path: root/arch/arm/mach-ep93xx
2016-06-27rtc: m48t86: move m48t86.h to platform_dataAlexandre Belloni
m48t86.h belongs to include/linux/platform_data/ Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-12-07ARM: nand: make use of mtd_to_nand() where appropriateBoris BREZILLON
mtd_to_nand() was recently introduced to avoid direct accesses to the mtd->priv field. Update all ARM specific implementations to use this helper. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Signed-off-by: Brian Norris <computersforpeace@gmail.com>
2015-08-13ARM/fb: ep93xx: switch framebuffer to use modedb onlyLinus Walleij
All the EP93xx boards exclusively use modedb to look up video modes from the command line. Root out the parametrization of custom video modes from the platform data and board files and simplify the driver. Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-13ARM: ep93xx/timer: Migrate to new 'set-state' interfaceViresh Kumar
Migrate EP93xx driver to the new 'set-state' interface provided by clockevents core, the earlier 'set-mode' interface is marked obsolete now. This also enables us to implement callbacks for new states of clockevent devices, for example: ONESHOT_STOPPED. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-07-17ARM: ep93xx: simone: enable DMA on the SPI hostLinus Walleij
The SPI host on the SIM.ONE is used for the MMC/SD card and will badly need this turbo boost. Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-17ARM: ep93xx: vision_ep9307: add audio supportH Hartley Sweeten
Add I2S audio support to the vision_ep9307 system. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-17ARM: ep93xx: vision_ep9307: enable DMA for SPIH Hartley Sweeten
Enable the 'use_dma' flag in the SPI platform data to improve the speed of the mmc_spi driver. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-17ARM: ep93xx: toss the device ID into the entropy poolLinus Walleij
It doesn't hurt to add this random stuff into the entropy pool as is custom to do with device-unique numbers. Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-17ARM: ep93xx: remove memory configuration optionsH Hartley Sweeten
The ARM_PATCH_PHYS_VIRT option makes the ep93xx memory configuration options obsolete. This allows support for all the ep93xx variations to be built into a single kernel. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-17ARM: ep93xx: update comment on timer usageLinus Walleij
When refactoring the EP93xx timer some of the documentation git out of date. Update it. Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-08ARM: ep93xx: switch clockevent to timer 3Linus Walleij
If we switch clock events to timer 3 we will have more bits to use and can sleep longer when using NO_HZ. Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-08ARM: ep93xx: use non-raw accessors for timerLinus Walleij
The timer has no business using __raw accessors, in this case the readl/writel makes perfect sense as the changes really need to hit these registers before we continue. Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-08ARM: ep93xx: switch to GENERIC_CLOCKEVENTSLinus Walleij
This switches the EP93xx to use GENERIC_CLOCKEVENTS and CLKSRC_MMIO. Also implements a sched_clock() hook. Tested on the SIM.ONE. Use only oneshot events. Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-08ARM: ep93xx: move timer to its own fileLinus Walleij
This breaks the timer code out of the core file in preparation for refactoring. Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-06-11ARM: ep93xx: simone: support for SPI-based MMC/SD cardsMika Westerberg
This includes setting up EGPIOs 0 and 9 for card detection and chip select respectively. This patch is needed to mount a root filesystem on the SPI-based MMC card reader found on the Sim.One. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Kevin Hilman <khilman@linaro.org>
2014-11-28arm: ep93xx: add dma_masks for the M2P and M2M DMA controllersH Hartley Sweeten
The dma_mask and coherent_dma_mask need to be set or DMA memory allocations will fail with error messages like this: ep93xx-dma ep93xx-dma-m2p: coherent DMA mask is unset ep93xx-dma ep93xx-dma-m2m: coherent DMA mask is unset Add the missing information to the ep93xx-dma-m2p and ep93xx-dma-m2m devices. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Reported-by: Jeremy Moles <cubicool@gmail.com> Tested-by: Alexander Sverdlin <subaparts@yandex.ru> Cc: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-10-02kbuild: remove unnecessary variable initializaionsMasahiro Yamada
