The CPPI 4.1 DMA in USB subsystem shares its clock with the
USB OTG, and most of the time, the clock will be enabled by
USB. But during the init of the DMA, USB is not enabled
(waiting for DMA), and then we must enable the DMA clock
before doing anything.
Add clock for the CPPI 4.1 DMA engine.
Signed-off-by: Alexandre Bailon <abailon@baylibre.com>
[nsekhar@ti.com: minor commit message tweaks]
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Pull ARM SoC platform updates from Arnd Bergmann:
"In the SoC branch we normally collect classic arch/arm/mach-*
contents, i.e. C code changes for SoC platforms. This release cycle
the diffstat is quite nice, in that we're removing 3x the amount of
code that's being added.
The main reason for this is that there's a removal of camera drivers
for Freescale i.MX chips (driver was removed so the device
registration isn't needed any more). There's also removal of display
initialization code for OMAP that is no longer needed.
The rest are mostly minor tweaks and cleanups; constification on
Samsung platforms, cleanup of ux500 platform data, purge of other
unused platform data/device seutp on i.MX and other good stuff.
New SoC support this cycle is for two Allwinner platforms, H2+ and
V3s"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (55 commits)
ARM: ux500: remove deleted file from Makefile
ARM: ep93xx: Disable TS-72xx watchdog before uncompressing
ARM: ux500: cut some platform data
MAINTAINERS: Update for the current location of the bcm2835 tree.
ARM: davinci: remove BUG_ON() from da850_register_sata()
ARM: davinci: da850: model the SATA refclk
ARM: davinci: da850: add con_id for the SATA clock
ARM: davinci: da8xx-dt: add OF_DEV_AUXDATA entry for SATA
arm: mvebu: support for SMP on 98DX3336 SoC
dt-bindings: video: exynos7-decon: Remove obsolete samsung,power-domain property
soc: dove: constify reset_control_ops structures
ARM: mv78xx0: fix possible PCI buffer overflow
MAINTAINERS: transfer maintainership for the EZX platform
ARM: shmobile: rcar-gen2: Add more register documentation
ARM: tegra: paz00: Fix __initdata placement
ARM: OMAP: clock: Remove unused mpurate cmdline option
ARM: davinci: add skeleton for pdata-quirks
arm: sunxi: add support for V3s SoC
ARM: OMAP2+: omap_hwmod: Add support for earlycon
arm: hisi: drop extern hip01_cpu_die
Pull ARM SoC non-urgent fixes from Arnd Bergmann:
"We sometimes collect non-critical fixes that come in during the later
part of the merge window in a branch for the next release instead, and
this is that contents for v4.11.
Most of these are OMAP fixes, dealing with OMAP36/37 detection, quirks
and setup. There's also some fixes for Davinci and a Kconfig fix for
SCPI to only enable on ARM{,64}"
* tag 'armsoc-fixes-nc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
firmware: arm_scpi: Add hardware dependencies
ARM: OMAP3: Fix SoC detection of OMAP36/37 Family
ARM: OMAP5: Add HWMOD_SWSUP_SIDLE_ACT flag for UART
ARM: dts: Fix compatible for ti81xx uarts for 8250
ARM: dts: Fix am335x and dm814x scm syscon to probe children
ARM: OMAP2+: Fix init for multiple quirks for the same SoC
ARM: dts: Fix omap3 off mode pull defines
bus: da850-mstpri: fix my e-mail address
ARM: davinci: da850: fix da850_set_pll0rate()
ARM: davinci: da850: coding style fix
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/soc
Pull "SoC updates needed for SATA support on DA850" from Sekhar Nori:
This includes a merge of non-critical-fixes
branch already queued for v4.11 because
SATA clock addition conflicts with the fix-up
done earlier.
* tag 'davinci-for-v4.11/soc-2' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
The ahci-da850 SATA driver is now capable of retrieving clocks by
con_id. Add the connection id for the sysclk2-derived SATA clock.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
The aemif driver can now access struct of_dev_auxdata (using platform
data).
Add the device id to the clock lookup table for the nand clock and
create a separate lookup table for aemif subnodes.
This function is confusing - its second argument is an index to the
freq table, not the requested clock rate in Hz, but it's used as the
set_rate callback for the pll0 clock. It leads to an oops when the
caller doesn't know the internals and passes the rate in Hz as
argument instead of the cpufreq index since this argument isn't bounds
checked either.
Fix it by iterating over the array of supported frequencies and
selecting a one that matches or returning -EINVAL for unsupported
rates.
