We now have a proper clocksource driver for davinci. Switch the da850
platform to using it.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Reviewed-by: David Lechner <david@lechnology.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Currently the timer code checks if the clock pointer passed to it is
good (!IS_ERR(clk)). The new clocksource driver expects the clock to
be functional and doesn't perform any checks so emit a warning if
clk_get() fails. Apply this to all davinci platforms.
Now that we've gotten rid of clk_readl() we can remove io.h from the
clk-provider header and push out the io.h include to any code that isn't
already including the io.h header but using things like readl/writel,
etc.
Found with this grep:
git grep -l clk-provider.h | grep '.c$' | xargs git grep -L 'linux/io.h' | \
xargs git grep -l \
-e '\<__iowrite32_copy\>' --or \
-e '\<__ioread32_copy\>' --or \
-e '\<__iowrite64_copy\>' --or \
-e '\<ioremap_page_range\>' --or \
-e '\<ioremap_huge_init\>' --or \
-e '\<arch_ioremap_pud_supported\>' --or \
-e '\<arch_ioremap_pmd_supported\>' --or \
-e '\<devm_ioport_map\>' --or \
-e '\<devm_ioport_unmap\>' --or \
-e '\<IOMEM_ERR_PTR\>' --or \
-e '\<devm_ioremap\>' --or \
-e '\<devm_ioremap_nocache\>' --or \
-e '\<devm_ioremap_wc\>' --or \
-e '\<devm_iounmap\>' --or \
-e '\<devm_ioremap_release\>' --or \
-e '\<devm_memremap\>' --or \
-e '\<devm_memunmap\>' --or \
-e '\<__devm_memremap_pages\>' --or \
-e '\<pci_remap_cfgspace\>' --or \
-e '\<arch_has_dev_port\>' --or \
-e '\<arch_phys_wc_add\>' --or \
-e '\<arch_phys_wc_del\>' --or \
-e '\<memremap\>' --or \
-e '\<memunmap\>' --or \
-e '\<arch_io_reserve_memtype_wc\>' --or \
-e '\<arch_io_free_memtype_wc\>' --or \
-e '\<__io_aw\>' --or \
-e '\<__io_pbw\>' --or \
-e '\<__io_paw\>' --or \
-e '\<__io_pbr\>' --or \
-e '\<__io_par\>' --or \
-e '\<__raw_readb\>' --or \
-e '\<__raw_readw\>' --or \
-e '\<__raw_readl\>' --or \
-e '\<__raw_readq\>' --or \
-e '\<__raw_writeb\>' --or \
-e '\<__raw_writew\>' --or \
-e '\<__raw_writel\>' --or \
-e '\<__raw_writeq\>' --or \
-e '\<readb\>' --or \
-e '\<readw\>' --or \
-e '\<readl\>' --or \
-e '\<readq\>' --or \
-e '\<writeb\>' --or \
-e '\<writew\>' --or \
-e '\<writel\>' --or \
-e '\<writeq\>' --or \
-e '\<readb_relaxed\>' --or \
-e '\<readw_relaxed\>' --or \
-e '\<readl_relaxed\>' --or \
-e '\<readq_relaxed\>' --or \
-e '\<writeb_relaxed\>' --or \
-e '\<writew_relaxed\>' --or \
-e '\<writel_relaxed\>' --or \
-e '\<writeq_relaxed\>' --or \
-e '\<readsb\>' --or \
-e '\<readsw\>' --or \
-e '\<readsl\>' --or \
-e '\<readsq\>' --or \
-e '\<writesb\>' --or \
-e '\<writesw\>' --or \
-e '\<writesl\>' --or \
-e '\<writesq\>' --or \
-e '\<inb\>' --or \
-e '\<inw\>' --or \
-e '\<inl\>' --or \
-e '\<outb\>' --or \
-e '\<outw\>' --or \
-e '\<outl\>' --or \
