path: root/arch/arm/mach-footbridge
2012-05-13ARM: PCI: provide a default bus scan implementationRussell King
Most PCI implementations perform simple root bus scanning. Rather than having each group of platforms provide a duplicated bus scan function, provide the PCI configuration ops structure via the hw_pci structure, and call the root bus scanning function from core ARM PCI code. Acked-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-13ARM: PCI: get rid of pci_std_swizzle()Russell King
Most PCI implementations use the standard PCI swizzle function, which handles the well defined behaviour of PCI-to-PCI bridges which can be found on cards (eg, four port ethernet cards.) Rather than having almost every platform specify the standard swizzle function, make this the default when no swizzle function is supplied. Therefore, a swizzle function only needs to be provided when there is something exceptional which needs to be handled. This gets rid of the swizzle initializer from 47 files, and leaves us with just two platforms specifying a swizzle function: ARM Integrator and Chalice CATS. Acked-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-04-26ARM: PCI: footbridge: provide a 'no swizzle' function for CATSRussell King
CATS sets its swizzle function to zero, which at the moment means that no swizzling is required. Make this explicit for CATS. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-03-29Merge tag 'cleanup2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull "ARM: cleanups of io includes" from Olof Johansson: "Rob Herring has done a sweeping change cleaning up all of the mach/io.h includes, moving some of the oft-repeated macros to a common location and removing a bunch of boiler plate. This is another step closer to a common zImage for multiple platforms." Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes around it, tegra localtimer.o is *still* gone, yadda-yadda). * tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits) ARM: tegra: Include assembler.h in sleep.S to fix build break ARM: pxa: use common IOMEM definition ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol ARM: __io abuse cleanup ARM: create a common IOMEM definition ARM: iop13xx: fix missing declaration of iop13xx_init_early ARM: fix ioremap/iounmap for !CONFIG_MMU ARM: kill off __mem_pci ARM: remove bunch of now unused mach/io.h files ARM: make mach/io.h include optional ARM: clps711x: remove unneeded include of mach/io.h ARM: dove: add explicit include of dove.h to addr-map.c ARM: at91: add explicit include of hardware.h to uncompressor ARM: ep93xx: clean-up mach/io.h ARM: tegra: clean-up mach/io.h ARM: orion5x: clean-up mach/io.h ARM: davinci: remove unneeded mach/io.h include [media] davinci: remove includes of mach/io.h ARM: OMAP: Remove remaining includes for mach/io.h ARM: msm: clean-up mach/io.h ...
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Disintegrate asm/system.h for ARMDavid Howells
Disintegrate asm/system.h for ARM. Signed-off-by: David Howells <dhowells@redhat.com> cc: Russell King <linux@arm.linux.org.uk> cc: linux-arm-kernel@lists.infradead.org
2012-03-23Merge branch 'for-armsoc' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull #1 ARM updates from Russell King: "This one covers stuff which Arnd is waiting for me to push, as this is shared between both our trees and probably other trees elsewhere. Essentially, this contains: - AMBA primecell device initializer updates - mostly shrinking the size of the device declarations in platform code to something more reasonable. - Getting rid of the NO_IRQ crap from AMBA primecell stuff. - Nicolas' idle cleanups. This in combination with the restart cleanups from the last merge window results in a great many mach/system.h files being deleted." Yay: ~80 files, ~2000 lines deleted. * 'for-armsoc' of git://git.linaro.org/people/rmk/linux-arm: (60 commits) ARM: remove disable_fiq and arch_ret_to_user macros ARM: make entry-macro.S depend on !MULTI_IRQ_HANDLER ARM: rpc: make default fiq handler run-time installed ARM: make arch_ret_to_user macro optional ARM: amba: samsung: use common amba device initializers ARM: amba: spear: use common amba device initializers ARM: amba: nomadik: use common amba device initializers ARM: amba: u300: use common amba device initializers ARM: amba: lpc32xx: use common amba device initializers ARM: amba: netx: use common amba device initializers ARM: amba: bcmring: use common amba device initializers ARM: amba: ep93xx: use common amba device initializers ARM: amba: omap2: use common amba device initializers ARM: amba: integrator: use common amba device initializers ARM: amba: realview: get rid of private platform amba_device initializer ARM: amba: versatile: get rid of private platform amba_device initializer ARM: amba: vexpress: get rid of private platform amba_device initializer ARM: amba: provide common initializers for static amba devices ARM: amba: make use of -1 IRQs warn ARM: amba: u300: get rid of NO_IRQ initializers ...
