Up to this point, the USB phy clock configuration was handled manually in
the board files and in the usb drivers. This adds proper clocks so that
the usb drivers can use clk_get and clk_enable and not have to worry about
the details. Also, the related code is removed from the board files and
replaced with the new clock registration functions.
This also removes the #if IS_ENABLED(CONFIG_USB_MUSB_HDRC) around the musb
declaration and renames the musb platform device so that we can reference
it from the usb20 clock even if the musb device is not used.
Signed-off-by: David Lechner <david@lechnology.com>
Signed-off-by: Axel Haslam <ahaslam@baylibre.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
There is now a proper phy driver for the DA8xx SoC USB PHY. This adds the
platform device declarations needed to use it.
[nsekhar@ti.com: keep usb-davinci.h included in board-da830-evm.c
minor subject line adjustment]
The phy framework requests an optional "phy" regulator. If it does
not find one, it returns -EPROBE_DEFER. In the case of non-DT boot
for the omap138-lcdk board, this would prevent the usb11 phy to probe
correctly and ohci would not enumerate.
By calling regulator_has_full_constraints(), An error would be returned
instead of -EPROBE_DEFER for the regulator, and the probe of the phy driver
can continue normally without a regulator.
[nsekhar@ti.com: minor commit message updates]
The CFGCHIP registers are used by a number of devices, so use a syscon
device to share them. The first consumer of this will be the phy-da8xx-usb
driver.
Add the syscon device and register it.
[nsekhar@ti.com: minor commit message fixes]
Some macro for DA8xx CFGCHIP are defined in usb-davinci.h,
but da8xx-cfgchip.h intend to replace them.
Remove duplicated defines between da8xx-cfgchip.h and usb-davinci.h
Signed-off-by: Alexandre Bailon <abailon@baylibre.com>
Some header files are never included outside of a mach-davinci
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
Acked-by: Sekhar Nori <nsekhar@ti.com>
Convert printks to pr_<level> and pr_warning to pr_warn.
Other miscellanea:
o Coalesce formats
o Realign arguments
o Use %s, __func__ instead of embedded function names
o Add pr_fmt to mityomapl138 and mux
The problem that the set timings code contains the call of Davinci
platform function davinci_aemif_setup_timing() which is not
accessible if kernel is built for another platform like Keystone.
The Keysone platform is going to use TI AEMIF driver.
If TI AEMIF is used we don't need to set timings and bus width.
It is done by AEMIF driver.
To get rid of davinci-nand driver dependency on aemif platform code
we moved aemif code to davinci platform.
The platform AEMIF code (aemif.c) has to be removed once Davinci
will be converted to DT and use ti-aemif.c driver.
Acked-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
[nsekhar@ti.com: fixed checkpatch error and a build breakage due to
missing include, rebased onto l2-mtd/master]
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c changes from Wolfram Sang:
- new drivers for exynos5, bcm kona, and st micro
- bigger overhauls for drivers mxs and rcar
- typical driver bugfixes, cleanups, improvements
- got rid of the superfluous 'driver' member in i2c_client struct This
touches a few drivers in other subsystems. All acked.
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (38 commits)
i2c: bcm-kona: fix error return code in bcm_kona_i2c_probe()
i2c: i2c-eg20t: do not print error message in syslog if no ACK received
i2c: bcm-kona: Introduce Broadcom I2C Driver
i2c: cbus-gpio: Fix device tree binding
i2c: wmt: add missing clk_disable_unprepare() on error
i2c: designware: add new ACPI IDs
i2c: i801: Add Device IDs for Intel Wildcat Point-LP PCH
i2c: exynos5: Remove incorrect clk_disable_unprepare
i2c: i2c-st: Add ST I2C controller
i2c: exynos5: add High Speed I2C controller driver
i2c: rcar: fixup rcar type naming
i2c: scmi: remove some bogus NULL checks
i2c: sh_mobile & rcar: Enable the driver on all ARM platforms
i2c: sh_mobile: Convert to clk_prepare/unprepare
i2c: mux: gpio: use reg value for i2c_add_mux_adapter
i2c: mux: gpio: use gpio_set_value_cansleep()
i2c: Include linux/of.h header
i2c: mxs: Fix PIO mode on i.MX23
i2c: mxs: Rework the PIO mode operation
i2c: mxs: distinguish i.MX23 and i.MX28 based I2C controller
Pull ARM driver updates from Olof Johansson:
"Updates of SoC-near drivers and other driver updates that makes more
sense to take through our tree. In this case it's involved:
- Some Davinci driver updates that has required corresponding
platform code changes (gpio mostly)
- CCI bindings and a few driver updates
- Marvell mvebu patches for PCI MSI support (could have gone through
the PCI tree for this release, but they were acked by Bjorn for
3.12 so we kept them through arm-soc).
