path: root/arch/arm/mach-cns3xxx/cns3420vb.c
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-07-12ARM: remove unnecessary mach/hardware.h includesRob Herring
Remove some includes of mach/hardware.h which are not needed. hardware.h will be removed completely for tegra and cns3xxx in follow on patch. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-07ARM: cns3xxx: Add support for L2 Cache ControllerAnton Vorontsov
CNS3xxx SOCs have L310-compatible cache controller, so let's use it. With this patch benchmarking with 'gzip' shows that performance is doubled, and I'm still able to boot full-fledged userland over NFS (using PCIe NIC), so the support should be pretty robust. p.s. While CNS3xxx reports that it has PL310, it still needs to wait on cache line operations, so we should not select 'CACHE_PL310', which is a micro-optimization that removes these waits for v7 CPUs. Someday we'd better rename CACHE_PL310 Kconfig option into NO_CACHE_WAIT or something less ambiguous. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
2010-11-26ARM: cns3xxx: Add architecture definition for EHCI/OHCI controllerMac Lin
This patch add plateform_device for EHCI and OHCI controller on CNS3XXX. Power reference count (usb_pwr_ref) is used to control enabling and disabling the single clock control for both EHCI and OHCI controller. It also removes EHCI/OHCI unused virtual address definitions. Signed-off-by: Mac Lin <mkl0301@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-06-08ARM: cns3xxx: Add support for AHCI controllersAnton Vorontsov
CNS3xxx chips have AHCI-compatible SATA controller. This patch adds the support using generic ahci_platform driver. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
2010-06-08ARM: cns3xxx: Add support for SDHCI controllersAnton Vorontsov
CNS3xxx chips have SDHCI-compatible SDIO/SD/MMC controller. This patch adds the support using sdhci-cns3xxx driver. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
2010-05-02ARM: cns3xxx: Add CNS3420 Validation Board supportAnton Vorontsov
This patch adds support for CNS3420VB rev 1.3 boards. With this patch CNS3420VB boards are able to boot up to the userspace, with a console available on UART0. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