-e '\<inb_p\>' --or \
-e '\<inw_p\>' --or \
-e '\<inl_p\>' --or \
-e '\<outb_p\>' --or \
-e '\<outw_p\>' --or \
-e '\<outl_p\>' --or \
-e '\<insb\>' --or \
-e '\<insw\>' --or \
-e '\<insl\>' --or \
-e '\<outsb\>' --or \
-e '\<outsw\>' --or \
-e '\<outsl\>' --or \
-e '\<insb_p\>' --or \
-e '\<insw_p\>' --or \
-e '\<insl_p\>' --or \
-e '\<outsb_p\>' --or \
-e '\<outsw_p\>' --or \
-e '\<outsl_p\>' --or \
-e '\<ioread8\>' --or \
-e '\<ioread16\>' --or \
-e '\<ioread32\>' --or \
-e '\<ioread64\>' --or \
-e '\<iowrite8\>' --or \
-e '\<iowrite16\>' --or \
-e '\<iowrite32\>' --or \
-e '\<iowrite64\>' --or \
-e '\<ioread16be\>' --or \
-e '\<ioread32be\>' --or \
-e '\<ioread64be\>' --or \
-e '\<iowrite16be\>' --or \
-e '\<iowrite32be\>' --or \
-e '\<iowrite64be\>' --or \
-e '\<ioread8_rep\>' --or \
-e '\<ioread16_rep\>' --or \
-e '\<ioread32_rep\>' --or \
-e '\<ioread64_rep\>' --or \
-e '\<iowrite8_rep\>' --or \
-e '\<iowrite16_rep\>' --or \
-e '\<iowrite32_rep\>' --or \
-e '\<iowrite64_rep\>' --or \
-e '\<__io_virt\>' --or \
-e '\<pci_iounmap\>' --or \
-e '\<virt_to_phys\>' --or \
-e '\<phys_to_virt\>' --or \
-e '\<ioremap_uc\>' --or \
-e '\<ioremap\>' --or \
-e '\<__ioremap\>' --or \
-e '\<iounmap\>' --or \
-e '\<ioremap_nocache\>' --or \
-e '\<ioremap_wc\>' --or \
-e '\<ioremap_wt\>' --or \
-e '\<ioport_map\>' --or \
-e '\<ioport_unmap\>' --or \
-e '\<xlate_dev_kmem_ptr\>' --or \
-e '\<xlate_dev_mem_ptr\>' --or \
-e '\<unxlate_dev_mem_ptr\>' --or \
-e '\<virt_to_bus\>' --or \
-e '\<bus_to_virt\>' --or \
-e '\<memset_io\>' --or \
-e '\<memcpy_fromio\>' --or \
-e '\<memcpy_toio\>'
I also reordered a couple includes when they weren't alphabetical and
removed clk.h from kona, replacing it with clk-provider.h because
that driver doesn't use clk consumer APIs.
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: Chen-Yu Tsai <wens@csie.org>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Acked-by: Tero Kristo <t-kristo@ti.com>
Acked-by: Sekhar Nori <nsekhar@ti.com>
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Mark Brown <broonie@kernel.org>
Cc: Chris Zankel <chris@zankel.net>
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Acked-by: John Crispin <john@phrozen.org>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
Pull power management updates from Rafael Wysocki:
"These are PM-runtime framework changes to use ktime instead of jiffies
for accounting, new PM core flag to mark devices that don't need any
form of power management, cpuidle updates including driver API
documentation and a new governor, cpufreq updates including a new
driver for Armada 8K, thermal cleanups and more, some energy-aware
scheduling (EAS) enabling changes, new chips support in the intel_idle
and RAPL drivers and assorted cleanups in some other places.