2012-03-06ARM: kill off __mem_pciRob Herring
__mem_pci is only used to enable readl/writel and friends. Just condition this on readl being defined and remove all the __mem_pci defines. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Lennert Buytenhek <kernel@wantstofly.org> Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Cc: Nicolas Pitre <nico@fluxnic.net> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: Colin Cross <ccross@android.com> Cc: Olof Johansson <olof@lixom.net> Cc: Stephen Warren <swarren@nvidia.com>
2012-02-23arm/PCI: get rid of device resource fixupsBjorn Helgaas
Tell the PCI core about host bridge address translation so it can take care of bus-to-resource conversion for us. CC: Russell King <linux@arm.linux.org.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-02-22Merge branch 'entry-macro-cleanup' of git://sources.calxeda.com/kernel/linux ↵Russell King
into for-armsoc
2012-02-21ARM: remove disable_fiq and arch_ret_to_user macrosRob Herring
Now that most platforms don't need disable_fiq and arch_ret_to_user macros, we can remove the empty macros or empty entry-macro.S files. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Ryan Mallon <rmallon@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2012-01-20ARM: big removal of now unused arch_idle()Nicolas Pitre
When this is the only content remaining in mach/system.h then the whole file is removed. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-and-tested-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-11Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (80 commits) x86/PCI: Expand the x86_msi_ops to have a restore MSIs. PCI: Increase resource array mask bit size in pcim_iomap_regions() PCI: DEVICE_COUNT_RESOURCE should be equal to PCI_NUM_RESOURCES PCI: pci_ids: add device ids for STA2X11 device (aka ConneXT) PNP: work around Dell 1536/1546 BIOS MMCONFIG bug that breaks USB x86/PCI: amd: factor out MMCONFIG discovery PCI: Enable ATS at the device state restore PCI: msi: fix imbalanced refcount of msi irq sysfs objects PCI: kconfig: English typo in pci/pcie/Kconfig PCI/PM/Runtime: make PCI traces quieter PCI: remove pci_create_bus() xtensa/PCI: convert to pci_scan_root_bus() for correct root bus resources x86/PCI: convert to pci_create_root_bus() and pci_scan_root_bus() x86/PCI: use pci_scan_bus() instead of pci_scan_bus_parented() x86/PCI: read Broadcom CNB20LE host bridge info before PCI scan sparc32, leon/PCI: convert to pci_scan_root_bus() for correct root bus resources sparc/PCI: convert to pci_create_root_bus() sh/PCI: convert to pci_scan_root_bus() for correct root bus resources powerpc/PCI: convert to pci_create_root_bus() powerpc/PCI: split PHB part out of pcibios_map_io_space() ... Fix up conflicts in drivers/pci/msi.c and include/linux/pci_regs.h due to the same patches being applied in other branches.
2012-01-06arm/PCI: convert to pci_scan_root_bus() for correct root bus resourcesBjorn Helgaas
Convert from pci_scan_bus() to pci_scan_root_bus() and remove root bus resource fixups. This fixes the problem of "early" and "header" quirks seeing incorrect root bus resources. CC: Russell King <linux@arm.linux.org.uk> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-05Merge branch 'restart' into for-linusRussell King
Conflicts: arch/arm/mach-exynos/cpu.c The changes to arch/arm/mach-exynos/cpu.c were moved to mach-exynos/common.c.
