path: root/arch/arm/mach-ep93xx
2011-08-15ARM: 6967/1: ep93xx: ts72xx: fix board model detectionPetr Štetiar
Fix the obvious error in board detection logic, because according to the TS's manual, the model is stored in the least three significant bits. For example the byte read on my ts-7300 is 0x23 and the detection then fails. Cc: Ryan Mallon <ryan@bluewatersys.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Petr Štetiar <ynezz@true.cz> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-15ARM: 6965/1: ep93xx: add model detection for ts-7300 and ts-7400 boardsPetr Štetiar
2011-07-26Merge branch 'next/cross-platform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: Consolidate the clkdev header files ARM: set vga memory base at run-time ARM: convert PCI defines to variables ARM: pci: make pcibios_assign_all_busses use pci_has_flag ARM: remove unnecessary mach/hardware.h includes pci: move microblaze and powerpc pci flag functions into asm-generic powerpc: rename ppc_pci_*_flags to pci_*_flags Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-22Merge branch 'spi/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6: (34 commits) spi/imx: add device tree probe support spi/imx: copy gpio number passed by platform data into driver private data spi/imx: use soc name in spi device type naming scheme spi/imx: merge type SPI_IMX_VER_0_7 into SPI_IMX_VER_0_4 spi/imx: do not use spi_imx2_3 to name SPI_IMX_VER_2_3 function and macro spi/imx: use mx21 to name SPI_IMX_VER_0_0 function and macro spi/imx: do not make copy of spi_imx_devtype_data spi/dw: Add spi number into spi irq desc spi/tegra: Use engineering names in DT compatible property spi/fsl_spi: fix CPM spi driver mach-s3c2410: remove unused spi-gpio.h file spi: remove obsolete spi-s3c24xx-gpio driver mach-gta2: remove unused spi-gpio.h include mach-qt2410: convert to spi_gpio mach-jive: convert to spi_gpio spi/pxa2xx: Remove unavailable ssp_type from documentation spi/bfin_spi: uninline fat queue funcs spi/bfin_spi: constify pin array spi/bfin_spi: use structs for accessing hardware regs spi/topcliff-pch: Support new device ML7223 IOH ... Fix up trivial conflict in arch/arm/mach-ep93xx/Makefile
2011-07-22Merge branch 'gpio/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6: (61 commits) gpio/mxc/mxs: fix build error introduced by the irq_gc_ack() renaming mcp23s08: add i2c support mcp23s08: isolate spi specific parts mcp23s08: get rid of setup/teardown callbacks gpio/tegra: dt: add binding for gpio polarity mcp23s08: remove unused work queue gpio/da9052: remove a redundant assignment for gpio->da9052 gpio/mxc: add device tree probe support ARM: mxc: use ARCH_NR_GPIOS to define gpio number gpio/mxc: get rid of the uses of cpu_is_mx() gpio/mxc: add missing initialization of basic_mmio_gpio shadow variables gpio: Move mpc5200 gpio driver to drivers/gpio GPIO: DA9052 GPIO module v3 gpio/tegra: Use engineering names in DT compatible property of/gpio: Add new method for getting gpios under different property names gpio/dt: Refine GPIO device tree binding gpio/ml-ioh: fix off-by-one for displaying variable i in dev_err gpio/pca953x: Deprecate meaningless device-tree bindings gpio/pca953x: Remove dynamic platform data pointer gpio/pca953x: Fix IRQ support. ...