Specifics:
- Update the PM-runtime framework to use ktime instead of jiffies for
accounting (Thara Gopinath, Vincent Guittot)
- Optimize the autosuspend code in the PM-runtime framework somewhat
(Ladislav Michl)
- Add a PM core flag to mark devices that don't need any form of
power management (Sudeep Holla)
- Introduce driver API documentation for cpuidle and add a new
cpuidle governor for tickless systems (Rafael Wysocki)
- Add Jacobsville support to the intel_idle driver (Zhang Rui)
- Clean up a cpuidle core header file and the cpuidle-dt and ACPI
processor-idle drivers (Yangtao Li, Joseph Lo, Yazen Ghannam)
- Add new cpufreq driver for Armada 8K (Gregory Clement)
- Fix and clean up cpufreq core (Rafael Wysocki, Viresh Kumar, Amit
Kucheria)
- Add support for light-weight tear-down and bring-up of CPUs to the
cpufreq core and use it in the cpufreq-dt driver (Viresh Kumar)
- Fix cpu_cooling Kconfig dependencies, add support for CPU cooling
auto-registration to the cpufreq core and use it in multiple
cpufreq drivers (Amit Kucheria)
- Fix some minor issues and do some cleanups in the davinci,
e_powersaver, ap806, s5pv210, qcom and kryo cpufreq drivers
(Bartosz Golaszewski, Gustavo Silva, Julia Lawall, Paweł Chmiel,
Taniya Das, Viresh Kumar)
- Add a Hisilicon CPPC quirk to the cppc_cpufreq driver (Xiongfeng
Wang)
- Clean up the intel_pstate and acpi-cpufreq drivers (Erwan Velu,
Rafael Wysocki)
- Clean up multiple cpufreq drivers (Yangtao Li)
- Update cpufreq-related MAINTAINERS entries (Baruch Siach, Lukas
Bulwahn)
- Add support for exposing the Energy Model via debugfs and make
multiple cpufreq drivers register an Energy Model to support
energy-aware scheduling (Quentin Perret, Dietmar Eggemann, Matthias
Kaehlcke)
- Add Ice Lake mobile and Jacobsville support to the Intel RAPL
power-capping driver (Gayatri Kammela, Zhang Rui)
- Add a power estimation helper to the operating performance points
(OPP) framework and clean up a core function in it (Quentin Perret,
Viresh Kumar)
- Make minor improvements in the generic power domains (genpd), OPP
and system suspend frameworks and in the PM core (Aditya Pakki,
Douglas Anderson, Greg Kroah-Hartman, Rafael Wysocki, Yangtao Li)"
* tag 'pm-5.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (80 commits)
cpufreq: kryo: Release OPP tables on module removal
cpufreq: ap806: add missing of_node_put after of_device_is_available
cpufreq: acpi-cpufreq: Report if CPU doesn't support boost technologies
cpufreq: Pass updated policy to driver ->setpolicy() callback
cpufreq: Fix two debug messages in cpufreq_set_policy()
cpufreq: Reorder and simplify cpufreq_update_policy()
cpufreq: Add kerneldoc comments for two core functions
PM / core: Add support to skip power management in device/driver model
cpufreq: intel_pstate: Rework iowait boosting to be less aggressive
cpufreq: intel_pstate: Eliminate intel_pstate_get_base_pstate()
cpufreq: intel_pstate: Avoid redundant initialization of local vars
powercap/intel_rapl: add Ice Lake mobile
ACPI / processor: Set P_LVL{2,3} idle state descriptions
cpufreq / cppc: Work around for Hisilicon CPPC cpufreq
ACPI / CPPC: Add a helper to get desired performance
cpufreq: davinci: move configuration to include/linux/platform_data
cpufreq: speedstep: convert BUG() to BUG_ON()
cpufreq: powernv: fix missing check of return value in init_powernv_pstates()
cpufreq: longhaul: remove unneeded semicolon
cpufreq: pcc-cpufreq: remove unneeded semicolon
The fields related to the two davinci interrupt controllers are no
longer used. Remove them.
Modify the cp-intc driver to take all its configuration from the new
config structure. Stop referencing davinci_soc_info in any way.
Move the declaration for davinci_cp_intc_init() to
irq-davinci-cp-intc.h and make it take the new config structure as
parameter. Convert all users to the new version.
Also: since the two da8xx SoCs default all irq priorities to 7, just
drop the priority configuration at all and hardcode the channels to 7.
It will simplify the driver code and make our lives easier when it
comes to device-tree support.
In preparation for moving the driver to drivers/irqchip do some
cleanup: use a common prefix for all symbols.
Add the new-style config structures for da8xx SoCs. They will be used
once we make the cp-intc driver stop using davinci_soc_info.
We're going to extend the cp_intc_init() function with a config
structure so we can drop the intc-related fields from davinci_soc_info.
Once we do it, we won't be able to use this routine directly as the
init_irq callback. Wrap the calls in additional helpers that don't
take parameters and can be assigned to init_irq.
The existence of irqs.h in mach-davinci/include/mach only makes sense
without SPARSE_IRQ as it's then expected to define NR_IRQS and is
included from asm/irq.h. As we now support SPARSE_IRQ, this header can
be moved to mach-davinci and used as the source of HW interrupt numbers.
While updating the includes in various files - also rearrange the
headers by directory (linux/asm/mach).
Once we select SPARSE_IRQ, the interrupt numbers defined in mach/irqs.h
will only signify the hardware interrupt offsets, not the interrupt
numbers seen by linux. Introduce a wrapper macro that translates the
hwirq number to virtual numbers. For now it's just a dummy. Use that
macro when specifying the interrupts in resources for platform devices.
