path: root/arch/arm/mach-exynos4/mct.c
2011-09-15ARM: EXYNOS4: restart clocksource while system resumesChanghwan Youn
System resume can't be completed because mct-frc isn't restarted after system suspends. This patch restarts mct-frc during system resume. Reported-by: Jongpill Lee <boyko.lee@samsung.com> Signed-off-by: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-15ARM: EXYNOS4: Fix return type of local_timer_setup()Kukjin Kim
According to commmit af90f10d ("ARM: 6759/1: smp: Select local timers vs broadcast timer support"), the return type of local_timer_setup() should be int instead of void. Reported-by: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: EXYNOS4: set the affinity of mct1 interrupt using IRQ_MCT_L1Changhwan Youn
IRQ_MCT_L1 is connected directly to GIC in external GIC mapping, while in internal GIC mapping, it is connected to GIC through interrupt combiner. Therfore the affinity for mct1 event timer interrupt should be changed through IRQ_MCT_L1. Signed-off-by: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-03-11ARM: EXYNOS4: Implement kernel timers using MCTChanghwan Youn
The Multi-Core Timer(MCT) of EXYNOS4 is designed for implementing clock source timer and clock event timers. This patch implements 1 clock source timer with 64 bit free running counter of MCT and 2 clock event timers with two of 31-bit tick counters. Signed-off-by: Changhwan Youn <chaos.youn@samsung.com> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
