path: root/arch/arm/mach-exynos4
2011-11-11ARM: smp: fix clipping of number of CPUsRussell King
commit a06f916b7a9b57447ceb875eb0a89f1a66b31bca upstream. Rather than clipping the number of CPUs using the compile-time NR_CPUS constant, use the runtime nr_cpu_ids value instead. This allows the nr_cpus command line option to work as expected. Reported-by: Mark Salter <msalter@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-09-27ARM: EXYNOS4: Rename sclk_cam clocks for FIMC driverSylwester Nawrocki
The sclk_cam clocks are now controlled by the top level FIMC media device driver bound to "s5p-fimc-md" platform device. Rename sclk_cam clocks so they accessible by the corresponding driver. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-15ARM: EXYNOS4: fix incorrect pad configuration for keypad row linesThomas Abraham
The keypad controller requires a external pull-up for all the keypad row lines. Fix the incorrect pad configuration for keypad controller row lines by enabling the pad pull-up for the all row lines of the keypad controller. Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-15ARM: EXYNOS4: restart clocksource while system resumesChanghwan Youn
System resume can't be completed because mct-frc isn't restarted after system suspends. This patch restarts mct-frc during system resume. Reported-by: Jongpill Lee <boyko.lee@samsung.com> Signed-off-by: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-15ARM: EXYNOS4: Fix routing timer interrupt to offline CPUKukjin Kim
The commit 5dfc54e087c15f823ee9b6541d2f0f314e69cbed ("ARM: GIC: avoid routing interrupts to offline CPUs") prevents routing interrupts to offline CPUs. But in case of timer on EXYNOS4, the irq_set_affinity() method is called in percpu_timer_setup() before CPU1 becomes online. So this patch fixes routing timer interrupt to offline CPU. Reported-by: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-15ARM: EXYNOS4: Fix return type of local_timer_setup()Kukjin Kim
According to commmit af90f10d ("ARM: 6759/1: smp: Select local timers vs broadcast timer support"), the return type of local_timer_setup() should be int instead of void. Reported-by: Changhwan Youn <chaos.youn@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-09-15ARM: EXYNOS4: Fix wrong pll type for vpllJonghwan Choi
The PLL4650C is used for VPLL on EXYNOS4 so should be fixed. Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> [kgene.kim@samsung.com: added message] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-08-19ARM: EXYNOS4: Add restart hook for proper rebootKyungmin Park
This is required to use SWRESET. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-08-19ARM: EXYNOS4: Increase reset delay for USB HOST PHYYulgon Kim
This patch increases reset delay from 50 usec to 80 usec for USB HOST PHY. In order to reset USB HOST PHY controller properly, a little extra time is required during its reset cycle. Signed-off-by: Yulgon Kim <yulgon.kim@samsung.com> Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-08-19ARM: EXYNOS4: add required chained_irq_enter/exit to eint codeMarek Szyprowski
This patch adds chained IRQ enter/exit functions to external interrupt handler in order to function correctly on primary controllers with different methods of flow control. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-08-19ARM: EXYNOS4: Fix the IRQ definitions for MIPI CSIS deviceSylwester Nawrocki
This is a regression fix after migration to the external GIC. The breakage has been introduced in commit 69644a8e23ab ("ARM: EXYNOS4: modify interrupt mappings for external GIC") Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> [kgene.kim@samsung.com: added commit id] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-08-19ARM: EXYNOS4: remove duplicated inclusionHuang Weiyi
Remove duplicated #include('s) in arch/arm/mach-exynos4/cpu.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-08-19ARM: EXYNOS4: Fix wrong devname to support clkdevJonghwan Choi
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-08-19ARM: EXYNOS4: Use the correct regulator names on universal_c210Kyungmin Park
