path: root/arch/arm/mach-ep93xx
2012-01-31dmaengine: move drivers to dma_transfer_directionVinod Koul
fixup usage of dma direction by introducing dma_transfer_direction, this patch moves dma/drivers/* to use new enum Cc: Jassi Brar <jaswinder.singh@linaro.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Viresh Kumar <viresh.kumar@st.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Mika Westerberg <mika.westerberg@iki.fi> Cc: H Hartley Sweeten <hartleys@visionengravers.com> Cc: Li Yang <leoli@freescale.com> Cc: Zhang Wei <zw@zh-kernel.org> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Shawn Guo <shawn.guo@freescale.com> Cc: Yong Wang <yong.y.wang@intel.com> Cc: Tomoya MORINAGA <tomoya-linux@dsn.lapis-semi.com> Cc: Boojin Kim <boojin.kim@samsung.com> Cc: Barry Song <Baohua.Song@csr.com> Acked-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2011-07-06ARM: 6966/1: ep93xx: fix inverted RTS/DTR signals on uart1Petr Štetiar
It was discovered by Roberto Bergo, that RTS/DTR signals are inverted after the boot, because it was causing him problems with hardware controlled modem connected on ttyAM0. Todd Valentic came with this patch for the issue. Discussion: http://tech.groups.yahoo.com/group/ts-7000/message/20259 Comments from Petr Štetiar: Sorry, but forget to add Acked-by[1]: 1. https://patchwork.kernel.org/patch/873052/ Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Todd Valentic <todd.valentic@sri.com> Tested-by: Roberto Bergo <roberto.bergo@robson.it> Signed-off-by: Petr Štetiar <ynezz@true.cz> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-11ep93xx: set DMA masks for the ep93xx_ethMika Westerberg
Since the driver uses the DMA API, we should pass it valid DMA masks. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: Petr Stetiar <ynezz@true.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11ARM: 6852/1: EP93xx: Remove ep93xx_gpio_dbg_show functionRyan Mallon
The interrupt printing functionality in the ep93xx gpio debugfs function does not behave as expected. It prints [interrupt] beside all pins which are capable of being interrupts, not just those which are currently configured as interrupts. The best solution is just to remove the custom ep93xx gpio debugfs function all together. The generic gpiolib one is good enough. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: ep93xx: Use proper irq accessor functionsThomas Gleixner
No need to write the flow type. Core code does already. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25arm: ep93xx: Add basic interrupt infoRyan Mallon
For the time being can we fix up the ep93xx gpio code with the amended patch below. It keeps the information that the pin is also configured as an interrupt and cleans the code up a bit. [ tglx: Rebased it on the removal patch ] Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25arm/gpio: Remove three copies of broken and racy debug codeThomas Gleixner
gpiolib plus two gpio implementations in arm fiddle in the guts of irq_desc in a racy and buggy way. Remove the stuff. I already told the gpio folks that we can provide that information in a proper way if necessary. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Grant Likely <grant.likely@secretlab.ca> LKML-Reference: <20110324212508.931638262@linutronix.de>
2011-03-16Merge branch 'p2v' into develRussell King
Conflicts: arch/arm/kernel/module.c arch/arm/mach-s5pv210/sleep.S
2011-03-16Merge branches 'at91', 'ep93xx', 'errata', 'footbridge', 'fncpy', 'gemini', ↵Russell King
'irqdata', 'pm', 'sh', 'smp', 'spear', 'ux500' and 'via' into devel
2011-03-06ARM: 6780/1: EDB93xx: Add support for CS4271 SPI-connected CODECAlexander Sverdlin
Add support for CS4271 SPI-connected CODEC to EDB93xx. Signed-off-by: Alexander Sverdlin <subaparts@yandex.ru> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-05ARM: 6652/1: ep93xx: correct the end address of the AC97 memory resourceMika Westerberg
The last register is at offset 0xa8 making the resource end to be 0xac - 1 instead of 0xb0 - 1. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-05ARM: 6643/1: ep93xx: add framebuffer support to edb93xx boardsHartley Sweeten