Also: update the davinci cpufreq driver. It's the only user of this
clock and currently it passes the cpufreq table index to
clk_set_rate(), which is confusing. Make it pass the requested clock
rate in Hz.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
[nsekhar@ti.com: commit headline update]
Fix alignment of the clock lookup table entries.
Similarly to the aemif clock - this screws up the linked list of clock
children. Create a separate clock for mdio inheriting the rate from
emac_clk.
Cc: <stable@vger.kernel.org> # 3.12.x-
[nsekhar@ti.com: add a comment over mdio_clk to explaing its existence +
commit headline updates]
The aemif clock is added twice to the lookup table in da850.c. This
breaks the children list of pll0_sysclk3 as we're using the same list
links in struct clk. When calling clk_set_rate(), we get stuck in
propagate_rate().
Create a separate clock for nand, inheriting the rate of the aemif
clock and retrieve it in the davinci_nand module.
Cc: <stable@vger.kernel.org> # 4.9.x
"These are updates for platform specific code on 32-bit ARM machines,
essentially anything that can not (yet) be expressed using DT files.
Noteworthy changes include:
- Added support for the TI DRA71x family of SoCs in mach-omap2, this
is an new variant of the the DRA72x/DRA74x automotive infotainment
chips we already supported for a while.
- Added support for the ST STM32F746 SoC, the first Cortex-M7 based
microcontroller we support, related to the smaller STM32F4 family.
- Renesas adds support for r8a7743 and r8a7745 in mach-shmobile, see
http://elinux.org/RZ-G
- SMP is now supported on the OX820 platform
- A lot of code in mach-omap2 gets removed as a follow-up to removing
support for board files in the previous release
- Davinci has some new work to improve USB support
- For i.MX, the performance monitor now supports profiling the memory
controller using 'perf'"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (95 commits)
ARM: davinci: da830-evm: use gpio descriptor for mmc pins
ARM: davinci: da850-evm: use gpio descriptor for mmc pins
ARM: davinci: hawk: use gpio descriptor for mmc pins
ARM: ARTPEC-6: add select MFD_SYSCON to MACH_ARTPEC6
ARM: davinci: da8xx: Fix ohci device name
ARM: oxnas: Add OX820 config and makefile entry
ARM: oxnas: Add OX820 SMP support
ARM: davinci: PM: fix build when da850 not compiled in
ARM: orion5x: remove legacy support of ls-chl
ARM: integrator: drop EBI access use syscon
ARM: BCM5301X: Add back handler ignoring external imprecise aborts
ARM: davinci: PM: support da8xx DT platforms
ARM: davinci: PM: cleanup: remove references to pdata
ARM: davinci: PM: rework init, remove platform device
ARM: Kconfig: Introduce MACH_STM32F746 flag
ARM: mach-stm32: Add a new SOC - STM32F746
ARM: shmobile: document SK-RZG1E board
ARM: shmobile: r8a7745: basic SoC support
ARM: imx: mach-imx6ul: add imx6ull support
ARM: zynq: Reserve correct amount of non-DMA RAM
Pull "DaVinci SoC updates for v4.10 (part 3)" from Sekhar Nori:
mach-davinci SoC support updates to adjust
USB ohci device name to that used by drivers
and update of various board files to use gpio
descriptor API used by MMC subsystem for card
detect and write-protect detection.
* tag 'davinci-for-v4.10/soc-3' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
Pull DaVinci cleanup for v4.10 from Sekhar Nori:
mach-davinci cleanup to make it easy to add PM support
for DT-boot.
* tag 'davinci-for-v4.10/cleanup-2' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
While the clk lookup table is making reference to "ohci"
other subsystems (such as phy) are trying to match "ohci.0"
Since there is a single ohci instance, instead of changing
the clk name, change the dev id to -1, and add the "-da8xx"
postfix to match the driver name that will also be changed
in a subsequent patch.
Signed-off-by: Axel Haslam <ahaslam@baylibre.com>
Remove fake platform device used for PM init. Move pdata values which
are common across all current platforms into pm.c.
Also, since PM is only used on da8xx, remove davinci_pm_init() from
common init code, and only use in da850/omapl138 board files that are
currently creating the fake platform_device.
Suggested-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
[nsekhar@ti.com: subject line adjustment]
This fixes pwm name matching for DA850 familiy devices. When using device
tree, the da850_auxdata_lookup[] table caused pwm devices to have the exact
same name, which caused errors when trying to register the devices.
We cannot have multiple entries for the same clock in in da850_clks[], so
we have added child clocks to the EHRPWM and ECAP LPSC clocks so that each
PWM device will have its own clock for proper name matching.
