[ Upstream commit 0c0c9b5753cd04601b17de09da1ed2885a3b42fe ]
The BB expander at 0x21 i2c bus 1 fails to probe on da850-evm because
the board doesn't set has_full_constraints to true in the regulator
API.
Call regulator_has_full_constraints() at the end of board registration
just like we do in da850-lcdk and da830-evm.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
[ Upstream commit 1b6fe9798af8cb7d80fad5dd30ee1bcd1e0f51eb ]
When booting from MMC/SD in rw mode on DA850 EVM, the system
crashes because the write protect pin should be active high
and not active low. This patch fixes the polarity of the WP pin.
Fixes: bdf0e8364fd3 ("ARM: davinci: da850-evm: use gpio descriptor for mmc pins")
[ Upstream commit 67c6b6ff221f807180aea6dd597246f87e1dd98a ]
The GPIO chip is called davinci_gpio.0 in legacy mode. Fix it, so that
mmc can correctly lookup the wp and cp gpios. Also fix the GPIO numbers
as they are not offsets within a bank.
Note that it is the gpio-davinci driver that sets the gpiochip label to
davinci_gpio.0.
Reviewed-by: David Lechner <david@lechnology.com>
From Boris:
This pull request contains the following core changes:
* Fix memory leaks in the core
* Remove unused NAND locking support
* Rename nand.h into rawnand.h (preparing support for spi NANDs)
* Use NAND_MAX_ID_LEN where appropriate
* Fix support for 20nm Hynix chips
* Fix support for Samsung and Hynix SLC NANDs
and the following driver changes:
* Various cleanup, improvements and fixes in the qcom driver
* Fixes for bugs detected by various static code analysis tools
* Fix mxc ooblayout definition
* Add a new part_parsers to tmio and sharpsl platform data in order to
define a custom list of partition parsers
* Request the reset line in exclusive mode in the sunxi driver
* Fix a build error in the orion-nand driver when compiled for ARMv4
* Allow 64-bit mvebu platforms to select the PXA3XX driver
We are planning to share more code between different NAND based
devices (SPI NAND, OneNAND and raw NANDs), but before doing that
we need to move the existing include/linux/mtd/nand.h file into
include/linux/mtd/rawnand.h so we can later create a nand.h header
containing all common structure and function prototypes.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Peter Pan <peterpandong@micron.com>
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Alexander Sverdlin <alexander.sverdlin@gmail.com>
Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Han Xu <han.xu@nxp.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-By: Harvey Hunt <harveyhuntnexus@gmail.com>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
A change to the platform data definitions caused a warning in the board code:
arch/arm/mach-davinci/board-da850-evm.c:1221:13: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
arch/arm/mach-davinci/board-da850-evm.c:1231:13: warning: initialization discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
This is a bit unfortunate, since we generally like structure definitions to
be const, but as this is legacy code, the easiest way out is still to
remove the 'const' annotation here.
Fixes: 4a5f8ae50b66 ("[media] davinci: vpif_capture: get subdevs from DT when available")
Fixes: 231ce279e6e3 ("ARM: davinci: fix const warnings")
Acked-by: Sekhar Nori <nsekhar@ti.com>
Pull ARM SoC platform updates from Olof Johansson:
"SoC platform changes (arch/arm/mach-*). This merge window, the bulk is
for a few platforms:
Gemini:
- Legacy platform that Linus Walleij has converted to multiplatform
and DT, so a handful of various tweaks there, removal of some old
stale support, etc.
Atmel AT91:
- Fixup of various power management related pieces
- Move of SoC detection to a drivers/soc driver instead
ST Micro STM32:
- New SoC support: STM32H743
TI platforms:
- More driver support for Davinci (SATA in particular)
- Removal of some old stale hwmod files (linkspace platform)
Misc:
- A couple of smaller patches for i.MX, sunxi, hisi"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (57 commits)
ARM: davinci: Add clock for CPPI 4.1 DMA engine
ARM: mxs: add support for I2SE Duckbill 2 boards
MAINTAINERS: Update the Allwinner sunXi entry
ARM: i.MX25: globally disable supervisor protect
ARM: at91: move SoC detection to its own driver
ARM: at91: pm: correct typo
ARM: at91: pm: Remove at91_pm_set_standby
ARM: at91: pm: Merge all at91sam9*_pm_init
ARM: at91: pm: Tie the USB clock mask to the pmc
ARM: at91: pm: Tie the memory controller type to the ramc id
ARM: at91: pm: Workaround DDRSDRC self-refresh bug with LPDDR1 memories.