- Marvell dove switch-over to DT-based PCIe configuration
- Misc updates for Samsung platform dmaengine drivers"
* tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits)
ARM: S3C24XX: add dma pdata for s3c2410, s3c2440 and s3c2442
dmaengine: s3c24xx-dma: add support for the s3c2410 type of controller
ARM: S3C24XX: Fix possible dma selection warning
PCI: mvebu: make local functions static
PCI: mvebu: add I/O access wrappers
PCI: mvebu: Dynamically detect if the PEX link is up to enable hot plug
ARM: mvebu: fix gated clock documentation
ARM: dove: remove legacy pcie and clock init
ARM: dove: switch to DT probed mbus address windows
ARM: SAMSUNG: set s3c24xx_dma_filter for s3c64xx-spi0 device
ARM: S3C24XX: add platform-devices for new dma driver for s3c2412 and s3c2443
dmaengine: add driver for Samsung s3c24xx SoCs
ARM: S3C24XX: number the dma clocks
PCI: mvebu: add support for Marvell Dove SoCs
PCI: mvebu: add support for reset on GPIO
PCI: mvebu: remove subsys_initcall
PCI: mvebu: increment nports only for registered ports
PCI: mvebu: move clock enable before register access
PCI: mvebu: add support for MSI
irqchip: armada-370-xp: implement MSI support
This patch proposes to remove the IRQF_DISABLED flag from Davinci code ;)
It's a NOOP since 2.6.35, and will be removed one day
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
This patch moves the at24.h header from include/linux/i2c to
include/linux/platform_data and updates existing support accordingly.
It also fixes the following checkpatch warning:
WARNING: please, no space before tabs
#436: FILE: include/linux/platform_data/at24.h:31:
+ * ^Iu8 *mac_addr = ethernet_pdata->mac_addr;$
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Register gpio platform device on DA8XX boards.
While at it, group related include files together.
Signed-off-by: Philip Avinash <avinashphilip@ti.com>
[nsekhar@ti.com: remove SoC specific parts from this file.
fix compile warnings]
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
"struct davinci_uart_config" was introduced to specify
UART ports brought out or enabled on the board. But
none of the boards use it for that purpose and we are
not going to add anymore board files, so remove the
structure.
Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com>
Suggested-by: Sekhar Nori <nsekhar@ti.com>
[nsekhar@ti.com: split patch to remove davinci_serial_setup_clk()
changes.]
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/boards
From Sekhar Nori:
v3.10 board updates for DaVinci
This set of patches enables remoteproc support
on DA850 EVM and fixes some sparse warnings for
the same board.
* tag 'davinci-for-v3.10/board-2-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
ARM: davinci: da850 evm: fix const qualifier placement
ARM: davinci: da850 board: add remoteproc support
ARM: davinci: ensure global variables are declared
ARM: davinci: sram.c: fix incorrect type in assignment
ARM: davinci: da8xx dt: make file local symbols static
ARM: davinci: da8xx: add remoteproc support
ARM: davinci: remove test for undefined Kconfig macro
ARM: davinci: mmc: derive version information from device name
ARM: davinci: da850: add ECAP & EHRPWM clock nodes
ARM: davinci: clk framework support for enable/disable functionality
Remove specifying mmc controller IP version information via platform
data, instead specify device name so that driver derives it from
platform_device_id table. Also change the clock node name to match
the changed dev_id.
Tested on da850-evm to make sure driver loads without clk_get failures.
Reviewed-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Chris Ball <cjb@laptop.org>
This patches replaces #if defined() by IS_ENABLED macro, which provides
better readability.