Signed-off-by: David Lechner <david@lechnology.com>
This adds device names for the SoC USB devices to the clock lookup tables
in da830.c and da850.c.
Also add the USB device names to the da850_auxdata_lookup[] table.
The davinci boards don't have their clocks in DT yet and getting a clock
will fail, unless registering them as clk_lookups. This registers the
aemif clock for the ti-aemif memory driver.
The current aemif lookup entry resolving to the same clock:
'CLK(NULL, "aemif", &aemif_clk)'
is currently used by davinci_nand and remains for non-DT and backward
compatibility.
Currently the davinci boards only configure the AEMIF in case of non-DT
boot, via some code in mach-davinci.
This change will allow DT-based davinci platforms to do the same, via
the ti-aemif memory driver code.
Signed-off-by: Karl Beldan <kbeldan@baylibre.com>
[nsekhar@ti.com: reworded commit message]
Add clock definitions "davinci-mcbsp.0" and "davinci-mcbsp.1" in order
to make McBSP driver work on the DA850 platform.
The McBSP 0 and 1 interfaces were not defined for the DA850 platform.
Neither were the related clocks. In order to make the use of McBSP via
devicetree the clocks need to be defined.
Signed-off-by: Petr Kulhavy <petr@barix.com>
The da850 family of processors has an async3 clock domain that can be
muxed to either pll0_sysclk2 or pll1_sysclk2. Now that the davinci clocks
have a set_parent callback, we can use this to control the async3 mux
instead of a stand-alone function.
This adds a new async3_clk and sets the appropriate child clocks. The
default is use to pll1_sysclk2 since it is not affected by processor
frequency scaling.
[nsekhar@ti.com: drop unnecessary comment]
Some clocks (such as the USB PHY clocks in DA8xx) will need to use iomem.
The davinci_common_init() function must be called before the ioremap, so
the clock init is now split out as separate function.
Some header files are never included outside of a mach-davinci
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
Acked-by: Sekhar Nori <nsekhar@ti.com>
Init data marked const should be annotated with __initconst for
correctness and not __initdata. In some cases the array gathering
references to that data has to be marked const as well. This fixes
LTO builds that otherwise fail with section mismatch errors.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
clk_add_alias() is provided by clkdev, and is not part of the clk API.
Howver, it is prototyped in two locations: linux/clkdev.h and
linux/clk.h. This is a mess. Get rid of the redundant and unnecessary
version in linux/clk.h.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
The cpufreq core now supports the cpufreq_for_each_entry macro helper
for iteration over the cpufreq_frequency_table, so use it.
It should have no functional changes.
Signed-off-by: Stratos Karafotis <stratosk@semaphore.gr>
Acked-and-tested-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Update SATA AHCI support to make use of the new ahci_da850 host
driver (instead of the generic ahci_platform one) and remove
deprecated ahci_platform_data code.
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/drivers
From Sekhar Nori:
This patch updates the davinci watchdog
platform device name from generic "watchdog"
to something more specific.
* tag 'davinci-for-v3.14/watchdog' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
watchdog: davinci: rename platform driver to davinci-wdt
Signed-off-by: Kevin Hilman <khilman@linaro.org>
As we switch to use the watchdog core which permits more than one
active watchdog in the system, rename platform driver to
"davinci-wdt" to be identifiable.
Acked-by: Wim Van Sebroeck <wim@iguana.be>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
As the davinci-gpio driver is migrated to use irqdomain
there is no need to pass the irq base for the gpio driver.
This patch removes this variable from davinci_gpio_platform_data
and also the refrences from the machine file.
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
DaVinci GPIO driver now uses platform device model.
Convert DA8XX SoC code to use the new model.
Add da8xx_register_gpio() to create platform device for da8xx
platforms.
Signed-off-by: KV Sujith <sujithkv@ti.com>
Signed-off-by: Philip Avinash <avinashphilip@ti.com>
[nsekhar@ti.com: simplify commit message]
This patch removes the clock alias for mdio device and adds a entry
in clock lookup table, this entry can now be used by both DT and
non-DT case.
Get rid of davinci_serial_setup_clk() since its not called
from multiple places now. Instead initialize clock in
davinci_serial_init() itself. This also helps get rid of
"serial_dev" member of struct davinci_soc_info.
Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com>
[nsekhar@ti.com: split removal of davinci_serial_setup_clk()
into a separate patch.]
For modules having single clock, clk_get should be done with dev_id.
But current davinci implementation handles multiple instances
of the UART devices with single platform_device_register. Hence clk_get
is based on con_id rather than dev_id, this is not correct. Do
platform_device_register for each instance and clk_get on dev_id.