ARM: at91: pm: Simplify at91rm9200_standby
ARM: at91: pm: Use struct at91_pm_data in pm_suspend.S
ARM: at91: pm: Move global variables into at91_pm_data
ARM: at91: pm: Move at91_ramc_read/write to pm.c
ARM: at91: pm: Cleanup headers
MAINTAINERS: Add memory drivers to AT91 entry
MAINTAINERS: Update AT91 entry
ARM: davinci: add pata_bk3710 libata driver support
ARM: OMAP2+: mark omap_init_rng as __init
The vpif display driver uses a static i2c adapter ID of 1 but on the
da850-evm board in DT boot mode the i2c adapter ID is actually 0.
Make the adapter ID configurable like it already is for vpif capture.
Acked-by: Kevin Hilman <khilman@baylibre.com>
Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Without this regulator the tca6416 GPIO expander on the UI board can't
be probed in board file mode and we're not getting VPIF IRQs.
VPIF capture driver now has a way to specific I2C adapter ID (was
previously hard-coded.) Use the new interface.
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
Some of the davinci boards, da850-evm, dm644x-evm and neuros-osd2 depends
on leds.h. Explicitly include it instead of relying on the public mmc
header host.h.
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@kernel.org>
Cc: <linux-arm-kernel@lists.infradead.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/soc
Pull "DaVinci SoC updates for v4.10 (part 3)" from Sekhar Nori:
mach-davinci SoC support updates to adjust
USB ohci device name to that used by drivers
and update of various board files to use gpio
descriptor API used by MMC subsystem for card
detect and write-protect detection.
* tag 'davinci-for-v4.10/soc-3' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
ARM: davinci: da830-evm: use gpio descriptor for mmc pins
ARM: davinci: hawk: use gpio descriptor for mmc pins
ARM: davinci: da8xx: Fix ohci device name
Pull DaVinci cleanup for v4.10 from Sekhar Nori:
mach-davinci cleanup to make it easy to add PM support
for DT-boot.
* tag 'davinci-for-v4.10/cleanup-2' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
ARM: davinci: PM: fix build when da850 not compiled in
ARM: davinci: PM: cleanup: remove references to pdata
ARM: davinci: PM: rework init, remove platform device
Currently the mmc driver is polling the gpio to know if the
card was removed.
By using a gpio descriptor instead of the platform callbacks,
the driver will be able to register the gpio using the mmc core
APIs designed for this purpose.
This has the advantage that an irq will be registered, and
polling is no longer needed. Also, a dependency on platform
callbacks is removed for this board.
Signed-off-by: Axel Haslam <ahaslam@baylibre.com>
[nsekhar@ti.com: minor commit message edit]
Remove fake platform device used for PM init. Move pdata values which
are common across all current platforms into pm.c.
Also, since PM is only used on da8xx, remove davinci_pm_init() from
common init code, and only use in da850/omapl138 board files that are
currently creating the fake platform_device.
Suggested-by: Sekhar Nori <nsekhar@ti.com>
[nsekhar@ti.com: subject line adjustment]
The CFGCHIP registers are used by a number of devices, so use a syscon
device to share them. The first consumer of this will be the phy-da8xx-usb
driver.
Add the syscon device and register it.
Signed-off-by: David Lechner <david@lechnology.com>
[nsekhar@ti.com: minor commit message fixes]
Pull ARM SoC multiplatform code updates from Arnd Bergmann:
"This branch is the culmination of 5 years of effort to bring the ARMv6
and ARMv7 platforms together such that they can all be enabled and
boot the same kernel. It has been a tremendous amount of cleanup and
refactoring by a huge number of people, and creation of several new
(and major) subsystems to better abstract out all the platform details
in an appropriate manner.