2011-07-19Merge branch 'cross-platform/clkdev' into next/cross-platformArnd Bergmann
2011-07-19ARM: Consolidate the clkdev header filesKyungmin Park
Now most of ARM machines has the alsmot same __clk_get/put() macro So place it at the arch/arm/include/asm/clkdev.h and remove the reduntant header files But some machines don't have the same form as above. It can use the machince specific clkdev file by HAVE_MACH_CLKDEV config Now there are only 3 caese. 1) define the clk structure with clkdev macro => Need to move clk structure to proper header file arch/arm/mach-versatile/include/mach/clkdev.h arch/arm/mach-realview/include/mach/clkdev.h arch/arm/mach-vexpress/include/mach/clkdev.h arch/arm/mach-integrator/include/mach/clkdev.h 2) export the __clk_get/put function at clock.c arch/arm/mach-shmobile/include/mach/clkdev.h 3) demuxing the clk source arch/arm/mach-u300/include/mach/clkdev.h Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-07-12ARM: pci: make pcibios_assign_all_busses use pci_has_flagRob Herring
Convert pcibios_assign_all_busses from a define to inline so platforms can control this setting. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-11Merge branch 'master' into for-nextJiri Kosina
Sync with Linus' tree to be able to apply pending patches that are based on newer code already present upstream.
2011-07-06ARM: 6966/1: ep93xx: fix inverted RTS/DTR signals on uart1Petr Štetiar
It was discovered by Roberto Bergo, that RTS/DTR signals are inverted after the boot, because it was causing him problems with hardware controlled modem connected on ttyAM0. Todd Valentic came with this patch for the issue. Discussion: http://tech.groups.yahoo.com/group/ts-7000/message/20259 Comments from Petr Štetiar: Sorry, but forget to add Acked-by[1]: 1. https://patchwork.kernel.org/patch/873052/ Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Todd Valentic <todd.valentic@sri.com> Tested-by: Roberto Bergo <roberto.bergo@robson.it> Signed-off-by: Petr Štetiar <ynezz@true.cz> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-17Merge branch 'spi/merge' into spi/nextGrant Likely
2011-06-16Change Ryan Mallon's email address across the kernelRyan Mallon
I no longer work at Bluewater Systems. Update my email address accordingly. I have deleted my email address from C files rather than change it. This was suggested by several people, since the commit from my new email address will cause scripts/get_maintainer.pl to function properly. I have not added the .mailmap entry as suggested by Joe because I think it is no longer necessary if I touch all the files which had my name in them. Signed-off-by: Ryan Mallon <rmallon@gmail.com> Cc: Andre Renaud <andre@bluewatersys.com> Cc: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Andrew Victor <avictor.za@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Anton Vorontsov <cbou@mail.ru> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Liam Girdwood <lrg@ti.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Joe Perches <joe@perches.com> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: trivial@kernel.org Cc: linux-kernel@vger.kernel.org Reviewed-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-15Merge branch 'gpio/next-tegra' into gpio/nextGrant Likely
Conflicts: drivers/gpio/Kconfig drivers/gpio/Makefile
2011-06-11ep93xx: set DMA masks for the ep93xx_ethMika Westerberg
Since the driver uses the DMA API, we should pass it valid DMA masks. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: Petr Stetiar <ynezz@true.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-10gpio/ep93xx: Add missing EP93XX_GPIO_PHYS_BASE defineH Hartley Sweeten
The patch to convert of the ep93xx gpio driver to a platform_driver is missing the define for the memory resource that is passed to the driver. This is needed to prevent a build error. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-08gpio/ep93xx: convert to platform_driver and use basic_mmio_gpio libraryH Hartley Sweeten
This converts the gpio-ep93xx driver into a platform_driver and uses the basic_mmio_gpio library. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-08spi/ep93xx: add DMA supportMika Westerberg
This patch adds DMA support for the EP93xx SPI driver. By default the DMA is not enabled but it can be enabled by setting ep93xx_spi_info.use_dma to true in board configuration file. Note that the SPI driver still uses PIO for small transfers (<= 8 bytes) for performance reasons. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-08ep93xx: remove the old M2P DMA codeMika Westerberg