We now use the generic ARM irq handler on davinci. There are no more
users that check davinci_intc_type. Remove the variable and all its
references.
The header containing the configuration structure for davinci cpufreq
driver lives in mach-davinci/include/mach/. This is fine for now but
if we want to make davinci part of the multi_v5 build, no code external
to mach-davinci should include machine-specific headers.
Move the configuration structure to include/linux/platform_data.
While we're at it: convert the GPL-2.0 boilerplate to a proper SPDX
license identifier.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Commit 587f7a694f01 ("gpio: davinci: Use dev name for label and
automatic base selection") broke the network support in legacy boot
mode for da850-evm since we can no longer request the MDIO clock GPIO.
We now have the option to specify the GPIO base manually for davinci,
so add the relevant fields to platform data.
Fixes: 587f7a694f01 ("gpio: davinci: Use dev name for label and automatic base selection")
Cc: stable@vger.kernel.org
This removes the unused legacy clock init code from
arch/arm/mach-davinci/da850.c.
Signed-off-by: David Lechner <david@lechnology.com>
Reviewed-by: Sekhar Nori <nsekhar@ti.com>
This adds the new board-specific clock init in mach-davinci/da850.c
using the new common clock framework drivers.
The #ifdefs are needed to prevent compile errors until the entire
ARCH_DAVINCI is converted.
Also clean up the #includes since we are adding some here.
Some CFGCHIP macros were removed because we are now including
linux/mfd/da8xx-cfgchip.h which defines the same values.
This changes davinci_timer_init() so that we pass the clock as a
parameter instead of using clk_get(). This is done in preparation
for converting to the common clock framework.
It removes the requirement that we have to have a clock with con_id
of "timer0", which will be good for DT bindings since clock-names =
"timer0" doesn't really make sense.
Also, drop use of extern in header file since we are touching the
definition.
This moves the call of davinci_clk_init() from map_io to init_time for all
boards.
This is the proper place to init clocks. This is also done in preparation
for moving to the common clock framework.
dm646x is a special case because we need to handle different ref_clk rates
depending on which board is being used. The clock init in this case is
modified to set the rate before registering the clocks instead of using
davinci_set_refclk_rate() to recalculate the entire clock tree after all
of the clocks are registered.
Also, the cpu_clks field is removed from struct davinci_soc_info since it
is no longer needed.
Pull ARM SoC platform updates from Arnd Bergmann:
"These are mostly minor bugfixes, cleanup and many defconfig updates to
support added drivers. In particular OMAP and PXA keep cleaning up the
legacy code base, as usual.
Nvidia adds some more SoC support code for Tegra 186.
For the first time on years, we are actually adding a non-DT platform
for the EP93xx based Liebherr controller BK3.1. It's a minor variation
of the EP93xx reference design and in active use, while EP93xx
apparently doesn't have enough new development to have any device tree
support"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (73 commits)
ARM: omap: hwmod: fix section mismatch warnings
ARM: pxa/tosa-bt: add MODULE_LICENSE tag
arm64: defconfig: enable CONFIG_ACPI_APEI_EINJ
arm64: defconfig: enable EDAC GHES option
arm64: defconfig: enable CONFIG_ACPI_APEI_MEMORY_FAILURE
ARM: imx_v6_v7_defconfig: enable CONFIG_CPU_FREQ_STAT
Wind down ARM/TANGO port
ARM: davinci: constify gpio_led
ARM: davinci: drop unneeded newline
soc: Add SoC driver for Gemini
ARM: SAMSUNG: Add SPDX license identifiers
ARM: S5PV210: Add SPDX license identifiers
ARM: S3C64XX: Add SPDX license identifiers
ARM: S3C24XX: Add SPDX license identifiers
ARM: EXYNOS: Add SPDX license identifiers
ARM: imx: remove unused imx3 pm definitions
ARM: imx: don't abort MMDC probe if power saving status doesn't match
ARM: imx_v6_v7_defconfig: enable RTC_DRV_MXC_V2
ARM: imx_v6_v7_defconfig: Add missing config for DART-MX6 SoM
ARM: davinci: Use PTR_ERR_OR_ZERO()
There is only one clock each for "musb-da8xx" and "ohci-da8xx", so we
do not the the con_id. Removing them will also prevent needing an
unnecessary device tree property when device tree bindings are added
for clocks.