[nsekhar@ti.com: actually stop using con_id in clk_get(), squash the
patch adding OF aux data into this one]
The "index" field of struct cpufreq_frequency_table was never an
index and isn't used at all by the cpufreq core. It only is useful
for cpufreq drivers for their internal purposes.
Many people nowadays blindly set it in ascending order with the
assumption that the core will use it, which is a mistake.
Rename it to "driver_data" as that's what its purpose is. All of its
users are updated accordingly.
[rjw: Changelog]
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Remove specifying mmc controller IP version information via platform
data, instead specify device name so that driver derives it from
platform_device_id table. Also change the clock node name to match
the changed dev_id.
Tested on da850-evm to make sure driver loads without clk_get failures.
Reviewed-by: Sekhar Nori <nsekhar@ti.com>
Acked-by: Chris Ball <cjb@laptop.org>
Add ECAP and EHRPWM module clock nodes. Also add a clock
node for TBCLK for EHRWPM.
Added dsp clock definition, keyed to "davinci-rproc.0".
DSP clocks is derived from pll0 sysclk1. Add a clock tree
node for that too.
Signed-off-by: Robert Tivy <rtivy@ti.com>
[nsekhar@ti.com: merge addition of pll0 sysclk1 and dsp clock
into one commit. Add PSC_FORCE to dsp clock node to handle the
case where DSP does not go into IDLE and its clock needs to
be disabled.]
Pull fbdev changes from Tomi Valkeinen:
"OMAPDSS changes, including:
- use dynanic debug prints
- OMAP platform dependency removals
- Creation of compat-layer, helping us to improve omapdrm
- Misc cleanups, aiming to make omadss more in line with the upcoming
common display framework
Exynos DP changes for the 3.8 merge window:
- Device Tree support for Samsung Exynos DP
- SW Link training is cleaned up.
- HPD interrupt is supported.
Samsung Framebuffer changes for the 3.8 merge window:
- The bit definitions of header file are updated.
- Some minor typos are fixed.
- Some minor bugs of s3c_fb_check_var() are fixed.
FB related changes for SH Mobile, Freescale DIU
Add support for the Solomon SSD1307 OLED Controller"
* tag 'fbdev-for-3.8' of git://gitorious.org/linux-omap-dss2/linux: (191 commits)
OMAPDSS: fix TV-out issue with DSI PLL
Revert "OMAPFB: simplify locking"
OMAPFB: remove silly loop in fb2display()
OMAPFB: fix error handling in omapfb_find_best_mode()
OMAPFB: use devm_kzalloc to allocate omapfb2_device
OMAPDSS: DISPC: remove dispc fck uses
OMAPDSS: DISPC: get dss clock rate from dss driver
drivers/video/console/softcursor.c: remove redundant NULL check before kfree()
drivers/video: add support for the Solomon SSD1307 OLED Controller
OMAPDSS: use omapdss_compat_init() in other drivers
OMAPDSS: export dispc functions
OMAPDSS: export dss_feat functions
OMAPDSS: export dss_mgr_ops functions
OMAPDSS: separate compat files in the Makefile
OMAPDSS: move display sysfs init to compat layer
OMAPDSS: DPI: use dispc's check_timings
OMAPDSS: DISPC: add dispc_ovl_check()
OMAPDSS: move irq handling to dispc-compat
OMAPDSS: move omap_dispc_wait_for_irq_interruptible_timeout to dispc-compat.c
OMAPDSS: move blocking mgr enable/disable to compat layer
arch/arm/mach-davinci/devices-da8xx.c
arch/arm/plat-omap/common.c
drivers/media/platform/omap/omap_vout.c
do clk_get on connection id "fck" to support OMAP based
platforms having multiple clocks for module. Without this
driver change clk_get fails on am335x.
This patch is based on the discussion in community
http://marc.info/?l=linux-kernel&m=135166018907827&w=2
Signed-off-by: Manjunathappa <prakash.pm@ti.com>
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Adds PRUSS clock support and registration helper for the
uio_pruss device.
Signed-off-by: Matt Porter <mporter@ti.com>
This patch modifies the sram allocator to allocate memory
from the DA8XX shared RAM.
Regression tested suspend/resume on AM180x EVM.
Signed-off-by: Subhasish Ghosh <subhasish@mistralsolutions.com>
[rebased onto consolidated SRAM patches]
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
[rebased to mainline as consolidated SRAM patches were dropped]
The current davinci init sets up SRAM in iotables. There has been
an observed failure to boot a da850 with 128K specified in the
iotable.
