It appears the wrong GPIO registers were used
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@gmail.com>
Makes it consistent with VMALLOC_START
Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com>
Otherwise more complicated uart configuration won't be possible.
We can use r1 for tmp register for both head.S and debug.S.
NOTE: This patch depends on another patch to add the the tmp register
into all debug-macro.S files. That can be done with:
$ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/"
arch/arm/*/include/*/debug-macro.S
flush(void)
Because of the include of the decompress_inflate.c file from
boot/compress/misc.c, there are different flush() defines:
In file included from arch/arm/boot/compressed/misc.c:249:
arch/arm/boot/compressed/../../../../lib/decompress_inflate.c:138:29: error: macro "flush" passed 2 arguments, but takes just 0
Fix this by removing the define of flush() in misc.c for
CONFIG_DEBUG_ICEDCC as it's already defined in mach/uncompress.h,
and that is being included unconditionally.
Also use a static inline function instead of define
for mach-mxc and mach-gemini to avoid similar bug
for those platforms.
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt>
Add it to the new platforms.
v2:
- update copyrights
Adds support for Cortina Systems Gemini family CPUs:
http://www.cortina-systems.com/products/category/18
v3:
- fixed __io(a) to be defined as __typesafe_io(a)
v2:
- #include <asm/io.h> -> <linux/io.h>
- remove asm/system.h include
- revorked mm.c to use named initializers
- removed "empty" dma.h
- updated copyrights