Clearing obj-y, obj-m, obj-n, obj- in each Makefile is a useless habit. They are non-exported variables; therefore they are always empty whenever descending into each subdirectory. (Moreorver, obj-y and obj-m are also set to empty at the beginning of scripts/Makefile.build) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Peter Foley <pefoley2@pefoley.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2014-07-29ARM: 8113/1: remove remaining definitions of PLAT_PHYS_OFFSET from ↵Uwe Kleine-König
<mach/memory.h> The platforms selecting NEED_MACH_MEMORY_H defined the start address of their physical memory in the respective <mach/memory.h>. With ARM_PATCH_PHYS_VIRT=y (which is quite common today) this is useless though because the definition isn't used but determined dynamically. So remove the definitions from all <mach/memory.h> and provide the Kconfig symbol PHYS_OFFSET with the respective defaults in case ARM_PATCH_PHYS_VIRT isn't enabled. This allows to drop the dependency of PHYS_OFFSET on !NEED_MACH_MEMORY_H which prevents compiling an integrator nommu-kernel. (CONFIG_PAGE_OFFSET which has "default PHYS_OFFSET if !MMU" expanded to "0x" because CONFIG_PHYS_OFFSET doesn't exist as INTEGRATOR selects NEED_MACH_MEMORY_H.) Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-07-18ARM: convert all "mov.* pc, reg" to "bx reg" for ARMv6+Russell King
ARMv6 and greater introduced a new instruction ("bx") which can be used to return from function calls. Recent CPUs perform better when the "bx lr" instruction is used rather than the "mov pc, lr" instruction, and this sequence is strongly recommended to be used by the ARM architecture manual (section A.4.1.1). We provide a new macro "ret" with all its variants for the condition code which will resolve to the appropriate instruction. Rather than doing this piecemeal, and miss some instances, change all the "mov pc" instances to use the new macro, with the exception of the "movs" instruction and the kprobes code. This allows us to detect the "mov pc, lr" case and fix it up - and also gives us the possibility of deploying this for other registers depending on the CPU selection. Reported-by: Will Deacon <will.deacon@arm.com> Tested-by: Stephen Warren <swarren@nvidia.com> # Tegra Jetson TK1 Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> # mioa701_bootresume.S Tested-by: Andrew Lunn <andrew@lunn.ch> # Kirkwood Tested-by: Shawn Guo <shawn.guo@freescale.com> Tested-by: Tony Lindgren <tony@atomide.com> # OMAPs Tested-by: Gregory CLEMENT <gregory.clement@free-electrons.com> # Armada XP, 375, 385 Acked-by: Sekhar Nori <nsekhar@ti.com> # DaVinci Acked-by: Christoffer Dall <christoffer.dall@linaro.org> # kvm/hyp Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> # PXA3xx Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> # Xen Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> # ARMv7M Tested-by: Simon Horman <horms+renesas@verge.net.au> # Shmobile Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-25ARM: 8036/1: Enable IRQs before attempting to read user space in __und_usrCatalin Marinas
The Undef abort handler in the kernel reads the undefined instruction from user space. If the page table was modified from another CPU, the user access could fail and do_page_fault() will be executed with interrupts disabled. This can potentially deadlock on ARM11MPCore or on Cortex-A15 with erratum 798181 workaround enabled (both implying IPI for TLB maintenance with page table lock held). This patch enables the IRQs in __und_usr before attempting to read the instruction from user space. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Tested-by: Arun KS <getarunks@gmail.com> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-25ARM: 8035/1: Disable preemption in crunch_task_enable()Catalin Marinas
