[ Upstream commit 4d8e3e951a856777720272ce27f2c738a3eeef8c ]
During early system resume on Exynos5422 with performance counters enabled
the following kernel oops happens:
Internal error: Oops - undefined instruction: 0 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 1433 Comm: bash Tainted: G W 5.0.0-rc5-next-20190208-00023-gd5fb5a8a13e6-dirty #5480
Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
Flags: nZCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment none
Control: 10c5387d Table: 4451006a DAC: 00000051
Process bash (pid: 1433, stack limit = 0xb7e0e22f)
(reset_ctrl_regs) from [<c0112ad0>] (dbg_cpu_pm_notify+0x1c/0x24)
(dbg_cpu_pm_notify) from [<c014c840>] (notifier_call_chain+0x44/0x84)
(notifier_call_chain) from [<c014cbc0>] (__atomic_notifier_call_chain+0x7c/0x128)
(__atomic_notifier_call_chain) from [<c01ffaac>] (cpu_pm_notify+0x30/0x54)
(cpu_pm_notify) from [<c055116c>] (syscore_resume+0x98/0x3f4)
(syscore_resume) from [<c0189350>] (suspend_devices_and_enter+0x97c/0xe74)
(suspend_devices_and_enter) from [<c0189fb8>] (pm_suspend+0x770/0xc04)
(pm_suspend) from [<c0187740>] (state_store+0x6c/0xcc)
(state_store) from [<c09fa698>] (kobj_attr_store+0x14/0x20)
(kobj_attr_store) from [<c030159c>] (sysfs_kf_write+0x4c/0x50)
(sysfs_kf_write) from [<c0300620>] (kernfs_fop_write+0xfc/0x1e0)
(kernfs_fop_write) from [<c0282be8>] (__vfs_write+0x2c/0x160)
(__vfs_write) from [<c0282ea4>] (vfs_write+0xa4/0x16c)
(vfs_write) from [<c0283080>] (ksys_write+0x40/0x8c)
(ksys_write) from [<c0101000>] (ret_fast_syscall+0x0/0x28)
Undefined instruction is triggered during CP14 reset, because bits: #16
(Secure privileged invasive debug disabled) and #17 (Secure privileged
noninvasive debug disable) are set in DSCR. Those bits depend on SPNIDEN
and SPIDEN lines, which are provided by Secure JTAG hardware block. That
block in turn is powered from cluster 0 (big/Eagle), but the Exynos5422
boots on cluster 1 (LITTLE/KFC).
To fix this issue it is enough to turn on the power on the cluster 0 for
a while. This lets the Secure JTAG block to propagate the needed signals
to LITTLE/KFC cores and change their DSCR.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
commit 629266bf7229cd6a550075f5961f95607b823b59 upstream.
The call to of_get_next_child returns a node pointer with refcount
incremented thus it must be explicitly decremented after the last
usage.
Detected by coccinelle with warnings like:
arch/arm/mach-exynos/firmware.c:201:2-8: ERROR: missing of_node_put;
acquired a node pointer with refcount incremented on line 193,
but without a corresponding object release within this function.
Cc: stable@vger.kernel.org
Signed-off-by: Wen Yang <wen.yang99@zte.com.cn>
[ Upstream commit cd4806911cee3901bc2b5eb95603cf1958720b57 ]
For most of Exynos SoCs, Power Management Unit (PMU) address space is
mapped into global variable 'pmu_base_addr' very early when initializing
PMU interrupt controller. A lot of other machine code depends on it so
when doing iounmap() on this address, clear the global as well to avoid
usage of invalid value (pointing to unmapped memory region).
Properly mapped PMU address space is a requirement for all other machine
code so this fix is purely theoretical. Boot will fail immediately in
many other places after following this error path.
commit a7480dbcf983c31d8111f864c848e8a75116a87d upstream.
Since commit 04c8b0f82c7d ("irqchip/gic: Make locking a BL_SWITCHER only
feature") coupled CPU idle freezes from time to time on Exynos4210. Later
commit 313c8c16ee62 ("PM / CPU: replace raw_notifier with atomic_notifier")
changed the context in which the CPU idle code is executed, what results
in fully reproducible freeze all the time. However, almost the same coupled
CPU idle code works fine on Exynos3250 regardless of the changes made in
the mentioned commits.
It turned out that the IPI call used on Exynos4210 is conflicting with the
change done in the first mentioned commit in GIC. Fix this by using the
same code path as for Exynos3250, instead of the IPI call for
synchronization with second CPU core, call dsb_sev() directly.
Tested on Exynos4210-based Trats and Origen boards.
