[ Upstream commit 564b6bb9d42d31fc80c006658cf38940a9b99616 ]
dm365 have only single McBSP, so the device name is without .0
Fixes: 0c750e1fe481d ("ARM: davinci: dm365: Add dma_slave_map to edma")
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
The driver is converted to not use the DMA resource.
commit 6bce5efd4424 ("ARM: davinci: remove unused davinci-i2s pdata")
removed all instances of davinci-i2s pdata. However, on DM365 EVM,
the same platform data is passed to the voicecodec present on that
device.
This causes build breakage when voicecodec support is enabled:
arch/arm/mach-davinci/board-dm365-evm.c:764:17: error: 'dm365_evm_snd_data' undeclared (first use in this function)
voicecodec driver does not use the platform data as well, and
it is safe to remove it.
Fixes: 6bce5efd4424 ("ARM: davinci: remove unused davinci-i2s pdata")
The davinci-i2s driver ("davinci-mcbsp") does not use platform
data any longer. Remove the dummy pdata provided by the board
drivers dm355, dm365, dm644x and neuros-osd2.
Signed-off-by: Petr Kulhavy <petr@barix.com>
Reviewed-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Some clocks (such as the USB PHY clocks in DA8xx) will need to use iomem.
The davinci_common_init() function must be called before the ioremap, so
the clock init is now split out as separate function.
Signed-off-by: David Lechner <david@lechnology.com>
Provide the dma_slave_map to edma which will allow us to move the drivers
to the new, simpler dmaengine API and we can remove the DMA resources also
for the devices.
Some header files are never included outside of a mach-davinci
directory and do not need to be made visible in include/mach,
so let's just move them all down one level.
Acked-by: Sekhar Nori <nsekhar@ti.com>
Currently we have one device created to handle all (maximum 2) eDMAs in the
system.
With this change all eDMA instance will have it's own device/driver.
This change is needed for further cleanups in the eDMA driver stack since
the one device/driver to handle all eDMAs in the system was not flexible
enough and prevents the upcoming work.
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
SPI Davinci driver has been updated to allow SOCs to specify their minimum
prescale value. Update the various SOCs board files that use this driver with
their proper prescaler limit.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
In order to have subsytem agnostic media bus format definitions we've
moved media bus definition to include/uapi/linux/media-bus-format.h and
prefixed values with MEDIA_BUS_FMT instead of V4L2_MBUS_FMT.
Reference new definitions in all platform drivers.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
The following parameters are no longer needed by the edma driver since the
information can be obtained from the IP's CCCFG register:
n_channel, n_region, n_slot and n_tc.
Remove the initialization of n_cc as well since in this context it has no
meaning. We have separate edma_soc_info struct/eDMA3_CC instance so this
member does not make any sense (and the driver no longer uses it).
It is ignored by the edma driver since we are just setting back the default
mapping of TC -> Queue.
Fix multiple watchdog device registration on da8xx devices
due to davinci_init_devices blindly registering watchdog
device.
Fix this by getting rid of the initcall and instead registering
watchdog for each soc.
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/drivers
From Sekhar Nori:
This patch updates the davinci watchdog
platform device name from generic "watchdog"
to something more specific.
* tag 'davinci-for-v3.14/watchdog' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
watchdog: davinci: rename platform driver to davinci-wdt
Signed-off-by: Kevin Hilman <khilman@linaro.org>
As we switch to use the watchdog core which permits more than one
active watchdog in the system, rename platform driver to
"davinci-wdt" to be identifiable.
Acked-by: Wim Van Sebroeck <wim@iguana.be>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
As the davinci-gpio driver is migrated to use irqdomain
there is no need to pass the irq base for the gpio driver.
This patch removes this variable from davinci_gpio_platform_data
and also the refrences from the machine file.
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into fixes
From Sekhar Nori:
This pull request includes a patch
to align platform code to driver's
usage of platform_get_resource_byname()
This is needed to start successfully probing
audio again. The regression was introduced
in v3.13 merge window.
* tag 'davinci-fixes-for-v3.13-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
ARM: davinci: Fix McASP mem resource names
The ASoC McASP driver looks for the mem resources by name
"mpu" and "dat" regions.