The bulk of this branch is a large patchset from Arnd that brings
several of the more minor and older platforms we have closer to
multiplatform support. Among these are MMP, S3C64xx, Orion5x, mv78xx0
and realview Much of this is moving around header files from old mach
directories, but there are also some cleanup patches of debug_ll
(lowlevel debug per-platform options) and other parts.
Linus Walleij also has some patchs to clean up the older ARM Realview
platforms by finally introducing DT support, and Rob Herring has some
for ARM Versatile which is now DT-only. Both of these platforms are
now multiplatform.
Finally, a couple of patches from Russell for Dove PMU, and a fix from
Valentin Rothberg for Exynos ADC, which were rebased on top of the
series to avoid conflicts"
* tag 'armsoc-multiplatform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (75 commits)
ARM: realview: don't select SMP_ON_UP for UP builds
ARM: s3c: simplify s3c_irqwake_{e,}intallow definition
ARM: s3c64xx: fix pm-debug compilation
iio: exynos-adc: fix irqf_oneshot.cocci warnings
ARM: realview: build realview-dt SMP support only when used
ARM: realview: select apropriate targets
ARM: realview: clean up header files
ARM: realview: make all header files local
ARM: no longer make CPU targets visible separately
ARM: integrator: use explicit core module options
ARM: realview: enable multiplatform
ARM: make default platform work for NOMMU
ARM: debug-ll: move DEBUG_LL_UART_EFM32 to correct Kconfig location
ARM: defconfig: use correct debug_ll settings
ARM: versatile: convert to multi-platform
ARM: versatile: merge mach code into a single file
ARM: versatile: switch to DT only booting and remove legacy code
ARM: versatile: add DT based PCI detection
ARM: pxa: mark ezx structures as __maybe_unused
ARM: pxa: mark raumfeld init functions as __maybe_unused
Some header files are never included outside of a mach-davinci
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
Currently, include/media is messy, as it contains both the V4L2 core
headers and some driver-specific headers on the same place. That makes
harder to identify what core headers should be documented and what
headers belong to I2C drivers that are included only by bridge/main
drivers that would require the functions provided by them.
Let's move those i2c specific files to its own subdirectory.
The files to move were produced via the following script:
mkdir include/media/i2c
(cd include/media; for i in *.h; do n=`echo $i|sed s/.h$/.c/`; if [ -e ../../drivers/media/i2c/$n ]; then echo $i; git mv $i i2c/; fi; done)
(cd include/media; for i in *.h; do n=`echo $i|sed s/.h$/.c/`; if [ -e ../../drivers/media/*/i2c/$n ]; then echo $i; git mv $i i2c/; fi; done)
for i in include/media/*.h; do n=`basename $i`; (for j in $(git grep -l $n); do dirname $j; done)|sort|uniq|grep -ve '^.$' > list; num=$(wc -l list|cut -d' ' -f1); if [ $num == 1 ]; then if [ "`grep i2c list`" != "" ]; then git mv $i include/media/i2c; fi; fi; done
And the references corrected via this script:
MAIN_DIR="media/"
PREV_DIR="media/"
DIRS="i2c/"
echo "Checking affected files" >&2
for i in $DIRS; do
for j in $(find include/$MAIN_DIR/$i -type f -name '*.h'); do
n=`basename $j`
git grep -l $n
done
done|sort|uniq >files && (
echo "Handling files..." >&2;
echo "for i in \$(cat files|grep -v Documentation); do cat \$i | \\";
cd include/$MAIN_DIR;
for j in $DIRS; do
for i in $(ls $j); do
echo "perl -ne 's,(include [\\\"\\<])$PREV_DIR($i)([\\\"\\>]),\1$MAIN_DIR$j\2\3,; print \$_' |\\";
done;
done;
echo "cat > a && mv a \$i; done";
echo "Handling documentation..." >&2;
echo "for i in MAINTAINERS \$(cat files); do cat \$i | \\";
for j in $DIRS; do
echo " perl -ne 's,include/$PREV_DIR($i)\b,include/$MAIN_DIR$j\1,; print \$_' |\\";
done;
done;
) >script && . ./script
Merged Sakari Ailus patch that moves smiapp.h to include/media/i2c.