CC: <stable@vger.kernel.org> # v4.13+
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Pull ARM updates from Russell King:
"Low priority fixes and updates for ARM:
- add some missing includes
- efficiency improvements in system call entry code when tracing is
enabled
- ensure ARMv6+ is always built as EABI
- export save_stack_trace_tsk()
- fix fatal signal handling during mm fault
- build translation table base address register from scratch
- appropriately align the .data section to a word boundary where we
rely on that data being word aligned"
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm:
ARM: 8691/1: Export save_stack_trace_tsk()
ARM: 8692/1: mm: abort uaccess retries upon fatal signal
ARM: 8690/1: lpae: build TTB control register value from scratch in v7_ttb_setup
ARM: align .data section
ARM: always enable AEABI for ARMv6+
ARM: avoid saving and restoring registers unnecessarily
ARM: move PC value into r9
ARM: obtain thread info structure later
ARM: use aliases for registers in entry-common
ARM: 8689/1: scu: add missing errno include
ARM: 8688/1: pm: add missing types include
Now that we have a custom printf format specifier, convert users of
full_name to use %pOF instead. This is preparation to remove storing
of the full path string for each node.
Signed-off-by: Rob Herring <robh@kernel.org>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Javier Martinez Canillas <javier@osg.samsung.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Tony Lindgren <tony@atomide.com>
Cc: "Benoît Cousson" <bcousson@baylibre.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Robert Jarzmik reports that his PXA25x system fails to boot with 4.12,
failing at __flush_whole_cache in arch/arm/mm/proc-xscale.S:215:
0xc0019e20 <+0>: ldr r1, [pc, #788]
0xc0019e24 <+4>: ldr r0, [r1] <== here
with r1 containing 0xc06f82cd, which is the address of "clean_addr".
Examination of the System.map shows:
c06f22c8 D user_pmd_table
c06f22cc d __warned.19178
c06f22cd d clean_addr
indicating that a .data.unlikely section has appeared just before the
.data section from proc-xscale.S. According to objdump -h, it appears
that our assembly files default their .data alignment to 2**0, which
is bad news if the preceding .data section size is not power-of-2
aligned at link time.
Add the appropriate .align directives to all assembly files in arch/arm
that are missing them where we require an appropriate alignment.
Reported-by: Robert Jarzmik <robert.jarzmik@free.fr>
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
- nommu updates from Afzal Mohammed cleaning up the vectors support
- allow DMA memory "mapping" for nommu Benjamin Gaignard
- fixing a correctness issue with R_ARM_PREL31 relocations in the
module linker
- add strlen() prototype for the decompressor
- support for DEBUG_VIRTUAL from Florian Fainelli
- adjusting memory bounds after memory reservations have been
registered
- unipher cache handling updates from Masahiro Yamada
- initrd and Thumb Kconfig cleanups
* 'for-linus' of git://git.armlinux.org.uk/~rmk/linux-arm: (23 commits)
ARM: mm: round the initrd reservation to page boundaries
ARM: mm: clean up initrd initialisation
ARM: mm: move initrd init code out of arm_memblock_init()
ARM: 8655/1: improve NOMMU definition of pgprot_*()
ARM: 8654/1: decompressor: add strlen prototype
ARM: 8652/1: cache-uniphier: clean up active way setup code
ARM: 8651/1: cache-uniphier: include <linux/errno.h> instead of <linux/types.h>
ARM: 8650/1: module: handle negative R_ARM_PREL31 addends correctly
ARM: 8649/2: nommu: remove Hivecs configuration is asm
ARM: 8648/2: nommu: display vectors base
ARM: 8647/2: nommu: dynamic exception base address setting
ARM: 8646/1: mmu: decouple VECTORS_BASE from Kconfig
ARM: 8644/1: Reduce "CPU: shutdown" message to debug level
ARM: 8641/1: treewide: Replace uses of virt_to_phys with __pa_symbol
ARM: 8640/1: Add support for CONFIG_DEBUG_VIRTUAL
ARM: 8639/1: Define KERNEL_START and KERNEL_END
ARM: 8638/1: mtd: lart: Rename partition defines to be prefixed with PART_
ARM: 8637/1: Adjust memory boundaries after reservations
ARM: 8636/1: Cleanup sanity_check_meminfo
ARM: add CPU_THUMB_CAPABLE to indicate possible Thumb support
All low-level PM/SMP code using virt_to_phys() should actually use
__pa_symbol() against kernel symbols. Update code where relevant to move
away from virt_to_phys().
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Reviewed-by: Laura Abbott <labbott@redhat.com>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Pull ARM SoC driver updates from Arnd Bergmann:
"Driver updates for ARM SoCs.