This patch is in preparation for calling the crunch_task_enable() function with interrupts enabled. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-04-05Merge tag 'cleanup-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "These cleanup patches are mainly move stuff around and should all be harmless. They are mainly split out so that other branches can be based on top to avoid conflicts. Notable changes are: - We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no longer used (Uwe Kleine-König) - The Qualcomm MSM platform is split out into legacy mach-msm and new-style mach-qcom, to allow easier maintainance of the new hardware support without regressions (Kumar Gala) - A rework of some of the Kconfig logic to simplify multiplatform support (Rob Herring) - Samsung Exynos gets closer to supporting multiplatform (Sachin Kamat and others) - mach-bcm3528 gets merged into mach-bcm (Stephen Warren) - at91 gains some common clock framework support (Alexandre Belloni, Jean-Jacques Hiblot and other French people)" * tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits) ARM: hisi: select HAVE_ARM_SCU only for SMP ARM: efm32: allow uncompress debug output ARM: prima2: build reset code standalone ARM: at91: add PWM clock ARM: at91: move sam9261 SoC to common clk ARM: at91: prepare common clk transition for sam9261 SoC ARM: at91: updated the at91_dt_defconfig with support for the ADS7846 ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs ARM: at91: dt: Add at91sam9261 dt SoC support ARM: at91: switch sam9rl to common clock framework ARM: at91/dt: define main clk frequency of at91sam9rlek ARM: at91/dt: define at91sam9rl clocks ARM: at91: prepare common clk transition for sam9rl SoCs ARM: at91: prepare sam9 dt boards transition to common clk ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs ARM: at91: Add at91sam9rl DT SoC support ARM: at91: prepare at91sam9rl DT transition ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig ...
2014-03-21ARM: ep93xx: export ep93xx_chip_revisionArnd Bergmann
ep93xx_chip_revision is used by the pata_ep93xx driver, which can be a loadable module. Exporting the symbol avoids a link error in this case. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com>
2014-02-18Merge tag 'dropmachtimexh-v2' of git://git.pengutronix.de/git/ukl/linux into ↵Olof Johansson
next/cleanup This cleanup series gets rid of <mach/timex.h> for platforms not using ARCH_MULTIPLATFORM. (For multi-platform code it's already unused since 387798b (ARM: initial multiplatform support).) To make this work some code out of arch/arm needed to be adapted. The respective changes got acks by their maintainers to be taken via armsoc (with Andrew Morton substituting for Alessandro Zummo as rtc maintainer). Compared to the previous pull request there was another patch added that fixes a (non-critical) regression on ixp4xx. Olof Johansson asked to not squash this fix into the original commit to save him from the need to reverify the series. * tag 'dropmachtimexh-v2' of git://git.pengutronix.de/git/ukl/linux: ARM: ixp4xx: fix timer latch calculation ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, too ARM: rpc: stop using <mach/timex.h> ARM: ixp4xx: stop using <mach/timex.h> input: ixp4xx-beeper: don't use symbols from <mach/timex.h> ARM: at91: don't use <mach/timex.h> ARM: ep93xx: stop using mach/timex.h ARM: mmp: stop using mach/timex.h ARM: netx: stop using mach/timex.h ARM: sa1100: stop using mach/timex.h clocksource: sirf/marco+prima2: drop usage of CLOCK_TICK_RATE rtc: pxa: drop unused #define TIMER_FREQ rtc: at91sam9: include <mach/hardware.h> explicitly ARM/serial: at91: switch atmel serial to use gpiolib Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-20ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, tooUwe Kleine-König
While <mach/timex.h> isn't used for multi-platform builds since long it still is for "normal" builds. As the previous patches fix all sites to not make use of this per-platform file, it can go now for good also for platforms that are not (yet) converted to multi-platform. While at it there are no users of CLOCK_TICK_RATE any more, so also drop the dummy #define. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-12-20ARM: ep93xx: stop using mach/timex.hUwe Kleine-König
mach/timex.h is the last remaining header that is unused for multiarch builds but necessary for singlearch builds. To allow to get rid of it for singlearch builds, too, drop its usage in ep93xx arch code by substituting CLOCK_TICK_RATE by an already defined local cpp symbol. Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-11-25ARM: ep93xx: use soc busH Hartley Sweeten
