Document the UNCACHEABLE_ADDR definitions for footbridge and SA1100
so that we know where they're located and/or what they're accessing.
Change RiscPC to calculate the UNCACHEABLE_ADDR value from FLUSH_BASE
as that's where we locate that.
UNCACHEABLE_ADDR is used to perform an uncached access (ARMv4
terminology) necessary to force a CPU clock-switch to the memory-
speed clock, as required for entering WFI.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Footbridge has two debug ports that are handled a bit differently:
The 8250 port uses the normal debug/8250.S implementation that is shared
with a lot of other platforms, but it relies on the DEBUG_UART_8250
option to be turned on automatically instead of being selected by
DEBUG_FOOTBRIDGE_COM1 as we do for most other platforms. I'm changing
this to use a 'select' and change the dependency to the debug symbol
rather than the platform symbol for consistency.
The DC21285 UART has a separate top-level option, and relies on
the traditional include/mach/debug-macro.S method. With the s3c64xx
multiplatform series queued up for 4.5, it is now the last one that does
this, so by moving this file to include/debug/dc21285.S, we can get
all platforms to do things the same way.
<mach/memory.h>
The platforms selecting NEED_MACH_MEMORY_H defined the start address of
their physical memory in the respective <mach/memory.h>. With
ARM_PATCH_PHYS_VIRT=y (which is quite common today) this is useless
though because the definition isn't used but determined dynamically.
So remove the definitions from all <mach/memory.h> and provide the
Kconfig symbol PHYS_OFFSET with the respective defaults in case
ARM_PATCH_PHYS_VIRT isn't enabled.
This allows to drop the dependency of PHYS_OFFSET on !NEED_MACH_MEMORY_H
which prevents compiling an integrator nommu-kernel.
(CONFIG_PAGE_OFFSET which has "default PHYS_OFFSET if !MMU" expanded to
"0x" because CONFIG_PHYS_OFFSET doesn't exist as INTEGRATOR selects
NEED_MACH_MEMORY_H.)
next/cleanup
This cleanup series gets rid of <mach/timex.h> for platforms not using
ARCH_MULTIPLATFORM. (For multi-platform code it's already unused since
387798b (ARM: initial multiplatform support).)
To make this work some code out of arch/arm needed to be adapted. The
respective changes got acks by their maintainers to be taken via armsoc
(with Andrew Morton substituting for Alessandro Zummo as rtc maintainer).
Compared to the previous pull request there was another patch added that
fixes a (non-critical) regression on ixp4xx. Olof Johansson asked to not
squash this fix into the original commit to save him from the need to
reverify the series.
* tag 'dropmachtimexh-v2' of git://git.pengutronix.de/git/ukl/linux:
ARM: ixp4xx: fix timer latch calculation
ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, too
ARM: rpc: stop using <mach/timex.h>
ARM: ixp4xx: stop using <mach/timex.h>
input: ixp4xx-beeper: don't use symbols from <mach/timex.h>
ARM: at91: don't use <mach/timex.h>
ARM: ep93xx: stop using mach/timex.h
ARM: mmp: stop using mach/timex.h
ARM: netx: stop using mach/timex.h
ARM: sa1100: stop using mach/timex.h
clocksource: sirf/marco+prima2: drop usage of CLOCK_TICK_RATE
rtc: pxa: drop unused #define TIMER_FREQ
rtc: at91sam9: include <mach/hardware.h> explicitly
ARM/serial: at91: switch atmel serial to use gpiolib
Cleanup the LEDs code to use ioremap()/writeb() to access the register.
This allows us to move the definitions out of a header file directly
into the ebsa285 support code.
While <mach/timex.h> isn't used for multi-platform builds since long it
still is for "normal" builds. As the previous patches fix all sites to
not make use of this per-platform file, it can go now for good also for
platforms that are not (yet) converted to multi-platform.
While at it there are no users of CLOCK_TICK_RATE any more, so also drop
the dummy #define.
Now that the 8250 debug include can stand alone without requiring
platforms to provide any macros, move it into the debug directory
so it can be directly included. This allows us to get rid of a lot
of debug-macros include files.
Move the definition of the UART register addresses out of the platform
specific header file into the Kconfig files.