Since we have converted all existing users of the old DMA API to use the DMA engine API the old code can be dropped. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Ryan Mallon <rmallon@gmail.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-08ep93xx: add dmaengine platform codeMika Westerberg
Add platform support code for the new EP93xx dmaengine driver. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Ryan Mallon <rmallon@gmail.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-08dmaengine: add ep93xx DMA supportMika Westerberg
The ep93xx DMA controller has 10 independent memory to peripheral (M2P) channels, and 2 dedicated memory to memory (M2M) channels. M2M channels can also be used by SPI and IDE to perform DMA transfers to/from their memory mapped FIFOs. This driver supports both M2P and M2M channels with DMA_SLAVE, DMA_CYCLIC and DMA_MEMCPY (M2M only) capabilities. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Ryan Mallon <rmallon@gmail.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-06gpio/ep93xx: move driver to drivers/gpioH Hartley Sweeten
The GPIO driver should reside in drivers/gpio. v3: Change Kconfig option to def_bool y v2: Make the Kconfig symbol a silent option, dependent on ARCH_EP93XX Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-11ARM: 6852/1: EP93xx: Remove ep93xx_gpio_dbg_show functionRyan Mallon
The interrupt printing functionality in the ep93xx gpio debugfs function does not behave as expected. It prints [interrupt] beside all pins which are capable of being interrupts, not just those which are currently configured as interrupts. The best solution is just to remove the custom ep93xx gpio debugfs function all together. The generic gpiolib one is good enough. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: ep93xx: Use proper irq accessor functionsThomas Gleixner
No need to write the flow type. Core code does already. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25arm: ep93xx: Add basic interrupt infoRyan Mallon
For the time being can we fix up the ep93xx gpio code with the amended patch below. It keeps the information that the pin is also configured as an interrupt and cleans the code up a bit. [ tglx: Rebased it on the removal patch ] Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25arm/gpio: Remove three copies of broken and racy debug codeThomas Gleixner
gpiolib plus two gpio implementations in arm fiddle in the guts of irq_desc in a racy and buggy way. Remove the stuff. I already told the gpio folks that we can provide that information in a proper way if necessary. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> LKML-Reference: <20110324212508.931638262@linutronix.de>
2011-03-16Merge branch 'p2v' into develRussell King
Conflicts: arch/arm/kernel/module.c arch/arm/mach-s5pv210/sleep.S
2011-03-16Merge branches 'at91', 'ep93xx', 'errata', 'footbridge', 'fncpy', 'gemini', ↵Russell King
'irqdata', 'pm', 'sh', 'smp', 'spear', 'ux500' and 'via' into devel
2011-03-06ARM: 6780/1: EDB93xx: Add support for CS4271 SPI-connected CODECAlexander Sverdlin
Add support for CS4271 SPI-connected CODEC to EDB93xx. Signed-off-by: Alexander Sverdlin <subaparts@yandex.ru> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-05ARM: 6652/1: ep93xx: correct the end address of the AC97 memory resourceMika Westerberg
The last register is at offset 0xa8 making the resource end to be 0xac - 1 instead of 0xb0 - 1. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-05ARM: 6643/1: ep93xx: add framebuffer support to edb93xx boardsHartley Sweeten
The ep9307, ep9312, and ep9315 variants of the ep93xx processor include the raster engine needed for framebuffer support. This allows the EDB93xx boards with those processors to use the framebuffer driver. Tested on an EDB9307A with the following kernel parameters: video=640x480-16@60 video=1024x768-16@60 Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-27ARM: 6641/1: ep93xx: implement gpiolib set_debounce for built-in GPIOsHartley Sweeten
GPIO Ports A, B, and F on the ep93xx provide interrupt capability. It is possible to debounce the input signal on these ports when interrupts are enabled. Support for this debounce capability was provided with an ep93xx internal function. Now that gpiolib knows about gpio debounce, use the gpiolib method and do not export the internal function. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-25ARM: 6636/1: ep93xx: default multiplexed gpio ports to gpio modeHartley Sweeten
