advertised since it always fell back to plain ioremap(). Clean this up as the new direction we want is to convert ioremap_<type>() usages to memremap(..., flags). Suggested-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2015-07-28ARM: appropriate __init annotation for const dataNicolas Pitre
Init data marked const should be annotated with __initconst for correctness and not __initdata. In some cases the array gathering references to that data has to be marked const as well. This fixes LTO builds that otherwise fail with section mismatch errors. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-10-08Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Arnd Bergmann: "New and updated SoC support. Among the things new for this release are: - at91: Added support for the new SAMA5D4 SoC, following the earlier SAMA5D3 - bcm: Added support for BCM63XX family of DSL SoCs - hisi: Added support for HiP04 server-class SoC - meson: Initial support for the Amlogic Meson6 (aka 8726MX) platform - shmobile: added support for new r8a7794 (R-Car E2) automotive SoC Noteworthy changes to existing SoC support are: - imx: convert i.MX1 to device tree - omap: lots of power management work - omap: base support to enable moving to standard UART driver - shmobile: lots of progress for multiplatform support, still ongoing" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (171 commits) ARM: hisi: depend on ARCH_MULTI_V7 CNS3xxx: Fix debug UART. ARM: at91: fix nommu build regression ARM: meson: add basic support for MesonX SoCs ARM: meson: debug: add debug UART for earlyprintk support irq: Export handle_fasteoi_irq ARM: mediatek: Add earlyprintk support for mt6589 ARM: hisi: Fix platmcpm compilation when ARMv6 is selected ARM: debug: fix alphanumerical order on debug uarts ARM: at91: document Atmel SMART compatibles ARM: at91: add sama5d4 support to sama5_defconfig ARM: at91: dt: add device tree file for SAMA5D4ek board ARM: at91: dt: add device tree file for SAMA5D4 SoC ARM: at91: SAMA5D4 SoC detection code and low level routines ARM: at91: introduce basic SAMA5D4 support clk: at91: add a driver for the h32mx clock ARM: pxa3xx: provide specific platform_devices for all ssp ports ARM: pxa: ssp: provide platform_device_id for PXA3xx ARM: OMAP4+: Remove static iotable mappings for SRAM ARM: OMAP4+: Move SRAM data to DT ...
2014-09-04ARM: clps711x: Add SOC BUS supportAlexander Shiyan
Add SOC BUS support with CPU family, machine name and unique ID. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-09-04ARM: clps711x: edb7211: Use new PWM driver for backlightAlexander Shiyan
Remove existing tricks for handling PWM and use CLPS711X PWM driver. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-09-04ARM: clps711x: Switch CLPS711X subarch to use clk and clocksource driverAlexander Shiyan
This patch removes old support for clk and clocksource support and switches platform to use new drivers. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-08-08Merge tag 'cleanup-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This merge window brings a good size of cleanups on various platforms. Among the bigger ones: - Removal of Samsung s5pc100 and s5p64xx platforms. Both of these have lacked active support for quite a while, and after asking around nobody showed interest in keeping them around. If needed, they could be resurrected in the future but it's more likely that we would prefer reintroduction of them as DT and multiplatform-enabled platforms instead. - OMAP4 controller code register define diet. They defined a lot of registers that were never actually used, etc. - Move of some of the Tegra platform code (PMC, APBIO, fuse, powergate) to drivers/soc so it can be shared with 64-bit code. This also converts them over to traditional driver models where possible. - Removal of legacy gpio-samsung driver, since the last users have been removed (moved to pinctrl) Plus a bunch of smaller changes for various platforms that sort of dissapear in the diffstat for the above. clps711x cleanups, shmobile header file refactoring/moves for multiplatform friendliness, some misc cleanups, etc" * tag 'cleanup-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (117 commits) drivers: CCI: Correct use of ! and & video: clcd-versatile: Depend on ARM video: fix up versatile CLCD helper move MAINTAINERS: Add sdhci-st file to ARCH/STI architecture ARM: EXYNOS: Fix build breakge with PM_SLEEP=n MAINTAINERS: Remove Kirkwood ARM: tegra: Convert PMC to a driver soc/tegra: fuse: Set up in early initcall ARM: tegra: Always lock the CPU reset vector ARM: tegra: Setup CPU hotplug in a pure initcall soc/tegra: Implement runtime check for Tegra SoCs soc/tegra: fuse: fix dummy functions soc/tegra: fuse: move APB DMA into Tegra20 fuse driver soc/tegra: Add efuse and apbmisc bindings soc/tegra: Add efuse driver for Tegra ARM: tegra: move fuse exports to soc/tegra/fuse.h ARM: tegra: export apb dma readl/writel ARM: tegra: Use a function to get the chip ID ARM: tegra: Sort includes alphabetically ARM: tegra: Move includes to include/soc/tegra ...