2012-01-05ARM: restart: remove the now empty arch_reset()Russell King
Remove the now empty arch_reset() from all the mach/system.h includes, and remove its callsite. Remove arm_machine_restart() as this function no longer does anything useful. For samsung platforms, remove the include of mach/system-reset.h and plat/system-reset.h from their respective mach/system.h headers as these just define their arch_reset functions. As a result, the s3c2410 and plat-samsung system-reset.h files are no longer referenced, so remove these files entirely. Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-01-05ARM: restart: footbridge: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-12-05Merge branch 'vmalloc' of git://git.linaro.org/people/nico/linux into ↵Russell King
devel-stable
2011-11-26ARM: big removal of now unused vmalloc.h filesNicolas Pitre
2011-11-21ARM: restart: only perform setup for restart when soft-restartingRussell King
We only need to set the system up for a soft-restart if we're going to be doing a soft-restart. Provide a new function (soft_restart()) which does the setup and final call for this, and make platforms use it. Eliminate the call to setup_restart() from the default handler. This means that platforms arch_reset() function is no longer called with the page tables prepared for a soft-restart, and caches will still be enabled. Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: Krzysztof Ha■asa <khc@pm.waw.pl> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-10ARM: restart: allow platforms more flexibility specifying restart modeRussell King
Change 'soft_reboot' into a more generic 'restart_mode' variable, allowing the default restart mode to be specified. Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-26Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) rtmutex: Add missing rcu_read_unlock() in debug_rt_mutex_print_deadlock() lockdep: Comment all warnings lib: atomic64: Change the type of local lock to raw_spinlock_t locking, lib/atomic64: Annotate atomic64_lock::lock as raw locking, x86, iommu: Annotate qi->q_lock as raw locking, x86, iommu: Annotate irq_2_ir_lock as raw locking, x86, iommu: Annotate iommu->register_lock as raw locking, dma, ipu: Annotate bank_lock as raw locking, ARM: Annotate low level hw locks as raw locking, drivers/dca: Annotate dca_lock as raw locking, powerpc: Annotate uic->lock as raw locking, x86: mce: Annotate cmci_discover_lock as raw locking, ACPI: Annotate c3_lock as raw locking, oprofile: Annotate oprofilefs lock as raw locking, video: Annotate vga console lock as raw locking, latencytop: Annotate latency_lock as raw locking, timer_stats: Annotate table_lock as raw locking, rwsem: Annotate inner lock as raw locking, semaphores: Annotate inner lock as raw locking, sched: Annotate thread_group_cputimer as raw ... Fix up conflicts in kernel/posix-cpu-timers.c manually: making cputimer->cputime a raw lock conflicted with the ABBA fix in commit bcd5cff7216f ("cputimer: Cure lock inversion").
2011-10-25Merge branch 'misc' into for-linusRussell King
Conflicts: arch/arm/mach-integrator/integrator_ap.c
2011-10-25Merge branches 'arnd-randcfg-fixes', 'debug', 'io' (early part), 'l2x0', ↵Russell King
'p2v', 'pgt' (early part) and 'smp' into for-linus
2011-10-18Merge branch 'mach_memory_h' of git://git.linaro.org/people/nico/linux into ↵Russell King
devel-stable
2011-10-17ARM: platform fixups: remove mdesc argument to fixup functionRussell King
Get rid of the mdesc pointer in the fixup function call. No one uses the mdesc pointer, it shouldn't be modified anyway, and we can't wrap it, so let's remove it. Platform files found by: $ regexp=$(git grep -h '\.fixup.*=' arch/arm | sed 's!.*= *\([^,]*\),* *!\1!' | sort -u | tr '\n' '|' | sed 's,|$,,;s,|,\\|,g') $ git grep $regexp arch/arm Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-17ARM: 7078/1: Footbridge: Sort KConfig Options alphabeticallyPeter Hüwe
As per request of rmk, the options should be sorted alphabetically. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-17ARM: 7022/1: allow to detect conflicting zreladdrsSascha Hauer
Boards used to specify zreladdr in their Makefile.boot with zreladdr-y := x, so conflicting zreladdrs were silently overwritten. This patch changes this to zreladdr-y += x, so that we end up with multiple words in zreladdr in such a case. We can detect this later and complain if necessary. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-09-26ARM: add an extra temp register to the low level debugging addruart macroNicolas Pitre
Some platforms (like OMAP not to name it) are doing rather complicated hacks just to determine the base UART address to use. Let's give their addruart macro some slack by providing an extra work register which will allow for much needed cleanups. This is basically a no-op as this commit is only adding the extra argument to the macro but no one is using it yet. Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-09-16Merge branch 'for-rmk' of git://linux-arm.org/linux-2.6-wd into devel-stableRussell King
Conflicts: arch/arm/mach-imx/mach-cpuimx27.c
2011-09-13locking, ARM: Annotate low level hw locks as rawThomas Gleixner
