This is required to use SWRESET.
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
This is a regression fix after migration to the external GIC.
The breakage has been introduced in commit 69644a8e23ab
("ARM: EXYNOS4: modify interrupt mappings for external GIC")
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
[kgene.kim@samsung.com: added commit id]
Add support for MFC device to plat-s5p, mach-exynos4, mach-s5pv210:
- clock support
- memory mapping and reserving
- s5p_device_mfc platform device
Signed-off-by: Kamil Debski <k.debski@samsung.com>
This patch adds resource definitions for EXYNOS4 FIMD.
IRQ and SFR definitions are added.
Signed-off-by: Jonghun Han <jonghun.han@samsung.com>
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Exynos4 and S5PC110(S5PV210) has Internal dma(idma) in AUDSS.
To support idma, register idma platform device.
and Exynos4 and S5PC110 has different IDMA address.
TO handle different IDMA address, register idma platform data
Signed-off-by: Sangbeom Kim <sbkim73@samsung.com>
These registers are crucial for PM to work properly.
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
This is temporary patch for building with clkdev.
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
This patch adds platform device for Synopsys DesignWare
Multimedia Card Interface driver.
Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com>
MAX8997/17042, which are used by Exynos4-NURI, use additional IRQ
numbers after GPIO's IRQs. The patch creates some room for those
devices.
The PLL restore routine supports waiting pll locking. If PLL is
enabled in restoring sequence, it should wait until PLL is locked.
Signed-off-by: Jaecheol Lee <jc.lee@samsung.com>
EXYNOS4 supports 3 different system level power down mode by PMU (Power
Management Unit). Each power down mode need to configure many PMU registers
with different value. This patch supports function to configure PMU registers
with pre-defined values in PMU code. This function may be used by PM code and
AFTR/LPA support driver.
To insert the code for power on/off with pmu control to support hotplug in/out core1
As for hotplug.c, the codes for core1 to be hotplug in/out is inserted.
As for regs-pmu.h, S5P_CORE_LOCAL_PWR_EN is defined.
As for platsmp.c, the codes for core1 to be powered on is inserted.
Signed-off-by: JungHi Min <junghi.min@samsung.com>
External GIC cannot support PPI (Private Peripheral Interrupt) for
ARM private timers. Thus MCT should be selected as clock event timers
by default.
Signed-off-by: Changhwan Youn <chaos.youn@samsung.com>
For full support of power modes, this patch adds implementation
external GIC on EXYNOS4.
External GIC of Exynos4 cannot support register banking so
several interrupt related code for CPU1 should be different
from that of CPU0.
To support external GIC needs to update mapping of interrupt number.
This patch modifies it for external GIC and accordingly removes
the unused code.
This patch adds external GIC io memory mapping
to support external GIC on EXYNOS4.
The patch "ARM: SAMSUNG: Add support for pre-sleep/post-restore gpio
control" broke compilation on Exynos4 platform with power management
enabled. This patch adds missing stubs that fixes this issue.
Basically, other S3C SoCs and S5PC100 use 'S3C_VA_USB_HSPHY'
commonly. It should be changed to 'S3C_VA_USB_HSPHY' for common
usage and others. Now happens build error on S5PC100.
Cc: Greg Kroah-Hartman <gregkh@suse.de>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (137 commits)
ARM: bcmring: convert to use sp804 clockevents
ARM: bcmring: convert to sp804 clocksource
ARM: 6912/1: bcmring: Add clkdev table in init_early
clockevents: ARM sp804: obtain sp804 timer rate via clks
clockevents: ARM sp804: allow clockevent name to be specified
clocksource: ARM sp804: obtain sp804 timer rate via clks
clocksource: ARM sp804: allow clocksource name to be specified
clocksource: convert OMAP1 to 32-bit down counting clocksource
clocksource: convert MXS timrotv2 to 32-bit down counting clocksource
clocksource: convert SPEAr platforms 16-bit up counting clocksource
clocksource: convert Integrator/AP 16-bit down counting clocksource
clocksource: convert W90x900 24-bit down counting clocksource
clocksource: convert ARM 32-bit down counting clocksources
clocksource: convert ARM 32-bit up counting clocksources
clocksource: add common mmio clocksource
ARM: update sa1100 to reflect PXA updates
ARM: omap1: convert to using readl/writel instead of volatile struct
ARM: omap1: delete useless interrupt handler
ARM: s5p: consolidate selection of timer register
ARM: 6939/1: fix missing 'cpu_relax()' declaration
'consolidate-generic', 'consolidate-smp', 'consolidate-stmp' and 'consolidate-zones' into consolidate
Rather than having each platform class provide a mach/smp.h header for
smp_cross_call(), arrange for them to register the function with the
core ARM SMP code instead.
