path: root/arch/arm/mach-dove
2014-04-26ARM: orion: switch to a per-platform handle_irq() functionThomas Petazzoni
Moving to the Device Tree implies having CONFIG_MULTI_IRQ_HANDLER enabled, even for non-DT platforms (if we want both DT and non-DT platforms to be supported in a single kernel). However, the common CONFIG_MULTI_IRQ_HANDLER handler for non-DT platforms in plat-orion/irq.c doesn't match the needs of Orion5x. Also, it doesn't make much sense for orion_irq_init() to register the multi-IRQ handler: orion_irq_init() is called once for each IRQ cause/mask tuple, while the multi-IRQ handler only needs to be registered once. To solve this problem, we move the multi-IRQ handle in per-platform code: mach-kirkwood/irq.c and mach-dove/irq.c. The Orion5x variant will be introduced in a followup commit. Of course, this code will ultimately be completely removed once all boards are converted to the Device Tree. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Link: https://lkml.kernel.org/r/1398202002-28530-23-git-send-email-thomas.petazzoni@free-electrons.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-04-05Merge tag 'drivers-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Arnd Bergmann: "These changes are mostly for ARM specific device drivers that either don't have an upstream maintainer, or that had the maintainer ask us to pick up the changes to avoid conflicts. A large chunk of this are clock drivers (bcm281xx, exynos, versatile, shmobile), aside from that, reset controllers for STi as well as a large rework of the Marvell Orion/EBU watchdog driver are notable" * tag 'drivers-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (99 commits) Revert "dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac." Revert "net: stmmac: Add SOCFPGA glue driver" ARM: shmobile: r8a7791: Fix SCIFA3-5 clocks ARM: STi: Add reset controller support to mach-sti Kconfig drivers: reset: stih416: add softreset controller drivers: reset: stih415: add softreset controller drivers: reset: Reset controller driver for STiH416 drivers: reset: Reset controller driver for STiH415 drivers: reset: STi SoC system configuration reset controller support dts: socfpga: Add sysmgr node so the gmac can use to reference dts: socfpga: Add support for SD/MMC on the SOCFPGA platform reset: Add optional resets and stubs ARM: shmobile: r7s72100: fix bus clock calculation Power: Reset: Generalize qnap-poweroff to work on Synology devices. dts: socfpga: Update clock entry to support multiple parents ARM: socfpga: Update socfpga_defconfig dts: socfpga: Add DTS entry for adding the stmmac glue layer for stmmac. net: stmmac: Add SOCFPGA glue driver watchdog: orion_wdt: Use %pa to print 'phys_addr_t' drivers: cci: Export CCI PMU revision ...
2014-04-05Merge tag 'soc-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC specific changes from Arnd Bergmann: "Lots of changes specific to one of the SoC families. Some that stick out are: - mach-qcom gains new features, most importantly SMP support for the newer chips (Stephen Boyd, Rohit Vaswani) - mvebu gains support for three new SoCs: Armada 375, 380 and 385 (Thomas Petazzoni and Free-electrons team) - SMP support for Rockchips (Heiko Stübner) - Lots of i.MX changes (Shawn Guo) - Added support for BCM5301x SoC (Hauke Mehrtens) - Multiplatform support for Marvell Kirkwood and Dove (Andrew Lunn and Sebastian Hesselbarth doing the final part of a long journey) - Unify davinci platforms and remove obsolete ones (Sekhar Nori, Arnd Bergmann)" * tag 'soc-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (126 commits) ARM: sunxi: Select HAVE_ARM_ARCH_TIMER ARM: cache-tauros2: remove ARMv6 code ARM: mvebu: don't select CONFIG_NEON ARM: davinci: fix DT booting with default defconfig ARM: configs: bcm_defconfig: enable bcm590xx regulator support ARM: davinci: remove tnetv107x support MAINTAINERS: Update ARM STi maintainers ARM: restrict BCM_KONA_UART to ARCH_BCM_MOBILE ARM: bcm21664: Add board support. ARM: sunxi: Add the new watchog compatibles to the reboot code ARM: enable ARM_HAS_SG_CHAIN for multiplatform ARM: davinci: remove da8xx_omapl_defconfig ARM: davinci: da8xx: fix multiple watchdog device registration ARM: davinci: add da8xx specific configs to davinci_all_defconfig ARM: davinci: enable da8xx build concurrently with older devices ARM: BCM5301X: workaround suppress fault ARM: BCM5301X: add early debugging support ARM: BCM5301X: initial support for the BCM5301X/BCM470X SoCs with ARM CPU ARM: mach-bcm: Remove GENERIC_TIME ARM: shmobile: APMU: Fix warnings due to improper printk formats ...