Change/add the needed name for the mem resources so the driver can pick the
correct resource.
The davinci_gpio_register() function expects the number of
resources as the second parameter, but sizeof() resources
was passed to it due to which it was causing unexpected
behaviour. This patch fixes the same by passing the
ARRAY_SIZE() of resources.
Reported-by: Grygorii Strashko <grygorii.strashko@ti.com>
DaVinci GPIO driver now uses platform device model.
Add a GPIO platform register API to convert the
traditional DaVinci SoCs to use the new model.
While at it, also group related include files together
wherever that was not the case.
Signed-off-by: Philip Avinash <avinashphilip@ti.com>
[nsekhar@ti.com: move function declaration to local header,
simplify commit message, merge SoC specific
portions from other patches into this patch]
git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci into next/soc
From Sekhar Nori:
DaVinci SoC updates for v3.12
This set of SoC updates contains changes to the
way UART clock is handled to enabled DT-boot to
obtain UART clock frequency instead of relying
on DT-binding being supplied. Similarly handling
of MDIO clock is fixed to make it easier to support
MDIO in DT-boot. Finally there is patch to remove
now unnecessary setting of wake-up capable flag for
RTC.
* tag 'davinci-for-v3.12/soc' of git://git.kernel.org/pub/scm/linux/kernel/git/nsekhar/linux-davinci:
ARM: davinci: fix clock lookup for mdio device
ARM: davinci: da8xx: remove hard coding of rtc device wakeup
ARM: davinci: serial: remove davinci_serial_setup_clk()
ARM: davinci: serial: get rid of davinci_uart_config
ARM: davinci: da8xx: remove da8xx_uart_clk_enable
ARM: davinci: uart: move to devid based clk_get
This patch removes the clock alias for mdio device and adds a entry
in clock lookup table, this entry can now be used by both DT and
non-DT case.
Get rid of davinci_serial_setup_clk() since its not called
from multiple places now. Instead initialize clock in
davinci_serial_init() itself. This also helps get rid of
"serial_dev" member of struct davinci_soc_info.
Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com>
Suggested-by: Sekhar Nori <nsekhar@ti.com>
[nsekhar@ti.com: split removal of davinci_serial_setup_clk()
into a separate patch.]
"struct davinci_uart_config" was introduced to specify
UART ports brought out or enabled on the board. But
none of the boards use it for that purpose and we are
not going to add anymore board files, so remove the
structure.
[nsekhar@ti.com: split patch to remove davinci_serial_setup_clk()
changes.]
For modules having single clock, clk_get should be done with dev_id.
But current davinci implementation handles multiple instances
of the UART devices with single platform_device_register. Hence clk_get
is based on con_id rather than dev_id, this is not correct. Do
platform_device_register for each instance and clk_get on dev_id.
[nsekhar@ti.com: actually stop using con_id in clk_get(), squash the
patch adding OF aux data into this one]
Make file local variables static in mach-davinci.
This fixes sparse warnings of the form:
arch/arm/mach-davinci/dm355.c:863:27: warning: symbol 'dm355_venc_pdata' was not declared. Should it be static?
Cc: Prabhakar Lad <prabhakar.csengg@gmail.com>
Acked-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
Adds support for parsing the TI EDMA DT data into the required EDMA
private API platform data. Enables runtime PM support to initialize
the EDMA hwmod. Enables build on OMAP.
Changes by Joel:
* Setup default one-to-one mapping for queue_priority and queue_tc
mapping as discussed in [1].
* Split out xbar stuff to separate patch. [1]
* Dropped unused DT helper to convert to array
* Fixed dangling pointer issue with Sekhar's changes
[1] https://patchwork.kernel.org/patch/2226761/
Signed-off-by: Matt Porter <mporter@ti.com>
[nsekhar@ti.com: fix checkpatch errors, build breakages. Introduce
edma_setup_info_from_dt() as part of that effort]
Signed-off-by: Joel A Fernandes <joelagnel@ti.com>
Move mach-davinci/dma.c to common/edma.c so it can be used
by OMAP (specifically AM33xx) as well.