A handful of driver changes this time around. The larger changes are:
- Reset drivers for hi3660 and zx2967
- AHCI driver for Davinci, acked by Tejun and brought in here due to
platform dependencies
- Cleanups of atmel-ebi (External Bus Interface)
- Tweaks for Rockchip GRF (General Register File) usage (kitchensink
misc register range on the SoCs)
- PM domains changes for support of two new ZTE SoCs (zx296718 and
zx2967)"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (53 commits)
soc: samsung: pmu: Add register defines for pad retention control
reset: make zx2967 explicitly non-modular
reset: core: fix reset_control_put
soc: samsung: pm_domains: Read domain name from the new label property
soc: samsung: pm_domains: Remove message about failed memory allocation
soc: samsung: pm_domains: Remove unused name field
soc: samsung: pm_domains: Use full names in subdomains registration log
sata: ahci-da850: un-hardcode the MPY bits
sata: ahci-da850: add a workaround for controller instability
sata: ahci: export ahci_do_hardreset() locally
sata: ahci-da850: implement a workaround for the softreset quirk
sata: ahci-da850: add device tree match table
sata: ahci-da850: get the sata clock using a connection id
soc: samsung: pmu: Remove duplicated define for ARM_L2_OPTION register
memory: atmel-ebi: Enable the SMC clock if specified
soc: samsung: pmu: Remove unused and duplicated defines
memory: atmel-ebi: Properly handle multiple reference to the same CS
memory: atmel-ebi: Fix the test to enable generic SMC logic
soc: samsung: pm_domains: Add new Exynos5433 compatible
soc: samsung: pmu: Add dummy support for Exynos5433 SoC
Pull ARM SoC platform updates from Arnd Bergmann:
"In the SoC branch we normally collect classic arch/arm/mach-*
contents, i.e. C code changes for SoC platforms. This release cycle
the diffstat is quite nice, in that we're removing 3x the amount of
code that's being added.
The main reason for this is that there's a removal of camera drivers
for Freescale i.MX chips (driver was removed so the device
registration isn't needed any more). There's also removal of display
initialization code for OMAP that is no longer needed.
The rest are mostly minor tweaks and cleanups; constification on
Samsung platforms, cleanup of ux500 platform data, purge of other
unused platform data/device seutp on i.MX and other good stuff.
New SoC support this cycle is for two Allwinner platforms, H2+ and
V3s"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (55 commits)
ARM: ux500: remove deleted file from Makefile
ARM: ep93xx: Disable TS-72xx watchdog before uncompressing
ARM: ux500: cut some platform data
MAINTAINERS: Update for the current location of the bcm2835 tree.
ARM: davinci: remove BUG_ON() from da850_register_sata()
ARM: davinci: da850: model the SATA refclk
ARM: davinci: da850: add con_id for the SATA clock
ARM: davinci: da8xx-dt: add OF_DEV_AUXDATA entry for SATA
arm: mvebu: support for SMP on 98DX3336 SoC
dt-bindings: video: exynos7-decon: Remove obsolete samsung,power-domain property
soc: dove: constify reset_control_ops structures
ARM: mv78xx0: fix possible PCI buffer overflow
MAINTAINERS: transfer maintainership for the EZX platform
ARM: shmobile: rcar-gen2: Add more register documentation
ARM: tegra: paz00: Fix __initdata placement
ARM: OMAP: clock: Remove unused mpurate cmdline option
ARM: davinci: add skeleton for pdata-quirks
arm: sunxi: add support for V3s SoC
ARM: OMAP2+: omap_hwmod: Add support for earlycon
arm: hisi: drop extern hip01_cpu_die
Linux 4.10-rc6
Resolved conflicts in:
drivers/pinctrl/pinctrl-amd.c
drivers/pinctrl/samsung/pinctrl-exynos.c
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/soc
Samsung mach/soc update for v4.11, second round:
1. Remove mach code for Exynos4415 as a continuation of removal
of this SoC.
2. Remove obsolete property from the bindings documentation.
* tag 'samsung-soc-4.11-2' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: EXYNOS: Remove Exynos4415 arch code (SoC not supported anymore)
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/drivers
Continuation of improvements for Exynos PM drivers for v4.11:
1. Add support for Exynos5433 to Power Management Unit (PMU) and Power
Domains drivers.
2. Cleanups of duplicated and unused defines.
* tag 'samsung-drivers-soc-pmu-4.11-2' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
The register ARM_L2_OPTION (0x2608 in Exynos4 and Exynos5 PMU) was
defined twice. Both names were used in the Exynos542x code. Simplify
this.
This patch moves pad retention control from PMU driver to Exynos pin
controller driver. This helps to avoid possible ordering and logical
dependencies between machine, PMU and pin control code. Till now it
worked fine only because sys_ops for PMU and pin controller were called
in registration order.
This is also a preparation for adding new features to Exynos pin
controller driver, like runtime power management and suspending
individual pin controllers, which might be a part of some power domain.
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Tomasz Figa <tomasz.figa@gmail.com>
Support for Exynos4415 is going away because there are no internal nor
external users.
Since commit 46dcf0ff0de3 ("ARM: dts: exynos: Remove exynos4415.dtsi"),
the platform cannot be instantiated so remove also the mach code.
Acked-by: Kukjin Kim <kgene@kernel.org>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
Samsung mach/soc update for v4.11. Mostly cleanups:
1. Removal of unused platform data in S3C24XX and S3C64xx as follow up of
conversion to new DMA channel request API.