2014-03-04ARM: mvebu: move DT Dove to MVEBUSebastian Hesselbarth
With all the DT support preparation done, we are able to move Dove to MVEBU easily. Legacy non-DT mach-dove is left untouched to rot for a while before removal. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-02-22watchdog: orion: Make RSTOUT register a separate resourceEzequiel Garcia
In order to support other SoC, it's required to distinguish the 'control' timer register, from the 'rstout' register that enables system reset on watchdog expiration. To prevent a compatibility break, this commit adds a fallback to a hardcoded RSTOUT address. Reviewed-by: Guenter Roeck <linux@roeck-us.net> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Wim Van Sebroeck <wim@iguana.be> Tested-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-02-18Merge tag 'dropmachtimexh-v2' of git://git.pengutronix.de/git/ukl/linux into ↵Olof Johansson
next/cleanup This cleanup series gets rid of <mach/timex.h> for platforms not using ARCH_MULTIPLATFORM. (For multi-platform code it's already unused since 387798b (ARM: initial multiplatform support).) To make this work some code out of arch/arm needed to be adapted. The respective changes got acks by their maintainers to be taken via armsoc (with Andrew Morton substituting for Alessandro Zummo as rtc maintainer). Compared to the previous pull request there was another patch added that fixes a (non-critical) regression on ixp4xx. Olof Johansson asked to not squash this fix into the original commit to save him from the need to reverify the series. * tag 'dropmachtimexh-v2' of git://git.pengutronix.de/git/ukl/linux: ARM: ixp4xx: fix timer latch calculation ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, too ARM: rpc: stop using <mach/timex.h> ARM: ixp4xx: stop using <mach/timex.h> input: ixp4xx-beeper: don't use symbols from <mach/timex.h> ARM: at91: don't use <mach/timex.h> ARM: ep93xx: stop using mach/timex.h ARM: mmp: stop using mach/timex.h ARM: netx: stop using mach/timex.h ARM: sa1100: stop using mach/timex.h clocksource: sirf/marco+prima2: drop usage of CLOCK_TICK_RATE rtc: pxa: drop unused #define TIMER_FREQ rtc: at91sam9: include <mach/hardware.h> explicitly ARM/serial: at91: switch atmel serial to use gpiolib Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-20ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, tooUwe Kleine-König
While <mach/timex.h> isn't used for multi-platform builds since long it still is for "normal" builds. As the previous patches fix all sites to not make use of this per-platform file, it can go now for good also for platforms that are not (yet) converted to multi-platform. While at it there are no users of CLOCK_TICK_RATE any more, so also drop the dummy #define. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-11-24ARM: Dove: Fix compiler warnings with C=1 buildsAndrew Lunn
Add missing static keywords. Remove the unused function dove_crypto_init(). Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-11-11Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM driver updates from Olof Johansson: "Updates of SoC-near drivers and other driver updates that makes more sense to take through our tree. In this case it's involved: - Some Davinci driver updates that has required corresponding platform code changes (gpio mostly) - CCI bindings and a few driver updates - Marvell mvebu patches for PCI MSI support (could have gone through the PCI tree for this release, but they were acked by Bjorn for 3.12 so we kept them through arm-soc). - Marvell dove switch-over to DT-based PCIe configuration - Misc updates for Samsung platform dmaengine drivers" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits) ARM: S3C24XX: add dma pdata for s3c2410, s3c2440 and s3c2442 dmaengine: s3c24xx-dma: add support for the s3c2410 type of controller ARM: S3C24XX: Fix possible dma selection warning PCI: mvebu: make local functions static PCI: mvebu: add I/O access wrappers PCI: mvebu: Dynamically detect if the PEX link is up to enable hot plug ARM: mvebu: fix gated clock documentation ARM: dove: remove legacy pcie and clock init ARM: dove: switch to DT probed mbus address windows ARM: SAMSUNG: set s3c24xx_dma_filter for s3c64xx-spi0 device ARM: S3C24XX: add platform-devices for new dma driver for s3c2412 and s3c2443 dmaengine: add driver for Samsung s3c24xx SoCs ARM: S3C24XX: number the dma clocks PCI: mvebu: add support for Marvell Dove SoCs PCI: mvebu: add support for reset on GPIO PCI: mvebu: remove subsys_initcall PCI: mvebu: increment nports only for registered ports PCI: mvebu: move clock enable before register access PCI: mvebu: add support for MSI irqchip: armada-370-xp: implement MSI support ...