Acked-by: Chris Ball <cjb@laptop.org> # davinci_mmc.c
Acked-by: Mark Brown <broonie@linaro.org>
Acked-by: Olof Johansson <olof@lixom.net>
[nsekhar@ti.com: dropped davinci sffsdr changes]
Pull ARM SoC platform updates from Olof Johansson:
"This branch contains part 1 of the platform updates for 3.10. Among
the highlights:
- Support for the new Atmel Cortex-A5 based platforms (SAMA5D3)
- New support for CSR SiRFatlas6 SoCs
- A handful of updates for NVidia T114 (a.k.a. Tegra 4)
- A bunch of updates for the shmobile platforms
- A handful of updates for davinci
- A few updates for Qualcomm MSM
- Plus a handful of other patches, defconfig updates, etc."
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (135 commits)
ARM: tegra: pm: fix build error w/o PM_SLEEP
ARM: davinci: ensure global variables are declared
ARM: davinci: sram.c: fix incorrect type in assignment
ARM: davinci: da8xx dt: make file local symbols static
ARM: davinci: da8xx: add remoteproc support
ARM: socfpga: Upgrade clk driver for socfpga to make use of dts clock entries
ARM: socfpga: Add clock entries into device tree
ARM: socfpga: Enable soft reset
ARM: EXYNOS: replace cpumask by the corresponding macro
ARM: EXYNOS: handle properly the return values
ARM: EXYNOS: factor out the idle states
ARM: OMAP4: Enable fix for Cortex-A9 erratas
ARM: OMAP2+: Export SoC information to userspace
ARM: OMAP2+: SoC name and revision unification
ARM: OMAP2+: Move common part of late init into common function
ARM: tegra: pm: remove duplicated include from pm.c
ARM: davinci: da850: override mmc DT node device name
ARM: davinci: da850: add mmc DT entries
mmc: davinci_mmc: add DT support
ARM: SAMSUNG: check processor type before cache restoration in resume
Create platform devices for various video modules like venc,osd,
vpbe and v4l2 driver for dm365.
By default the VPSS clocks were enabled in capture driver
for davinci family which creates duplicates for dm355/dm365/dm644x.
This patch adds support to enable the VPSS clocks in VPSS driver,
which avoids duplication of code and also adding clock aliases.
This patch uses PM runtime API to enable/disable clock, instead
of DaVinci clock framework. con_ids for master and slave clocks of
vpss is added in pm_domain.
This patch cleanups the VPSS clock enabling in the capture driver,
and also removes the clock alias in machine file. Along side adds
a vpss slave clock for DM365 as mentioned by Sekhar
(https://patchwork.kernel.org/patch/1221261/).
The Suspend/Resume in dm644x_ccdc.c which enabled/disabled the VPSS clock
is now implemented as part of the VPSS driver.
Remove specifying mmc controller IP version information via platform
data, instead specify device name so that driver derives it from
platform_device_id table. Also change the clock node name to match
the changed dev_id.
Tested on da850-evm to make sure driver loads without clk_get failures.
Reviewed-by: Sekhar Nori <nsekhar@ti.com>
The current davinci init sets up SRAM in iotables. There has been
an observed failure to boot a da850 with 128K specified in the
iotable.
Make the davinci sram allocator do an ioremap of the region
specified by the entries in davinci_soc_info before registering
with gen_pool_add_virt(). Remove all iotable SRAM mappings and
SRAM_VIRT.
Regression tested suspend/resume on AM180x EVM.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"This contains pretty many small commits covering fairly large range of
files in sound/ directory. Partly because of additional API support
and partly because of constantly developed ASoC and ARM stuff.
Some highlights:
- Introduced the helper function and documentation for exposing the
channel map via control API, as discussed in Plumbers; most of PCI
drivers are covered, will follow more drivers later
- Most of drivers have been replaced with the new PM callbacks (if
the bus is supported)
- HD-audio controller got the support of runtime PM and the support
of D3 clock-stop. Also changing the power_save option in sysfs
kicks off immediately to enable / disable the power-save mode.
- Another significant code change in HD-audio is the rewrite of
firmware loading code. Other than that, most of changes in
HD-audio are continued cleanups and standardization for the generic
auto parser and bug fixes (HBR, device-specific fixups), in
addition to the support of channel-map API.