2. Adding const and __ro_after_init to various data in Samsung platforms.
* tag 'samsung-soc-4.11' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: s3c64xx: Constify wake_irqs
ARM: s3c24xx: Constify wake_irqs
ARM: SAMSUNG: Constify array of wake irqs passed to samsung_sync_wakemask
ARM: s3c64xx: Annotate external clock frequencies __ro_after_init
ARM: s3c24xx: Constify few integer tables
ARM: EXYNOS: Annotate iomem and pm_data pointers __ro_after_init
ARM: EXYNOS: Constify list of retention registers
ARM: s3c24xx: Drop unused struct s3c_audio_pdata entries
ARM: s3c64xx: Drop initialization of unused struct s3c_audio_pdata fields
The pointers to __iomem sysram and exynos_pm_data are set only during
initcalls. Later the pointers itself are used only in read-only way so
we can mark them __ro_after_init to increase code safeness.
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
The list of retention registers (release_ret_regs field of struct
exynos_pm_data and arrays with values) are not modified and can be made
const to improve the const safeness.
We can safely remove exynos_smp_init_cpus() hook from mach-exynos/platsmp.c,
as all SMP platforms in mach-exynos can rely on DT for CPU core description
instead of determining number of cores from the SCU.
Signed-off-by: Pankaj Dubey <pankaj.dubey@samsung.com>
Reviewed-by: Alim Akhtar <alim.akhtar@samsung.com>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
"These are updates for platform specific code on 32-bit ARM machines,
essentially anything that can not (yet) be expressed using DT files.
Noteworthy changes include:
- We get support for running in big-endian mode on two platforms:
sunxi (Allwinner) and s3c24xx (old Samsung).
- The recently added Uniphier platform now uses standard PSCI methods
for SMP booting and we remove support for old bootloader versions
that did not support it yet.
- In sunxi, we gain support for the "Nextthing GR8" SoC, which is a
close relative of the Allwinner A13 and R8 chips.
- PXA completes its move over to the generic dmaengine framework and
removes its old private API
- mach-bcm gains support for BCM47189/BCM53573, their first ARM SoC
with integrated 802.11ac wireless networking"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits)
ARM: imx legacy: pca100: move peripheral initialization to .init_late
ARM: imx legacy: mx27ads: move peripheral initialization to .init_late
ARM: imx legacy: mx21ads: move peripheral initialization to .init_late
ARM: imx legacy: pcm043: move peripheral initialization to .init_late
ARM: imx legacy: mx35-3ds: move peripheral initialization to .init_late
ARM: imx legacy: mx27-3ds: move peripheral initialization to .init_late
ARM: imx legacy: imx27-visstrim-m10: move peripheral initialization to .init_late
ARM: imx legacy: vpr200: move peripheral initialization to .init_late
ARM: imx legacy: mx31moboard: move peripheral initialization to .init_late
ARM: imx legacy: armadillo5x0: move peripheral initialization to .init_late
ARM: imx legacy: qong: move peripheral initialization to .init_late
ARM: imx legacy: mx31-3ds: move peripheral initialization to .init_late
ARM: imx legacy: pcm037: move peripheral initialization to .init_late
ARM: imx legacy: mx31lilly: move peripheral initialization to .init_late
ARM: imx legacy: mx31ads: move peripheral initialization to .init_late
ARM: imx legacy: mx31lite: move peripheral initialization to .init_late
ARM: imx legacy: kzm: move peripheral initialization to .init_late
MAINTAINERS: update list of Oxnas maintainers
ARM: orion5x: remove extraneous NO_IRQ
ARM: orion: simplify orion_ge00_switch_init
Pull ARM SoC cleanups from Arnd Bergmann:
"The cleanups for v4.9 are a little larger that usual, but thankfully
that is almost exclusively due to removing a significant number of
files that have become obsolete after the still ongoing conversion of
old board files to devicetree.
- for mach-omap2, which is still the largest platform in arch/arm/,
the conversion to DT is finally complete after the Nokia N900 is
now fully supported there, along with the omap3 LDP, and we can
remove those two board files. If no regressions are found, another
large cleanup for the platform will happen as a follow-up, removing
dead code and restructuring the platform based on being DT-only.
- In mach-imx, similar work is ongoing, but has not come that far.
This time, we remove the obsolete board file for the i.MX1
generation, which like i.MX25, i.MX5, i.MX6, and i.MX7 is now
DT-only. The remaining board files are for i.MX2 and i.MX3 machines
based on old ARM926 or ARM1136 cores that should work with DT in
principle.
- realview has just been converted from board files to DT, and a lot
of code gets removed in the process. This is the last
ARM/Keil/Versatile derived platform that was still using board
files, the other ones being integrator, versatile and vexpress. We
can probably merge the remaining code into a single directory in
the near future.