2014-07-23platform: Remove most references to platform_bus devicePawel Moll
A number of board files in arch/arm and arch/unicore32 explicitly reference platform_bus device as a parent for new platform devices. This is unnecessary, as platform device API guarantees that devices with NULL parent are going to by adopted by the mentioned "root" device. This patch removes or replaces with NULL such references. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-06ARM: clps711x: edb7211: Remove excess layer to calling clps711x_devices_init()Alexander Shiyan
clps711x_devices_init() can be used directly in ".machine_init" without any intermediate function. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-06ARM: clps711x: clep7312: Add common devices initializationAlexander Shiyan
Add initialization of commonly used devices to the CLEP7312 generic board. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-06ARM: clps711x: Switch CLPS711X subarch to use cpuidle driverAlexander Shiyan
This patch removes old support for cpuidle and switches all current users to use new cpuidle driver. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-06ARM: clps711x: Move debug include into arch/arm/include/debug/Alexander Shiyan
One more step to allowing CLPS711X to participate in the multi-platform defconfig. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-07-06ARM: clps711x: Remove IO_ADDRESS() macroAlexander Shiyan
All uses of the IO_ADDRESS() macro has been removed. This patch removes the definition of this macro. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-06-01ARM: 8025/1: Get rid of meminfoLaura Abbott
memblock is now fully integrated into the kernel and is the prefered method for tracking memory. Rather than reinvent the wheel with meminfo, migrate to using memblock directly instead of meminfo as an intermediate. Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Tested-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Leif Lindholm <leif.lindholm@linaro.org> Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-05Merge tag 'soc-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC specific changes from Arnd Bergmann: "Lots of changes specific to one of the SoC families. Some that stick out are: - mach-qcom gains new features, most importantly SMP support for the newer chips (Stephen Boyd, Rohit Vaswani) - mvebu gains support for three new SoCs: Armada 375, 380 and 385 (Thomas Petazzoni and Free-electrons team) - SMP support for Rockchips (Heiko Stübner) - Lots of i.MX changes (Shawn Guo) - Added support for BCM5301x SoC (Hauke Mehrtens) - Multiplatform support for Marvell Kirkwood and Dove (Andrew Lunn and Sebastian Hesselbarth doing the final part of a long journey) - Unify davinci platforms and remove obsolete ones (Sekhar Nori, Arnd Bergmann)" * tag 'soc-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (126 commits) ARM: sunxi: Select HAVE_ARM_ARCH_TIMER ARM: cache-tauros2: remove ARMv6 code ARM: mvebu: don't select CONFIG_NEON ARM: davinci: fix DT booting with default defconfig ARM: configs: bcm_defconfig: enable bcm590xx regulator support ARM: davinci: remove tnetv107x support MAINTAINERS: Update ARM STi maintainers ARM: restrict BCM_KONA_UART to ARCH_BCM_MOBILE ARM: bcm21664: Add board support. ARM: sunxi: Add the new watchog compatibles to the reboot code ARM: enable ARM_HAS_SG_CHAIN for multiplatform ARM: davinci: remove da8xx_omapl_defconfig ARM: davinci: da8xx: fix multiple watchdog device registration ARM: davinci: add da8xx specific configs to davinci_all_defconfig ARM: davinci: enable da8xx build concurrently with older devices ARM: BCM5301X: workaround suppress fault ARM: BCM5301X: add early debugging support ARM: BCM5301X: initial support for the BCM5301X/BCM470X SoCs with ARM CPU ARM: mach-bcm: Remove GENERIC_TIME ARM: shmobile: APMU: Fix warnings due to improper printk formats ...
2014-04-05Merge tag 'cleanup-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "These cleanup patches are mainly move stuff around and should all be harmless. They are mainly split out so that other branches can be based on top to avoid conflicts. Notable changes are: - We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no longer used (Uwe Kleine-König) - The Qualcomm MSM platform is split out into legacy mach-msm and new-style mach-qcom, to allow easier maintainance of the new hardware support without regressions (Kumar Gala) - A rework of some of the Kconfig logic to simplify multiplatform support (Rob Herring) - Samsung Exynos gets closer to supporting multiplatform (Sachin Kamat and others) - mach-bcm3528 gets merged into mach-bcm (Stephen Warren) - at91 gains some common clock framework support (Alexandre Belloni, Jean-Jacques Hiblot and other French people)" * tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits) ARM: hisi: select HAVE_ARM_SCU only for SMP ARM: efm32: allow uncompress debug output ARM: prima2: build reset code standalone ARM: at91: add PWM clock ARM: at91: move sam9261 SoC to common clk ARM: at91: prepare common clk transition for sam9261 SoC ARM: at91: updated the at91_dt_defconfig with support for the ADS7846 ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs ARM: at91: dt: Add at91sam9261 dt SoC support ARM: at91: switch sam9rl to common clock framework ARM: at91/dt: define main clk frequency of at91sam9rlek ARM: at91/dt: define at91sam9rl clocks ARM: at91: prepare common clk transition for sam9rl SoCs ARM: at91: prepare sam9 dt boards transition to common clk ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs ARM: at91: Add at91sam9rl DT SoC support ARM: at91: prepare at91sam9rl DT transition ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig ...