2013-10-08ARM: dove: remove legacy pcie and clock initSebastian Hesselbarth
With DT support for PCIe controllers on Dove, we can now remove the legacy pcie init and the last remaining clock workaround for its clocks. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-08ARM: dove: switch to DT probed mbus address windowsSebastian Hesselbarth
With proper mbus ranges and all internal nodes moved over, we can now switch from static address window allocation to DT probed allocation. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-29ARM: dove: remove custom .init_time hookSebastian Hesselbarth
With arch/arm calling of_clk_init(NULL) from time_init(), we can now remove custom .init_time hooks. While at it, also remove some obsolete includes. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Acked-by: Jason Cooper <jason@lakedaemon.net>
2013-09-06Merge tag 'boards-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC board updates from Olof Johansson: "Board updates for 3.12. Again, a bit of domain overlap with SoC and DT branches, but most of this is around legacy code and board support. We've found that platform maintainers have a hard time separating all of these out and might move towards fewer branches for next release. - Removal of a number of Marvell Kirkwood board files, since contents is now common and mostly configured via DT. - Device-tree updates for Marvell Dove, including irqchip and clocksource setup. - Defconfig updates. Gotta go somewhere. One new one for Renesas Lager. - New backlight drivers for backlights used on Renesas shmobile platforms. - Removal of Renesas leds driver. - Shuffling of some of the new Broadcom platforms to give room for others in the same mach directory. More in 3.13" * tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (67 commits) mmc: sdhci-bcm-kona: Staticize sdhci_bcm_kona_card_event mmc: sdhci-bcm-kona: Remove unneeded version.h inclusion ARM: bcm: Make secure API call optional ARM: DT: binding fixup to align with vendor-prefixes.txt (drivers) ARM: mmc: fix NONREMOVABLE test in sdhci-bcm-kona ARM: bcm: Rename board_bcm mmc: sdhci-bcm-kona: make linker-section warning go away ARM: tegra: defconfig updates ARM: dove: add initial DT file for Globalscale D2Plug ARM: dove: add GPIO IR receiver node to SolidRun CuBox ARM: dove: add common pinmux functions to DT ARM: dove: add cpu device tree node ARM: dove: update dove_defconfig with SI5351, PCI, and xHCI arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument ARM: kirkwood: fix DT building and update defconfig ARM: kirkwood: Remove all remaining trace of DNS-320/325 platform code ARM: configs: disable DEBUG_LL in bcm_defconfig ARM: bcm281xx: Board specific reboot code ARM bcm281xx: Turn on socket & network support. ARM: bcm281xx: Turn on L2 cache. ...