- clps711x had completed the conversion in v4.8, but we accidentally
left the files in place that should have been deleted then"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (21 commits)
ARM: select PCI_DOMAINS config from ARCH_MULTIPLATFORM
ARM: stop *MIGHT_HAVE_PCI* config from being selected redundantly
ARM: imx: (trivial) fix typo and grammar
ARM: clps711x: remove extraneous files
ARM: imx: use IS_ENABLED() instead of checking for built-in or module
ARM: OMAP2+: use IS_ENABLED() instead of checking for built-in or module
ARM: OMAP1: use IS_ENABLED() instead of checking for built-in or module
ARM: imx: remove platform-mxc_rnga
ARM: realview: imply device tree boot
ARM: realview: no need to select SMP_ON_UP explicitly
ARM: realview: delete the RealView board files
ARM: imx: no need to select SMP_ON_UP explicitly
ARM: i.MX: Move SOC_IMX1 into 'Device tree only'
ARM: i.MX: Remove i.MX1 non-DT support
ARM: i.MX: Remove i.MX1 Synertronixx SCB9328 board support
ARM: i.MX: Remove i.MX1 Armadeus APF9328 board support
ARM: mxs: remove obsolete startup code for TX28
ARM: i.MX31 iomux: remove duplicates with alternate name
ARM: i.MX31 iomux: remove plain duplicates
ARM: OMAP2+: Drop legacy board file for LDP
PCI_DOMAINS config should be selected for any SoCs
having more than a single PCIe controller. Without PCI_DOMAINS
config, only one PCIe controller gets registered.
Select PCI_DOMAINS in ARCH_MULTIPLATFORM if PCI is selected, since
it doesn't harm even if a platform has a single PCIe port.
Also remove PCI_DOMAINS being selected from other platform
specific configs.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Acked-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
*MIGHT_HAVE_PCI* config is already selected in ARCH_MULTIPLATFORM.
Don't select it redundantly in all ARCH_MULTIPLATFORM based machines.
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The Exynos PMU node is an interrupt, clock and PMU (Power Management Unit)
controller, and these functionalities are supported by different drivers
that matches the same compatible strings.
Since commit 15cc2ed6dcf9 ("of/irq: Mark initialised interrupt controllers
as populated") the OF core flags interrupt controllers registered with the
IRQCHIP_DECLARE() macro as OF_POPULATED, so platform devices with the same
compatible string as the interrupt controller will not be registered.
This prevents the PMU platform device to be registered so the Exynos PMU
driver is never probed. This breaks (among other things) Suspend-to-RAM.
Fix this by clearing the OF_POPULATED flag in the PMU IRQ init callback,
to allow the Exynos PMU platform driver to be probed. The patch is based
on Philipp Zabel's "ARM: imx6: mark GPC node as not populated after irq
init to probe pm domain driver".
Fixes: 15cc2ed6dcf9 ("of/irq: Mark initialised interrupt controllers as populated")
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Currently there is no user of DMC and CMU SFR offsets so we can safely
remove mapping of their SFR address space and cleanup related offset
macros from mach-exynos.
Now the initial fixes have the big-endian code working on EXYNOS, make sure
we explicitly mark our arch as being big endian capable.
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Pull ARM SoC driver updates from Olof Johansson:
A slew of changes this release cycle. The reset driver tree, that we
merge through arm-soc for historical reasons, is also sizable this
time around.
Among the changes:
- clps711x: Treewide changes to compatible strings, merged here for simplicity.
- Qualcomm: SCM firmware driver cleanups, move to platform driver
- ux500: Major cleanups, removal of old mach-specific infrastructure.
- Atmel external bus memory driver
- Move of brcmstb platform to the rest of bcm
- PMC driver updates for tegra, various fixes and improvements
- Samsung platform driver updates to support 64-bit Exynos platforms
- Reset controller cleanups moving to devm_reset_controller_register() APIs
- Reset controller driver for Amlogic Meson
- Reset controller driver for Hisilicon hi6220
- ARM SCPI power domain support"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (100 commits)
ARM: ux500: consolidate base platform files
ARM: ux500: move soc_id driver to drivers/soc
ARM: ux500: call ux500_setup_id later
ARM: ux500: consolidate soc_device code in id.c
ARM: ux500: remove cpu_is_u* helpers
ARM: ux500: use CLK_OF_DECLARE()
ARM: ux500: move l2x0 init to .init_irq
mfd: db8500 stop passing around platform data
ASoC: ab8500-codec: remove platform data based probe
ARM: ux500: move ab8500_regulator_plat_data into driver
ARM: ux500: remove unused regulator data
soc: raspberrypi-power: add CONFIG_OF dependency
firmware: scpi: add CONFIG_OF dependency
video: clps711x-fb: Changing the compatibility string to match with the smallest supported chip
input: clps711x-keypad: Changing the compatibility string to match with the smallest supported chip
pwm: clps711x: Changing the compatibility string to match with the smallest supported chip
serial: clps711x: Changing the compatibility string to match with the smallest supported chip
irqchip: clps711x: Changing the compatibility string to match with the smallest supported chip
clocksource: clps711x: Changing the compatibility string to match with the smallest supported chip
clk: clps711x: Changing the compatibility string to match with the smallest supported chip
Pull ARM SoC platform updates from Olof Johansson:
"Improved and new platform support for various SoCs:
New SoC support:
- Broadcom BCM23550
- Freescale i.MX7Solo
- Qualcomm MDM9615
- Renesas r8a7792
Improvements:
- convert clps711x to multiplatform
- debug uart improvements for Atmel platforms
- Tango platform improvements: HOTPLUG_CPU, Suspend-to-ram
- OMAP tweaks and improvements to hwmod
- OMAP support for kexec on SMP"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (109 commits)
ARM: davinci: fix build break because of undeclared dm365_evm_snd_data
ARM: s3c64xx: smartq: Avoid sparse warnings
ARM: sti: Implement dummy L2 cache's write_sec
ARM: STi: Update machine _namestr to be more generic.