Move the definition of the UART register shift out of the platform
Move the definition out of the machine class debug-macro.S header
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c,
all the arch_decomp_wdog() definition at platform level is unneeded.
Remmove it.
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Jason Cooper <jason@lakedaemon.net>
This is a series from Arnd that fixes a number of compiler warnings
when building defconfigs on ARM.
* late/fixes:
ARM: footbridge: nw_gpio_lock is raw_spin_lock
ARM: mv78xx0: correct addr_map_cfg __initdata annotation
ARM: footbridge: remove RTC_IRQ definition
ARM: soc: dependency warnings for errata
ARM: ks8695: __arch_virt_to_dma type handling
ARM: rpc: check device_register return code in ecard_probe
ARM: davinci: don't mark da850_register_cpufreq as __init
ARM: iop13xx: fix iq81340sc_atux_map_irq prototype
ARM: iop13xx: mark iop13xx_scan_bus as __devinit
ARM: mv78xx0: mark mv78xx0_timer_init as __init_refok
ARM: s3c24xx: fix multiple section mismatch warnings
ARM: at91: unused variable in at91_pm_verify_clocks
ARM: at91: skip at91_io_desc definition for NOMMU
ARM: pxa: work around duplicate definition of GPIO24_SSP1_SFRM
ARM: pxa: remove sharpsl_fatal_check function
ARM: pxa: define palmte2_pxa_keys conditionally
ARM: pxa: Wunused-result warning in viper board file
ARM: shark: fix shark_pci_init return code
Fixed trivial conflicts in arch/arm/mach-at91/setup.c.
Since commit bd8abc9a32c "ARM: mc146818rtc: remove unnecessary include of
mach/irqs.h", building footbridge_defconfig results in this warning:
In file included from include/linux/mc146818rtc.h:16:0,
from arch/arm/mach-footbridge/isa-rtc.c:21:
arch/arm/include/asm/mc146818rtc.h:10:0: warning: "RTC_IRQ" redefined [enabled by default]
arch/arm/mach-footbridge/include/mach/irqs.h:93:0: note: this is the location of the previous definition
The above commit was intentionally made to catch errors like this,
where code relies on the RTC_IRQ definition. The only driver using
it is the legacy PC-style drivers/char/rtc.c driver.
However, the ARM architecture has been using the RTC_LIB framework
since at least 2006, and that doesn't use it.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: rtc-linux@googlegroups.com
Move footbridge PCI to fixed i/o mapping. io.h is still needed for the
!MMU case.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
__mem_pci is only used to enable readl/writel and friends. Just condition
this on readl being defined and remove all the __mem_pci defines.
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Cc: Imre Kaloz <kaloz@openwrt.org>
Cc: Krzysztof Halasa <khc@pm.waw.pl>
Cc: Nicolas Pitre <nico@fluxnic.net>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Colin Cross <ccross@android.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Stephen Warren <swarren@nvidia.com>
into for-armsoc
Now that most platforms don't need disable_fiq and arch_ret_to_user
macros, we can remove the empty macros or empty entry-macro.S files.
Acked-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Ryan Mallon <rmallon@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
When this is the only content remaining in mach/system.h then the
whole file is removed.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-and-tested-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: David Brown <davidb@codeaurora.org>
arch/arm/mach-exynos/cpu.c
The changes to arch/arm/mach-exynos/cpu.c were moved to
mach-exynos/common.c.
Remove the now empty arch_reset() from all the mach/system.h includes,
and remove its callsite. Remove arm_machine_restart() as this function
no longer does anything useful.
For samsung platforms, remove the include of mach/system-reset.h and
plat/system-reset.h from their respective mach/system.h headers as these
just define their arch_reset functions. As a result, the s3c2410 and
plat-samsung system-reset.h files are no longer referenced, so remove
these files entirely.
Hook these platforms restart code into the new restart hook rather
than using arch_reset().
devel-stable
We only need to set the system up for a soft-restart if we're going to
be doing a soft-restart. Provide a new function (soft_restart()) which
does the setup and final call for this, and make platforms use it.
Eliminate the call to setup_restart() from the default handler.
This means that platforms arch_reset() function is no longer called with
the page tables prepared for a soft-restart, and caches will still be
enabled.