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Now that we have wlcore device-tree bindings in place
(for both wl12xx and wl18xx), remove the legacy
wl12xx_platform_data struct, and move its members
into the platform device data (that is passed to wlcore)
Davinci 850 is the only platform that still set
the platform data in the legacy way (and doesn't
have DT bindings), so remove the relevant
code/Kconfig option from the board file (as suggested
by Sekhar Nori)
Since no one currently uses wlcore_spi, simply remove its
platform data support (DT bindings will have to be added
if someone actually needs it)
Signed-off-by: Luciano Coelho <luca@coelho.fi>
Signed-off-by: Eliad Peller <eliad@wizery.com>
Tested-by: Nikita Kiryanov <nikita@compulab.co.il>
Acked-by: Kalle Valo <kvalo@codeaurora.org>
Instead of defining an enumeration with the FW specific values for the
different clock rates, use the actual frequency instead. Also add a
boolean to specify whether the clock is XTAL or not.
Change all board files to reflect this.
[Eliad - small fixes, update board file changes]
The platform_quirk element in the platform data was used
to change the way the IRQ is triggered. When set,
the EDGE_IRQ quirk would change the irqflags used
and treat edge trigger differently from the rest.
Instead of hiding this irq flag setting behind the quirk,
have the board files set the irq_trigger explicitly.
This will allow us to use standard irq DT definitions
later on.
[Eliad - rebase, add irq_trigger field and pass it,
These casts to char* are unnecessary and slightly confusing, since
both operands actually have type const char*.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
IOVDD: tps65070's dcdc2
AVDD and DRVDD: fixed regulator derived from 5V via TPS73701DCQ
DVDD: fixed regulator derived from 5V via TPS73701DCQ
This patch needed to be able to probe the audio codec.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
DCDC2 should not be turned off since it is powering the CPU among other
things.
The problem that the set timings code contains the call of Davinci
platform function davinci_aemif_setup_timing() which is not
accessible if kernel is built for another platform like Keystone.
The Keysone platform is going to use TI AEMIF driver.
If TI AEMIF is used we don't need to set timings and bus width.
It is done by AEMIF driver.
To get rid of davinci-nand driver dependency on aemif platform code
we moved aemif code to davinci platform.
The platform AEMIF code (aemif.c) has to be removed once Davinci
will be converted to DT and use ti-aemif.c driver.
Acked-by: Brian Norris <computersforpeace@gmail.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
[nsekhar@ti.com: fixed checkpatch error and a build breakage due to
missing include, rebased onto l2-mtd/master]
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c changes from Wolfram Sang:
- new drivers for exynos5, bcm kona, and st micro
- bigger overhauls for drivers mxs and rcar
- typical driver bugfixes, cleanups, improvements
- got rid of the superfluous 'driver' member in i2c_client struct This
touches a few drivers in other subsystems. All acked.
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (38 commits)
i2c: bcm-kona: fix error return code in bcm_kona_i2c_probe()
i2c: i2c-eg20t: do not print error message in syslog if no ACK received
i2c: bcm-kona: Introduce Broadcom I2C Driver
i2c: cbus-gpio: Fix device tree binding
i2c: wmt: add missing clk_disable_unprepare() on error
i2c: designware: add new ACPI IDs
i2c: i801: Add Device IDs for Intel Wildcat Point-LP PCH
i2c: exynos5: Remove incorrect clk_disable_unprepare
i2c: i2c-st: Add ST I2C controller
i2c: exynos5: add High Speed I2C controller driver
i2c: rcar: fixup rcar type naming
i2c: scmi: remove some bogus NULL checks
i2c: sh_mobile & rcar: Enable the driver on all ARM platforms
i2c: sh_mobile: Convert to clk_prepare/unprepare
i2c: mux: gpio: use reg value for i2c_add_mux_adapter
i2c: mux: gpio: use gpio_set_value_cansleep()
i2c: Include linux/of.h header
i2c: mxs: Fix PIO mode on i.MX23
i2c: mxs: Rework the PIO mode operation
i2c: mxs: distinguish i.MX23 and i.MX28 based I2C controller
This patch moves the at24.h header from include/linux/i2c to
include/linux/platform_data and updates existing support accordingly.
