path: root/arch/arm/mach-gemini
2015-05-12ARM: gemini: fix compiler warning due wrong data typeHans Ulli Kroll
This patch fixes a compiler warning in gemini_restart() issued by commit 7b6d864b48d9 ("reboot:arm: reboot_mode changes from char to enum reboot_mode"). arch/arm/mach-gemini/board-rut1xx.c:93:2: warning: initialization from incompatible pointer type The warning is harmless, and the patch does not need to be backported to stable kernels. Fixes: 7b6d864b48d ("reboot:arm: reboot_mode changes from char to enum reboot_mode.") Signed-off-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2014-04-05Merge tag 'cleanup-3.15' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Arnd Bergmann: "These cleanup patches are mainly move stuff around and should all be harmless. They are mainly split out so that other branches can be based on top to avoid conflicts. Notable changes are: - We finally remove all mach/timex.h, after CLOCK_TICK_RATE is no longer used (Uwe Kleine-König) - The Qualcomm MSM platform is split out into legacy mach-msm and new-style mach-qcom, to allow easier maintainance of the new hardware support without regressions (Kumar Gala) - A rework of some of the Kconfig logic to simplify multiplatform support (Rob Herring) - Samsung Exynos gets closer to supporting multiplatform (Sachin Kamat and others) - mach-bcm3528 gets merged into mach-bcm (Stephen Warren) - at91 gains some common clock framework support (Alexandre Belloni, Jean-Jacques Hiblot and other French people)" * tag 'cleanup-3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (89 commits) ARM: hisi: select HAVE_ARM_SCU only for SMP ARM: efm32: allow uncompress debug output ARM: prima2: build reset code standalone ARM: at91: add PWM clock ARM: at91: move sam9261 SoC to common clk ARM: at91: prepare common clk transition for sam9261 SoC ARM: at91: updated the at91_dt_defconfig with support for the ADS7846 ARM: at91: dt: sam9261: Device Tree support for the at91sam9261ek ARM: at91: dt: defconfig: Added the sam9261 to the list of DT-enabled SOCs ARM: at91: dt: Add at91sam9261 dt SoC support ARM: at91: switch sam9rl to common clock framework ARM: at91/dt: define main clk frequency of at91sam9rlek ARM: at91/dt: define at91sam9rl clocks ARM: at91: prepare common clk transition for sam9rl SoCs ARM: at91: prepare sam9 dt boards transition to common clk ARM: at91: dt: sam9rl: Device Tree for the at91sam9rlek ARM: at91/defconfig: Add the sam9rl to the list of DT-enabled SOCs ARM: at91: Add at91sam9rl DT SoC support ARM: at91: prepare at91sam9rl DT transition ARM: at91/defconfig: refresh at91sam9260_9g20_defconfig ...
2014-02-25ARM: 7989/1: Delete asm/system.hDavid Howells
Delete ARM's asm/system.h. It's the last holdout and should be got rid of. This builds for defconfig, lpc32xx_defconfig, exynos_defconfig + XEN, the previous changed to a Gemini system and an omap3 config with TI_DAVINCI_EMAC. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-12-20ARM: drop <mach/timex.h> for !ARCH_MULTIPLATFORM, tooUwe Kleine-König
While <mach/timex.h> isn't used for multi-platform builds since long it still is for "normal" builds. As the previous patches fix all sites to not make use of this per-platform file, it can go now for good also for platforms that are not (yet) converted to multi-platform. While at it there are no users of CLOCK_TICK_RATE any more, so also drop the dummy #define. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-11-12Merge tag 'gpio-v3.13-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO changes from Linus Walleij: "Here is the bulk of GPIO changes for the v3.13 development cycle. I've got ACKs for the things that affect other subsystems (or it's my own subsystem, like pinctrl). Most of that pertain to an attempt from my side to consolidate and get rid of custom GPIO implementations in the ARM tree. I will continue doing this. The main change this time is the new GPIO descriptor API, background for this can be found in Corbet's summary from this january in LWN: http://lwn.net/Articles/533632/ Summary: - Merged the GPIO descriptor API from Alexandre Courbot. This is a first step toward trying to get rid of the global GPIO numberspace for the future. - Add an API so that driver can flag that a certain GPIO line is being used by a irqchip backend for generating IRQs, so that we can enforce checks, like not allowing users to switch that line to an output at runtime, since this makes no sense. Implemented corresponding calls in a few select drivers. - ACPI GPIO cleanups, refactorings and switch to using the descriptor-based interface. - Support for the TPS80036 Palmas GPIO variant. - A new driver for the Broadcom Kona GPIO SoC IP block. - Device tree support for the PCF857x driver. - A set of ARM GPIO refactorings with the goal of getting rid of a bunch of custom GPIO implementations from the arch/arm/* tree: * Move the IOP GPIO driver to the GPIO subsystem and fix all users to use the gpiolib API for accessing GPIOs. Delete the old custom GPIO implementation. * Delete the unused custom PXA GPIO implemention. * Convert all users of the IXP4 custom GPIO implementation to use gpiolib and delete the custom implementation. * Delete the custom Gemini GPIO implementation, also completely unused. - Various cleanups and renamings" * tag 'gpio-v3.