Acked-by: Will Deacon <will.deacon@arm.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: Krzysztof Ha■asa <khc@pm.waw.pl>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits)
ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET
ARM: gic, local timers: use the request_percpu_irq() interface
ARM: gic: consolidate PPI handling
ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H
ARM: mach-s5p64x0: remove mach/memory.h
ARM: mach-s3c64xx: remove mach/memory.h
ARM: plat-mxc: remove mach/memory.h
ARM: mach-prima2: remove mach/memory.h
ARM: mach-zynq: remove mach/memory.h
ARM: mach-bcmring: remove mach/memory.h
ARM: mach-davinci: remove mach/memory.h
ARM: mach-pxa: remove mach/memory.h
ARM: mach-ixp4xx: remove mach/memory.h
ARM: mach-h720x: remove mach/memory.h
ARM: mach-vt8500: remove mach/memory.h
ARM: mach-s5pc100: remove mach/memory.h
ARM: mach-tegra: remove mach/memory.h
ARM: plat-tcc: remove mach/memory.h
ARM: mach-mmp: remove mach/memory.h
ARM: mach-cns3xxx: remove mach/memory.h
Fix up mostly pretty trivial conflicts in:
- arch/arm/Kconfig
- arch/arm/include/asm/localtimer.h
- arch/arm/kernel/Makefile
- arch/arm/mach-shmobile/board-ap4evb.c
- arch/arm/mach-u300/core.c
- arch/arm/mm/dma-mapping.c
- arch/arm/mm/proc-v7.S
- arch/arm/plat-omap/Kconfig
largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP ->
CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and
addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits)
rtmutex: Add missing rcu_read_unlock() in debug_rt_mutex_print_deadlock()
lockdep: Comment all warnings
lib: atomic64: Change the type of local lock to raw_spinlock_t
locking, lib/atomic64: Annotate atomic64_lock::lock as raw
locking, x86, iommu: Annotate qi->q_lock as raw
locking, x86, iommu: Annotate irq_2_ir_lock as raw
locking, x86, iommu: Annotate iommu->register_lock as raw
locking, dma, ipu: Annotate bank_lock as raw
locking, ARM: Annotate low level hw locks as raw
locking, drivers/dca: Annotate dca_lock as raw
locking, powerpc: Annotate uic->lock as raw
locking, x86: mce: Annotate cmci_discover_lock as raw
locking, ACPI: Annotate c3_lock as raw
locking, oprofile: Annotate oprofilefs lock as raw
locking, video: Annotate vga console lock as raw
locking, latencytop: Annotate latency_lock as raw
locking, timer_stats: Annotate table_lock as raw
locking, rwsem: Annotate inner lock as raw
locking, semaphores: Annotate inner lock as raw
locking, sched: Annotate thread_group_cputimer as raw
Fix up conflicts in kernel/posix-cpu-timers.c manually: making
cputimer->cputime a raw lock conflicted with the ABBA fix in commit
bcd5cff7216f ("cputimer: Cure lock inversion").
Some platforms (like OMAP not to name it) are doing rather complicated
hacks just to determine the base UART address to use. Let's give their
addruart macro some slack by providing an extra work register which will
allow for much needed cleanups.
This is basically a no-op as this commit is only adding the extra argument
to the macro but no one is using it yet.
Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org>
Reviewed-by: Kevin Hilman <khilman@ti.com>
Annotate the low level hardware locks which must not be preempted.
In mainline this change documents the low level nature of
the lock - otherwise there's no functional difference. Lockdep
and Sparse checking will work as usual.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Remove IO_SPACE_LIMIT definitions from platforms which have a well
defined ISA or PCI, and has a 64K window.
EBSA110 - well defined set of ISA devices.
Footbridge, Integrator, IXP4xx, VT8500 - PCI platforms.
Convert PCIBIOS_MIN_IO and PCIBIOS_MIN_MEM to variables to allow
multi-platform builds. This also removes the requirement for a platform to
have a mach/hardware.h.
The default values for i/o and mem are 0x1000 and 0x01000000, respectively.
Per Arnd Bergmann, other values are likely to be incorrect, but this commit
does not try to address that issue.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Convert pcibios_assign_all_busses from a define to inline so platforms can
control this setting.