It also fixes the following checkpatch warning:
WARNING: please, no space before tabs
#436: FILE: include/linux/platform_data/at24.h:31:
+ * ^Iu8 *mac_addr = ethernet_pdata->mac_addr;$
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Register gpio platform device on DA8XX boards.
While at it, group related include files together.
Signed-off-by: Philip Avinash <avinashphilip@ti.com>
[nsekhar@ti.com: remove SoC specific parts from this file.
fix compile warnings]
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Pull ARM SoC platform changes from Olof Johansson:
"This branch contains mostly additions and changes to platform
enablement and SoC-level drivers. Since there's sometimes a
dependency on device-tree changes, there's also a fair amount of
those in this branch.
Pieces worth mentioning are:
- Mbus driver for Marvell platforms, allowing kernel configuration
and resource allocation of on-chip peripherals.
- Enablement of the mbus infrastructure from Marvell PCI-e drivers.
- Preparation of MSI support for Marvell platforms.
- Addition of new PCI-e host controller driver for Tegra platforms
- Some churn caused by sharing of macro names between i.MX 6Q and 6DL
platforms in the device tree sources and header files.
- Various suspend/PM updates for Tegra, including LP1 support.
- Versatile Express support for MCPM, part of big little support.
- Allwinner platform support for A20 and A31 SoCs (dual and quad
Cortex-A7)
- OMAP2+ support for DRA7, a new Cortex-A15-based SoC.
The code that touches other architectures are patches moving MSI
arch-specific functions over to weak symbols and removal of
ARCH_SUPPORTS_MSI, acked by PCI maintainers"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (266 commits)
tegra-cpuidle: provide stub when !CONFIG_CPU_IDLE
PCI: tegra: replace devm_request_and_ioremap by devm_ioremap_resource
ARM: tegra: Drop ARCH_SUPPORTS_MSI and sort list
ARM: dts: vf610-twr: enable i2c0 device
ARM: dts: i.MX51: Add one more I2C2 pinmux entry
ARM: dts: i.MX51: Move pins configuration under "iomuxc" label
ARM: dtsi: imx6qdl-sabresd: Add USB OTG vbus pin to pinctrl_hog
ARM: dtsi: imx6qdl-sabresd: Add USB host 1 VBUS regulator
ARM: dts: imx27-phytec-phycore-som: Enable AUDMUX
ARM: dts: i.MX27: Disable AUDMUX in the template
ARM: dts: wandboard: Add support for SDIO bcm4329
ARM: i.MX5 clocks: Remove optional clock setup (CKIH1) from i.MX51 template
ARM: dts: imx53-qsb: Make USBH1 functional
ARM i.MX6Q: dts: Enable I2C1 with EEPROM and PMIC on Phytec phyFLEX-i.MX6 Ouad module
ARM i.MX6Q: dts: Enable SPI NOR flash on Phytec phyFLEX-i.MX6 Ouad module
ARM: dts: imx6qdl-sabresd: Add touchscreen support
ARM: imx: add ocram clock for imx53
ARM: dts: imx: ocram size is different between imx6q and imx6dl
ARM: dts: imx27-phytec-phycore-som: Fix regulator settings
ARM: dts: i.MX27: Remove clock name from CPU node
Pull ARM SoC cleanups from Olof Johansson:
"This branch contains code cleanups, moves and removals for 3.12.
There's a large number of various cleanups, and a nice net removal of
13500 lines of code.
Highlights worth mentioning are:
- A series of patches from Stephen Boyd removing the ARM local timer
API.
- Move of Qualcomm MSM IOMMU code to drivers/iommu.
- Samsung PWM driver cleanups from Tomasz Figa, removing legacy PWM
driver and switching over to the drivers/pwm one.
- Removal of some unusued auto-generated headers for OMAP2+ (PRM/CM).