Use the soc bus to report the silicon revision and Maverick Key. Both are not currently exposed to the user. In addition, fill in the SoC family and machine for completeness. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Ryan Mallon <rmallon@gmail.com> Cc: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-11-25ARM: ep93xx: remove deprecated IRQF_DISABLEDMichael Opdenacker
This patch proposes to remove the use of the IRQF_DISABLED flag It's a NOOP since 2.6.35 and it will be removed one day. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-10-29usb: ohci: remove ep93xx bus glue platform driverH Hartley Sweeten
Convert ep93xx to use the OHCI platform driver and remove the ohci-ep93xx bus glue driver. Enable CONFIG_OHCI_HCD_PLATFORM in the ep93xx_defconfig so that USB is still enabled by default on the EP93xx platform. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Olof Johansson <olof@lixom.net> Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-12Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A small batch of fixes that have trickled in over the last week of the merge window. Also included are few small devicetree updates for sunxi, since it enables me to use one of their newer boards (cubieboard2) for additional test coverage. The support for that SoC is new for 3.12, so there's no exposure to new regressions due to it" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: dts: sun7i: olinuxino-micro: Enable the EMAC ARM: dts: sun7i: cubieboard2: Enable the EMAC ARM: dts: sun7i: Add the muxing options for the EMAC ARM: dts: sun7i: Enable the Ethernet in the A20 i2c: davinci: Fix bad dev_get_platdata() conversion ARM: vexpress: allow dcscb and tc2_pm in a combined ARMv6+v7 build ARM: shmobile: lager: Do not use register_type field of struct sh_eth_plat_data ARM: pxa: ssp: Check return values from phandle lookups ARM: PCI: versatile: Fix SMAP register offsets ARM: PCI: versatile: Fix PCI I/O ARM: PCI: versatile: Fix map_irq function to match hardware ARM: ep93xx: Don't use modem interface on the second UART ARM: shmobile: r8a7779: Update early timer initialisation order
2013-09-10Merge tag 'ep93xx-fixes-for-3.12' of ↵Olof Johansson
git://github.com/RyanMallon/linux-ep93xx into fixes From Ryan Mallon, a fix for ep93xx. * tag 'ep93xx-fixes-for-3.12' of git://github.com/RyanMallon/linux-ep93xx: ARM: ep93xx: Don't use modem interface on the second UART Signed-off-by: Olof Johansson <olof@lixom.net>
2013-09-10Merge tag 'mmc-updates-for-3.12-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc Pull MMC updates from Chris Ball: "MMC highlights for 3.12: Core: - Support Allocation Units 8MB-64MB in SD3.0, previous max was 4MB. - The slot-gpio helper can now handle GPIO debouncing card-detect. - Read supported voltages from DT "voltage-ranges" property. Drivers: - dw_mmc: Add support for ARC architecture, and support exynos5420. - mmc_spi: Support CD/RO GPIOs. - sh_mobile_sdhi: Add compatibility for more Renesas SoCs. - sh_mmcif: Add DT support for DMA channels" * tag 'mmc-updates-for-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (50 commits) Revert "mmc: tmio-mmc: Remove .set_pwr() callback from platform data" mmc: dw_mmc: Add support for ARC mmc: sdhci-s3c: initialize host->quirks2 for using quirks2 mmc: sdhci-s3c: fix the wrong register value, when clock is disabled mmc: esdhc: add support to get voltage from device-tree mmc: sdhci: get voltage from sdhc host mmc: core: parse voltage from device-tree mmc: omap_hsmmc: use the generic config for omap2plus devices mmc: omap_hsmmc: clear status flags before starting a new command mmc: dw_mmc: exynos: Add a new compatible string for exynos5420 mmc: sh_mmcif: revision-specific CLK_CTRL2 handling mmc: sh_mmcif: revision-specific Command Completion Signal handling mmc: sh_mmcif: add support for Device Tree DMA bindings mmc: sh_mmcif: move header include from header into .c mmc: SDHI: add DT compatibility strings for further SoCs mmc: dw_mmc-pci: enable bus-mastering mode mmc: dw_mmc-pci: get resources from a proper BAR mmc: tmio-mmc: Remove .set_pwr() callback from platform data mmc: tmio-mmc: Remove .get_cd() callback from platform data mmc: sh_mobile_sdhi: Remove .set_pwr() callback from platform data ...