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (85 commits) gpio: gpio-mxs: Remove unneeded dt checks gpio: pl061: don't depend on CONFIG_ARM gpio: bcm-kona: add missing .owner to struct gpio_chip gpiolib: provide a declaration of seq_file in gpio/driver.h gpiolib: include gpio/consumer.h in of_gpio.h for desc_to_gpio() gpio: provide stubs for devres gpio functions gpiolib: devres: add missing headers gpiolib: make GPIO_DEVRES depend on GPIOLIB gpiolib: devres: fix devm_gpiod_get_index() gpiolib / ACPI: document the GPIO descriptor based interface gpiolib / ACPI: allow passing GPIOF_ACTIVE_LOW for GpioInt resources gpiolib / ACPI: add ACPI support for gpiod_get_index() gpiolib / ACPI: convert to gpiod interfaces gpiolib: add gpiod_get() and gpiod_put() functions gpiolib: port of_ functions to use gpiod gpiolib: export descriptor-based GPIO interface Fixup "MAINTAINERS: GPIO-INTEL-MID: add maintainer" gpio: bcm281xx: Don't print addresses of GPIO area in probe() gpio: tegra: use new gpio_lock_as_irq() API gpio: rcar: Include linux/of.h header ...
2013-10-28ARM: gemini: convert to GENERIC_CLOCKEVENTSLinus Walleij
This converts the gemini machine to use generic clockevents by rewriting the timer driver. Cc: arm@kernel.org Cc: Hans Ulli Kroll <ulli.kroll@googlemail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-10-01ARM: gemini: delete <mach/gpio.h>Linus Walleij
The Gemini has no need of a <mach/gpio.h> header as this is only used by the machine-local gpio.c gpiochip driver, which is also only using the irq_to_gpio() macro. Delete the file, move the single macro into the driver and remove the NEED_MACH_GPIO_H flag. Cc: Hans Ulli Kroll <ulli.kroll@googlemail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-08-25ARM: debug: move 8250 debug include into arch/arm/include/debug/Russell King
Now that the 8250 debug include can stand alone without requiring platforms to provide any macros, move it into the debug directory so it can be directly included. This allows us to get rid of a lot of debug-macros include files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: provide 8250 debug uart phys/virt address configuration optionsRussell King
Move the definition of the UART register addresses out of the platform specific header file into the Kconfig files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: provide 8250 debug uart register shift configuration optionRussell King
Move the definition of the UART register shift out of the platform specific header file into the Kconfig files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-25ARM: debug: provide 8250 debug uart flow control configuration optionRussell King
Move the definition out of the machine class debug-macro.S header into the Kconfig files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-05-02Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanup from Olof Johansson: "Here is a collection of cleanup patches. Among the pieces that stand out are: - The deletion of h720x platforms - Split of at91 non-dt platforms to their own Kconfig file to keep them separate - General cleanups and refactoring of i.MX and MXS platforms - Some restructuring of clock tables for OMAP - Convertion of PMC driver for Tegra to dt-only - Some renames of sunxi -> sun4i (Allwinner A10) - ... plus a bunch of other stuff that I haven't mentioned" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits) ARM: i.MX: remove unused ARCH_* configs ARM i.MX53: remove platform ahci support ARM: sunxi: Rework the restart code irqchip: sunxi: Rename sunxi to sun4i irqchip: sunxi: Make use of the IRQCHIP_DECLARE macro clocksource: sunxi: Rename sunxi to sun4i clocksource: sunxi: make use of CLKSRC_OF clocksource: sunxi: Cleanup the timer code ARM: at91: remove trailing semicolon from macros ARM: at91/setup: fix trivial typos ARM: EXYNOS: remove "config EXYNOS_DEV_DRM" ARM: EXYNOS: change the name of USB ohci header ARM: SAMSUNG: Remove unnecessary code for dma ARM: S3C24XX: Remove unused GPIO drive strength register definitions ARM: OMAP4+: PM: Restore CPU power state to ON with clockdomain force wakeup method ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2412 ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2410 ARM: S3C24XX: Removed unneeded dependency on ARCH_S3C24XX for boards ARM: SAMSUNG: Fix typo "CONFIG_SAMSUNG_DEV_RTC" ARM: S5P64X0: Fix typo "CONFIG_S5P64X0_SETUP_SDHCI" ...