2014-02-28ARM: clps711x: Remove EP72XX_ROM_BOOT optionAlexander Shiyan
CLPS711X CPUs have 128 bytes of on-chip Boot ROM with an instruction sequence that configure UART1 to receive up to 2 Kbytes of serial data which is then placed in the on-chip SRAM. Once the download is complete, the program counter jumps to SRAM to begin executed the downloaded data. The purpose of this mode is to allow the downloaded code to facilitate programming of FLASH or other ROM device. Selection of the internal Boot ROM is accomplished at power-on-reset time. No reason to keep this special (develop only) mode in the kernel. This patch removes EP72XX_ROM_BOOT kernel symbol. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-02-28ARM: clps711x: autcpu12: Fix incorrect NAND CLE GPIOAlexander Shiyan
2014-02-28ARM: clps711x: Migrate CLPS711X subarch to the new irqchip driverAlexander Shiyan
This patch remove old code and migrate Cirrus Logic CLPS711X subarch to the new irqchip driver. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-02-28ARM: clps711x: Add CLPS711X irqchip driverAlexander Shiyan
This adds the irqchip driver for Cirrus Logic CLPS711X series SoCs. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-02-18Merge tag 'dropmachtimexh-v2' of git://git.pengutronix.de/git/ukl/linux into ↵Olof Johansson
next/cleanup This cleanup series gets rid of <mach/timex.h> for platforms not using ARCH_MULTIPLATFORM. (For multi-platform code it's already unused since 387798b (ARM: initial multiplatform support).) To make this work some code out of arch/arm needed to be adapted. The respective changes got acks by their maintainers to be taken via armsoc (with Andrew Morton substituting for Alessandro Zummo as rtc maintainer). Compared to the previous pull request there was another patch added that fixes a (non-critical) regression on ixp4xx. Olof Johansson asked to not squash this fix into the original commit to save him from the need to reverify the series. * tag 'dropmachtimexh-v2' of git://git.pengutronix.de/git/ukl/linux: ARM: ixp4xx: fix timer latch calculation ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, too ARM: rpc: stop using <mach/timex.h> ARM: ixp4xx: stop using <mach/timex.h> input: ixp4xx-beeper: don't use symbols from <mach/timex.h> ARM: at91: don't use <mach/timex.h> ARM: ep93xx: stop using mach/timex.h ARM: mmp: stop using mach/timex.h ARM: netx: stop using mach/timex.h ARM: sa1100: stop using mach/timex.h clocksource: sirf/marco+prima2: drop usage of CLOCK_TICK_RATE rtc: pxa: drop unused #define TIMER_FREQ rtc: at91sam9: include <mach/hardware.h> explicitly ARM/serial: at91: switch atmel serial to use gpiolib Signed-off-by: Olof Johansson <olof@lixom.net>
2014-01-23Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "New core SoC-specific changes. New platforms: * Introduction of a vendor, Hisilicon, and one of their SoCs with some random numerical product name. * Introduction of EFM32, embedded platform from Silicon Labs (ARMv7m, i.e. !MMU). * Marvell Berlin series of SoCs, which include the one in Chromecast. * MOXA platform support, ARM9-based platform used mostly in industrial products * Support for Freescale's i.MX50 SoC. Other work: * Renesas work for new platforms and drivers, and conversion over to more multiplatform-friendly device registration schemes. * SMP support for Allwinner sunxi platforms. * ... plus a bunch of other stuff across various platforms" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (201 commits) ARM: tegra: fix tegra_powergate_sequence_power_up() inline ARM: msm_defconfig: Update for multi-platform ARM: msm: Move MSM's DT based hardware to multi-platform support ARM: msm: Only build timer.c if required ARM: msm: Only build clock.c on proc_comm based platforms ARM: ux500: Enable system suspend with WFI support ARM: ux500: turn on PRINTK_TIME in u8500_defconfig ARM: shmobile: r8a7790: Fix I2C controller names ARM: msm: Simplify ARCH_MSM_DT config ARM: msm: Add support for MSM8974 SoC ARM: sunxi: select ARM_PSCI MAINTAINERS: Update Allwinner sunXi maintainer files ARM: sunxi: Select RESET_CONTROLLER ARM: imx: improve the comment of CCM lpm SW workaround ARM: imx: improve status check of clock gate ARM: imx: add necessary interface for pfd ARM: imx_v6_v7_defconfig: Select CONFIG_REGULATOR_PFUZE100 ARM: imx_v6_v7_defconfig: Select MX35 and MX50 device tree support ARM: imx: Add cpu frequency scaling support ARM i.MX35: Add devicetree support. ...
