Almost all Exynos-series of SoCs that run in secure mode don't need
additional offset for every CPU, with Exynos4412 being the only
exception.
Tested on Origen-Quad (Exynos4412) and Arndale-Octa (Exynos5420).
While at it, fix the coding style (space around *).
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
Tested-by: Andreas Faerber <afaerber@suse.de>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc
Samsung Exynos updates for 3.16
- add new SoCs support
: exynos3250, 5260, 5410 and 5800
- enable multi-platform on exynos
: consolidate exynos related Kconfig entries
* tag 'samsung-exynos' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: (22 commits)
ARM: EXYNOS: Enable multi-platform build support
ARM: EXYNOS: Consolidate Kconfig entries
ARM: EXYNOS: Add support for EXYNOS5410 SoC
ARM: EXYNOS: Support secondary CPU boot of Exynos3250
ARM: EXYNOS: Add Exynos3250 SoC ID
ARM: EXYNOS: Add 5800 SoC support
ARM: EXYNOS: initial board support for exynos5260 SoC
cpufreq: exynos: Fix the compile error
ARM: S3C24XX: move debug-macro.S into the common space
ARM: S3C24XX: use generic DEBUG_UART_PHY/_VIRT in debug macro
ARM: S3C24XX: trim down debug uart handling
ARM: compressed/head.S: remove s3c24xx special case
ARM: EXYNOS: Remove unnecessary inclusion of cpu.h
ARM: EXYNOS: Migrate Exynos specific macros from plat to mach
ARM: EXYNOS: Remove exynos_subsys registration
ARM: EXYNOS: Remove duplicate lines in Makefile
ARM: EXYNOS: use v7_exit_coherency_flush macro for cache disabling
ARM: dts: Remove g2d_pd node for exynos5420
ARM: dts: Remove mau_pd node for exynos5420
ARM: exynos_defconfig: enable HS-I2C to fix for mmc partition mount
This patch fix the offset of CPU boot address and don't
need to send smc call of SMC_CMD_CPU1BOOT command for
secondary CPU boot because Exynos3250 removes WFE in
secure mode.
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Exynos specific macros and declarations have been moved to
mach-exynos. Inclusion of plat/cpu.h is no more necessary.
This patch fixes the offset of CPU boot address and changes
the parameter of smc call for SMC_CMD_CPU1BOOT command on
exynos4212.
Instead of hardcoding the SYSRAM details for each SoC,
pass this information through device tree (DT) and make
the code SoC agnostic. Generic DT SRAM bindings are
used for achieving this.
Acked-by: Heiko Stuebner <heiko@sntech.de>
This patch makes the firmware setup code assume presence of DT, since it
is now the only way of booting supported for Exynos.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Some Exynos-based boards contain secure firmware and must use firmware
operations to set up some hardware.
This patch adds firmware operations for Exynos secure firmware and a way
for board code and device tree to specify that they must be used.
Example of use:
In board code:
...MACHINE_START(...)
.init_early = exynos_firmware_init,
MACHINE_END
In device tree:
firmware@0203F000 {
compatible = "samsung,secure-firmware";
reg = <0x0203F000 0x1000>;