2013-04-08arm: Use generic idle loopThomas Gleixner
Use the generic idle loop and replace enable/disable_hlt with the respective core functions. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Magnus Damm <magnus.damm@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Tested-by: Kevin Hilman <khilman@linaro.org> # OMAP Link: http://lkml.kernel.org/r/20130321215233.826238797@linutronix.de
2013-03-14ARM: gemini: get platform to build againArnd Bergmann
There is no defconfig file for gemini, which has lead to a lot of bitrot. This makes the broken board files, the gpio implementation and the reset logic work again, and fixes the build warnings that got introduced with the changes to the readl/writel prototypes. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-02-05Merge tag 'cleanup-decompwdog-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which are unused on ARM architecure. Samsung has some code setting up wdog in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined nowhere, it will not run. Otherwise, system can not boot at all when wdog is set up but no one pats it. * tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: samsung: remove unused arch_decomp_wdog() code ARM: remove unused arch_decomp_wdog() ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-11ARM: remove unused arch_decomp_wdog()Shawn Guo
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c, all the arch_decomp_wdog() definition at platform level is unneeded. Remmove it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Jason Cooper <jason@lakedaemon.net>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-04ARM: gemini: fix the gemini buildLinus Walleij
Test-compiling obscure machines I notice that the gemini (which by the way lacks a defconfig) is broken since some time back. Adding a simple missing include makes it build again. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-06ARM: remove bunch of now unused mach/io.h filesRob Herring
Now that many platforms don't need mach/io.h, remove the unused ones. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Nicolas Pitre <nico@linaro.org>
2012-02-22Merge branch 'entry-macro-cleanup' of git://sources.calxeda.com/kernel/linux ↵Russell King
into for-armsoc
2012-02-21ARM: remove disable_fiq and arch_ret_to_user macrosRob Herring
Now that most platforms don't need disable_fiq and arch_ret_to_user macros, we can remove the empty macros or empty entry-macro.S files. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Ryan Mallon <rmallon@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2012-01-20ARM: big removal of now unused arch_idle()Nicolas Pitre
When this is the only content remaining in mach/system.h then the whole file is removed. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-and-tested-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-20ARM: mach-gemini: move special idle code out of lineNicolas Pitre
... and hook it to arm_pm_idle. Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org>
2011-11-26ARM: big removal of now unused vmalloc.h filesNicolas Pitre
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-27Merge branch 'gpio' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'gpio' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (43 commits) ARM: 7135/1: ep93xx: bring back missing <mach/gpio.h> ARM: 7104/1: plat-pxa: break out GPIO driver specifics ARM: 7103/1: plat-pxa: move PXA GPIO driver to GPIO subsystem ARM: 7042/3: mach-ep93xx: break out GPIO driver specifics ARM: 7101/1: arm/tegra: Replace <mach/gpio.h> with <mach/gpio-tegra.h> ARM: 7094/1: arm/tegra: Move EN_VDD_1V05_GPIO to board-harmony.h ARM: 7083/1: rewrite U300 GPIO to use gpiolib ARM: 7074/1: gpio: davinci: eliminate unused variable warnings ARM: 7063/1: Orion: gpio: add missing include of linux/types.h ARM: 7055/1: arm/tegra: mach/gpio.h: include linux/types.h to fix build ARM: 7054/1: arm/tegra: Delete custom gpio_to_irq, and irq_to_gpio ARM: 7053/1: gpio/tegra: Implement gpio_chip.to_irq ARM: 7052/1: gpio/tegra: Remove use of irq_to_gpio ARM: 7057/1: mach-pnx4008: rename GPIO header ARM: 7056/1: plat-nomadik: kill off <plat/gpio.h> ARM: 7050/1: mach-sa1100: delete irq_to_gpio() function ARM: 7049/1: mach-sa1100: move SA1100 GPIO driver to GPIO subsystem ARM: 7045/1: mach-lpc32xx: break out GPIO driver specifics ARM: 7044/1: mach-lpc32xx: move LPC32XX GPIO driver to GPIO subsystem ARM: 7043/1: mach-ixp2000: rename GPIO header ... Fix up trivial conflicts in arch/arm/mach-u300/Kconfig manually