Make the davinci sram allocator do an ioremap of the region
specified by the entries in davinci_soc_info before registering
with gen_pool_add_virt(). Remove all iotable SRAM mappings and
SRAM_VIRT.
Applied on the top of changeset 782cd9e, as some of those patches
depend on some fixes that went via -arm tree.
* staging/for_v3.7: (109 commits)
[media] m5mols: Add missing #include <linux/sizes.h>
[media] stk1160: Add support for S-Video input
Revert "[media] omap3isp: Replace cpu_is_omap3630() with ISP revision check"
[media] dvb: LNA implementation changes
[media] v4l2-ioctl: fix W=1 warnings
[media] v4l2-ioctl: add blocks check for VIDIOC_SUBDEV_G/S_EDID
[media] omap3isp: Fix compilation error in ispreg.h
[media] rc-msi-digivox-ii: Add full scan keycodes
[media] cx25821: testing the wrong variable
[media] tda18271-common: hold the I2C adapter during write transfers
[media] ds3000: add module parameter to force firmware upload
[media] drivers/media: Remove unnecessary semicolon
[media] winbond: remove space from driver name
[media] iguanair: cannot send data from the stack
[media] dvb-usb: print small buffers via %*ph
[media] uvc: Add return code check at vb2_queue_init()
[media] em28xx: Replace memcpy with struct assignment
[media] bt8xx: Add video4linux control V4L2_CID_COLOR_KILLER
[media] mem2mem_testdev: Use devm_kzalloc() in probe
This is a series from Arnd that fixes a number of compiler warnings
when building defconfigs on ARM.
* late/fixes:
ARM: footbridge: nw_gpio_lock is raw_spin_lock
ARM: mv78xx0: correct addr_map_cfg __initdata annotation
ARM: footbridge: remove RTC_IRQ definition
ARM: soc: dependency warnings for errata
ARM: ks8695: __arch_virt_to_dma type handling
ARM: rpc: check device_register return code in ecard_probe
ARM: davinci: don't mark da850_register_cpufreq as __init
ARM: iop13xx: fix iq81340sc_atux_map_irq prototype
ARM: iop13xx: mark iop13xx_scan_bus as __devinit
ARM: mv78xx0: mark mv78xx0_timer_init as __init_refok
ARM: s3c24xx: fix multiple section mismatch warnings
ARM: at91: unused variable in at91_pm_verify_clocks
ARM: at91: skip at91_io_desc definition for NOMMU
ARM: pxa: work around duplicate definition of GPIO24_SSP1_SFRM
ARM: pxa: remove sharpsl_fatal_check function
ARM: pxa: define palmte2_pxa_keys conditionally
ARM: pxa: Wunused-result warning in viper board file
ARM: shark: fix shark_pci_init return code
Fixed trivial conflicts in arch/arm/mach-at91/setup.c.
The mityomapl138_cpufreq_init and read_factory_config function in
board-mityomapl138.c are not __init functions and might be called
at a later stage, so da850_register_cpufreq must not be __init either.
Without this patch, building da8xx_omapl_defconfig results in:
WARNING: arch/arm/mach-davinci/built-in.o(.text+0x2eb4): Section mismatch in reference from the function read_factory_config() to the function .init.text:da850_register_cpufreq()
The function read_factory_config() references
the function __init da850_register_cpufreq().
This is often because read_factory_config lacks a __init
annotation or the annotation of da850_register_cpufreq is wrong.
Cc: Kevin Hilman <khilman@ti.com>
Add clock, pin mux definitions and registration function for
VPIF capture and display driver on DA850/OMAP-L138 SoC.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com>
All callers (board-mityomapl138.c and board-da850-evm.c) use it in
__init functions only.
This fixes:
WARNING: vmlinux.o(.text+0xd664): Section mismatch in reference from the function da850_register_pm() to the function .init.text:da8xx_get_mem_ctlr()
The function da850_register_pm() references
the function __init da8xx_get_mem_ctlr().
This is often because da850_register_pm lacks a __init
annotation or the annotation of da8xx_get_mem_ctlr is wrong.
DA850: sysclk4-7 only exist for pll0. for pll1 sysclk1-3 exist.
Remove the non-existing clocks.
Signed-off-by: Bas van den Berg <b.van.den.berg.nl@gmail.com>
Rather than using DaVinci specific davinci_soc_info based
restart hook, use the restart hook available in the machine
descriptor instead.
Tested on DM365 and AM18x EVMs.
v2:
Changed to use restart hook in machine descriptor
per Russell's comment.