Use the correct regulator names for cpufreq Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-07-25Merge branch 'next/cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (133 commits) ARM: EXYNOS4: Change devname for FIMD clkdev ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xx ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210 ARM: S5PC100: Cleanup mach/regs-fb.h from mach-s5pc100 ARM: S3C24XX: Use generic s3c_set_platdata for devices ARM: S3C64XX: Use generic s3c_set_platdata for OneNAND ARM: SAMSUNG: Use generic s3c_set_platdata for NAND ARM: SAMSUNG: Use generic s3c_set_platdata for USB OHCI ARM: SAMSUNG: Use generic s3c_set_platdata for HWMON ARM: SAMSUNG: Use generic s3c_set_platdata for FB ARM: SAMSUNG: Use generic s3c_set_platdata for TS ARM: S3C64XX: Add PWM backlight support on SMDK6410 ARM: S5P64X0: Add PWM backlight support on SMDK6450 ARM: S5P64X0: Add PWM backlight support on SMDK6440 ARM: S5PC100: Add PWM backlight support on SMDKC100 ARM: S5PV210: Add PWM backlight support on SMDKV210 ARM: EXYNOS4: Add PWM backlight support on SMDKC210 ARM: EXYNOS4: Add PWM backlight support on SMDKV310 ARM: SAMSUNG: Create a common infrastructure for PWM backlight support clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0 ... Fix up trivial conflict in arch/arm/mach-imx/mach-scb9328.c
2011-07-24Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] s5pv210: make needlessly global symbols static [CPUFREQ] exynos4210: make needlessly global symbols static [CPUFREQ] S3C6410: Add some lower frequencies for 800MHz base clock operation [CPUFREQ] S5PV210: Add reboot notifier to prevent system hang [CPUFREQ] S5PV210: Adjust udelay prior to voltage scaling down [CPUFREQ] S5PV210: Lock a mutex while changing the cpu frequency [CPUFREQ] S5PV210: Add pm_notifier to prevent system unstable [CPUFREQ] S5PV210: Add arm/int voltage control support [CPUFREQ] S5PV210: Add additional symantics for "relation" in cpufreq with pm [CPUFREQ] S3C64xx: Notify transition complete as soon as frequency changed [CPUFREQ] S3C6410: Support 800MHz operation in cpufreq [CPUFREQ] s5pv210-cpufreq.c: Add missing clk_put [CPUFREQ] Move compile for S3C64XX cpufreq to /drivers/cpufreq [CPUFREQ] Remove some vi noise that escaped into the Makefile. [CPUFREQ] Move ARM Samsung cpufreq drivers to drivers/cpufreq/ [CPUFREQ/S3C64xx] Move S3C64xx CPUfreq driver into drivers/cpufreq [CPUFREQ] Handle CPUs with different capabilities in acpi-cpufreq
2011-07-22Merge branches 'btc', 'dma', 'entry', 'fixes', 'linker-layout', 'misc', ↵Russell King
'mmci', 'suspend' and 'vfp' into for-next
2011-07-21ARM: EXYNOS4: Enable MFC on Samsung NURIMarek Szyprowski
2011-07-21ARM: EXYNOS4: Enable MFC on universal_c210Kamil Debski
Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: S5P: Add support for MFC deviceKamil Debski
Add support for MFC device to plat-s5p, mach-exynos4, mach-s5pv210: - clock support - memory mapping and reserving - s5p_device_mfc platform device Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: EXYNOS4: Add support FIMD on SMDKC210Jingoo Han
This patch adds support EXYNOS4 FIMD0 and LTE480WV LCD pannel on Samsung SMDKC210 board. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Jonghun Han <jonghun.han@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: EXYNOS4: Add platform device and helper functions for FIMDJonghun Han
This patch adds platform device s5p_device_fimd0 for EXYNOS4 FIMD0. EXYNOS4 has two FIMDs(FIMD0, FIMD1). FIMD1 will be added later. Some definitions used to enable EXYNOS4 FIMD0 are added. Signed-off-by: Jonghun Han <jonghun.han@samsung.com> Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: EXYNOS4: Add resource definition for FIMDJonghun Han
This patch adds resource definitions for EXYNOS4 FIMD. IRQ and SFR definitions are added. Signed-off-by: Jonghun Han <jonghun.han@samsung.com> Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: EXYNOS4: Change devname for FIMD clkdevJingoo Han
According to SoC name, EXYNOS4, this patch changes devname for FIMD from 's5pv310-fb' to 'exynos4-fb'. Signed-off-by: Jingoo Han <jg1.han@samsung.com> [kgene.kim@samsung.com: removed to change wrong clock name] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21Merge branch 'next-samsung-clkdev-fix' into next-samsung-develKukjin Kim
2011-07-21ARM: SAMSUNG: Add platform device for idmaSangbeom Kim
Exynos4 and S5PC110(S5PV210) has Internal dma(idma) in AUDSS. To support idma, register idma platform device. and Exynos4 and S5PC110 has different IDMA address. TO handle different IDMA address, register idma platform data Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: EXYNOS4: Add more registers to be saved and restored for PMMyungJoo Ham
We need more registers to be saved and restored for PM of EXYNOS4210. Otherwise, with additional drivers running, suspend-to-RAM fails to wake up properly. This patch adds registers omitted in the initial PM patches. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: EXYNOS4: Add more register addresses of CMUMyungJoo Ham