arm: meson: explicitly select clk drivers
ARM: tango: add Suspend-to-RAM support
ARM: hisi: consolidate the hisilicon machine entries
ARM: tango: fix CONFIG_HOTPLUG_CPU=n build
MAINTAINERS: Update BCM281XX/BCM11XXX/BCM216XX entry
MAINTAINERS: Update BCM63XX entry
MAINTAINERS: Add NS2 entry
MAINTAINERS: Fix nsp false-positives
MAINTAINERS: Change L to M for Broadcom ARM/ARM64 SoC entries
ARM: debug: Enable DEBUG_BCM_5301X for Northstar Plus SoCs
ARM: clps711x: Switch to MULTIPLATFORM
ARM: clps711x: Remove boards support
ARM: clps711x: Add basic DT support
ARM: clps711x: Reduce static map size
ARM: SAMSUNG: Constify iomem address passed to s5p_init_cpu
ARM: oxnas: Change OX810SE default driver config
Pull ARM SoC cleanups from Olof Johansson:
"The cleanup branch keeps going down in size as we've completed a lot
of the major legacy platform removals and conversions.
A handful of changes this time around, some of the themes or larger
sets are:
- A bunch of i.MX cleanups around platform detection, init call cleanups
- Misc fixes of missing/implicit includes
- Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits)
ARM: mps2: fix typo
ARM: s3c64xx: avoid warning about 'struct device_node'
bus: mvebu-mbus: make mvebu_mbus_syscore_ops static
bus: mvebu-mbus: fix __iomem on register pointers
ARM: tegra: Remove board_init_funcs array
ARM: iop: Fix indentation
ARM: imx: remove cpu_is_mx*()
ARM: imx: remove last call to cpu_is_mx5*
ARM: imx: rework mx27_pm_init() call
ARM: imx: deconstruct mx3_idle
ARM: imx: deconstruct mxc_rnga initialization
ARM: imx: remove cpu_is_mx1 check
ARM: i.MX: Do not explicitly call l2x0_of_init()
ARM: i.MX: system.c: Tweak prefetch settings for performance
ARM: i.MX: system.c: Replace magic numbers
ARM: i.MX: system.c: Remove redundant errata 752271 code
ARM: i.MX: system.c: Convert goto to if statement
ARM: Kirkwood: fix kirkwood_pm_init() declaration/type
ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static
ARM: orion5x: make orion5x_legacy_handle_irq static
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree updates from Rob Herring:
- remove most of_platform_populate() calls in arch code. Now the DT
core code calls it in the default case and platforms only need to
call it if they have special needs
- use pr_fmt on all the DT core print statements
- CoreSight binding doc improvements to block name descriptions
- add dt_to_config script which can parse dts files and list
corresponding kernel config options
- fix memory leak hit with a PowerMac DT
- correct a bunch of STMicro compatible strings to use the correct
vendor prefix
- fix DA9052 PMIC binding doc to match what is actually used in dts
files
* tag 'devicetree-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (35 commits)
documentation: da9052: Update regulator bindings names to match DA9052/53 DTS expectations
xtensa: Partially Revert "xtensa: Remove unnecessary of_platform_populate with default match table"
xtensa: Fix build error due to missing include file
MIPS: ath79: Add missing include file
Fix spelling errors in Documentation/devicetree
ARM: dts: fix STMicroelectronics compatible strings
powerpc/dts: fix STMicroelectronics compatible strings
Documentation: dt: i2c: use correct STMicroelectronics vendor prefix
scripts/dtc: dt_to_config - kernel config options for a devicetree
of: fdt: mark unflattened tree as detached
of: overlay: add resolver error prints
coresight: document binding acronyms
Documentation/devicetree: document cavium-pip rx-delay/tx-delay properties
of: use pr_fmt prefix for all console printing
of: fix memory leak related to safe_name()
Revert "of/platform: export of_default_bus_match_table"
of: unittest: use of_platform_default_populate() to populate default bus
memory: omap-gpmc: use of_platform_default_populate() to populate default bus
bus: uniphier-system-bus: use of_platform_default_populate() to populate default bus
* commit '5c34a4e89c743339f78cafb2f2a826a010f0746a':
ARM: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB
ARM: uniphier: drop code for old DT binding
These cause a harmless conflict with the clps711x multiplatform
support, and it's easy to resolve.
