path: root/arch/arm/mach-ep93xx/micro9.c
2013-01-14Merge tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux ↵Olof Johansson
into next/cleanup From Rob Herring: Initial irqchip init infrastructure and GIC and VIC clean-ups This creates irqchip initialization infrastructure from Thomas Petazzoni. The VIC and GIC irqchip code is moved to drivers/irqchips and adapted to use the new infrastructure. All DT enabled platforms using GIC and VIC are converted over to use the new irqchip_init. * tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux: irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.h ARM: picoxcell: use common irqchip_init function ARM: spear: use common irqchip_init function irqchip: Move ARM VIC to drivers/irqchip ARM: samsung: remove unused tick.h ARM: remove unneeded vic.h includes ARM: remove mach .handle_irq for VIC users ARM: VIC: set handle_arch_irq in VIC initialization ARM: VIC: shrink down vic.h irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.h ARM: use common irqchip_init for GIC init irqchip: Move ARM GIC to drivers/irqchip ARM: remove mach .handle_irq for GIC users ARM: GIC: set handle_arch_irq in GIC initialization ARM: GIC: remove direct use of gic_raise_softirq ARM: GIC: remove assembly ifdefs from gic.h ARM: mach-ux500: use SGI0 to wake up the other core arm: add set_handle_irq() to register the parent IRQ controller handler function irqchip: add basic infrastructure irqchip: add to the directories part of the IRQ subsystem in MAINTAINERS Fixed up massive merge conflicts with the timer cleanup due to adjacent changes: Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-bcm/board_bcm.c arch/arm/mach-cns3xxx/cns3420vb.c arch/arm/mach-ep93xx/adssphere.c arch/arm/mach-ep93xx/edb93xx.c arch/arm/mach-ep93xx/gesbc9312.c arch/arm/mach-ep93xx/micro9.c arch/arm/mach-ep93xx/simone.c arch/arm/mach-ep93xx/snappercl15.c arch/arm/mach-ep93xx/ts72xx.c arch/arm/mach-ep93xx/vision_ep9307.c arch/arm/mach-highbank/highbank.c arch/arm/mach-imx/mach-imx6q.c arch/arm/mach-msm/board-dt-8960.c arch/arm/mach-netx/nxdb500.c arch/arm/mach-netx/nxdkn.c arch/arm/mach-netx/nxeb500hmi.c arch/arm/mach-nomadik/board-nhk8815.c arch/arm/mach-picoxcell/common.c arch/arm/mach-realview/realview_eb.c arch/arm/mach-realview/realview_pb1176.c arch/arm/mach-realview/realview_pb11mp.c arch/arm/mach-realview/realview_pba8.c arch/arm/mach-realview/realview_pbx.c arch/arm/mach-socfpga/socfpga.c arch/arm/mach-spear13xx/spear1310.c arch/arm/mach-spear13xx/spear1340.c arch/arm/mach-spear13xx/spear13xx.c arch/arm/mach-spear3xx/spear300.c arch/arm/mach-spear3xx/spear310.c arch/arm/mach-spear3xx/spear320.c arch/arm/mach-spear3xx/spear3xx.c arch/arm/mach-spear6xx/spear6xx.c arch/arm/mach-tegra/board-dt-tegra20.c arch/arm/mach-tegra/board-dt-tegra30.c arch/arm/mach-u300/core.c arch/arm/mach-ux500/board-mop500.c arch/arm/mach-ux500/cpu-db8500.c arch/arm/mach-versatile/versatile_ab.c arch/arm/mach-versatile/versatile_dt.c arch/arm/mach-versatile/versatile_pb.c arch/arm/mach-vexpress/v2m.c include/asm-generic/vmlinux.lds.h
2013-01-12ARM: remove unneeded vic.h includesRob Herring
Numerous includes of asm/hardware/vic.h aren't needed, so remove them. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Hubert Feurstein <hubert.feurstein@contec.at> Cc: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Acked-By: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: linux-samsung-soc@vger.kernel.org Cc: patches@opensource.wolfsonmicro.com Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-01-12ARM: remove mach .handle_irq for VIC usersRob Herring
Now that the VIC initialization sets up the handle_arch_irq pointer, we can remove it for all machines and make it static. Move vic_handle_irq to avoid a forward declaration. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Hubert Feurstein <hubert.feurstein@contec.at> Cc: Alessandro Rubini <rubini@unipv.it> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Rajeev Kumar <rajeev-dlh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-05-05ARM: ep93xx: use machine specific hook for late initShawn Guo
Cc: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
2012-03-14ep93xx: Move PHYS_BASE defines to local SoC header fileRyan Mallon
The PHYS_BASE defines in arch/arm/mach-ep93xx/include/mach-ep93xx-regs.h are only used in the SoC code. Move the defines to a local header file. Signed-off-by: Ryan Mallon <rmallon@gmail.com> Reviewed-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Hartley Sweeten <hsweeten@visionengravers.com>
2012-01-05Merge branch 'restart' into for-linusRussell King
Conflicts: arch/arm/mach-exynos/cpu.c The changes to arch/arm/mach-exynos/cpu.c were moved to mach-exynos/common.c.