These registers are crucial for PM to work properly. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: EXYNOS4: Add PWM backlight support on SMDKC210Banajit Goswami
This patch adds support for LCD backlight using PWM timer for Samsung SMDKC210 board. Signed-off-by: Banajit Goswami <banajit.g@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: EXYNOS4: Add PWM backlight support on SMDKV310Banajit Goswami
This patch adds support for LCD backlight using PWM timer for Samsung SMDKV310 board. Signed-off-by: Banajit Goswami <banajit.g@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21Merge branch 'next-samsung-clkdev-fix' into next-samsung-cleanupKukjin Kim
2011-07-21ARM: SAMSUNG: Added mach/clkdev.hThomas Abraham
This is temporary patch for building with clkdev. Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: EXYNOS4: Add clkdev supportThomas Abraham
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com> [kgene.kim@samsung.com: removed changes of mach-exynos4/time.c] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: EXYNOS4: Add platform device for dwmci driverSeungwon Jeon
This patch adds platform device for Synopsys DesignWare Multimedia Card Interface driver. Signed-off-by: Seungwon Jeon <tgih.jun@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: EXYNOS4: configure rtc-s3c on NURIMyungJoo Ham
2011-07-21ARM: EXYNOS4: configure MAX8903 secondary charger on NURIMyungJoo Ham
2011-07-21ARM: EXYNOS4: configure ADC on NURIMyungJoo Ham
2011-07-21ARM: EXYNOS4: configure MAX17042 fuel gauge on NURIMyungJoo Ham
2011-07-21ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURIMyungJoo Ham
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> [kgene.kim@samsung.com: Fix build - inclusion of max8997-private.h] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-21ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQsMyungJoo Ham
MAX8997/17042, which are used by Exynos4-NURI, use additional IRQ numbers after GPIO's IRQs. The patch creates some room for those devices. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: EXYNOS4: Support ADCMyungJoo Ham
2011-07-20ARM: EXYNOS4: Add save/restore function for PLLJaecheol Lee
The PLL restore routine supports waiting pll locking. If PLL is enabled in restoring sequence, it should wait until PLL is locked. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: EXYNOS4: Add save/restore for other ARM registersJaecheol Lee
This patch adds save/restore values for Power Control Register and Diagnostic Register for PM. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: EXYNOS4: Move S5P_CENTRAL_SEQ_CONFIGURATION setting for PMJaecheol Lee
We need to balance between set and check S5P_CENTRAL_SEQ_CONFIGURATION register in syscore_ops suspend/resume function when failure in enter suspend mode. Moved this register setting for PM for the purpose of balancing. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: EXYNOS4: Support early wakeup entering sleep modeJaecheol Lee
Since early wakeup can be handled in pm so we don't need masking interrupts of external GIC. When the early wakeup interrupt happens, PMU(Power Management Unit) ignores WFI instruction. This means that PC(Program Counter) passed without any changes. This patch can handle that case by early wakeup interrupt. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> [kgene.kim@samsung.com: fixed return of exynos4_cpu_suspend()] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: EXYNOS4: Remove PMU configuration for S2RAMJaecheol Lee
PMU(Power Management Unit) configuraion for S2RAM(SLEEP) is removed and using function which provided by PMU support code to configure PMU register. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: EXYNOS4: Support system level power down configurationJaecheol Lee
EXYNOS4 supports 3 different system level power down mode by PMU (Power Management Unit). Each power down mode need to configure many PMU registers with different value. This patch supports function to configure PMU registers with pre-defined values in PMU code. This function may be used by PM code and AFTR/LPA support driver. Signed-off-by: Jaecheol Lee <jc.lee@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2011-07-20ARM: EXYNOS4: Add SPDIF for SMDKV310Naveen Krishna Chatradhi
This patch adds spdif to the machine supported device list for SMDKV310. Signed-off-by: Naveen Krishna Chatradhi <ch.naveen@samsung.com> Acked-by: Jassi Brar <jassisinghbrar@gmail.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