Annotate the low level hardware locks which must not be preempted. In mainline this change documents the low level nature of the lock - otherwise there's no functional difference. Lockdep and Sparse checking will work as usual. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-29Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: pm: avoid writing the auxillary control register for ARMv7 ARM: pm: some ARMv7 requires a dsb in resume to ensure correctness ARM: pm: arm920/926: fix number of registers saved ARM: pm: CPU specific code should not overwrite r1 (v:p offset) ARM: 7066/1: proc-v7: disable SCTLR.TE when disabling MMU ARM: 7065/1: kexec: ensure new kernel is entered in ARM state ARM: 7003/1: vexpress: Add clock definition for the SP805. ARM: 7051/1: cpuimx* boards: fix mach-types errors ARM: 7019/1: Footbridge: select CLKEVT_I8253 for ARCH_NETWINDER ARM: 7015/1: ARM errata: Possible cache data corruption with hit-under-miss enabled ARM: 7014/1: cache-l2x0: Fix L2 Cache size calculation. ARM: 6967/1: ep93xx: ts72xx: fix board model detection ARM: 6965/1: ep93xx: add model detection for ts-7300 and ts-7400 boards ARM: cache: detect VIPT aliasing I-cache on ARMv6 ARM: twd: register clockevents device before enabling PPI ARM: realview: ensure visibility of writes during reset ARM: perf: make name of arm_pmu_type consistent ARM: perf: fix prototype of release_pmu ARM: fix perf build with uclibc toolchains
2011-08-25ARM: mach-footbridge: add missing header file <video/vga.h>Bryan Wu
This patch fixes following building error: -- arch/arm/mach-footbridge/dc21285.c: In function 'dc21285_preinit': arch/arm/mach-footbridge/dc21285.c:299:2: error: 'vga_base' undeclared (first use in this function) arch/arm/mach-footbridge/dc21285.c:299:2: note: each undeclared identifier is reported only once for each function it appears in make[1]: *** [arch/arm/mach-footbridge/dc21285.o] Error 1 -- Signed-off-by: Bryan Wu <bryan.wu@canonical.com> Acked-by: Rob Herring <rob.herring@calxeda.com>
2011-08-21ARM: mach-footbridge: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-08-19ARM: 7019/1: Footbridge: select CLKEVT_I8253 for ARCH_NETWINDERAxel Lin
Since commit 8560a6cfc9818edde1fd8677961714b264ffa03d "arm: Footbridge: Use common i8253 clockevent", ARCH_NETWINDER needs to select CLKEVT_I8253. This patch fixes below build error with "make netwinder_defconfig". LD .tmp_vmlinux1 arch/arm/mach-footbridge/built-in.o: In function `isa_timer_init': isa-rtc.c:(.init.text+0x12c8): undefined reference to `clockevent_i8253_init' isa-rtc.c:(.init.text+0x12d0): undefined reference to `i8253_clockevent' arch/arm/mach-footbridge/built-in.o:(.data+0x198): undefined reference to `i8253_clockevent' make: *** [.tmp_vmlinux1] Error 1 Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-17ARM: io: remove IO_SPACE_LIMIT from platforms with ISA/PCI and 64K windowRussell King
Remove IO_SPACE_LIMIT definitions from platforms which have a well defined ISA or PCI, and has a 64K window. EBSA110 - well defined set of ISA devices. Footbridge, Integrator, IXP4xx, VT8500 - PCI platforms. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-29Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: remove printks about disabled bridge windows PCI: fold pci_calc_resource_flags() into decode_bar() PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR PCI: correct pcie_set_readrq write size PCI: pciehp: change wait time for valid configuration access x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems PCI: ARI is a PCIe v2 feature x86/PCI: quirks: Use pci_dev->revision PCI: Make the struct pci_dev * argument of pci_fixup_irqs const. PCI hotplug: cpqphp: use pci_dev->vendor PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device} x86/PCI: config space accessor functions should not ignore the segment argument PCI: Assign values to 'pci_obff_signal_type' enumeration constants x86/PCI: reduce severity of host bridge window conflict warnings PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI PCI: PCIe AER: add aer_recover_queue x86/PCI: select direct access mode for mmconfig option PCI hotplug: Rename is_ejectable which also exists in dock.c
2011-07-26Merge branch 'next/cross-platform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: Consolidate the clkdev header files ARM: set vga memory base at run-time ARM: convert PCI defines to variables ARM: pci: make pcibios_assign_all_busses use pci_has_flag ARM: remove unnecessary mach/hardware.h includes pci: move microblaze and powerpc pci flag functions into asm-generic powerpc: rename ppc_pci_*_flags to pci_*_flags Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