2012-01-05ARM: restart: ep93xx: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-15ARM: ep93xx: convert to MULTI_IRQ_HANDLERJamie Iles
Now that there is a generic IRQ handler for multiple VIC devices use it for ep93xx to help building multi platform kernels. Cc: Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com>
2011-08-21ARM: mach-ep93xx: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Petr Štetiar <ynezz@true.cz> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-06-16ARM: 6168/1: ep93xx: move physmap flash registration into core.cHartley Sweeten
Create a core.c __init function to handle the physmap flash registration for all the ep93xx platforms. Also, modify all the ep93xx platforms to use this new function. This simplifies all the ep93xx platform init code and reduces the size of the kernel when including multiple ep93xx boards. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: Martin Guy <martinwguy@gmail.com> Acked-by: Hubert Feurstein <hubert.feurstein@contec.at> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-14ARM: 5992/1: ep93xx: pass platform startup data as __initdataHartley Sweeten
A number of the peripherals for the ep93xx are registered at startup using platform_data that is passed from the board init code to the core code. This data is then copied to a local static variable in the core code. Since the data is copied, the original data can be marked as __initdata and discarded after startup is complete. This adds the __initdata tag to all the appropriate data in the various ep93xx board init's. Specifically, all the struct ep93xx_eth_data, struct ep93xxfb_mach_info, and struct i2c_gpio_platform_data. Also, document the various registration functions and note what data should be marked as __initdata. While here, also cleanup a couple over zealous whitespace tabs. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-05ARM: 5779/1: ep93xx/micro9.c: fix implicit declaration of function ↵Jean-Christop PLAGNIOL-VILLARD
__raw_readl and IOMEM Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-07ARM: 5751/1: ep93xx/micro9: Add Micro9-SlimHubert Feurstein
Add Contec Micro9-Slim support Cc: Ryan Mallon <ryan@bluewatersys.com> Requires: 5750/1 Signed-off-by: Hubert Feurstein <hubert.feurstein@contec.at> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-07ARM: 5750/1: ep93xx/micro9: Update platform codeHubert Feurstein
Update Contec Micro9 platform code Cc: Ryan Mallon <ryan@bluewatersys.com> Requires: 5749/1 Signed-off-by: Hubert Feurstein <hubert.feurstein@contec.at> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-10-07ARM: 5749/1: ep93xx/micro9: Update maintainerHubert Feurstein
Update Contec Micro9 maintainer and add entry in MAINTAINERS Cc: Ryan Mallon <ryan@bluewatersys.com> Requires: 5744/1 Signed-off-by: Hubert Feurstein <hubert.feurstein@contec.at> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Manfred Gruber <m.gruber@tirol.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-09[ARM] 5592/1: ep93xx: cleanup platform header includesHartley Sweeten
arch/arm/mach-ep93xx/include/mach/hardware.h 1. Properly name the include files so that they are loaded from the <mach/*> directory and not the local directory. 2. Remove including the ts72xx.h header. This header is not generic to the ep93xx platform. It should only be included by the ts72xx specific files that require it. The only two users in the tree are arch/arm/mach-ep93xx/ts72xx.c and drivers/mtd/nand/ts7250.c. arch/arm/mach-ep93xx/include/mach/ts72xx.h 1. <linux/io.h> should already be included by any user of this header. Doing the include here hides it from being needed by the calling source file. arch/arm/mach-ep93xx/core.c 1. Remove unnecessary headers. They were probably included originally due to cut-and-paste from other files. 2. <linux/io.h> should be included not <mach/gpio.h> arch/arm/mach-ep93xx/adsphere.c arch/arm/mach-ep93xx/edb93xx.c arch/arm/mach-ep93xx/gesbc9312.c arch/arm/mach-ep93xx/micro9.c arch/arm/mach-ep93xx/ts72xx.c 1. Remove unnecessary headers. arch/arm/mach-ep93xx/ts72xx.c 1. Remove unnecessary headers. 2. Add platform specific header <mach/ts72xx.h>. drivers/mtd/nand/ts7250.c 1. <linux/io.h> should be included not <asm/io.h>. 2. Add platform specific header <mach/ts72xx.h>. Cc: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-13[ARM] 5343/1: ep93xx: include linux/i2c.hHartley Sweeten
Include <linux/i2c.h> in all ep93xx platforms. Patch "5311/1: add core support for built in i2c bus" will cause build errors due to the following in arch/arm/mach-ep93xx/include/mach/platform.h: +void ep93xx_register_i2c(struct i2c_board_info *devices, int num); The i2c.h header needs to be included in order to define struct i2c_board_info. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-13[ARM] 5342/1: ep93xx: platform init cleanupHartley Sweeten
Use EP93XX_*_PHYS_BASE and SZ_* defines in ep93xx platform inits. The following patch changes the flash memory hard-coded resource addresses and MACHINE_START boot_params to EP93XX_*_PHYS_BASE and SZ_* defines to improve readability. Also some minor whitespace cleanup resulting from previous patches. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09Merge branches 'machtypes', 'core', 'ep93xx', 'ks8695', 'netdev' and ↵Russell King
'sa1100' into devel
2008-10-04[ARM] 5273/2: ep93xx: move ethernet support into core.cHartley Sweeten
All EP93xx based systems can support Ethernet. This patch moves the platform_device setup from the various board support files into the core support file. The Ethernet driver data still remains in the individual platform setup files to allow specific platform configuration. This also adds Ethernet support to the edb9302, edb9312, and edb9315 platforms. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-06[ARM] 4047/1: Add initial board support for Contec Hypercontrol Micro9 boards.Manfred Gruber
Contec Micro9 (H/M/L) boards based on Cirrus Logic ep93xx (ep9315/ep9307/ep9302). Signed-off-by: Manfred Gruber <m.gruber@tirol.com> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