The ep9307, ep9312, and ep9315 variants of the ep93xx processor include the raster engine needed for framebuffer support. This allows the EDB93xx boards with those processors to use the framebuffer driver. Tested on an EDB9307A with the following kernel parameters: video=640x480-16@60 video=1024x768-16@60 Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-27ARM: 6641/1: ep93xx: implement gpiolib set_debounce for built-in GPIOsHartley Sweeten
GPIO Ports A, B, and F on the ep93xx provide interrupt capability. It is possible to debounce the input signal on these ports when interrupts are enabled. Support for this debounce capability was provided with an ep93xx internal function. Now that gpiolib knows about gpio debounce, use the gpiolib method and do not export the internal function. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-25ARM: 6636/1: ep93xx: default multiplexed gpio ports to gpio modeHartley Sweeten
The EP93xx C and D GPIO ports are multiplexed with the Keypad Interface peripheral.  At power-up they default into non-GPIO mode with the Key Matrix controller enabled so these ports are unusable for GPIO.  Note that the Keypad Interface peripheral is only available in the EP9307, EP9312, and EP9315 processor variants. The keypad support will clear the DeviceConfig bits appropriately to enable the Keypad Interface when the driver is loaded.  And, when the driver is unloaded it will set the bits to return the ports to GPIO mode. To make these ports available for GPIO after power-up on all EP93xx processor variants, set the KEYS and GONK bits in the DeviceConfig register. Similarly, the E, G, and H ports are multiplexed with the IDE Interface peripheral.  At power-up these also default into non-GPIO mode.  Note that the IDE peripheral is only available in the EP9312 and EP9315 processor variants. Since an IDE driver is not even available in mainline, set the EONIDE, GONIDE, and HONIDE bits in the DeviceConfig register so that these ports will be available for GPIO use after power-up. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-13ARM: ep93xx: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Acked-by: Ryan Mallon <ryan@bluewatersys.com>
2011-01-06Merge branch 'smp' into miscRussell King
Conflicts: arch/arm/kernel/entry-armv.S arch/arm/mm/ioremap.c
2010-11-26ARM: 6483/1: arm & sh: factorised duplicated clkdev.cJean-Christop PLAGNIOL-VILLARD
factorise some generic infrastructure to assist looking up struct clks for the ARM & SH architecture. as the code is identical at 99% put the arch specific code for allocation as example in asm/clkdev.h Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-07ARM: 6462/1: EP93xx: Document DMA M2P APIRyan Mallon
Add kernel-doc documentation for the EP93xx DMA memory to peripheral/peripheral to memory API. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-26replace nested max/min macros with {max,min}3 macroHagen Paul Pfeifer
Use the new {max,min}3 macros to save some cycles and bytes on the stack. This patch substitutes trivial nested macros with their counterpart. Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Cc: Joe Perches <joe@perches.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits) ALSA: hda - Disable sticky PCM stream assignment for AD codecs ALSA: usb - Creative USB X-Fi volume knob support ALSA: ca0106: Use card specific dac id for mute controls. ALSA: ca0106: Allow different sound cards to use different SPI channel mappings. ALSA: ca0106: Create a nice spot for mapping channels to dacs. ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence. ALSA: ca0106: Pull out dac powering routine into separate function. ALSA: ca0106 - add Sound Blaster 5.1vx info. ASoC: tlv320dac33: Use usleep_range for delays ALSA: usb-audio: add Novation Launchpad support ALSA: hda - Add workarounds for CT-IBG controllers ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs ASoC: tpa6130a2: Error handling for broken chip ASoC: max98088: Staticise m98088_eq_band ASoC: soc-core: Fix codec->name memory leak ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066 ALSA: hda - Add some workarounds for Creative IBG ALSA: hda - Fix wrong SPDIF NID assignment for CA0110 ALSA: hda - Fix codec rename rules for ALC662-compatible codecs ALSA: hda - Add alc_init_jacks() call to other codecs ...
