path: root/arch/arm/mach-ep93xx/ts72xx.c
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-06-16ARM: 6168/1: ep93xx: move physmap flash registration into core.cHartley Sweeten
Create a core.c __init function to handle the physmap flash registration for all the ep93xx platforms. Also, modify all the ep93xx platforms to use this new function. This simplifies all the ep93xx platform init code and reduces the size of the kernel when including multiple ep93xx boards. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: Martin Guy <martinwguy@gmail.com> Acked-by: Hubert Feurstein <hubert.feurstein@contec.at> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-21Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (154 commits) mtd: cfi_cmdset_0002: use AMD standard command-set with Winbond flash chips mtd: cfi_cmdset_0002: Fix MODULE_ALIAS and linkage for new 0701 commandset ID mtd: mxc_nand: Remove duplicate NAND_CMD_RESET case value mtd: update gfp/slab.h includes jffs2: Stop triggering block erases from jffs2_write_super() jffs2: Rename jffs2_erase_pending_trigger() to jffs2_dirty_trigger() jffs2: Use jffs2_garbage_collect_trigger() to trigger pending erases jffs2: Require jffs2_garbage_collect_trigger() to be called with lock held jffs2: Wake GC thread when there are blocks to be erased jffs2: Erase pending blocks in GC pass, avoid invalid -EIO return jffs2: Add 'work_done' return value from jffs2_erase_pending_blocks() mtd: mtdchar: Do not corrupt backing device of device node inode mtd/maps/pcmciamtd: Fix printk format for ssize_t in debug messages drivers/mtd: Use kmemdup mtd: cfi_cmdset_0002: Fix argument order in bootloc warning mtd: nand: add Toshiba TC58NVG0 device ID pcmciamtd: add another ID pcmciamtd: coding style cleanups pcmciamtd: fixing obvious errors mtd: chips: add SST39WF160x NOR-flashes ... Trivial conflicts due to dev_node removal in drivers/mtd/maps/pcmciamtd.c
2010-04-14ARM: 5992/1: ep93xx: pass platform startup data as __initdataHartley Sweeten
A number of the peripherals for the ep93xx are registered at startup using platform_data that is passed from the board init code to the core code. This data is then copied to a local static variable in the core code. Since the data is copied, the original data can be marked as __initdata and discarded after startup is complete. This adds the __initdata tag to all the appropriate data in the various ep93xx board init's. Specifically, all the struct ep93xx_eth_data, struct ep93xxfb_mach_info, and struct i2c_gpio_platform_data. Also, document the various registration functions and note what data should be marked as __initdata. While here, also cleanup a couple over zealous whitespace tabs. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-26Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/nand/sh_flctl.c Maxim's patch to initialise sysfs attributes depends on the patch which actually adds sysfs_attr_init().
2010-03-06[WATCHDOG] ep93xx: added platform side support for TS-72xx WDT driverMika Westerberg
Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-01-06mtd: Update ep93xx/ts72xx to use generic platform nand driverH Hartley Sweeten
Update the ts72xx platform's nand driver support. This changes the ts72xx platform from using a custom nand driver (ts7250.c) to the generic platform nand driver (plat_nand.c). Tested on TS-7250 with 32MiB NAND. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: Matthieu Crapet <mcrapet@gmail.com> Cc: Jesse Off <joff@embeddedARM.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-12Merge branch 'master' into develRussell King
2009-07-23[ARM] 5611/1: ep93xx: update ts72xx nor flash supportHartley Sweeten
Update the NOR flash support for TS-7200. The TS-7200 models all have 16-bit NOR flash. Update the platform init to support this. Remove the private TS72XX_NOR_* defines and use the common ep93xx defines for the external chip select physical base address instead. Move the NOR flash registration into a static __init function. When the NAND flash support is updated this function will also be used to register the NAND flash for the TS-7250 and TS-7260. Tested-by: Matthieu Crapet <mcrapet@gmail.com> Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-09[ARM] 5592/1: ep93xx: cleanup platform header includesHartley Sweeten