- Addition of ASoC bindings for the compressed API, used by the
mid-x86 drivers.
- Lots of cleanups and API refreshes for ASoC codec drivers and
DaVinci.
- Conversion of OMAP to dmaengine.
- New machine driver for Wolfson Microelectronics Bells.
- New CODEC driver for Wolfson Microelectronics WM0010.
- Enhancements to the ux500 and wm2000 drivers
- A new driver for DA9055 and the support for regulator bypass mode."
Fix up various arm soc header file reorg conflicts.
* tag 'sound-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (339 commits)
ALSA: hda - Add new codec ALC283 ALC290 support
ALSA: hda - avoid unneccesary indices on "Headphone Jack" controls
ALSA: hda - fix indices on boost volume on Conexant
ALSA: aloop - add locking to timer access
ALSA: hda - Fix hang caused by race during suspend.
sound: Remove unnecessary semicolon
ALSA: hda/realtek - Fix detection of ALC271X codec
ALSA: hda - Add inverted internal mic quirk for Lenovo IdeaPad U310
ALSA: hda - make Realtek/Sigmatel/Conexant use the generic unsol event
ALSA: hda - make a generic unsol event handler
ASoC: codecs: Add DA9055 codec driver
ASoC: eukrea-tlv320: Convert it to platform driver
ALSA: ASoC: add DT bindings for CS4271
ASoC: wm_hubs: Ensure volume updates are handled during class W startup
ASoC: wm5110: Adding missing volume update bits
ASoC: wm5110: Add OUT3R support
ASoC: wm5110: Add AEC loopback support
ASoC: wm5110: Rename EPOUT to HPOUT3
ASoC: arizona: Add more clock rates
ASoC: arizona: Add more DSP options for mixer input muxes
Platform data for device drivers should be defined in
include/linux/platform_data/*.h, not in the architecture
and platform specific directories.
This moves such data out of the davinci include directories
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@ti.com>
Cc: "Ben Dooks" <ben-linux@fluff.org>
Cc: "Wolfram Sang" <w.sang@pengutronix.de>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Chris Ball <cjb@laptop.org>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Liam Girdwood <lrg@ti.com>
Cc: davinci-linux-open-source@linux.davincidsp.com
Davinci McASP header & driver are shared by few OMAP platforms (like
TI81xx, AM335x). Splitting asp header into Davinci platform specific
header and Audio specific header helps to share them across platforms.
Audio specific defines is moved to to common
<linux/platform_data/davinci_asp.h> so that the header can be
accessed by all related platforms.
While here, correct the header usage (remove multiple header
re-definitions and unused headers) and remove platform names from
structures comments and enum. Also some some coding style errors.
Signed-off-by: Hebbar, Gururaja <gururaja.hebbar@ti.com>
Acked-by: Vaibhav Bedia <vaibhav.bedia@ti.com>
spi_board_info is not modified in any of the spi registeration
functions and passed along as-is to the generic SPI layer.
Mark spi_board_info arguments as const to signal this.
[nsekhar@ti.com: extended for dm365 and dm355]
There are instances of IO_ADDRESS() being used for system module
(sysmod) register access. Eliminate this in favor of a ioremap()
based access. ioremap() the entire sysmod address space once during
boot-up and provide a helper macro to access specific register
offsets within the address space.
With this, also eliminate ioremap() of specific sysmodule registers
related to VPIF happening in DM646x EVM code.
While at it, also eliminate some duplicate sysmod register offset macros
defined in code and place offset definitions at one place in davinci.h
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
[nsekhar@ti.com: removed the addition of ifndef __ASSEMBLER__
in davinci.h, eliminate IO_ADDRESS() usage left out in dm646x.c,
cleanup VPIF sysmodule register access as part of this patch and
keep all sysmod offsets in davinci.h Also, convert the WARN_ON()
on failure to setup sysmod base to BUG_ON()]
Remove individual platform header files for dm365, dm355, dm644x
and dm646x and consolidate it into a single and common
header file davinci.h placed in arch/arm/mach-davinci.
This reduces the pollution in the include/mach and is consistent
with Russell's suggestions as part of his "pet peaves" mail.