There's also a move of a header file out of include/linux/i2c/ to
platform_data, where it really belongs. It touches mostly ARM
platform code for include changes so we took it through our tree"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits)
ARM: OMAP2+: Add back the define for AM33XX_RST_GLOBAL_WARM_SW_MASK
gpio: (gpio-pca953x) move header to linux/platform_data/
arm: zynq: hotplug: Remove unreachable code
ARM: SAMSUNG: Remove unnecessary exynos4_default_sdhci*()
tegra: simplify use of devm_ioremap_resource
ARM: SAMSUNG: Remove plat/regs-timer.h header
ARM: SAMSUNG: Remove remaining uses of plat/regs-timer.h header
ARM: SAMSUNG: Remove pwm-clock infrastructure
ARM: SAMSUNG: Remove old PWM timer platform devices
pwm: Remove superseded pwm-samsung-legacy driver
ARM: SAMSUNG: Modify board files to use new PWM platform device
ARM: SAMSUNG: Rework private data handling in dev-backlight
pwm: Add new pwm-samsung driver
ARM: mach-mvebu: remove redundant DT parsing and validation
ARM: msm: Only compile io.c on platforms that use it
iommu/msm: Move mach includes to iommu directory
ARM: msm: Remove devices-iommu.c
ARM: msm: Move mach/board.h contents to common.h
ARM: msm: Migrate msm_timer to CLOCKSOURCE_OF_DECLARE
ARM: msm: Remove TMR and TMR0 static mappings
This patch moves the pca953x.h header from include/linux/i2c to
"struct davinci_uart_config" was introduced to specify
UART ports brought out or enabled on the board. But
none of the boards use it for that purpose and we are
not going to add anymore board files, so remove the
structure.
Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com>
[nsekhar@ti.com: split patch to remove davinci_serial_setup_clk()
changes.]
This patch makes the platform data members as array wherever
possible, so as this makes easier while collecting the data
in DT case and read the entire array at once.
This patch also makes appropriate changes to board-da850-evm.c
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Prepare first set of updates for 3.11 merge window.
The vref field was not used by the driver and was removed from the
platform data structure.
Signed-off-by: Manish Badarkhe <badarkhe.manish@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/boards
From Sekhar Nori:
v3.10 board updates for DaVinci
This set of patches enables remoteproc support
on DA850 EVM and fixes some sparse warnings for
the same board.
* tag 'davinci-for-v3.10/board-2-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
ARM: davinci: da850 evm: fix const qualifier placement
ARM: davinci: da850 board: add remoteproc support
ARM: davinci: ensure global variables are declared
ARM: davinci: sram.c: fix incorrect type in assignment
ARM: davinci: da8xx dt: make file local symbols static
ARM: davinci: da8xx: add remoteproc support
ARM: davinci: remove test for undefined Kconfig macro
ARM: davinci: mmc: derive version information from device name
ARM: davinci: da850: add ECAP & EHRPWM clock nodes
ARM: davinci: clk framework support for enable/disable functionality
const qualifier was misplaced in couple of definitions.
This fixes the sparse error:
CHECK arch/arm/mach-davinci/board-mityomapl138.c
arch/arm/mach-davinci/board-da850-evm.c:404:19: error: Just how const do you want this type to be?
arch/arm/mach-davinci/board-da850-evm.c:568:19: error: Just how const do you want this type to be?
Add .reserve function for reserving CMA memory block to MACHINE_START.
Add call to remoteproc platform device registration function during init.
Signed-off-by: Robert Tivy <rtivy@ti.com>
Remove specifying mmc controller IP version information via platform
data, instead specify device name so that driver derives it from
platform_device_id table. Also change the clock node name to match
the changed dev_id.
Tested on da850-evm to make sure driver loads without clk_get failures.
Reviewed-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Chris Ball <cjb@laptop.org>
This patches replaces #if defined() by IS_ENABLED macro, which provides
better readability.
