This uncouple PHYS_OFFSET from the platform definitions, thereby
facilitating run-time computation of the physical memory offset.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Magnus Damm <damm@opensource.se>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
Commit 7c63984b86 (ARM: do not define VMALLOC_END relative to PAGE_OFFSET)
changed VMALLOC_END to be an explicit value. Before this, it was
relative to PAGE_OFFSET and therefore converted to unsigned long
as PAGE_OFFSET is an unsigned long. This introduced the following
build warning. Fix this by changing the explicit defines of
VMALLOC_END to be unsigned long.
CC arch/arm/mm/init.o
arch/arm/mm/init.c: In function 'mem_init':
arch/arm/mm/init.c:606: warning: format '%08lx' expects type 'long unsigned int', but argument 12 has type 'unsigned int'
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Acked-by: Uwe Kleine-K <u.kleine-koenig@pengutronix.dee>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
Rather than checking the MMU status in every instance of addruart, do it
once in kernel/debug.S, and change the existing addruart macros to
return both physical and virtual addresses. The main debug code can then
select the appropriate address to use.
This will also allow us to retreive the address of a uart for the MMU
state that we're not current in.
Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com>
and Tony Lindgren <tony@atomide.com>, and fix for versatile express from
Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Jason Wang <jason77.wang@gmail.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
VMALLOC_END is supposed to be an absolute value, while PAGE_OFFSET may
vary depending on the selected user:kernel memory split mode through
CONFIG_VMSPLIT_*. In fact, the goal of moving PAGE_OFFSET down is to
accommodate more directly addressed RAM by the kernel below the vmalloc
area, and having VMALLOC_END move along PAGE_OFFSET is rather against
the very reason why PAGE_OFFSET can be moved in the first place.
Signed-off-by: Eric Miao <eric.miao@canonical.com>
'pl', 'spear' and 'versatile' into devel
We need mach/hardware.h for CLPS7111_VIRT_BASE.
Move the platform specific bootmem memory reservations out of
arch/arm/mm/mmu.c into their respective platform files.
Everything should now be using sparsemem rather than discontigmem, so
remove the code supporting discontigmem from ARM.
arch/arm/mach-clps711x/Makefile.boot:2: ERROR: trailing whitespace
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
These files include linux/bootmem.h without using anything from this
file; remove the unnecessary include.
Otherwise more complicated uart configuration won't be possible.
We can use r1 for tmp register for both head.S and debug.S.
NOTE: This patch depends on another patch to add the the tmp register
into all debug-macro.S files. That can be done with:
$ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/"
arch/arm/*/include/*/debug-macro.S
Anders Grafström reports that footbridge fails to build after 1c4a4f4.
Fix this by adding the necessary definitions for __pfn_to_bus and
__bus_to_pfn.
Reported-by: Anders Grafström <anders.grafstrom@netinsight.net>
OMAP wishes to pass state to the boot loader upon reboot in order to
instruct it whether to wait for USB-based reflashing or not. There is
already a facility to do this via the reboot() syscall, except we ignore
the string passed to machine_restart().
This patch fixes things to pass this string to arch_reset(). This means
that we keep the reboot mode limited to telling the kernel _how_ to
perform the reboot which should be independent of what we request the
boot loader to do.
Fix:
include/asm-generic/pgtable.h:305: warning: 'struct vm_area_struct' declared inside parameter list
include/asm-generic/pgtable.h:305: warning: its scope is only this definition or declaration, which is probably not what you want
include/asm-generic/pgtable.h:317: warning: 'struct vm_area_struct' declared inside parameter list
include/asm-generic/pgtable.h:331: warning: 'struct vm_area_struct' declared inside parameter list
Fix:
arch/arm/include/asm/irq.h:26: warning: 'struct pt_regs' declared inside parameter list
As Al did for Versatile in 2ad4f86b60b649fd7428265c08d73a3bd360c81b,
add a typesafe __io implementation for platforms to use. Convert
platforms to use this new simple typesafe implementation.
When ISA_DMA_API is unset, we're not implementing the ISA DMA API,
so there's no point in publishing the prototypes via asm/dma.h, nor
including the machine dependent parts of that API.
This allows us to remove a lot of mach/dma.h files which don't contain
any useful code. Unfortunately though, some platforms put their own
private non-ISA definitions into mach/dma.h, so we leave these behind
and fix the appropriate #include statments.
Avoid unnecessarily pollution of the kernel's namespace by avoiding
mach/hardware.h in mach/io.h. Include this header file where necessary.
Let's provide an overridable default instead of having every machine
class define __virt_to_bus and __bus_to_virt to the same thing. What
most platforms are using is bus_addr == phys_addr so such is the default.
One exception is ebsa110 which has no DMA what so ever, so the actual
definition is not important except only for proper compilation. Also
added a comment about the special footbridge bus translation.
Let's also remove comments alluding to set_dma_addr which is not
(and should not) be commonly used.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
Fix the edb7211_defconfig build errors.
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
Move the xtime write mode seqlock into timer_tick(), so it only
surrounds the call to do_timer().
This avoids a deadlock in update_process_times() ...
hrtimer_get_softirq_time() which tries to get a read mode seqlock
on xtime, thereby preventing booting.
Add IRQF_IRQPOLL for each timer interrupt.
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
set_irq_chipdata -> set_irq_chip_data
get_irq_chipdata -> get_irq_chip_data
do_level_IRQ -> handle_level_irq
do_edge_IRQ -> handle_edge_irq
do_simple_IRQ -> handle_simple_irq
irqdesc -> irq_desc
irqchip -> irq_chip
Untested, but this should fix up the bulk of the totally mechanical
issues, and should make the actual detail fixing easier.
The irgflags consolidation did conflict with the ARM to generic IRQ
conversion and was not applied for ARM. Fix it up.
Use the new IRQF_ constants and remove the SA_INTERRUPT define
Patch from Thomas Gleixner
Fixup the conversion to generic irq subsystem.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Patch from Martin Michlmayr
Add help descriptions to ARCH config items that don't have one.
Signed-off-by: Martin Michlmayr <tbm@cyrius.com>
Kconfig | 32 ++++++++++++++++++++++++++++++--
mach-clps711x/Kconfig | 2 ++
2 files changed, 32 insertions(+), 2 deletions(-)
Patch from Nicolas Pitre
This field is redundent since it must be equal to PHYS_OFFSET anyway.
Now that no code uses it anymore, mark it deprecated and remove all
initializations from the tree.
Signed-off-by: Nicolas Pitre <nico@cam.org>
CLPS711x, EPXA10DB and Integrator contained a dma.c file which has never
been built. Remove these redundant files.
No longer maintained
Patch from Jon Ringle
Updated 2898/1 per comments:
- Removed fixup
- Moved code in mach-mp1000/ to mach-clps711x/
- Cleaned up code in mp1000-seprom.c. Eliminated code that displayed the contents of the eeprom
Please comment.
Signed-off-by: Jon Ringle
Patch from Deepak Saxena
CLSP711x map_desc.pfn conversion
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
Patch from Vincent Sanders
When building the fortunet ARM platform it fails to compile because of
missing include.
Signed-off-by: Vincent Sanders <vince@arm.linux.org.uk>
Remove the pointless machine description macros, favouring C99
initialisers instead.
VST needs to know which timer handler is for the timer interrupt.
Mark all timer interrupts with the SA_TIMER flag.
The merge of sparsemem broke ARM discontigmem. Fix it.
Rather than using a long "depends on..." and "default y" lines for
these options, use select instead.
Signed-off-by: Russell King <rmk@arm.linux.org.uk>
infrastructure for it.
Let it rip!