Make davinci_soc_info structures const as they are either passed to the
function davinci_common_init having the argument as const or their field
cpu_clks of type struct clk_lookup * is passed to the function
davinci_clk_init.
So, the fields are never modified and the structures can be const.
Done using Coccinelle.
Signed-off-by: Bhumika Goyal <bhumirks@gmail.com>
[nsekhar@ti.com: minor commit message adjustment]
The CPPI 4.1 DMA in USB subsystem shares its clock with the
USB OTG, and most of the time, the clock will be enabled by
USB. But during the init of the DMA, USB is not enabled
(waiting for DMA), and then we must enable the DMA clock
before doing anything.
Add clock for the CPPI 4.1 DMA engine.
Signed-off-by: Alexandre Bailon <abailon@baylibre.com>
[nsekhar@ti.com: minor commit message tweaks]
"In the SoC branch we normally collect classic arch/arm/mach-*
contents, i.e. C code changes for SoC platforms. This release cycle
the diffstat is quite nice, in that we're removing 3x the amount of
code that's being added.
The main reason for this is that there's a removal of camera drivers
for Freescale i.MX chips (driver was removed so the device
registration isn't needed any more). There's also removal of display
initialization code for OMAP that is no longer needed.
The rest are mostly minor tweaks and cleanups; constification on
Samsung platforms, cleanup of ux500 platform data, purge of other
unused platform data/device seutp on i.MX and other good stuff.
New SoC support this cycle is for two Allwinner platforms, H2+ and
V3s"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (55 commits)
ARM: ux500: remove deleted file from Makefile
ARM: ep93xx: Disable TS-72xx watchdog before uncompressing
ARM: ux500: cut some platform data
MAINTAINERS: Update for the current location of the bcm2835 tree.
ARM: davinci: remove BUG_ON() from da850_register_sata()
ARM: davinci: da850: model the SATA refclk
ARM: davinci: da850: add con_id for the SATA clock
ARM: davinci: da8xx-dt: add OF_DEV_AUXDATA entry for SATA
arm: mvebu: support for SMP on 98DX3336 SoC
dt-bindings: video: exynos7-decon: Remove obsolete samsung,power-domain property
soc: dove: constify reset_control_ops structures
ARM: mv78xx0: fix possible PCI buffer overflow
MAINTAINERS: transfer maintainership for the EZX platform
ARM: shmobile: rcar-gen2: Add more register documentation
ARM: tegra: paz00: Fix __initdata placement
ARM: OMAP: clock: Remove unused mpurate cmdline option
ARM: davinci: add skeleton for pdata-quirks
arm: sunxi: add support for V3s SoC
ARM: OMAP2+: omap_hwmod: Add support for earlycon
arm: hisi: drop extern hip01_cpu_die
Pull ARM SoC non-urgent fixes from Arnd Bergmann:
"We sometimes collect non-critical fixes that come in during the later
part of the merge window in a branch for the next release instead, and
this is that contents for v4.11.
Most of these are OMAP fixes, dealing with OMAP36/37 detection, quirks
and setup. There's also some fixes for Davinci and a Kconfig fix for
SCPI to only enable on ARM{,64}"
* tag 'armsoc-fixes-nc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
firmware: arm_scpi: Add hardware dependencies
ARM: OMAP3: Fix SoC detection of OMAP36/37 Family
ARM: OMAP5: Add HWMOD_SWSUP_SIDLE_ACT flag for UART
ARM: dts: Fix compatible for ti81xx uarts for 8250
ARM: dts: Fix am335x and dm814x scm syscon to probe children
ARM: OMAP2+: Fix init for multiple quirks for the same SoC
ARM: dts: Fix omap3 off mode pull defines
bus: da850-mstpri: fix my e-mail address
ARM: davinci: da850: fix da850_set_pll0rate()
ARM: davinci: da850: coding style fix
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/soc
Pull "SoC updates needed for SATA support on DA850" from Sekhar Nori:
This includes a merge of non-critical-fixes
branch already queued for v4.11 because
SATA clock addition conflicts with the fix-up
done earlier.
* tag 'davinci-for-v4.11/soc-2' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
The ahci-da850 SATA driver is now capable of retrieving clocks by
con_id. Add the connection id for the sysclk2-derived SATA clock.