The EP93xx C and D GPIO ports are multiplexed with the Keypad Interface peripheral.  At power-up they default into non-GPIO mode with the Key Matrix controller enabled so these ports are unusable for GPIO.  Note that the Keypad Interface peripheral is only available in the EP9307, EP9312, and EP9315 processor variants. The keypad support will clear the DeviceConfig bits appropriately to enable the Keypad Interface when the driver is loaded.  And, when the driver is unloaded it will set the bits to return the ports to GPIO mode. To make these ports available for GPIO after power-up on all EP93xx processor variants, set the KEYS and GONK bits in the DeviceConfig register. Similarly, the E, G, and H ports are multiplexed with the IDE Interface peripheral.  At power-up these also default into non-GPIO mode.  Note that the IDE peripheral is only available in the EP9312 and EP9315 processor variants. Since an IDE driver is not even available in mainline, set the EONIDE, GONIDE, and HONIDE bits in the DeviceConfig register so that these ports will be available for GPIO use after power-up. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-13ARM: ep93xx: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Acked-by: Ryan Mallon <ryan@bluewatersys.com>
2011-01-06Merge branch 'smp' into miscRussell King
Conflicts: arch/arm/kernel/entry-armv.S arch/arm/mm/ioremap.c
2010-11-26ARM: 6483/1: arm & sh: factorised duplicated clkdev.cJean-Christop PLAGNIOL-VILLARD
factorise some generic infrastructure to assist looking up struct clks for the ARM & SH architecture. as the code is identical at 99% put the arch specific code for allocation as example in asm/clkdev.h Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-07ARM: 6462/1: EP93xx: Document DMA M2P APIRyan Mallon
Add kernel-doc documentation for the EP93xx DMA memory to peripheral/peripheral to memory API. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-26replace nested max/min macros with {max,min}3 macroHagen Paul Pfeifer
Use the new {max,min}3 macros to save some cycles and bytes on the stack. This patch substitutes trivial nested macros with their counterpart. Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Cc: Joe Perches <joe@perches.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits) ALSA: hda - Disable sticky PCM stream assignment for AD codecs ALSA: usb - Creative USB X-Fi volume knob support ALSA: ca0106: Use card specific dac id for mute controls. ALSA: ca0106: Allow different sound cards to use different SPI channel mappings. ALSA: ca0106: Create a nice spot for mapping channels to dacs. ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence. ALSA: ca0106: Pull out dac powering routine into separate function. ALSA: ca0106 - add Sound Blaster 5.1vx info. ASoC: tlv320dac33: Use usleep_range for delays ALSA: usb-audio: add Novation Launchpad support ALSA: hda - Add workarounds for CT-IBG controllers ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs ASoC: tpa6130a2: Error handling for broken chip ASoC: max98088: Staticise m98088_eq_band ASoC: soc-core: Fix codec->name memory leak ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066 ALSA: hda - Add some workarounds for Creative IBG ALSA: hda - Fix wrong SPDIF NID assignment for CA0110 ALSA: hda - Fix codec rename rules for ALC662-compatible codecs ALSA: hda - Add alc_init_jacks() call to other codecs ...
2010-10-25Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: arch/powerpc/platforms/85xx/p1022_ds.c
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-10-15ASoC: ep93xx: add Simplemachines Sim.One AC97 audio supportMika Westerberg
Add AC97 audio support for Simplemachines Sim.One board. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-15ARM: ep93xx: add AC97 platform supportMika Westerberg
Add platform support for the EP93xx AC97 controller driver. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-12ARM: 6440/1: ep93xx: DMA: fix channel_disableMika Westerberg
When channel_disable() is called, it disables per channel interrupts and waits until channels state becomes STATE_STALL, and then disables the channel. Now, if the DMA transfer is disabled while the channel is in STATE_NEXT we will not wait anything and disable the channel immediately. This seems to cause weird data corruption for example in audio transfers. Fix is to wait while we are in STATE_NEXT or STATE_ON and only then disable the channel. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-08ARM: 6359/1: ep93xx: move clock initialization earlierMika Westerberg
Commit 7cfe24947 ("ARM: AMBA: Add pclk support to AMBA bus infrastructure") changed AMBA bus to handle the PCLK automatically. However, in EP93xx clock initialization is arch_initcall which is done later than AMBA device identification. This causes amba_get_enable_pclk() to fail resulting device where UARTs are not functional. So change ep93xx_clock_init() to be postcore_initcall. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