2010-10-25Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: arch/powerpc/platforms/85xx/p1022_ds.c
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-10-15ASoC: ep93xx: add Simplemachines Sim.One AC97 audio supportMika Westerberg
Add AC97 audio support for Simplemachines Sim.One board. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-15ARM: ep93xx: add AC97 platform supportMika Westerberg
Add platform support for the EP93xx AC97 controller driver. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-12ARM: 6440/1: ep93xx: DMA: fix channel_disableMika Westerberg
When channel_disable() is called, it disables per channel interrupts and waits until channels state becomes STATE_STALL, and then disables the channel. Now, if the DMA transfer is disabled while the channel is in STATE_NEXT we will not wait anything and disable the channel immediately. This seems to cause weird data corruption for example in audio transfers. Fix is to wait while we are in STATE_NEXT or STATE_ON and only then disable the channel. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-08ARM: 6359/1: ep93xx: move clock initialization earlierMika Westerberg
Commit 7cfe24947 ("ARM: AMBA: Add pclk support to AMBA bus infrastructure") changed AMBA bus to handle the PCLK automatically. However, in EP93xx clock initialization is arch_initcall which is done later than AMBA device identification. This causes amba_get_enable_pclk() to fail resulting device where UARTs are not functional. So change ep93xx_clock_init() to be postcore_initcall. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-08-16Merge branch 'for-2.6.36' into for-2.6.37Mark Brown
Fairly simple conflicts, the most serious ones are the i.MX ones which I suspect now need another rename. Conflicts: arch/arm/mach-mx2/clock_imx27.c arch/arm/mach-mx2/devices.c arch/arm/mach-omap2/board-rx51-peripherals.c arch/arm/mach-omap2/board-zoom2.c sound/soc/fsl/mpc5200_dma.c sound/soc/fsl/mpc5200_dma.h sound/soc/fsl/mpc8610_hpcd.c sound/soc/pxa/spitz.c
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits) ALSA: hda - Add pin-fix for HP dc5750 ALSA: als4000: Fix potentially invalid DMA mode setup ALSA: als4000: enable burst mode ALSA: hda - Fix initial capsrc selection in patch_alc269() ASoC: TWL4030: Capture route runtime DAPM ordering fix ALSA: hda - Add PC-beep whitelist for an Intel board ALSA: hda - More relax for pending period handling ALSA: hda - Define AC_FMT_* constants ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs ALSA: hda - Add support for HDMI HBR passthrough ALSA: hda - Set Stream Type in Stream Format according to AES0 ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF ASoC: wm9081: fix resource reclaim in wm9081_register error path ASoC: wm8978: fix a memory leak if a wm8978_register fail ASoC: wm8974: fix a memory leak if another WM8974 is registered ASoC: wm8961: fix resource reclaim in wm8961_register error path ASoC: wm8955: fix resource reclaim in wm8955_register error path ASoC: wm8940: fix a memory leak if wm8940_register return error ASoC: wm8904: fix resource reclaim in wm8904_register error path ...