2011-10-17ARM: 7022/1: allow to detect conflicting zreladdrsSascha Hauer
Boards used to specify zreladdr in their Makefile.boot with zreladdr-y := x, so conflicting zreladdrs were silently overwritten. This patch changes this to zreladdr-y += x, so that we end up with multiple words in zreladdr in such a case. We can detect this later and complain if necessary. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-13ARM: mach-gemini: remove mach/memory.hNicolas Pitre
2011-09-26ARM: add an extra temp register to the low level debugging addruart macroNicolas Pitre
Some platforms (like OMAP not to name it) are doing rather complicated hacks just to determine the base UART address to use. Let's give their addruart macro some slack by providing an extra work register which will allow for much needed cleanups. This is basically a no-op as this commit is only adding the extra argument to the macro but no one is using it yet. Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-08-21ARM: mach-gemini: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-08-12ARM: gpio: make trivial GPIOLIB implementation the defaultRussell King
Rather than marking the mach/gpio.h header files which want to use the trivial GPIOLIB implementation, mark those which do not want to use it instead. This means that by default, you get the trivial implementation and only have to do something extra if you need to. This should encourage the use of the trivial default implementation. As an additional bonus, several gpio.h header files become empty. Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-12ARM: gpio: consolidate trivial gpiolib implementationsRussell King
Consolidate 24 trivial gpiolib implementions out of mach/gpio.h into asm/gpio.h. This is basically the include of asm-generic/gpio.h and the definition of gpio_get_value, gpio_set_value, and gpio_cansleep as described in Documentation/gpio.txt Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: David Brown <davidb@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Tested-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-27Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (97 commits) mtd: kill CONFIG_MTD_PARTITIONS mtd: remove add_mtd_partitions, add_mtd_device and friends mtd: convert remaining users to mtd_device_register() mtd: samsung onenand: convert to mtd_device_register() mtd: omap2 onenand: convert to mtd_device_register() mtd: txx9ndfmc: convert to mtd_device_register() mtd: tmio_nand: convert to mtd_device_register() mtd: socrates_nand: convert to mtd_device_register() mtd: sharpsl: convert to mtd_device_register() mtd: s3c2410 nand: convert to mtd_device_register() mtd: ppchameleonevb: convert to mtd_device_register() mtd: orion_nand: convert to mtd_device_register() mtd: omap2: convert to mtd_device_register() mtd: nomadik_nand: convert to mtd_device_register() mtd: ndfc: convert to mtd_device_register() mtd: mxc_nand: convert to mtd_device_register() mtd: mpc5121_nfc: convert to mtd_device_register() mtd: jz4740_nand: convert to mtd_device_register() mtd: h1910: convert to mtd_device_register() mtd: fsmc_nand: convert to mtd_device_register() ... Fixed up trivial conflicts in - drivers/mtd/maps/integrator-flash.c: removed in ARM tree - drivers/mtd/maps/physmap.c: addition of afs partition probe type clashing with removal of CONFIG_MTD_PARTITIONS
2011-05-25arm: mtd: gemini: convert to mtd_device_register()Jamie Iles
Convert to mtd_device_register() and remove the CONFIG_MTD_PARTITIONS preprocessor conditionals as partitioning is always available. Cc: Hans Ulli Kroll <ulli.kroll@googlemail.com> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-07ARM: zImage: remove the static qualifier from global data variablesNicolas Pitre