2013-09-06Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "This branch contains mostly additions and changes to platform enablement and SoC-level drivers. Since there's sometimes a dependency on device-tree changes, there's also a fair amount of those in this branch. Pieces worth mentioning are: - Mbus driver for Marvell platforms, allowing kernel configuration and resource allocation of on-chip peripherals. - Enablement of the mbus infrastructure from Marvell PCI-e drivers. - Preparation of MSI support for Marvell platforms. - Addition of new PCI-e host controller driver for Tegra platforms - Some churn caused by sharing of macro names between i.MX 6Q and 6DL platforms in the device tree sources and header files. - Various suspend/PM updates for Tegra, including LP1 support. - Versatile Express support for MCPM, part of big little support. - Allwinner platform support for A20 and A31 SoCs (dual and quad Cortex-A7) - OMAP2+ support for DRA7, a new Cortex-A15-based SoC. The code that touches other architectures are patches moving MSI arch-specific functions over to weak symbols and removal of ARCH_SUPPORTS_MSI, acked by PCI maintainers" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (266 commits) tegra-cpuidle: provide stub when !CONFIG_CPU_IDLE PCI: tegra: replace devm_request_and_ioremap by devm_ioremap_resource ARM: tegra: Drop ARCH_SUPPORTS_MSI and sort list ARM: dts: vf610-twr: enable i2c0 device ARM: dts: i.MX51: Add one more I2C2 pinmux entry ARM: dts: i.MX51: Move pins configuration under "iomuxc" label ARM: dtsi: imx6qdl-sabresd: Add USB OTG vbus pin to pinctrl_hog ARM: dtsi: imx6qdl-sabresd: Add USB host 1 VBUS regulator ARM: dts: imx27-phytec-phycore-som: Enable AUDMUX ARM: dts: i.MX27: Disable AUDMUX in the template ARM: dts: wandboard: Add support for SDIO bcm4329 ARM: i.MX5 clocks: Remove optional clock setup (CKIH1) from i.MX51 template ARM: dts: imx53-qsb: Make USBH1 functional ARM i.MX6Q: dts: Enable I2C1 with EEPROM and PMIC on Phytec phyFLEX-i.MX6 Ouad module ARM i.MX6Q: dts: Enable SPI NOR flash on Phytec phyFLEX-i.MX6 Ouad module ARM: dts: imx6qdl-sabresd: Add touchscreen support ARM: imx: add ocram clock for imx53 ARM: dts: imx: ocram size is different between imx6q and imx6dl ARM: dts: imx27-phytec-phycore-som: Fix regulator settings ARM: dts: i.MX27: Remove clock name from CPU node ...
2013-09-06Merge tag 'fixes-nc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC low-priority fixes from Olof Johansson: "This branch contains a handful of fixes for various platforms that weren't serious enough to be included in late 3.11-rc releases. Most of them are for minor cleanups and cosmetic fixes. There's also a bit of code removal here, one board file removal for clps711x, and removal of some legacy device creation on OMAP2+" * tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (25 commits) ARM: OMAP2: use 'int' instead of 'unsigned' for variable 'gpmc_irq_start' ARM: OMAP2: remove useless variable 'ret' ARM: OMAP: dma: fix error return code in omap_system_dma_probe() ARM: OMAP2+: fix wrong address when loading PRM_FRAC_INCREMENTOR_DENUMERATOR_RELOAD ARM: OMAP2+: am33xx-restart: trigger warm reset on omap2+ boards ARM: OMAP2: Use a consistent AM33XX SoC option description ARM: OMAP2+: Remove legacy device creation for McPDM and DMIC ARM: clps711x: edb7211: Remove extra iotable_init() call ARM: clps711x: autcpu12: Remove incorrect config checking ARM: clps711x: Drop fortunet board support ARM: clps711x: Remove the special name for the syscon driver ARM: dts: Fix memory node in skeleton64.dtsi ARM: Keystone: Convert device tree file to use IRQ defines ARM: keystone: use #include to include skeleton.dtsi ARM: keystone: Drop the un-necessary dsb from keystone_cpu_smc() ARM: Keystone: No need to preserve r12 across smc call ARM: keystone: remove redundant smp_init_cpus definition ARM: keystone: drop useless HAVE_SCHED_CLOCK ARM: dove: fix missing __init section of dove_mpp_gpio_mode ARM: shmobile: armadillo800eva-reference: fix compiler warning ...