EXYNOS4 has 2 phys for usb host and usb device. This patch supports to
control usb host phy of EXYNOS4.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
This patch adds usb ehci device definition for samsung s5p cpus.
Fix incorrect conditional execution of ldr instructions in
addruart macro.
Signed-off-by: Thomas Abraham <thomas.abraham@samsung.com>
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits)
davinci: DM644x EVM: register MUSB device earlier
davinci: add spi devices on tnetv107x evm
davinci: add ssp config for tnetv107x evm board
davinci: add tnetv107x ssp platform device
spi: add ti-ssp spi master driver
mfd: add driver for sequencer serial port
ARM: EXYNOS4: Implement Clock gating for System MMU
ARM: EXYNOS4: Enhancement of System MMU driver
ARM: EXYNOS4: Add support for gpio interrupts
ARM: S5P: Add function to register gpio interrupt bank data
ARM: S5P: Cleanup S5P gpio interrupt code
ARM: EXYNOS4: Add missing GPYx banks
ARM: S3C64XX: Fix section mismatch from cpufreq init
ARM: EXYNOS4: Add keypad device to the SMDKV310
ARM: EXYNOS4: Update clocks for keypad
ARM: EXYNOS4: Update keypad base address
ARM: EXYNOS4: Add keypad device helpers
ARM: EXYNOS4: Add support for SATA on ARMLEX4210
plat-nomadik: make GPIO interrupts work with cpuidle ApSleep
mach-u300: define a dummy filter function for coh901318
Fix up various conflicts in
- arch/arm/mach-exynos4/cpufreq.c
- arch/arm/mach-mxs/gpio.c
- drivers/net/Kconfig
- drivers/tty/serial/Kconfig
- drivers/tty/serial/Makefile
- drivers/usb/gadget/fsl_mxc_udc.c
- drivers/video/Kconfig
This patch includes the implementation of the clock gating
for System MMU. Initially, all System MMUs are not asserted
the system clock. Asserting the system clock to a System MMU
is enabled only when s5p_sysmmu_enable() is called. Likewise,
it is disabled only when s5p_sysmmu_disable() is called.
Therefore, clock gating on System MMUs are still invisible to
the outside of the System MMU driver.
Signed-off-by: KyongHo Cho <pullip.cho@samsung.com>
This patch includes the following enhancements for System MMU:
- Enhanced readability
- Removal of unused data structures or their members
- Simplified function definitions
- Corrections of some logical errors
- Full compliance with Linux coding style
- Simpler way of registering callback functions of System MMU faults
This patch adds support for gpio interrupts on Samsung EXYNOS4 platform.
Common s5p-gpioint.c code is used for handling gpio interrupts. Each gpio
line that needs gpio interrupt support must be later registered with
s5p_register_gpio_interrupt() function.
This patch adds missing GPYx gpio banks on Samsung EXYNOS4 platform.
This patch updates the keypad IF base address in the memory map
for EXYNOS4.
Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com>
Adds the device definitions, platform specific initialization
and clocks for SATA on ARMLEX4210.
arch/arm/mach-exynos4/include/mach/regs-pmu.h
This patch adds support suspend to ram for EXYNOS4210.
As a note, this includes function of outer cache flush
because it is used before entering PM.
This patch adds definitions of PMU and CMU registers for EXYNOS4 PM.
Add support for fourth FIMC platform device definition and define
resources for FIMC modules on EXYNOS4 machines.
Add common code for MIPI-CSIS and MIPI-DSIM drivers to support
their corresponding D-PHY's enable and reset control.
The Multi-Core Timer(MCT) of EXYNOS4 is designed for implementing
clock source timer and clock event timers. This patch implements
1 clock source timer with 64 bit free running counter of MCT and
2 clock event timers with two of 31-bit tick counters.
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
This patch adds IRQ_MCT_G0 to irq map. IRQ_MCT_G0 is an interrupt
of MCT comparator and used for kernel global timer.
The MCT(Multi-Core Timer) is used for implementing kernel timers
for EXYNOS4210.
This patche fixes wrong S/PDIF SFR base address.
Signed-off-by: Seungwhan Youn <sw.youn@samsung.com>
This patch updates Timer part of EXYNOS4 according to the change of
ARCH name, EXYNOS4.
This patch updates IRQ part of EXYNOS4 according to the change of
ARCH name, EXYNOS4.
This patch updates Clock part of EXYNOS4 according to the change of
ARCH name, EXYNOS4.
This patch adds EXYNOS4 CPU support files in mach-exynos4,
and basically they are moved from mach-s5pv310 so that it
can support Samsung's new CPU name, EXYNOS4.
The EXYNOS4 ingegrates a ARM Cortex A9 multi-core.