2010-07-31Merge branches 'at91', 'ep93xx', 'kexec', 'iop', 'lmb', 'nomadik', 'nuc', ↵Russell King
'pl', 'spear' and 'versatile' into devel
2010-07-22ARM: AMBA: Add pclk definition for platforms using primecellsRussell King
Add a dummy clk definition for the APB pclk signal on all platforms using the AMBA bus infrastructure. This ensures that these platforms continue to work when the core amba bus code controls the APB pclk. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-06-16ARM: 6174/1: ep93xx: clear devcfg bits before setting themHartley Sweeten
The ep93xx core helper function ep93xx_devcfg_set_clear should mask the clear_bits before setting the new set_bits in case the clear_bits are a mask value that also includes the set_bits. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-06-16ARM: 6168/1: ep93xx: move physmap flash registration into core.cHartley Sweeten
Create a core.c __init function to handle the physmap flash registration for all the ep93xx platforms. Also, modify all the ep93xx platforms to use this new function. This simplifies all the ep93xx platform init code and reduces the size of the kernel when including multiple ep93xx boards. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: Martin Guy <martinwguy@gmail.com> Acked-by: Hubert Feurstein <hubert.feurstein@contec.at> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-06-16ARM: 6167/1: ep93xx: register backlight driverHartley Sweeten
Add the platform registration for the ep93xx backlight driver that is now merged. Since the pwm BRIGHT signal only functions if the video system is operating, register the backlight when the framebuffer device is registered. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-06-09ASoC: EP93xx: Add Snapper CL15 i2s audio supportRyan Mallon
Add support for i2s audio on Bluewater Systems Snapper CL15 module Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-06-09Merge branch 'ep93xx' into for-2.6.36Mark Brown
Trivial add/add fixup required in the clock table. Conflicts: arch/arm/mach-ep93xx/clock.c
2010-06-09EP93xx: Add i2s core supportRyan Mallon
Add core support for EP93xx i2s audio Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-05-25Merge remote branch 'origin' into secretlab/next-spiGrant Likely
2010-05-25spi/ep93xx: implemented driver for Cirrus EP93xx SPI controllerMika Westerberg
This patch adds an SPI master driver for the Cirrus EP93xx SPI controller found in EP93xx chips. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-21Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (154 commits) mtd: cfi_cmdset_0002: use AMD standard command-set with Winbond flash chips mtd: cfi_cmdset_0002: Fix MODULE_ALIAS and linkage for new 0701 commandset ID mtd: mxc_nand: Remove duplicate NAND_CMD_RESET case value mtd: update gfp/slab.h includes jffs2: Stop triggering block erases from jffs2_write_super() jffs2: Rename jffs2_erase_pending_trigger() to jffs2_dirty_trigger() jffs2: Use jffs2_garbage_collect_trigger() to trigger pending erases jffs2: Require jffs2_garbage_collect_trigger() to be called with lock held jffs2: Wake GC thread when there are blocks to be erased jffs2: Erase pending blocks in GC pass, avoid invalid -EIO return jffs2: Add 'work_done' return value from jffs2_erase_pending_blocks() mtd: mtdchar: Do not corrupt backing device of device node inode mtd/maps/pcmciamtd: Fix printk format for ssize_t in debug messages drivers/mtd: Use kmemdup mtd: cfi_cmdset_0002: Fix argument order in bootloc warning mtd: nand: add Toshiba TC58NVG0 device ID pcmciamtd: add another ID pcmciamtd: coding style cleanups pcmciamtd: fixing obvious errors mtd: chips: add SST39WF160x NOR-flashes ... Trivial conflicts due to dev_node removal in drivers/mtd/maps/pcmciamtd.c
2010-05-17Merge branch 'devel-stable' into develRussell King
Conflicts: arch/arm/Kconfig arch/arm/include/asm/system.h arch/arm/mm/Kconfig
2010-05-13ARM: 6124/1: ep93xx: SPI driver platform support codeMika Westerberg
This patch adds platform side support code for the EP93xx SPI driver. This includes clock, resources and muxing. There is a new function: ep93xx_register_spi() which can be used by board support code to register new SPI devices for the board. This patch depends on patch 5998/1 ep93xx: added chip revision reading function Cc: Ryan Mallon <ryan@bluewatersys.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Martin Guy <martinwguy@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-10Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/mtd/mtdcore.c Pull in the bdi fixes and ARM platform changes that other outstanding patches depend on.
2010-04-14ARM: 5998/1: ep93xx: added chip revision reading functionMika Westerberg
Added a new function: ep93xx_chip_revision() which reads chip revision from the sysconfig register. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-04-14ARM: 5992/1: ep93xx: pass platform startup data as __initdataHartley Sweeten
A number of the peripherals for the ep93xx are registered at startup using platform_data that is passed from the board init code to the core code. This data is then copied to a local static variable in the core code. Since the data is copied, the original data can be marked as __initdata and discarded after startup is complete. This adds the __initdata tag to all the appropriate data in the various ep93xx board init's. Specifically, all the struct ep93xx_eth_data, struct ep93xxfb_mach_info, and struct i2c_gpio_platform_data. Also, document the various registration functions and note what data should be marked as __initdata. While here, also cleanup a couple over zealous whitespace tabs. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