2013-09-05Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "This set includes adding support for Neon acceleration of RAID6 XOR code from Ard Biesheuvel, cache flushing and barrier updates from Will Deacon, and a cleanup to the ARM debug code which reduces the amount of code by about 500 lines. A few other cleanups, such as constifying the machine descriptors which already shouldn't be written to, cleaning up the printing of the L2 cache size" * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (55 commits) ARM: 7826/1: debug: support debug ll on hisilicon soc ARM: 7830/1: delay: don't bother reporting bogomips in /proc/cpuinfo ARM: 7829/1: Add ".text.unlikely" and ".text.hot" to arm unwind tables ARM: 7828/1: ARMv7-M: implement restart routine common to all v7-M machines ARM: 7827/1: highbank: fix debug uart virtual address for LPAE ARM: 7823/1: errata: workaround Cortex-A15 erratum 773022 ARM: 7806/1: allow DEBUG_UNCOMPRESS for Tegra ARM: 7793/1: debug: use generic option for ep93xx PL10x debug port ARM: debug: move SPEAr debug to generic PL01x code ARM: debug: move davinci debug to generic 8250 code ARM: debug: move keystone debug to generic 8250 code ARM: debug: remove DEBUG_ROCKCHIP_UART ARM: debug: provide generic option choices for 8250 and PL01x ports ARM: debug: move PL01X debug include into arch/arm/include/debug/ ARM: debug: provide PL01x debug uart phys/virt address configuration options ARM: debug: add support for word accesses to debug/8250.S ARM: debug: move 8250 debug include into arch/arm/include/debug/ ARM: debug: provide 8250 debug uart phys/virt address configuration options ARM: debug: provide 8250 debug uart register shift configuration option ARM: debug: provide 8250 debug uart flow control configuration option ...
2013-08-25ARM: debug: move 8250 debug include into arch/arm/include/debug/Russell King
Now that the 8250 debug include can stand alone without requiring platforms to provide any macros, move it into the debug directory so it can be directly included. This allows us to get rid of a lot of debug-macros include files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: provide 8250 debug uart phys/virt address configuration optionsRussell King
Move the definition of the UART register addresses out of the platform specific header file into the Kconfig files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: provide 8250 debug uart register shift configuration optionRussell King
Move the definition of the UART register shift out of the platform specific header file into the Kconfig files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-06ARM: dove: Move to ID based window creationThomas Petazzoni
With the introduction of the ID based MBus API, it's better to switch to use it instead of the current name based scheme. This will allow to deprecate the name based API, once every user is removed. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-05ASoC: kirkwood: combine kirkwood-i2s and kirkwood-dma driversRussell King
These really should be a single driver because they're fully integrated in hardware. Make them so. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-25ARM: dove: convert to DT irqchip and clocksourceSebastian Hesselbarth
With recent support for true irqchip and clocksource drivers for Orion SoCs, now make use of it on DT enabled Dove boards. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-07-25ARM: dove: remove legacy mv643xx_eth setupSebastian Hesselbarth
With DT support for mv643xx_eth we do not need legacy platform_data based setup for DT enabled boards anymore. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-07-25ARM: dove: fix missing __init section of dove_mpp_gpio_modeSebastian Hesselbarth
Legacy dove_mpp_gpio_mode calls orion_gpio_set_valid which is in __init section. Offending function is not, so this causes a section mismatch. To fix the mismatch, also move dove_mpp_gpio_mode to __init section. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-07-11Watchdog: allow orion_wdt to be built for DoveRussell King
The watchdog infrastructure in Dove is no different from that in Orion5x or Kirkwood, so let's enable it for Dove. The only things missing are a few register settings in Dove's bridge-regs.h. Rather than duplicating the same register bit masks for the RSTOUTn_MASK and BRIDGE_CAUSE registers, move the definitions into the watchdog driver itself. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Jason Cooper <jason@lakedaemon.net> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-29ARM: dove: move DT boards to SoC-centric clock initSebastian Hesselbarth
SoC centric clock init for Dove can be used by calling of_clk_init. Use it and get rid of mvebu_clocks_init. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-15arm: mach-dove: convert to use mvebu-mbus driverThomas Petazzoni