arch/arm/mach-ep93xx/include/mach/hardware.h 1. Properly name the include files so that they are loaded from the <mach/*> directory and not the local directory. 2. Remove including the ts72xx.h header. This header is not generic to the ep93xx platform. It should only be included by the ts72xx specific files that require it. The only two users in the tree are arch/arm/mach-ep93xx/ts72xx.c and drivers/mtd/nand/ts7250.c. arch/arm/mach-ep93xx/include/mach/ts72xx.h 1. <linux/io.h> should already be included by any user of this header. Doing the include here hides it from being needed by the calling source file. arch/arm/mach-ep93xx/core.c 1. Remove unnecessary headers. They were probably included originally due to cut-and-paste from other files. 2. <linux/io.h> should be included not <mach/gpio.h> arch/arm/mach-ep93xx/adsphere.c arch/arm/mach-ep93xx/edb93xx.c arch/arm/mach-ep93xx/gesbc9312.c arch/arm/mach-ep93xx/micro9.c arch/arm/mach-ep93xx/ts72xx.c 1. Remove unnecessary headers. arch/arm/mach-ep93xx/ts72xx.c 1. Remove unnecessary headers. 2. Add platform specific header <mach/ts72xx.h>. drivers/mtd/nand/ts7250.c 1. <linux/io.h> should be included not <asm/io.h>. 2. Add platform specific header <mach/ts72xx.h>. Cc: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-13[ARM] 5343/1: ep93xx: include linux/i2c.hHartley Sweeten
Include <linux/i2c.h> in all ep93xx platforms. Patch "5311/1: add core support for built in i2c bus" will cause build errors due to the following in arch/arm/mach-ep93xx/include/mach/platform.h: +void ep93xx_register_i2c(struct i2c_board_info *devices, int num); The i2c.h header needs to be included in order to define struct i2c_board_info. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-13[ARM] 5342/1: ep93xx: platform init cleanupHartley Sweeten
Use EP93XX_*_PHYS_BASE and SZ_* defines in ep93xx platform inits. The following patch changes the flash memory hard-coded resource addresses and MACHINE_START boot_params to EP93XX_*_PHYS_BASE and SZ_* defines to improve readability. Also some minor whitespace cleanup resulting from previous patches. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-10-09Merge branches 'machtypes', 'core', 'ep93xx', 'ks8695', 'netdev' and ↵Russell King
'sa1100' into devel
2008-10-04[ARM] 5273/2: ep93xx: move ethernet support into core.cHartley Sweeten
All EP93xx based systems can support Ethernet. This patch moves the platform_device setup from the various board support files into the core support file. The Ethernet driver data still remains in the individual platform setup files to allow specific platform configuration. This also adds Ethernet support to the edb9302, edb9312, and edb9315 platforms. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-30[ARM] 3879/1: ep93xx: instantiate platform devices for ep93xx ethernetLennert Buytenhek
Instantiate platform devices for the ep93xx ethernet driver in a couple of ep93xx board support files. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-28[ARM] 3663/1: fix resource->end off-by-one thinko during physmap conversionLennert Buytenhek
Patch from Lennert Buytenhek Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-22[ARM] 3614/1: ep93xx: use platform devices for physmap flashLennert Buytenhek
Patch from Lennert Buytenhek Now that the physmap platform device rewrite is in, make the ep93xx boards use platform devices for physmap flash. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-08[PATCH] ep93xx build fixLennert Buytenhek
From: Lennert Buytenhek <buytenh@wantstofly.org> The recent renaming of m48t86's ->readb() and ->writeb() platform driver methods (2d7b20c1884777e66009be1a533641c19c4705f6) to ->readbyte() and ->writebyte() to fix the ia64 build broke the build of the cirrus ep93xx ARM platform. This patch fixes it up. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02[ARM] 3451/1: ep93xx: use the m48t86 rtc driver on the ts72xx platformLennert Buytenhek
Patch from Lennert Buytenhek Instantiate the recently merged m48t86 rtc driver in the ts72xx code. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] 3369/1: ep93xx: add core cirrus ep93xx supportLennert Buytenhek
Patch from Lennert Buytenhek This patch adds support for the Cirrus ep93xx series of CPUs. The ep93xx is an ARM920T based CPU with two VICs, PL010 based UARTs, IrDA, MaverickCrunch floating point coprocessor, between 24 and 64 GPIOs, ethernet, OHCI USB and, depending on the model, pcmcia, raster engine, graphics accelerator, IDE controller and a bunch of other stuff. This patch adds the core ep93xx support code, and support for the Glomation GESBC-9312-sx and the Technologic Systems TS-72xx SBCs. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