2013-09-06Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "This branch contains code cleanups, moves and removals for 3.12. There's a large number of various cleanups, and a nice net removal of 13500 lines of code. Highlights worth mentioning are: - A series of patches from Stephen Boyd removing the ARM local timer API. - Move of Qualcomm MSM IOMMU code to drivers/iommu. - Samsung PWM driver cleanups from Tomasz Figa, removing legacy PWM driver and switching over to the drivers/pwm one. - Removal of some unusued auto-generated headers for OMAP2+ (PRM/CM). There's also a move of a header file out of include/linux/i2c/ to platform_data, where it really belongs. It touches mostly ARM platform code for include changes so we took it through our tree" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits) ARM: OMAP2+: Add back the define for AM33XX_RST_GLOBAL_WARM_SW_MASK gpio: (gpio-pca953x) move header to linux/platform_data/ arm: zynq: hotplug: Remove unreachable code ARM: SAMSUNG: Remove unnecessary exynos4_default_sdhci*() tegra: simplify use of devm_ioremap_resource ARM: SAMSUNG: Remove plat/regs-timer.h header ARM: SAMSUNG: Remove remaining uses of plat/regs-timer.h header ARM: SAMSUNG: Remove pwm-clock infrastructure ARM: SAMSUNG: Remove old PWM timer platform devices pwm: Remove superseded pwm-samsung-legacy driver ARM: SAMSUNG: Modify board files to use new PWM platform device ARM: SAMSUNG: Rework private data handling in dev-backlight pwm: Add new pwm-samsung driver ARM: mach-mvebu: remove redundant DT parsing and validation ARM: msm: Only compile io.c on platforms that use it iommu/msm: Move mach includes to iommu directory ARM: msm: Remove devices-iommu.c ARM: msm: Move mach/board.h contents to common.h ARM: msm: Migrate msm_timer to CLOCKSOURCE_OF_DECLARE ARM: msm: Remove TMR and TMR0 static mappings ...
2013-09-03ARM: ep93xx: Don't use modem interface on the second UARTPetr Štetiar
Second UART doesn't have modem interface, so any attempt to use set_mctrl() it produce unwanted garbage on the line. There's no such 0x100 register offset for the second UART either. Signed-off-by: Petr Štetiar <ynezz@true.cz> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Ryan Mallon <rmallon@gmail.com>
2013-08-29gpio: (gpio-pca953x) move header to linux/platform_data/Vivien Didelot
This patch moves the pca953x.h header from include/linux/i2c to include/linux/platform_data and updates existing support accordingly. Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-08-25ARM: 7793/1: debug: use generic option for ep93xx PL10x debug portHartley Sweeten
The generic option DEBUG_LL_UART_PL01X is now used to select the UART type for the kernel low-level debugging on the ep93xx platform. This enables two config options to provide the physical and virtual base address of the debug UART. Use the generic options instead of providing platform specific options to select the debug UART. UART1 is selected with: DEBUG_UART_PHYS = 0x808c0000 DEBUG_UART_VIRT = 0xfedc0000 UART2 is selected with: DEBUG_UART_PHYS = 0x808d0000 DEBUG_UART_VIRT = 0xfedd0000 UART3 is selected with: DEBUG_UART_PHYS = 0x808e0000 DEBUG_UART_VIRT = 0xfede0000 The selected UART must already be initialized by the bootloader. If it isn't setup nothing will appear (which might be desired). Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: move PL01X debug include into arch/arm/include/debug/Russell King
Now that the PL01X debug include can mostly stand alone without requiring platforms to provide any macros, move it into the debug directory so it can be directly included. This allows us to get rid of a lot of debug-macros include files. The autodetect case for Versatile Express and the ux500 are left alone; these are more complicated implementations. Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: provide PL01x debug uart phys/virt address configuration optionsRussell King