This commit migrates the mach-dove platforms to use the mvebu-mbus driver and therefore removes the Dove-specific addr-map code. The dove_init_early() function now initializes the mvebu-mbus driver by calling mvebu_mbus_init(). The address decoding windows are now registered in the dove_setup_cpu_wins() function. It is worth noting that the four PCIe address decoding windows will ultimately no longer have to be registered here: it will be done automatically by the PCIe driver once Dove has been migrated to use the upcoming mvebu PCIe driver. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28Merge tag 'late-mvebu-rebased' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC mvebu platform changes from Olof Johansson: "This series contains changes for the Marvell EBU platforms (mvebu, orion, kirkwood, dove) that were not part of the first set of pull requests because of dependencies on the MMC tree, and being submitted a little late. Notable changes are: - More devices get moved out of board files into device tree descriptions. The remaining devices listed in there have patches that will get sent for 3.10, after which we can remove a lot of the board files entirely. We are doing the pinctrl and mmc drivers here, ethernet and PCI still remain. - SMP support for mvebu is improved with support for the local interrupt controller. - The Guruplug board file gets replaced with a DT description. Unfortunately, the dependency on the MMC tree turned out to be a much larger problem than expected, when the MMC maintainer rebased the patches in his tree that all of the patches in this branch are based on, which caused merge conflicts between the new and old versions of those patches. To work around the merge conflicts, this branch rebases all patches on top of the respective MMC patches that did get merged into 3.9. The patches are all identical to the versions that were part of linux-next, but have a new commit date." * tag 'late-mvebu-rebased' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (90 commits) arm: mvebu: enable the SD card slot on Armada 370 Reference Design board ARM: kirkwood: topkick: init mvsdio via DT ARM: kirkwood: nsa310: convert to pinctrl ARM: Kirkwood: topkick: Enable i2c bus. ARM: kirkwood: topkick: convert to pinctrl ARM: dove: convert serial DT nodes to clocks property arm: mvebu: Add SPI flash on Armada 370 DB board arm: mvebu: Add SPI flash on Armada XP-DB board arm: mvebu: Add SPI flash on Armada XP-GP board arm: mvebu: Add support for SPI controller in Armada 370/XP clocksource: update and move armada-370-xp-timer documentation to timer directory arm: mvebu: update DT to support local timers ARM: Dove: convert usb host controller to DT arm: mvebu: Enable USB controllers on Armada 370/XP boards arm: mvebu: Add support for USB host controllers in Armada 370/XP arm: mvebu: add button for OpenBlocks AX3-4 ARM: Kirkwood: Convert NS2 to gpio-poweroff. ARM: Kirkwood: Convert NSA310 I2C to device tree ARM: Kirkwood: Convert NSA310 to use gpio-poweroff driver ARM: Kirkwood: Convert NSA310 to DT based regulators. ...
2013-02-28ARM: Dove: convert usb host controller to DTSebastian Hesselbarth
With DT support for orion-ehci also convert Dove to it and remove the legacy calls and clock aliases. This patch is based on "ARM: Dove: split legacy and DT setup" applied to mvebu/boards recently. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28ARM: Dove: add fixed regulator for CuBox USB powerSebastian Hesselbarth
CuBox needs to enable USB power on a gpio pin. Add a fixed regulator to always enable usb power on boot. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28ARM: Dove: split legacy and DT setupArnd Bergmann
In the beginning of DT for Dove it was reasonable to have it close to non-DT code. With improved DT support, it became more and more difficult to not break non-DT while changing DT code. This patch splits up DT board setup and introduces a DOVE_LEGACY config to allow to remove legacy code for DT-only kernels. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28Merge branch 'timer/cleanup' into late/mvebu2Arnd Bergmann
Basing the mvebu patches on top of the timer cleanup avoids some nasty merges. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-31Merge tag 'tags/cleanup_for_v3.9_round2' into mvebu/boardsJason Cooper
cleanup for v3.9 round2 - remove unneeded #includes for mach-dove - remove unneeded #includes and code for the nsa310
2013-01-31ARM: dove: cleanup includesSebastian Hesselbarth
This patch cleans unneccessary includes and reorders the remaining includes in common dove code. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-01-29Merge tag 'cleanup_for_v3.9_round2' of ↵Olof Johansson
git://git.infradead.org/users/jcooper/linux into next/cleanup From Jason Cooper: cleanup for v3.9 round2 - remove unneeded #includes for mach-dove - remove unneeded #includes and code for the nsa310 * tag 'cleanup_for_v3.9_round2' of git://git.infradead.org/users/jcooper/linux: ARM: dove: cleanup includes ARM: kirkwood: nsa310: cleanup includes and unneeded code
2013-01-29ARM: dove: cleanup includesSebastian Hesselbarth
2013-01-14Merge branch 'clocksource/cleanup' into next/cleanupOlof Johansson