(See #4 in: http://lists.infradead.org/pipermail/linux-arm-kernel/2011-November/071516.html)
While at it, fix the forward declaration of spi_board_info,
and include the right header file instead.
The further patches in the series take advantage of this consolidation
for easy implementation of IO_ADDRESS elimination.
[nsekhar@ti.com: make davinci.h the first local include file,
fix forward declaration of spi_board_info and add back Deep Root
Systems, LLC copyright]
Move register base addresses and offsets used only in dm365.c
from arch/arm/mach-davinci/include/mach/dm365.h in to the C
file as these definitions are used only in C file.
This helps reduce code in arch/arm/mach-davinci/include/mach/
which is not really needed by rest of the kernel.
Rather than using DaVinci specific davinci_soc_info based
restart hook, use the restart hook available in the machine
descriptor instead.
Tested on DM365 and AM18x EVMs.
v2:
Changed to use restart hook in machine descriptor
per Russell's comment.
The <mach/gpio.h> file is included from upper directories
and deal with generic GPIO and gpiolib stuff. Break out the
platform and driver specific defines and functions into its own
header file.
For DMA operation, the davinci spi driver needs an event queue number.
Currently, this number is passed as a IORESOURCE_DMA. This is not
correct, as the event queue is not a DMA channel. Pass the event queue
via the platform data structure instead.
On dm355 and dm365, move the eventq assignment for spi0 out of resources
array and into platform data.
Signed-off-by: Michael Williamson <michael.williamson@criticallink.com>
Signed-off-by: Kevin Hilman <khilman@ti.com>
git://arago-project.org/git/projects/linux-davinci into spi/next
* 'for-grant' of git://arago-project.org/git/projects/linux-davinci into spi/next
spi: davinci: fix checkpatch errors
spi: davinci: whitespace cleanup
spi: davinci: remove unused variable 'pdata'
spi: davinci: set chip-select mode in SPIDEF only once
spi: davinci: enable both activation and deactivation of chip-selects
spi: davinci: remove unnecessary data transmit on CS disable
spi: davinci: enable GPIO lines to be used as chip selects
spi: davinci: simplify prescalar calculation
spi: davinci: remove 'wait_enable' platform data member
spi: davinci: make chip-slect specific parameters really chip-select specific
spi: davinci: consolidate setup of SPIFMTn in one function
spi: davinci: setup chip-select timers values only if timer enabled
spi: davinci: add support for wait enable timeouts
spi: davinci: remove unused members of davinci_spi_slave
spi: davinci: eliminate the single member structure davinci_spi_slave
spi: davinci: eliminate unnecessary update of davinci_spi->count
spi: davinci: simplify calculation of edma acount value
spi: davinci: check for NULL buffer pointer before using it
spi: davinci: remove unnecessary disable of SPI
spi: davinci: remove unnecessary 'count' variable in driver private data
spi: davinci: remove unnecessary completion variable initialization
spi: davinci: remove non-useful interrupt mode support
spi: davinci: simplify poll mode transfers
spi: davinci: add support for interrupt mode
spi: davinci: configure the invariable bits in spipc0 only once
spi: davinci: remove unnecessary function davinci_spi_bufs_prep()
spi: davinci: remove unnecessary call to davinci_spi_setup_transfer()
spi: davinci: do not store DMA channel information per chip select
spi: davinci: always start transmit DMA
spi: davinci: do not use temporary buffer if no transmit data provided
spi: davinci: always start receive DMA
spi: davinci: use edma_write_slot() to setup EDMA PaRAM slot
spi: davinci: fix DMA event generation stoppage
spi: davinci: fix EDMA CC errors at end of transfers
spi: davinci: handle DMA completion errors correctly
spi: davinci: remove usage of additional completion variables for DMA
spi: davinci: let DMA operation be specified on per-device basis
spi: davinci: remove non-useful "clk_internal" platform data
spi: davinci: enable and power-up SPI only when required
spi: davinci: setup the driver owner
spi: davinci: add additional comments
spi: davinci: add EF Johnson Technologies copyright
spi: davinci: removed unused #defines
spi: davinci: remove unnecessary typecast
spi: davinci: do not treat Tx interrupt being set as error
spi: davinci: do not allocate DMA channels during SPI device setup
spi: davinci: remove unnecessary private data member 'region_size'
spi: davinci: shorten variable names
spi: davinci: kconfig: add manufacturer name to prompt string
The "clk_internal" platform data member which contols the
CLKMOD bit in Global Control Register 1 is not useful
since CLKMOD needs be set to 1 *always* to ensure master
mode operation.