Cc: Randy Dunlap <rdunlap@infradead.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- Some cleanups at V4L2 documentation
- new drivers: ts2020 frontend, ov9650 sensor, s5c73m3 sensor,
sh-mobile veu mem2mem driver, radio-ma901, davinci_vpfe staging
driver
- Lots of missing MAINTAINERS entries added
- several em28xx driver improvements, including its conversion to
videobuf2
- several fixups on drivers to make them to better comply with the API
- DVB core: add support for DVBv5 stats, allowing the implementation of
statistics for new standards like ISDB
- mb86a20s: add statistics to the driver
- lots of new board additions, cleanups, and driver improvements.
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (596 commits)
[media] media: Add 0x3009 USB PID to ttusb2 driver (fixed diff)
[media] rtl28xxu: Add USB IDs for Compro VideoMate U620F
[media] em28xx: add usb id for terratec h5 rev. 3
[media] media: rc: gpio-ir-recv: add support for device tree parsing
[media] mceusb: move check earlier to make smatch happy
[media] radio-si470x doc: add info about v4l2-ctl and sox+alsa
[media] staging: media: Remove unnecessary OOM messages
[media] sh_vou: Use vou_dev instead of vou_file wherever possible
[media] sh_vou: Use video_drvdata()
[media] drivers/media/platform/soc_camera/pxa_camera.c: use devm_ functions
[media] mt9t112: mt9t111 format set up differs from mt9t112
[media] sh-mobile-ceu-camera: fix SHARPNESS control default
Revert "[media] fc0011: Return early, if the frequency is already tuned"
[media] cx18/ivtv: fix regression: remove __init from a non-init function
[media] em28xx: fix analog streaming with USB bulk transfers
[media] stv0900: remove unnecessary null pointer check
[media] fc0011: Add some sanity checks and cleanups
[media] fc0011: Fix xin value clamping
Revert "[media] [PATH,1/2] mxl5007 move reset to attach"
Pull ARM SoC board specific changes from Arnd Bergmann:
"These updates are all for board specific code, including
- defconfig updates for shmobile, davinci, bcm2835, imx, omap and
tegra
- SD/MMC and I2C support on bcm2835 (Raspberry PI)
- minor updates for PXA
- shmobile updates to GPIO usage in board files
- More things in OMAP board files are moved over to device tree
probing
- Better support for audio devices on some OMAP platforms"
* tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (55 commits)
ARM: imx_v4_v5_defconfig: Add VPU support
ARM: imx: configs: enable netfilter support
ARM: OMAP2+: Fix twl section warnings related to omap_twl4030_audio_init
ARM: OMAP2+: omap2plus_defconfig: enable omap1 rtc
RX-51: Register twl4030-madc device
RX-51: Add leds lp5523 names from Maemo 5 2.6.28 kernel
ARM: OMAP2+: AM33XX: omap2plus_defconfig: Add support for few drivers
ARM: OMAP1: nokia770: enable CBUS/Retu
ARM: OMAP2+: omap2plus_defconfig: enable CMA allocator
ARM: OMAP2+: omap2plus_defconfig: enable TFP410 chip support
ARM: OMAP3: igep0020: simplify GPIO LEDs dependencies
ARM: OMAP2+: craneboard: support the TPS65910 PMU
ARM: OMAP2+: craneboard: support NAND device
ARM: OMAP3: cm-t3517: add MMC support
ARM: OMAP2+: Remove apollon board support
ARM: shmobile: armadillo800eva: set clock rates before timer init
ARM: tegra: defconfig updates
ARM: shmobile: mackerel: Use gpio_request_one()
ARM: shmobile: kzm9g: Use gpio_request_one()
ARM: shmobile: bonito: Use gpio_request_one()
Without this patch the adv7343 encoder was being set to default
configuration which caused display not to work on this board.
This patch passes the necessary platform data required for adv7343
encoder to work on da850 evm.
Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com>
git://gitorious.org/linux-davinci/linux-davinci into next/soc
From Sekhar Nori:
DaVinci SoC changes for v3.9
This pull request:
1) Fixes a bug with the way SPI devices were registered on DA850
2) Adds support for DSP clock and resetting the DSP on DA850
3) Fixes checkpatch issue with some existing files.