2013-12-20ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, tooUwe Kleine-König
While <mach/timex.h> isn't used for multi-platform builds since long it still is for "normal" builds. As the previous patches fix all sites to not make use of this per-platform file, it can go now for good also for platforms that are not (yet) converted to multi-platform. While at it there are no users of CLOCK_TICK_RATE any more, so also drop the dummy #define. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-12-17serial: clps711x: Driver refactorAlexander Shiyan
This is a complex patch for refactoring CLPS711X serial driver. Major changes: - Eliminate <mach/hardware.h> usage. - Devicetree support. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-11-21ARM: clps711x: Switch to sched_clock_register()Stephen Boyd
The 32 bit sched_clock interface now supports 64 bits. Upgrade to the 64 bit function to allow us to remove the 32 bit registration interface. Cc: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-10-11ARM: clps711x: Use linux/sched_clock.hStephen Boyd
The sched_clock.h include is under include/linux now. Cc: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2013-08-13ARM: clps711x: edb7211: Remove extra iotable_init() callAlexander Shiyan
The keyboard driver for the CLPS711X platform is missing, so there is no need to call iotable_init() for this memory region. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-08-13ARM: clps711x: autcpu12: Remove incorrect config checkingAlexander Shiyan
This patch removes incorrect config symbols checking since these symbols not contain "CONFIG_" prefix. Anyway, checking is unneeded here and this patch remove it completely. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-08-13ARM: clps711x: Drop fortunet board supportAlexander Shiyan
This patch removes support for the fortunet board. This board is not maintained by long time and it seems no one is not using it. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-08-13ARM: clps711x: Remove the special name for the syscon driverAlexander Shiyan
This is a partial revert of the patch: "6597619f9c ARM: clps711x: Add support for SYSCON driver". No reason to make SYSCON driver name unique to that processor. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-11ARM: clps711x: Add support for SYSCON driverAlexander Shiyan
This patch adds support for SYSCON driver for CLPS711X targets. At this time there are no users for this driver, but it is will be used as start point to use in CLPS711X drivers and remove <mach/xx> dependencies. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-11ARM: clps711x: edb7211: Control LCD backlight via PWMAlexander Shiyan
This patch provide control LCD backlight via PWM. GPIO is used only for switch backlight ON and OFF. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-11ARM: clps711x: edb7211: Add support for I2CAlexander Shiyan
2013-06-11ARM: clps711x: Optimize interrupt handlingAlexander Shiyan
This patch modify interrupt handler for processing all penging interrupts at once. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-11ARM: clps711x: Add clocksource frameworkAlexander Shiyan
2013-06-11ARM: clps711x: Replace "arch_initcall" in common code with ".init_early"Alexander Shiyan
2013-06-11ARM: clps711x: Move specific definitions from hardware.h to boards filesAlexander Shiyan
2013-06-11ARM: clps711x: p720t: Define PLD registers as GPIOsAlexander Shiyan
2013-06-11ARM: clps711x: autcpu12: Move remaining specific definitions to board fileAlexander Shiyan
2013-06-11ARM: clps711x: autcpu12: Special driver for handling memory is removedAlexander Shiyan
This patch provide migration to using "mtd-ram" driver instead of using special driver for handling NVRAM memory. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-11ARM: clps711x: autcpu12: Add support for NOR flashAlexander Shiyan
2013-06-11ARM: clps711x: autcpu12: Move LCD DPOT definitions to board fileAlexander Shiyan
We do not have driver for Up/Down digital potentiometer (DPOT), so just define pins as GPIOs and export these pins to user. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-11ARM: clps711x: Set PLL clock to zero if we work from 13 mHz sourceAlexander Shiyan
This clock will be used in audio subsystem. Since audio cannot work without PLL we should indicate this. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-11ARM: clps711x: Remove NEED_MACH_MEMORY_H dependencyAlexander Shiyan
This patch removes dependency of NEED_MACH_MEMORY_H for CLPS711X-target. Since some board may have memory holes, define ARCH_HAS_HOLES_MEMORYMODEL for these boards. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-06-11ARM: clps711x: Re-add GPIO supportAlexander Shiyan
arch_initcall was been removed from GPIO driver, so this patch re-add support for GPIO into boards as platform_device. Since some drivers (spi, nand, etc.) is not support deferred probe, separate machine init calls is used in board code to make proper loading sequence. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