To be able to relocate the .bss section at run time independently from the rest of the code, we must make sure that no GOTOFF relocations are used with .bss symbols. This usually means that no global variables can be marked static unless they're also const. Let's remove the static qualifier from current offenders, or turn them into const variables when possible. Next commit will ensure the build fails if one of those is reintroduced due to otherwise enforced coding standards for the kernel. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Tony Lindgren <tony@atomide.com>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: gemini: Use proper irq accessor functionsThomas Gleixner
2011-03-16Merge branch 'p2v' into develRussell King
Conflicts: arch/arm/kernel/module.c arch/arm/mach-s5pv210/sleep.S
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-24ARM: 6604/1: Gemini: add platform support for Gemini RTCHans Ulli Kroll
adds rtc support for all Gemini SoC boards nas4220b, rut1xx, wbd111, wbd222 Signed-off-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-15Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (161 commits) ARM: pxa: fix building issue of missing physmap.h ARM: mmp: PXA910 drive strength FAST using wrong value ARM: mmp: MMP2 drive strength FAST using wrong value ARM: pxa: fix recursive calls in pxa_low_gpio_chip AT91: Support for gsia18s board AT91: Acme Systems FOX Board G20 board files AT91: board-sam9m10g45ek.c: Remove duplicate inclusion of mach/hardware.h ARM: pxa: fix suspend/resume array index miscalculation ARM: pxa: use cpu_has_ipr() consistently in irq.c ARM: pxa: remove unused variable in clock-pxa3xx.c ARM: pxa: fix warning in zeus.c ARM: sa1111: fix typo in sa1111_retrigger_lowirq() ARM mxs: clkdev related compile fixes ARM i.MX mx31_3ds: Fix MC13783 regulator names ARM: plat-stmp3xxx: irq_data conversion. ARM: plat-spear: irq_data conversion. ARM: plat-orion: irq_data conversion. ARM: plat-omap: irq_data conversion. ARM: plat-nomadik: irq_data conversion. ARM: plat-mxc: irq_data conversion. ... Fix up trivial conflict in arch/arm/plat-omap/gpio.c (Lennert Buytenhek's irq_data conversion clashing with some omap irq updates)
2011-01-13ARM: gemini: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
2010-11-01tree-wide: fix comment/printk typosUwe Kleine-König
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-05-13ARM: 6130/1: Gemini: add support for Raidsonic IB4220Hans Ulli Kroll
depends on patch # 6128, 6129 Add support for Nasbox IB4220 from Raidsonic. supported devices on SoC - GPIO with led und keys - UART - PFLASH, set fixed partition table Signed-off-by: Janos Laube <janos.dev@gmail.com> Signed-off-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-13ARM: 6129/1: Gemini: add support for Wiliboard WBD-222Hans Ulli Kroll
Depends on patch # 6128 Add support for Wiliboard WBD-222. supported devices on SoC - GPIO with led und keys - UART - PFLASH, set fixed partition table Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-13ARM: 6128/1: Gemini: add support for Wiligear WBD-111Hans Ulli Kroll
added base support for the Wiligear WBD-111 supported devices on SoC - GPIO with led und keys - UART - PFLASH, set fixed partition table Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-01Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits) ARM: Eliminate decompressor -Dstatic= PIC hack ARM: 5958/1: ARM: U300: fix inverted clk round rate ARM: 5956/1: misplaced parentheses ARM: 5955/1: ep93xx: move timer defines into core.c and document ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c ARM: 5953/1: ep93xx: fix broken build of clock.c ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig ARM: 5949/1: NUC900 add gpio virtual memory map ARM: 5948/1: Enable timer0 to time4 clock support for nuc910 ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk ARM: make_coherent(): fix problems with highpte, part 2 MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself ARM: 5945/1: ep93xx: include correct irq.h in core.c ARM: 5933/1: amba-pl011: support hardware flow control ARM: 5930/1: Add PKMAP area description to memory.txt. ARM: 5929/1: Add checks to detect overlap of memory regions. ARM: 5928/1: Change type of VMALLOC_END to unsigned long. ARM: 5927/1: Make delimiters of DMA area globally visibly. ARM: 5926/1: Add "Virtual kernel memory..." printout. ARM: 5920/1: OMAP4: Enable L2 Cache ... Fix up trivial conflict in arch/arm/mach-mx25/clock.c