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
git://gitorious.org/linux-davinci/linux-davinci into next/soc
From Sekhar Nori:
DaVinci SoC changes for v3.9
This pull request:
1) Fixes a bug with the way SPI devices were registered on DA850
2) Adds support for DSP clock and resetting the DSP on DA850
3) Fixes checkpatch issue with some existing files.
* tag 'davinci-for-v3.9/soc' of git://gitorious.org/linux-davinci/linux-davinci:
ARM: davinci: da850: add dsp clock definition
ARM: davinci: psc: introduce reset API
ARM: davinci: psc.c: change pr_warning() to pr_warn()
ARM: davinci: devices-da8xx.c: change pr_warning() to pr_warn()
ARM: davinci: da8xx_register_spi() should not register SPI board info
Without this patch, da8xx_register_spi() registers the SPI board info,
the SPI controller, and sets its number of chipselect to the size of the
static spi_board_info array. This is bad because a SPI board info may
declare devices for different SPI buses, and because other code can also
call spi_register_board_info() (e.g. a daughter board might provide
additional SPI devices).
This patch removes the spi_register_board_info() call from
da8xx_register_spi(), renames this last one to da8xx_register_spi_bus()
to be more explicit, takes the number of chipselect as a function
parameter, and updates the impacted board-da8{3,5}0-evm.c, and
board-mityomapl138.c files accordingly. It also sets the SPI platform
data static, as it doesn't need to be exported.
[nsekhar@ti.com: fixed conflicts with v3.7-rc7, converted to use pr_warn(),
modified print messages to use __func__]
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the davinci include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Kevin Hilman <khilman@ti.com>
Cc: "Ben Dooks" <ben-linux@fluff.org>
Cc: "Wolfram Sang" <w.sang@pengutronix.de>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Liam Girdwood <lrg@ti.com>
Cc: davinci-linux-open-source@linux.davincidsp.com
Rather than using DaVinci specific davinci_soc_info based
restart hook, use the restart hook available in the machine
descriptor instead.
Tested on DM365 and AM18x EVMs.
v2:
Changed to use restart hook in machine descriptor
per Russell's comment.
* git://git.infradead.org/mtd-2.6: (226 commits)
mtd: tests: annotate as DANGEROUS in Kconfig
mtd: tests: don't use mtd0 as a default
mtd: clean up usage of MTD_DOCPROBE_ADDRESS
jffs2: add compr=lzo and compr=zlib options
jffs2: implement mount option parsing and compression overriding
mtd: nand: initialize ops.mode
mtd: provide an alias for the redboot module name
mtd: m25p80: don't probe device which has status of 'disabled'
mtd: nand_h1900 never worked
mtd: Add DiskOnChip G3 support
mtd: m25p80: add EON flash EN25Q32B into spi flash id table
mtd: mark block device queue as non-rotational
mtd: r852: make r852_pm_ops static
mtd: m25p80: add support for at25df321a spi data flash
mtd: mxc_nand: preset_v1_v2: unlock all NAND flash blocks
mtd: nand: switch `check_pattern()' to standard `memcmp()'
mtd: nand: invalidate cache on unaligned reads
mtd: nand: do not scan bad blocks with NAND_BBT_NO_OOB set
mtd: nand: wait to set BBT version
mtd: nand: scrub BBT on ECC errors
Fix up trivial conflicts:
- arch/arm/mach-at91/board-usb-a9260.c
Merged into board-usb-a926x.c
- drivers/mtd/maps/lantiq-flash.c
add_mtd_partitions -> mtd_device_register vs changed to use
mtd_device_parse_register.
Recall the recently added prefix requirements:
* "NAND_" for flags in nand.h, used in nand_chip.options
* "NAND_BBT_" for flags in bbm.h, used in nand_chip.bbt_options
or in nand_bbt_descr.options
Thus, I am changing NAND_USE_FLASH_BBT to NAND_BBT_USE_FLASH.
Again, this flag is found in bbm.h and so should NOT be used in the
"nand_chip.options" field.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
This patch works with the following three flags from two headers (nand.h
and bbm.h):
(1) NAND_USE_FLASH_BBT (nand.h)
(2) NAND_USE_FLASH_BBT_NO_OOB (nand.h)
(3) NAND_BBT_NO_OOB (bbm.h)
These flags are all related and interdependent, yet they were in
different headers. Flag (2) is simply the combination of (1) and (3) and
can be eliminated.