* tag 'davinci-for-v3.9/soc' of git://gitorious.org/linux-davinci/linux-davinci:
ARM: davinci: da850: add dsp clock definition
ARM: davinci: psc: introduce reset API
ARM: davinci: psc.c: change pr_warning() to pr_warn()
ARM: davinci: devices-da8xx.c: change pr_warning() to pr_warn()
ARM: davinci: da8xx_register_spi() should not register SPI board info
Change all pr_warning() calls to pr_warn(), as advised by checkpatch.pl.
Also, while modifying those pr_warning() calls change hardcoded
function names to use '"%s:", __func__' instead, and converted acronym
usage to upper case.
Without this patch, da8xx_register_spi() registers the SPI board info,
the SPI controller, and sets its number of chipselect to the size of the
static spi_board_info array. This is bad because a SPI board info may
declare devices for different SPI buses, and because other code can also
call spi_register_board_info() (e.g. a daughter board might provide
additional SPI devices).
This patch removes the spi_register_board_info() call from
da8xx_register_spi(), renames this last one to da8xx_register_spi_bus()
to be more explicit, takes the number of chipselect as a function
parameter, and updates the impacted board-da8{3,5}0-evm.c, and
board-mityomapl138.c files accordingly. It also sets the SPI platform
data static, as it doesn't need to be exported.
[nsekhar@ti.com: fixed conflicts with v3.7-rc7, converted to use pr_warn(),
modified print messages to use __func__]
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
arch/arm/mach-davinci/board-da850-evm.c: In function 'da850_evm_init':
arch/arm/mach-davinci/board-da850-evm.c:1516:2: error: implicit declaration of function 'sram_get_gen_pool' [-Werror=implicit-function-declaration]
arch/arm/mach-davinci/board-da850-evm.c:1516:31: warning: assignment makes pointer from integer without a cast [enabled by default]
Cc: Kevin Hilman <khilman@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"This update contains a fairly wide range of changes all over in sound
subdirectory, mainly because of UAPI header moves by David and __dev*
annotation removals by Bill. Other highlights are:
- Introduced the support for wallclock timestamps in ALSA PCM core
- Add the poll loop implementation for HD-audio jack detection
- Yet more VGA-switcheroo fixes for HD-audio
- New VIA HD-audio codec support
- More fixes on resource management in USB audio and MIDI drivers
- More quirks for USB-audio ASUS Xonar U3, Reloop Play, Focusrite,
Roland VG-99, etc
- Add support for FastTrack C400 usb-audio
- Clean ups in many drivers regarding firmware loading
- Add PSC724 Ultiimate Edge support to ice1712
- A few hdspm driver updates
- New Stanton SCS.1d/1m FireWire driver
- Standardisation of the logging in ASoC codes
- DT and dmaengine support for ASoC Atmel
- Support for Wolfson ADSP cores
- New drivers for Freescale/iVeia P1022 and Maxim MAX98090
- Lots of other ASoC driver fixes and developments"
Fix up trivial conflicts. And go out on a limb and assume the dts file
'status' field of one of the conflicting things was supposed to be
"disabled", not "disable" like in pretty much all other cases.
* tag 'sound-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (341 commits)
ALSA: hda - Move runtime PM check to runtime_idle callback
ALSA: hda - Add stereo-dmic fixup for Acer Aspire One 522
ALSA: hda - Avoid doubly suspend after vga switcheroo
ALSA: usb-audio: Enable S/PDIF on the ASUS Xonar U3
ALSA: hda - Check validity of CORB/RIRB WP reads
ALSA: hda - use usleep_range in link reset and change timeout check
ALSA: HDA: VIA: Add support for codec VT1808.
ALSA: HDA: VIA Add support for codec VT1705CF.
ASoC: codecs: remove __dev* attributes
ASoC: utils: remove __dev* attributes
ASoC: ux500: remove __dev* attributes
ASoC: txx9: remove __dev* attributes
ASoC: tegra: remove __dev* attributes
ASoC: spear: remove __dev* attributes
ASoC: sh: remove __dev* attributes
ASoC: s6000: remove __dev* attributes
ASoC: OMAP: remove __dev* attributes
ASoC: nuc900: remove __dev* attributes
ASoC: mxs: remove __dev* attributes
ASoC: kirkwood: remove __dev* attributes