After patch "of/platform: Add common method to populate default bus",
it is possible for arch code to remove unnecessary callers of
of_platform_populate with default match table.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Ray Jui <rjui@broadcom.com>
Cc: Lee Jones <lee@kernel.org>
Cc: Krzysztof Halasa <khalasa@piap.pl>
Cc: Rob Herring <robh@kernel.org>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Santosh Shilimkar <ssantosh@kernel.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Heiko Stuebner <heiko@sntech.de>
Cc: Viresh Kumar <vireshk@kernel.org>
Cc: Shiraz Hashim <shiraz.linux.kernel@gmail.com>
Cc: Tony Prisk <linux@prisktech.co.nz>
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
The declaration of s5p_init_cpu() in arch/arm/mach-exynos/common.h
is not included in the platform file arch/arm/plat-samsung/cpu.c
which generates a warning.
Fix the following warning by moving the declaration to somewhere
both the machine and platform code can get to it, and including
the right files as necessary:
arch/arm/plat-samsung/cpu.c:47:13: warning: symbol 's5p_init_cpu' was not declared. Should it be static?
Fix the PMU code endian access code to deal with kernels built for
big endian operation by changing the __raw IO accessors to the
_relaxed variants.
Fix the PMU code endian access code to deal with kernels built for big endian
operation.
If the kernel is built big endian, then using the __raw read and write IO
accessors is not going to work as they end up writing big-endian data to
little-endian IO registers. Fix this by using the readl and writel relaxed
versions which ensure little endian IO.
Topic branch for Exynos MFC changes for v4.8:
Pull s5p-mfc changes from media tree so the arm/mach-exynos code
could be removed. The bindings are converted to generic reserved memory
bindings.
* tag 'samsung-drivers-exynos-mfc-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: dts: exynos: Enable MFC device on Exynos4412 Odroid boards
ARM: dts: exynos: Convert MFC device to generic reserved memory bindings
ARM: EXYNOS: Remove code for MFC custom reserved memory handling
media: s5p-mfc: add iommu support
media: s5p-mfc: replace custom reserved memory handling code with generic one
media: s5p-mfc: use generic reserved memory bindings
of: reserved_mem: add support for using more than one region for given device
media: set proper max seg size for devices on Exynos SoCs
media: vb2-dma-contig: add helper for setting dma max seg size
s5p-mfc: Fix race between s5p_mfc_probe() and s5p_mfc_open()
s5p-mfc: Add release callback for memory region devs
s5p-mfc: Set device name for reserved memory region devs
Once MFC driver has been converted to generic reserved memory bindings,
there is no need for custom memory reservation code.
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
This replaces:
- "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can
now be selected directly.
- "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB
is now selectable by everyone, so we need not declare our
intent to select it.
When ordering the symbols the following rationale was used:
if the selects were in alphabetical order, I moved select GPIOLIB
to be in alphabetical order, but if the selects were not
maintained in alphabetical order, I just replaced
"select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB".
Cc: Michael Büsch <m@bues.ch>
Cc: arm@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into fixes
Two fixes for v4.7 cycle for build issues:
1. Fix samsung-keypad build error if INPUT is selected as module.
The error though depends on some uncommon build settings so it
is not as easy to trigger.
2. Get rid of 'samsung_device_dma_mask' defined but not used warning.
* tag 'samsung-fixes-4.7' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: exynos: don't select keyboard driver
ARM: samsung: improve static dma_mask definition
Introduce a platform selectable symbol EXYNOS_PM_DOMAINS which can be
also toggled on by COMPILE_TEST for some build coverage.
Exynos PM domains driver does not have mach-specific dependencies so it
can be safely moved out of arm/mach-exynos to drivers/soc. This in
future will allow re-using it on ARM64 boards.
"Driver updates for ARM SoCs, these contain various things that touch
the drivers/ directory but got merged through arm-soc for practical
reasons.
For the most part, this is now related to power management
controllers, which have not yet been abstracted into a separate
subsystem, and typically require some code in drivers/soc or arch/arm
to control the power domains.
Another large chunk here is a rework of the NVIDIA Tegra USB3.0
support, which was surprisingly tricky and took a long time to get
done.