The aemif driver can now access struct of_dev_auxdata (using platform
data).
Add the device id to the clock lookup table for the nand clock and
create a separate lookup table for aemif subnodes.
This function is confusing - its second argument is an index to the
freq table, not the requested clock rate in Hz, but it's used as the
set_rate callback for the pll0 clock. It leads to an oops when the
caller doesn't know the internals and passes the rate in Hz as
argument instead of the cpufreq index since this argument isn't bounds
checked either.
Fix it by iterating over the array of supported frequencies and
selecting a one that matches or returning -EINVAL for unsupported
rates.
Also: update the davinci cpufreq driver. It's the only user of this
clock and currently it passes the cpufreq table index to
clk_set_rate(), which is confusing. Make it pass the requested clock
rate in Hz.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
[nsekhar@ti.com: commit headline update]
Fix alignment of the clock lookup table entries.
Similarly to the aemif clock - this screws up the linked list of clock
children. Create a separate clock for mdio inheriting the rate from
emac_clk.
Cc: <stable@vger.kernel.org> # 3.12.x-
[nsekhar@ti.com: add a comment over mdio_clk to explaing its existence +
commit headline updates]
The aemif clock is added twice to the lookup table in da850.c. This
breaks the children list of pll0_sysclk3 as we're using the same list
links in struct clk. When calling clk_set_rate(), we get stuck in
propagate_rate().
Create a separate clock for nand, inheriting the rate of the aemif
clock and retrieve it in the davinci_nand module.
Cc: <stable@vger.kernel.org> # 4.9.x
"These are updates for platform specific code on 32-bit ARM machines,
essentially anything that can not (yet) be expressed using DT files.
Noteworthy changes include:
- Added support for the TI DRA71x family of SoCs in mach-omap2, this
is an new variant of the the DRA72x/DRA74x automotive infotainment
chips we already supported for a while.
- Added support for the ST STM32F746 SoC, the first Cortex-M7 based
microcontroller we support, related to the smaller STM32F4 family.
- Renesas adds support for r8a7743 and r8a7745 in mach-shmobile, see
http://elinux.org/RZ-G
- SMP is now supported on the OX820 platform
- A lot of code in mach-omap2 gets removed as a follow-up to removing
support for board files in the previous release
- Davinci has some new work to improve USB support
- For i.MX, the performance monitor now supports profiling the memory
controller using 'perf'"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (95 commits)
ARM: davinci: da830-evm: use gpio descriptor for mmc pins
ARM: davinci: da850-evm: use gpio descriptor for mmc pins
ARM: davinci: hawk: use gpio descriptor for mmc pins
ARM: ARTPEC-6: add select MFD_SYSCON to MACH_ARTPEC6
ARM: davinci: da8xx: Fix ohci device name
ARM: oxnas: Add OX820 config and makefile entry
ARM: oxnas: Add OX820 SMP support
ARM: davinci: PM: fix build when da850 not compiled in
ARM: orion5x: remove legacy support of ls-chl
ARM: integrator: drop EBI access use syscon
ARM: BCM5301X: Add back handler ignoring external imprecise aborts
ARM: davinci: PM: support da8xx DT platforms
ARM: davinci: PM: cleanup: remove references to pdata
ARM: davinci: PM: rework init, remove platform device
ARM: Kconfig: Introduce MACH_STM32F746 flag
ARM: mach-stm32: Add a new SOC - STM32F746
ARM: shmobile: document SK-RZG1E board
ARM: shmobile: r8a7745: basic SoC support
ARM: imx: mach-imx6ul: add imx6ull support
ARM: zynq: Reserve correct amount of non-DMA RAM
Pull "DaVinci SoC updates for v4.10 (part 3)" from Sekhar Nori:
mach-davinci SoC support updates to adjust
USB ohci device name to that used by drivers
and update of various board files to use gpio
descriptor API used by MMC subsystem for card
detect and write-protect detection.
* tag 'davinci-for-v4.10/soc-3' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
Pull DaVinci cleanup for v4.10 from Sekhar Nori:
mach-davinci cleanup to make it easy to add PM support
for DT-boot.
* tag 'davinci-for-v4.10/cleanup-2' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
While the clk lookup table is making reference to "ohci"
other subsystems (such as phy) are trying to match "ohci.0"
Since there is a single ohci instance, instead of changing
the clk name, change the dev id to -1, and add the "-da8xx"
postfix to match the driver name that will also be changed
in a subsequent patch.
