Some header files are never included outside of a mach-davinci
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
Acked-by: Sekhar Nori <nsekhar@ti.com>
The cpu_do_idle() function is always used by the cpuidle drivers.
That led to have each driver including cpuidle.h and proc-fns.h, they are
always paired. That makes a lot of duplicate headers inclusion. Instead of
including both in each .c file, move the proc-fns.h header inclusion in the
cpuidle.h header file directly, so we can save some line of code.
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Kevin Hilman <khilman@linaro.org>
Acked-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
The only place where the time is invalid is when the ACPI_CSTATE_FFH entry
method is not set. Otherwise for all the drivers, the time can be correctly
measured.
Instead of duplicating the CPUIDLE_FLAG_TIME_VALID flag in all the drivers
for all the states, just invert the logic by replacing it by the flag
CPUIDLE_FLAG_TIME_INVALID, hence we can set this flag only for the acpi idle
driver, remove the former flag from all the drivers and invert the logic with
this flag in the different governor.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The commit 19976c2a88d125aec16b9255c7197c297bbdd637 changed the target
residency to 100000, assuming this is a careless mistake.
The same happened to the at91's cpuidle driver.
Fix it by putting the initial value to 10000.
Remove the duplicated code and use the cpuidle common code for initialization.
The en_core_tk_irqen flag is set in all the cpuidle driver which
means it is not necessary to specify this flag.
Remove the flag and the code related to it.
Acked-by: Kevin Hilman <khilman@linaro.org> # for mach-omap2/*
The davinci_enter_idle is called from the cpuidle with the
cpuidle_wrap_enter function. This one does the time compution
for entering and exiting the idle function and then we call
again cpuidle_wrap_enter for cpu_do_idle. This is wrong, we
are calling recursively cpuidle_wrap_enter for nothing and
furthermore reenabling the local irq.
Remove this and replace it by the cpu_do_idle function.
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
The device->state_count is initialized in the cpuidle_register_device
function.
Signed-off-by: Len Brown <len.brown@intel.com>
With one function handling the idle state and a single variable,
the usage of the davinci_ops is overkill.
This patch removes these ops and simplify the code.
Furthermore, the 'driver_data' field is no longer used, we have
1 of the 3 remaining user of this field removed.
The patch is mindless, it just moves the idle function below in the file
in order to prevent forward declaration in the next patch.
That will allow to cleanup the rest of the code right after,
because the ops won't make sense.
The recent cpuidle consolidation changes erroneously omitted one
critical line of code.
Signed-off-by: Robert Lee <rob.lee@linaro.org>
Tested-by: Sekhar Nori <nsekhar@ti.com>
Enable core cpuidle timekeeping and irq enabling and remove that
handling from this code.
Reviewed-by: Kevin Hilman <khilman@ti.com>
Reviewed-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Acked-by: Jean Pihet <j-pihet@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux:
cpuidle: Single/Global registration of idle states
cpuidle: Split cpuidle_state structure and move per-cpu statistics fields
cpuidle: Remove CPUIDLE_FLAG_IGNORE and dev->prepare()
cpuidle: Move dev->last_residency update to driver enter routine; remove dev->last_state
ACPI: Fix CONFIG_ACPI_DOCK=n compiler warning
ACPI: Export FADT pm_profile integer value to userspace
thermal: Prevent polling from happening during system suspend
ACPI: Drop ACPI_NO_HARDWARE_INIT
ACPI atomicio: Convert width in bits to bytes in __acpi_ioremap_fast()
PNPACPI: Simplify disabled resource registration
ACPI: Fix possible recursive locking in hwregs.c
ACPI: use kstrdup()
mrst pmu: update comment
tools/power turbostat: less verbose debugging
This patch makes the cpuidle_states structure global (single copy)
instead of per-cpu. The statistics needed on per-cpu basis
by the governor are kept per-cpu. This simplifies the cpuidle
subsystem as state registration is done by single cpu only.
Having single copy of cpuidle_states saves memory. Rare case
of asymmetric C-states can be handled within the cpuidle driver
and architectures such as POWER do not have asymmetric C-states.
Having single/global registration of all the idle states,
dynamic C-state transitions on x86 are handled by
the boot cpu. Here, the boot cpu would disable all the devices,
re-populate the states and later enable all the devices,
irrespective of the cpu that would receive the notification first.
Reference:
https://lkml.org/lkml/2011/4/25/83
Signed-off-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
Signed-off-by: Trinabh Gupta <g.trinabh@gmail.com>
Tested-by: Jean Pihet <j-pihet@ti.com>
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Kevin Hilman <khilman@ti.com>
This is the first step towards global registration of cpuidle
states. The statistics used primarily by the governor are per-cpu
and have to be split from rest of the fields inside cpuidle_state,
which would be made global i.e. single copy. The driver_data field
is also per-cpu and moved.
dev->last_state
Cpuidle governor only suggests the state to enter using the
governor->select() interface, but allows the low level driver to
override the recommended state. The actual entered state
may be different because of software or hardware demotion. Software
demotion is done by the back-end cpuidle driver and can be accounted
correctly. Current cpuidle code uses last_state field to capture the
actual state entered and based on that updates the statistics for the
state entered.
Ideally the driver enter routine should update the counters,
and it should return the state actually entered rather than the time
spent there. The generic cpuidle code should simply handle where
the counters live in the sysfs namespace, not updating the counters.
Reference:
https://lkml.org/lkml/2011/3/25/52
These files all make use of one of the EXPORT_SYMBOL variants
or the THIS_MODULE macro. So they will need <linux/export.h>
Move some DDR2 related defines into a private <mach/ddr2.h> beforehand.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
When suspend is supported, both cpuidle and suspend code
need to work on DDR2 registers. Instead of mapping the
DDR2 registers twice, do it once outside of cpuidle
driver and let cpuidle driver get the virtual base address
of DDR2 registers.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
Move defintions of DDR2 controller registers to memory.h
from cpuidle.c. The motivation behind the change is to be
able to use these defintions in assembly code that puts
DDR2 in self-refresh and enables the SoC to enter suspend
state.
The patch adds support for DaVinci cpu idle driver.
Two idle states are defined:
1. Wait for interrupt
2. Wait for interrupt and DDR self-refresh (or power down)
Some DaVinci SoCs support putting DDR in self-refresh (eg Dm644x, DM6467)
while others support putting DDR in self-refresh and power down (eg DM35x,
DA8xx).
Putting DDR (or mDDR) in power down saves more power than self-refresh.
The patch has been tested on DA850/OMAP-L138 EVM.