Remove this platform data.
Signed-off-by: Brian Niebuhr <bniebuhr@efjohnson.com>
Tested-By: Michael Williamson <michael.williamson@criticallink.com>
The interrupt mode support as it stands is another version
of poll mode. Even when interrupt mode is selected, the code
tight loops on interrupt status register, rendering it totally
useless. A completion variable is initialized, but never used.
Remove this fake interrupt mode since users can anyway use
poll mode with no functional difference. A usefully implemented
interrupt mode support can be added later.
Some chip-select specific paramterers like wdelay, parity, usage of
chip-select timers (and the actual timer values) are included in
platform data forcing the same behaviour across all chip-selects.
Create a new davinci_spi_config data structure which can be passed
along using controller_data member of spi_device data structure
on a per-device basis.
Let davinci_spi_chipselect() perform both activation and
deactivation of chip selects. This lets spi_bitbang fully
control chip select activation, as intended by the SPI API.
With this change, the chip select activation code need not
be duplicated in davinci_spi_bufs_{pio|dma}().
Also, keeping chip select active control is removed as a
platform data and simply controlled using information from
spi_bitbang on whether chip slect should be activated or
de-activated.
Multi-component commit f0fba2ad broke a few things which this patch should
fix. Tested on the DM355 EVM. I've been as careful as I can, but it would be
good if those with access to other Davinci boards could test.
The multi-component commit put the initialisation of
snd_soc_dai.[capture|playback]_dma_data into snd_soc_dai_ops.hw_params of the
McBSP, McASP & VCIF drivers (davinci-i2s.c, davinci-mcasp.c & davinci-vcif.c).
The initialisation had to be moved from the probe function in these drivers
because davinci_*_dai changed from snd_soc_dai to snd_soc_dai_driver.
Unfortunately, the DMA params pointer is needed by davinci_pcm_open (in
davinci-pcm.c) before hw_params is called. I have moved the initialisation to
a new snd_soc_dai_ops.startup function in each of these drivers. This fix
indicates that all platforms that use davinci-pcm must have been broken and
need to test with this fix.
The multi-component commit also changed the McBSP driver name from
"davinci-asp" to "davinci-i2s" in davinci-i2s.c without updating the board
level references to the driver name. This change is understandable, as there
is a similarly named "davinci-mcasp" driver in davinci-mcasp.c.
There is probably no 'correct' name for this driver. The DM6446 datasheet
calls it the "ASP" and describes it as a "specialised McBSP". The DM355
datasheet calls it the "ASP" and describes it as a "specialised ASP". The
DM365 datasheet calls it the "McBSP". Rather than fix this problem by
reverting to "davinci-asp", I've elected to avoid future confusion with the
"davinci-mcasp" driver by changing it to "davinci-mcbsp", which is also
consistent with the names of the functions in the driver. There are other
fixes required, so it was never going to be as simple as a revert anyway.
The DM365 only has one McBSP port (of the McBSP platforms, only the DM355 has
2 ports), so I've changed the the id of the platform_device from 0 to -1.
In davinci-evm.c, the DM6446 EVM can no longer share a snd_soc_dai_link
structure with the DM355 EVM as they use different cpu DAI names (the DM355
has 2 ports and the EVM uses the second port, but the DM6446 only has 1 port).
This also means that the 2 boards need different snd_soc_card structures.
The codec_name entries in davinci-evm.c didn't match the i2c ids in the board
files. I have only checked and fixed the details of the names used for the
McBSP based platforms. Someone with a McASP based platform (eg DA8xx) should
check the others.
Signed-off-by: Chris Paulson-Ellis <chris@edesix.com>
Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
arch/arm/mach-davinci/board-da830-evm.c
arch/arm/mach-davinci/board-da850-evm.c