Finally, reset controller handling as always gets merged through here
as well"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (97 commits)
arm-ccn: Enable building as module
soc/tegra: pmc: Add generic PM domain support
usb: xhci: tegra: Add Tegra210 support
usb: xhci: Add NVIDIA Tegra XUSB controller driver
dt-bindings: usb: xhci-tegra: Add Tegra210 XUSB controller support
dt-bindings: usb: Add NVIDIA Tegra XUSB controller binding
PCI: tegra: Support per-lane PHYs
dt-bindings: pci: tegra: Update for per-lane PHYs
phy: tegra: Add Tegra210 support
phy: Add Tegra XUSB pad controller support
dt-bindings: phy: tegra-xusb-padctl: Add Tegra210 support
dt-bindings: phy: Add NVIDIA Tegra XUSB pad controller binding
phy: core: Allow children node to be overridden
clk: tegra: Add interface to enable hardware control of SATA/XUSB PLLs
drivers: firmware: psci: make two helper functions inline
soc: renesas: rcar-sysc: Add support for R-Car H3 power areas
soc: renesas: rcar-sysc: Add support for R-Car E2 power areas
soc: renesas: rcar-sysc: Add support for R-Car M2-N power areas
soc: renesas: rcar-sysc: Add support for R-Car M2-W power areas
soc: renesas: rcar-sysc: Add support for R-Car H2 power areas
The samsung-keypad driver is implicitly selected by ARCH_EXYNOS4 (why?),
but this fails if CONFIG_INPUT is a loadable module:
drivers/input/built-in.o: In function `samsung_keypad_remove':
drivers/input/keyboard/samsung-keypad.c:461: undefined reference to `input_unregister_device'
drivers/input/built-in.o: In function `samsung_keypad_irq':
drivers/input/keyboard/samsung-keypad.c:137: undefined reference to `input_event'
include/linux/input.h:389: undefined reference to `input_event'
drivers/input/built-in.o: In function `samsung_keypad_probe':
drivers/input/keyboard/samsung-keypad.c:358: undefined reference to `devm_input_allocate_device'
drivers/input/built-in.o:(.debug_addr+0x34): undefined reference to `input_set_capability'
This removes the 'select' as suggested by Krzysztof Kozlowski and
instead enables the driver from the defconfig files.
The problem does not happen on mainline kernels, as we don't normally
build built-in input drivers when CONFIG_INPUT=m, but I am experimenting
with a patch to change this, and the samsung keypad driver showed up
as one example that was silently broken before.
Link: https://lkml.org/lkml/2016/2/14/55
* pm-cpufreq: (63 commits)
intel_pstate: Clean up get_target_pstate_use_performance()
intel_pstate: Use sample.core_avg_perf in get_avg_pstate()
intel_pstate: Clarify average performance computation
intel_pstate: Avoid unnecessary synchronize_sched() during initialization
cpufreq: schedutil: Make default depend on CONFIG_SMP
cpufreq: powernv: del_timer_sync when global and local pstate are equal
cpufreq: powernv: Move smp_call_function_any() out of irq safe block
intel_pstate: Clean up intel_pstate_get()
cpufreq: schedutil: Make it depend on CONFIG_SMP
cpufreq: governor: Fix handling of special cases in dbs_update()
cpufreq: intel_pstate: Ignore _PPC processing under HWP
cpufreq: arm_big_little: use generic OPP functions for {init, free}_opp_table
cpufreq: tango: Use generic platdev driver
cpufreq: Fix GOV_LIMITS handling for the userspace governor
cpufreq: mvebu: Move cpufreq code into drivers/cpufreq/
cpufreq: dt: Kill platform-data
mvebu: Use dev_pm_opp_set_sharing_cpus() to mark OPP tables as shared
cpufreq: dt: Identify cpu-sharing for platforms without operating-points-v2
cpufreq: governor: Change confusing struct field and variable names
cpufreq: intel_pstate: Enable PPC enforcement for servers
We want to skip reparenting a clock on turning on power domain, if we
do not have the parent yet. The parent is obtained when turning the
domain off. However due to a typo, the loop is continued on IS_ERR() of
clock being reparented, not on the IS_ERR() of the parent.
Theoretically this could lead to OOPS on first turn on of a power
domain, if there was no turn off before. Practically that should never
happen because all power domains are turned on by default (reset value,
bootloader does not turn off them usually) so the first action will be
always turn off.
Fixes: 29e5eea06bc1 ("ARM: EXYNOS: Get current parent clock for power domain on/off")
Reported-by: Vladimir Zapolskiy <vz@mleia.com>
Implement handling properties in subnodes and adding child devices to the
system. Child devices will not be added if configuration fails.
Since the driver now does more than suspend-resume support, dependency on
CONFIG_PM is removed.
Signed-off-by: Pavel Fedin <p.fedin@samsung.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
As now we have dedicated driver for SROM controller, it will take care
of saving register banks during S2R so we can safely remove these
settings from mach-exynos.
Signed-off-by: Kukjin Kim <kgene@kernel.org>
[k.kozlowski: Need to select also SAMSUNG_MC]