Clockevent cleanup series from Shawn Guo. Resolved move/change conflict in mach-pxa/time.c due to the sys_timer cleanup. * clocksource/cleanup: clocksource: use clockevents_config_and_register() where possible ARM: use clockevents_config_and_register() where possible clockevents: export clockevents_config_and_register for module use + sync to Linux 3.8-rc3 Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-pxa/time.c
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2013-01-03ARM: drivers: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-12-14Merge tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC updates for Marvell mvebu/kirkwood from Olof Johansson: "This is a branch with updates for Marvell's mvebu/kirkwood platforms. They came in late-ish, and were heavily interdependent such that it didn't make sense to split them up across the cross-platform topic branches. So here they are (for the second release in a row) in a branch on their own." * tag 'mvebu' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (88 commits) arm: l2x0: add aurora related properties to OF binding arm: mvebu: add Aurora L2 Cache Controller to the DT arm: mvebu: add L2 cache support dma: mv_xor: fix error handling path dma: mv_xor: fix error checking of irq_of_parse_and_map() dma: mv_xor: use request_irq() instead of devm_request_irq() dma: mv_xor: clear the window override control registers arm: mvebu: fix address decoding armada_cfg_base() function ARM: mvebu: update defconfig with I2C and RTC support ARM: mvebu: Add SATA support for OpenBlocks AX3-4 ARM: mvebu: Add support for the RTC in OpenBlocks AX3-4 ARM: mvebu: Add support for I2C on OpenBlocks AX3-4 ARM: mvebu: Add support for I2C controllers in Armada 370/XP arm: mvebu: Add hardware I/O Coherency support arm: plat-orion: Add coherency attribute when setup mbus target arm: dma mapping: Export a dma ops function arm_dma_set_mask arm: mvebu: Add SMP support for Armada XP arm: mm: Add support for PJ4B cpu and init routines arm: mvebu: Add IPI support via doorbells arm: mvebu: Add initial support for power managmement service unit ...
2012-11-21Dove: Fix irq_to_pmu()Russell King - ARM Linux
PMU interrupts start at IRQ_DOVE_PMU_START, not IRQ_DOVE_PMU_START + 1. Fix the condition. (It may have been less likely to occur had the code been written "if (irq >= IRQ_DOVE_PMU_START" which imho is the easier to understand notation, and matches the normal way of thinking about these things.) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: stable@vger.kernel.org Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-21Dove: Attempt to fix PMU/RTC interruptsRussell King - ARM Linux
Fix the acknowledgement of PMU interrupts on Dove: some Dove hardware has not been sensibly designed so that interrupts can be handled in a race free manner. The PMU is one such instance. The pending (aka 'cause') register is a bunch of RW bits, meaning that these bits can be both cleared and set by software (confirmed on the Armada-510 on the cubox.) Hardware sets the appropriate bit when an interrupt is asserted, and software is required to clear the bits which are to be processed. If we write ~(1 << bit), then we end up asserting every other interrupt except the one we're processing. So, we need to do a read-modify-write cycle to clear the asserted bit. However, any interrupts which occur in the middle of this cycle will also be written back as zero, which will also clear the new interrupts. The upshot of this is: there is _no_ way to safely clear down interrupts in this register (and other similarly behaving interrupt pending registers on this device.) The patch below at least stops us creating new interrupts. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: stable@vger.kernel.org Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-20arm: dove: Convert Dove to DT XOR DMA engineSebastian Hesselbarth
With DT support for Marvell XOR DMA engine, make use of it on Dove. Also remove the now redundant code in DT board init for xor engines. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20dma: mv_xor: change the driver name to 'mv_xor'Thomas Petazzoni
Since we got rid of the per-XOR channel 'mv_xor' driver, now the per-XOR engine driver that used to be called 'mv_xor_shared' can simply be named 'mv_xor'. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20ARM: dove: switch to DT clock providersSebastian Hesselbarth
With true DT clock providers available switch Dove clock setup in DT- enabled boards. While AUXDATA can be removed completely from bus probing, some devices still don't know about DT at all. Therefore, some clock aliases are created until the devices also move to DT. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
2012-10-17ARM: dove: Add crypto engine to DTSebastian Hesselbarth
Make use of DT support for the crypto engine on dove and remove the obsolete init call. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-10-17ARM: dove: Fix clock names of sata and gbeSebastian Hesselbarth
This patch fixes wrong clock names of lately added clock gates for sata and gbe (mv64xx_eth). Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