Move the definition of the UART register addresses out of the platform specific header files into the Kconfig files. Acked-by: Ryan Mallon <rmallon@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-24ARM: ep93xx: vision_ep9307: Use MMC CD and RO GPIOLaurent Pinchart
Pass the CD and RO GPIO numbers to the MMC SPI driver and remove the custom .get_cd() and .get_ro() callback functions. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2013-07-09reboot: arm: change reboot_mode to use enum reboot_modeRobin Holt
Preparing to move the parsing of reboot= to generic kernel code forces the change in reboot_mode handling to use the enum. [akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c] Signed-off-by: Robin Holt <holt@sgi.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-18ARM: ep93xx: Fix wait for UART FIFO to be emptyH Hartley Sweeten
Commit 210dce5f "ARM: ep93xx: properly wait for UART FIFO to be empty" Removed the timeout loop while waiting for the uart transmit fifo to empty. Some bootloaders leave the uart in a state where there might be bytes in the uart that are not transmitted when execution is handed over to the kernel. This results in a deadlocked system while waiting for the fifo to empty. Add back the timeout wait to prevent the deadlock. Increase the wait time to hopefully prevent the decompressor corruption that lead to commit 210dce5f. This corruption was probably due to a slow uart baudrate. The 10* increase in the wait time should be enough for all cases. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ryan Mallon <rmallon@gmail.com>
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-14Merge tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux ↵Olof Johansson
into next/cleanup From Rob Herring: Initial irqchip init infrastructure and GIC and VIC clean-ups This creates irqchip initialization infrastructure from Thomas Petazzoni. The VIC and GIC irqchip code is moved to drivers/irqchips and adapted to use the new infrastructure. All DT enabled platforms using GIC and VIC are converted over to use the new irqchip_init. * tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux: irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.h ARM: picoxcell: use common irqchip_init function ARM: spear: use common irqchip_init function irqchip: Move ARM VIC to drivers/irqchip ARM: samsung: remove unused tick.h ARM: remove unneeded vic.h includes ARM: remove mach .handle_irq for VIC users ARM: VIC: set handle_arch_irq in VIC initialization ARM: VIC: shrink down vic.h irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.h ARM: use common irqchip_init for GIC init irqchip: Move ARM GIC to drivers/irqchip ARM: remove mach .handle_irq for GIC users ARM: GIC: set handle_arch_irq in GIC initialization ARM: GIC: remove direct use of gic_raise_softirq ARM: GIC: remove assembly ifdefs from gic.h ARM: mach-ux500: use SGI0 to wake up the other core arm: add set_handle_irq() to register the parent IRQ controller handler function irqchip: add basic infrastructure irqchip: add to the directories part of the IRQ subsystem in MAINTAINERS Fixed up massive merge conflicts with the timer cleanup due to adjacent changes: Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-bcm/board_bcm.c arch/arm/mach-cns3xxx/cns3420vb.c arch/arm/mach-ep93xx/adssphere.c arch/arm/mach-ep93xx/edb93xx.c arch/arm/mach-ep93xx/gesbc9312.c arch/arm/mach-ep93xx/micro9.c arch/arm/mach-ep93xx/simone.c arch/arm/mach-ep93xx/snappercl15.c arch/arm/mach-ep93xx/ts72xx.c arch/arm/mach-ep93xx/vision_ep9307.c