More of the same of 5f2c1b30 (ARM: footbridge: fix debug macros),
this time for the DC21285-based debugging code rather than the 8250-
based debugging code.
arch/arm/kernel/module.c
arch/arm/mach-s5pv210/sleep.S
Use the correct I/O address definitions for Footbridge
peripherals when the kernel is compiled without MMU
support.
Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org>
This uncouple PHYS_OFFSET from the platform definitions, thereby
facilitating run-time computation of the physical memory offset.
Acked-by: Magnus Damm <damm@opensource.se>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
0ea1293 (arm: return both physical and virtual addresses from addruart)
changed the way the 'addruart' worked, making it return both the virt
and phys addresses. Unfortunately, for footbridge, these were reversed.
Fix that. Tested on Netwinder.
Commit 7c63984b86 (ARM: do not define VMALLOC_END relative to PAGE_OFFSET)
changed VMALLOC_END to be an explicit value. Before this, it was
relative to PAGE_OFFSET and therefore converted to unsigned long
as PAGE_OFFSET is an unsigned long. This introduced the following
build warning. Fix this by changing the explicit defines of
VMALLOC_END to be unsigned long.
CC arch/arm/mm/init.o
arch/arm/mm/init.c: In function 'mem_init':
arch/arm/mm/init.c:606: warning: format '%08lx' expects type 'long unsigned int', but argument 12 has type 'unsigned int'
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Acked-by: Uwe Kleine-K <u.kleine-koenig@pengutronix.dee>
Rather than checking the MMU status in every instance of addruart, do it
once in kernel/debug.S, and change the existing addruart macros to
return both physical and virtual addresses. The main debug code can then
select the appropriate address to use.
This will also allow us to retreive the address of a uart for the MMU
state that we're not current in.
Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com>
and Tony Lindgren <tony@atomide.com>, and fix for versatile express from
Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Jason Wang <jason77.wang@gmail.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
VMALLOC_END is supposed to be an absolute value, while PAGE_OFFSET may
vary depending on the selected user:kernel memory split mode through
CONFIG_VMSPLIT_*. In fact, the goal of moving PAGE_OFFSET down is to
accommodate more directly addressed RAM by the kernel below the vmalloc
area, and having VMALLOC_END move along PAGE_OFFSET is rather against
the very reason why PAGE_OFFSET can be moved in the first place.
Otherwise more complicated uart configuration won't be possible.
We can use r1 for tmp register for both head.S and debug.S.
NOTE: This patch depends on another patch to add the the tmp register
into all debug-macro.S files. That can be done with:
$ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/"
arch/arm/*/include/*/debug-macro.S
Anders Grafström reports that footbridge fails to build after 1c4a4f4.
Fix this by adding the necessary definitions for __pfn_to_bus and
__bus_to_pfn.
Reported-by: Anders Grafström <anders.grafstrom@netinsight.net>
OMAP wishes to pass state to the boot loader upon reboot in order to
instruct it whether to wait for USB-based reflashing or not. There is
already a facility to do this via the reboot() syscall, except we ignore
the string passed to machine_restart().
This patch fixes things to pass this string to arch_reset(). This means
that we keep the reboot mode limited to telling the kernel _how_ to
perform the reboot which should be independent of what we request the
boot loader to do.
Netwinder was using gpio_xxx names which could clash with the GPIO
layer. Add a 'nw_' prefix to ensure that these remain separate.
This avoids confusion with platform specific DMA implementations in
mach/dma.h
Avoid unnecessarily pollution of the kernel's namespace by avoiding
mach/hardware.h in mach/io.h. Include this header file where necessary.
Let's provide an overridable default instead of having every machine
class define __virt_to_bus and __bus_to_virt to the same thing. What
most platforms are using is bus_addr == phys_addr so such is the default.
One exception is ebsa110 which has no DMA what so ever, so the actual
definition is not important except only for proper compilation. Also
added a comment about the special footbridge bus translation.
Let's also remove comments alluding to set_dma_addr which is not
(and should not) be commonly used.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
This patch adds a config option (CONFIG_VMSPLIT_*) to allow choosing
between 3:1, 2:2 and 1:3 user:kernel memory splits.
Tested-by: Riku Voipio <riku.voipio@iki.fi>
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
This just leaves include/asm-arm/plat-* to deal with.