2011-07-22Merge branch 'timers-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mips: Fix i8253 clockevent fallout i8253: Cleanup outb/inb magic arm: Footbridge: Use common i8253 clockevent mips: Use common i8253 clockevent x86: Use common i8253 clockevent i8253: Create common clockevent implementation i8253: Export i8253_lock unconditionally pcpskr: MIPS: Make config dependencies finer grained pcspkr: Cleanup Kconfig dependencies i8253: Move remaining content and delete asm/i8253.h i8253: Consolidate definitions of PIT_LATCH x86: i8253: Consolidate definitions of global_clock_event i8253: Alpha, PowerPC: Remove unused asm/8253pit.h alpha: i8253: Cleanup remaining users of i8253pit.h i8253: Remove I8253_LOCK config i8253: Make pcsp sound driver use the shared i8253_lock i8253: Make pcspkr input driver use the shared i8253_lock i8253: Consolidate all kernel definitions of i8253_lock i8253: Unify all kernel declarations of i8253_lock i8253: Create linux/i8253.h and use it in all 8253 related files
2011-07-22PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.Ralf Baechle
Aside of the usual motivation for constification, this function has a history of being abused a hook for interrupt and other fixups so I turned this function const ages ago in the MIPS code but it should be done treewide. Due to function pointer passing in varous places a few other functions had to be constified as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Anton Vorontsov <avorontsov@mvista.com> To: Chris Metcalf <cmetcalf@tilera.com> To: Colin Cross <ccross@android.com> Acked-by: "David S. Miller" <davem@davemloft.net> To: Eric Miao <eric.y.miao@gmail.com> To: Erik Gilling <konkers@android.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> To: "H. Peter Anvin" <hpa@zytor.com> To: Imre Kaloz <kaloz@openwrt.org> To: Ingo Molnar <mingo@redhat.com> To: Ivan Kokshaysky <ink@jurassic.park.msu.ru> To: Jesse Barnes <jbarnes@virtuousgeek.org> To: Krzysztof Halasa <khc@pm.waw.pl> To: Lennert Buytenhek <kernel@wantstofly.org> To: Matt Turner <mattst88@gmail.com> To: Nicolas Pitre <nico@fluxnic.net> To: Olof Johansson <olof@lixom.net> Acked-by: Paul Mundt <lethal@linux-sh.org> To: Richard Henderson <rth@twiddle.net> To: Russell King <linux@arm.linux.org.uk> To: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-12ARM: set vga memory base at run-timeRob Herring
Convert the incorrectly named PCIMEM_BASE to a variable called vga_base. This removes the dependency on mach/hardware.h. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-12ARM: convert PCI defines to variablesRob Herring
Convert PCIBIOS_MIN_IO and PCIBIOS_MIN_MEM to variables to allow multi-platform builds. This also removes the requirement for a platform to have a mach/hardware.h. The default values for i/o and mem are 0x1000 and 0x01000000, respectively. Per Arnd Bergmann, other values are likely to be incorrect, but this commit does not try to address that issue. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-12ARM: pci: make pcibios_assign_all_busses use pci_has_flagRob Herring
Convert pcibios_assign_all_busses from a define to inline so platforms can control this setting. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-01arm: Footbridge: Use common i8253 clockeventThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: John Stultz <john.stultz@linaro.org> Link: http://lkml.kernel.org/r/20110609130622.241312122@linutronix.de
2011-06-11ARM: footbridge: fix clock event supportRussell King
4e8d7637 (ARM: footbridge: convert to clockevents/clocksource) did not set the cpumask for the clock event device. This causes boot to fail. Add the necessary initialization. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-11ARM: footbridge: fix debug macrosRussell King
More of the same of 5f2c1b30 (ARM: footbridge: fix debug macros), this time for the DC21285-based debugging code rather than the 8250- based debugging code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-09i8253: Consolidate all kernel definitions of i8253_lockRalf Baechle
Move them to drivers/clocksource/i8253.c and remove the implementations in arch/ [ tglx: Avoid the extra file in lib - folded arch patches in. The export will become conditional in a later step ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Link: http://lkml.kernel.org/r/20110601180610.221426078@duck.linux-mips.net Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-06-09i8253: Create linux/i8253.h and use it in all 8253 related filesRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Link: http://lkml.kernel.org/r/20110601180610.054254048@duck.linux-mips.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de> arch/arm/mach-footbridge/isa-timer.c | 2 +- arch/mips/cobalt/time.c | 2 +- arch/mips/jazz/irq.c | 2 +- arch/mips/kernel/i8253.c | 2 +- arch/mips/mti-malta/malta-time.c | 2 +- arch/mips/sgi-ip22/ip22-time.c | 2 +- arch/mips/sni/time.c | 2 +- arch/x86/kernel/apic/apic.c | 2 +- arch/x86/kernel/apm_32.c | 2 +- arch/x86/kernel/hpet.c | 2 +- arch/x86/kernel/i8253.c | 2 +- arch/x86/kernel/time.c | 2 +- drivers/block/hd.c | 2 +- drivers/clocksource/i8253.c | 2 +- drivers/input/gameport/gameport.c | 2 +- drivers/input/joystick/analog.c | 2 +- drivers/input/misc/pcspkr.c | 2 +- include/linux/i8253.h | 11 +++++++++++ sound/drivers/pcsp/pcsp.h | 2 +- 19 files changed, 29 insertions(+), 18 deletions(-)
2011-05-14clocksource: convert footbridge to generic i8253 clocksourceRussell King
Convert the footbridge isa-timer code to use generic i8253 clocksource. Acked-by: John Stultz <john.stultz@linaro.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