This patch accomplishes the following:
* eliminate NAND_USE_FLASH_BBT_NO_OOB (i.e., flag (2))
* move NAND_USE_FLASH_BBT (i.e., flag (1)) to bbm.h
It's important to note that because (1) and (3) are now both found in
bbm.h, they should NOT be used in the "nand_chip.options" field.
I removed a small section from the mtdnand DocBook because it referes to
NAND_USE_FLASH_BBT in nand.h, which has been moved to bbm.h.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
This patch adds the on-board SPI flash device to the
DA830/OMAP-L137/AM17x EVM. It also registers the SPI flash
device to the MTD subsystem.
Based on SPI flash device support for MityDSP-L138F platform.
[michael.williamson@criticallink.com: moved da830evm_spi0_pdata to devices-da8xx.c]
[michael.williamson@criticallink.com: moved da830evm_init_spi0 to devices-da8xx.c]
Signed-off-by: Michael Williamson <michael.williamson@criticallink.com>
Signed-off-by: Kevin Hilman <khilman@ti.com>
arch/arm/mach-davinci/board-da830-evm.c
arch/arm/mach-davinci/board-da850-evm.c
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
This patch removes davinci architecture code that has now been rendered
useless by the previous patches in the MDIO separation series.
In addition, the earlier phy_mask definitions have been replaced with
corresponding phy_id definitions.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
Tested-by: Michael Williamson <michael.williamson@criticallink.com>
Tested-by: Caglar Akyuz <caglarakyuz@gmail.com>
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
This patch adds machine checks in the serial console init routines
for the DA8XX EVM boards. This is needed because there are other
DA8XX based machines that use a different UART/tty as the console
and may be included in a common kernel build.
Setup the NAND flash timings for DA830 EVM.
Before configuring the timing values, throughput calculation
using dd command yielded 477 kB/s write and 970 kB/s read speed.
After the timing configuration, the throughput was measured to
be 2.5 MB/s write and 5.1 MB/s read.
[Mukul Bhatnagar: actual calculation of timing values from the
NAND datasheet]
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Cc: Mukul Bhatnagar <mbhatnagar@ti.com>
Acked-by: Kevin Hilman <khilman@deeprootsystems.com>
The Sitara AM17x SoCs from TI are an OMAP-L137 pin-to-pin
compatible ARM9 microprocessor offering from TI.
The Sitara AM18x SoCs from TI are an OMAP-L138 pin-to-pin
More information about these processors available at:
www.ti.com/am1x
Because of their compatibiliy with OMAP-L1x, the kernel
support for OMAP-L1x is fully relevant to AM1x processors.
This patch updates the Kconfig prompt and help text to include
the AM1x part names to help users select configurations required
for these parts easily.
Also, the hardware information that shows up in /proc/cpuinfo
is updated to show applicability of the respective OMAP-L1x EVMs
for AM1x parts.
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci
* 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci:
davinci: dm646x EVM: Specify reserved EDMA channel/slots
davinci: da8xx/omapl EVM: Specify reserved channels/slots
davinci: support for EDMA resource sharing
davinci: edma: provide ability to detect insufficient CC info data
davinci: da8xx: sparse cleanup: remove duplicate entries in irq priorities
davinci: DM365: fixed second serial port
Davinci: tnetv107x evm board initial support
Davinci: tnetv107x initial gpio support
Davinci: tnetv107x soc support
Davinci: tnetv107x decompresser uart definitions
Davinci: generalized debug macros
The drivers on da8xx/omapl EVMs do not utilize all the channels
and slots provided by EDMA. Some of these are better utilitzed by
the DSP on the SoC for speeding up codec operations.
Reserve these channels/slots for the DSP.
Currently the EDMA queue to be used by for servicing ASP through
internal RAM is fixed to EDMAQ_0 and that to service internal RAM
from external RAM is fixed to EDMAQ_1.