arch/arm/mach-highbank/highbank.c arch/arm/mach-imx/mach-imx6q.c arch/arm/mach-msm/board-dt-8960.c arch/arm/mach-netx/nxdb500.c arch/arm/mach-netx/nxdkn.c arch/arm/mach-netx/nxeb500hmi.c arch/arm/mach-nomadik/board-nhk8815.c arch/arm/mach-picoxcell/common.c arch/arm/mach-realview/realview_eb.c arch/arm/mach-realview/realview_pb1176.c arch/arm/mach-realview/realview_pb11mp.c arch/arm/mach-realview/realview_pba8.c arch/arm/mach-realview/realview_pbx.c arch/arm/mach-socfpga/socfpga.c arch/arm/mach-spear13xx/spear1310.c arch/arm/mach-spear13xx/spear1340.c arch/arm/mach-spear13xx/spear13xx.c arch/arm/mach-spear3xx/spear300.c arch/arm/mach-spear3xx/spear310.c arch/arm/mach-spear3xx/spear320.c arch/arm/mach-spear3xx/spear3xx.c arch/arm/mach-spear6xx/spear6xx.c arch/arm/mach-tegra/board-dt-tegra20.c arch/arm/mach-tegra/board-dt-tegra30.c arch/arm/mach-u300/core.c arch/arm/mach-ux500/board-mop500.c arch/arm/mach-ux500/cpu-db8500.c arch/arm/mach-versatile/versatile_ab.c arch/arm/mach-versatile/versatile_dt.c arch/arm/mach-versatile/versatile_pb.c arch/arm/mach-vexpress/v2m.c include/asm-generic/vmlinux.lds.h
2013-01-12irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.hRob Herring
Now that we have VIC moved to drivers/irqchip and all VIC DT init for platforms using irqchip_init, move gic.h and update the remaining includes. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: linux-samsung-soc@vger.kernel.org
2013-01-12ARM: remove unneeded vic.h includesRob Herring
Numerous includes of asm/hardware/vic.h aren't needed, so remove them. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Hubert Feurstein <hubert.feurstein@contec.at> Cc: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Acked-By: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: linux-samsung-soc@vger.kernel.org Cc: patches@opensource.wolfsonmicro.com Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-01-12ARM: remove mach .handle_irq for VIC usersRob Herring
Now that the VIC initialization sets up the handle_arch_irq pointer, we can remove it for all machines and make it static. Move vic_handle_irq to avoid a forward declaration. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Hubert Feurstein <hubert.feurstein@contec.at> Cc: Alessandro Rubini <rubini@unipv.it> Cc: STEricsson <STEricsson_nomadik_linux@list.st.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Cc: Rajeev Kumar <rajeev-dlh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Arnd Bergmann <arnd@arndb.de>
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-12-24ARM: set arch_gettimeoffset directlyStephen Warren
remove ARM's struct sys_timer .offset function pointer, and instead directly set the arch_gettimeoffset function pointer when the timer driver is initialized. This requires multiplying all function results by 1000, since the removed arm_gettimeoffset() did this. Also, s/unsigned long/u32/ just to make the function prototypes exactly match that of arch_gettimeoffset. Cc: Russell King <linux@arm.linux.org.uk> Cc: Andrew Victor <linux@maxim.org.za> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-12-12ARM: ep93xx: properly wait for UART FIFO to be emptyFlorian Fainelli
This patch changes the busy-waiting loop around in the decompressor putc() function on the UART FIFO register. Without a proper wait, the output of the decompressor was corrupted like this: Uncompressing Linx. done, booting th enl To highlight the issue more evidently, looping 100 times instead of 1000 makes the issue appear much faster. This patch takes the approach of using an active while loop until the FIFO is empty (not FULL). This issue happened to me on Sim.One running at 200Mhz. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ryan Mallon <rmallon@gmail.com>