Signed-off-by: Axel Haslam <ahaslam@baylibre.com>
Remove fake platform device used for PM init. Move pdata values which
are common across all current platforms into pm.c.
Also, since PM is only used on da8xx, remove davinci_pm_init() from
common init code, and only use in da850/omapl138 board files that are
currently creating the fake platform_device.
Suggested-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
[nsekhar@ti.com: subject line adjustment]
This fixes pwm name matching for DA850 familiy devices. When using device
tree, the da850_auxdata_lookup[] table caused pwm devices to have the exact
same name, which caused errors when trying to register the devices.
We cannot have multiple entries for the same clock in in da850_clks[], so
we have added child clocks to the EHRPWM and ECAP LPSC clocks so that each
PWM device will have its own clock for proper name matching.
This adds device names for the SoC USB devices to the clock lookup tables
in da830.c and da850.c.
Also add the USB device names to the da850_auxdata_lookup[] table.
The davinci boards don't have their clocks in DT yet and getting a clock
will fail, unless registering them as clk_lookups. This registers the
aemif clock for the ti-aemif memory driver.
The current aemif lookup entry resolving to the same clock:
'CLK(NULL, "aemif", &aemif_clk)'
is currently used by davinci_nand and remains for non-DT and backward
compatibility.
Currently the davinci boards only configure the AEMIF in case of non-DT
boot, via some code in mach-davinci.
This change will allow DT-based davinci platforms to do the same, via
the ti-aemif memory driver code.
Signed-off-by: Karl Beldan <kbeldan@baylibre.com>
[nsekhar@ti.com: reworded commit message]
Add clock definitions "davinci-mcbsp.0" and "davinci-mcbsp.1" in order
to make McBSP driver work on the DA850 platform.
The McBSP 0 and 1 interfaces were not defined for the DA850 platform.
Neither were the related clocks. In order to make the use of McBSP via
devicetree the clocks need to be defined.
Signed-off-by: Petr Kulhavy <petr@barix.com>
The da850 family of processors has an async3 clock domain that can be
muxed to either pll0_sysclk2 or pll1_sysclk2. Now that the davinci clocks
have a set_parent callback, we can use this to control the async3 mux
instead of a stand-alone function.
This adds a new async3_clk and sets the appropriate child clocks. The
default is use to pll1_sysclk2 since it is not affected by processor
frequency scaling.
[nsekhar@ti.com: drop unnecessary comment]
Some clocks (such as the USB PHY clocks in DA8xx) will need to use iomem.
The davinci_common_init() function must be called before the ioremap, so
the clock init is now split out as separate function.
Some header files are never included outside of a mach-davinci
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
Init data marked const should be annotated with __initconst for
correctness and not __initdata. In some cases the array gathering
references to that data has to be marked const as well. This fixes
LTO builds that otherwise fail with section mismatch errors.
Signed-off-by: Nicolas Pitre <nico@linaro.org>
clk_add_alias() is provided by clkdev, and is not part of the clk API.
Howver, it is prototyped in two locations: linux/clkdev.h and
linux/clk.h. This is a mess. Get rid of the redundant and unnecessary
version in linux/clk.h.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
The cpufreq core now supports the cpufreq_for_each_entry macro helper
for iteration over the cpufreq_frequency_table, so use it.
It should have no functional changes.
Signed-off-by: Stratos Karafotis <stratosk@semaphore.gr>
Acked-and-tested-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Update SATA AHCI support to make use of the new ahci_da850 host
driver (instead of the generic ahci_platform one) and remove
deprecated ahci_platform_data code.
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/drivers
From Sekhar Nori:
This patch updates the davinci watchdog
platform device name from generic "watchdog"
to something more specific.
* tag 'davinci-for-v3.14/watchdog' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
watchdog: davinci: rename platform driver to davinci-wdt
Signed-off-by: Kevin Hilman <khilman@linaro.org>
As we switch to use the watchdog core which permits more than one
active watchdog in the system, rename platform driver to
"davinci-wdt" to be identifiable.
Acked-by: Wim Van Sebroeck <wim@iguana.be>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
As the davinci-gpio driver is migrated to use irqdomain
there is no need to pass the irq base for the gpio driver.
This patch removes this variable from davinci_gpio_platform_data
and also the refrences from the machine file.
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