This may not be the desirable configuration on all platforms. For
example, on DM365, queue 0 has large fifo size and is more suitable
for video transfers. Having audio and video transfers on the same
queue may lead to starvation on audio side.
platform data as defined currently passes a queue number to the driver
but that remains unused inside the driver.
Fix this by defining one queue each for ASP and RAM transfers in the
platform data and using it inside the driver.
Since EDMAQ_0 maps to 0, thats the queue that will be used if
the asp queue number is not initialized. None of the platforms
currently utilize ping-pong transfers through internal RAM so that
functionality remains unchanged too.
This patch has been tested on DM644x and OMAP-L138 EVMs.
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
This patch implements the following:
- interrupt initialization uses ioremap() instead of passing a virtual address
via davinci_soc_info.
- machine definitions directly point to cp_intc_init() or davinci_irq_init()
- davinci_intc_type and davinci_intc_base now get initialized in controller
specific init functions instead of davinci_common_init()
- minor fix in davinci_irq_init() to use intc_irq_num instead of
DAVINCI_N_AINTC_IRQ
The board file #define's its own version of EMIFA base addresses, while there
are DA8XX_AEMIF_*_BASE macros #define'd in <mach/da8xx.h>. Start using them
instead.
Rename da8xx_pinmux_setup() to davinci_cfg_reg_list() and promote it for use in
other SOCs that may need the ability to configure multiple pins in one shot.
Host map configuration instructs the interrupt controller to route interrupt
channels to FIQ or IRQ lines. Currently, DA8xx family of devices leave these
registers at their reset-default values.
TNETV107X however does not have sane reset defaults, and therefore this
architecture needs to reconfigure the host-map such that channels 0 and 1
go to FIQ, and the remaining channels raise IRQs.
This patch adds an optional host map argument to cp_intc_init() for this.
The merge for 2.6.34 brings in 8-bit support to the DaVinci MMC/SD driver.
This patch updates the platform data for DA830/OMAP-L137 EVM to use 8-wire
support available in the driver.
Signed-off-by: Vipin Bhandari <vipin.bhandari@ti.com>
The DA830/OMAP-L137 EVM has GPIO based card detection logic, but the current
code does not use it.
Add support for GPIO based card detection to avoid reading the card to see
if a card is present or not.
OMAP-L138 adds a second SYSCFG region having useful functionality
like deep sleep, pull up/down control and SATA clock stop.
This patch makes provision for accessing registers from second
SYSCFG region in da8xx code.
Note that OMAP-L137 has a single SYSCFG region.
Include high speed capabilities in MMC/SD platform data
for DA830/OMAP-L137 and DA850/OMAP-L138 EVMs.
Signed-off-by: Chaithrika U S <chaithrika@ti.com>
When kernel is built with CONFIG_DEBUG_SECTION_MISMATCH=y
option, using da8xx_omapl_defconfig, some warnings are
observed:
WARNING: vmlinux.o(.text+0xc2a4): Section mismatch in reference
from the function da850_evm_setup_nor_nand() to the variable
.init.data:da850_nand_pins
The function da850_evm_setup_nor_nand() references
the variable __initdata da850_nand_pins.
This is often because da850_evm_setup_nor_nand lacks a __initdata
annotation or the annotation of da850_nand_pins is wrong.
This patch fixes such warnings.
is selected
On the DA830, AEMIF and MMC/SD pins are shared. On the EVM, when
the mux_mode signal is low MMC/SD works and when mux_mode signal
is high, NAND works.
When MMC/SD driver is configured in the kernel, do not let NAND
get registered and drive mux_mode high. Instead, print a warning
for user to understand why the platform device for NAND did not
get registered.
This patch supports runtime detection of DA830 UI card and
eliminates the need for DA830_UI config option. Successful
probe of GPIO expander present on the UI card is used to
detect its presence. For this reason, GPIO_PCF857X is auto-
selected when DA830 EVM is configured. In case the UI card
is absent, the probe fails in reasonable time.
As a side effect this patch also gets rid of the voilation
of Documentation/SubmittingPatches section 2.2 in function
da830_evm_ui_expander_setup()
Remove ifdefs inside da830_evm_init function since they are
discouraged in Documentation/SubmittingPatches section 2.2
Use the method outlined in that document for fixing it.
Tested on DA830 EVM.
