path: root/arch/arm/mach-h720x
2011-07-22Merge branch 'devel-stable' into for-nextRussell King
Conflicts: arch/arm/kernel/entry-armv.S
2011-07-18ARM: mach-h720x: move from ARM_DMA_ZONE_SIZE to mdesc->dma_zone_sizeNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2011-06-28ARM: entry: remove unused irq_prio_table macroRussell King
Platforms provide an empty irq_prio_table macro, and as nothing uses this macro, it can simply be removed. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-17ARM: 6962/1: mach-h720x: fix build errorLinus Walleij
The h7201/h7202 machines did not build since they define ARM_DMA_ZONE_OFFSET but do not select ZONE_DMA. Fix it up by selecting ZONE_DMA in their Kconfig. Cc: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-12ARM: Replace platform definition of ISA_DMA_THRESHOLD/MAX_DMA_ADDRESSRussell King
The values of ISA_DMA_THRESHOLD and MAX_DMA_ADDRESS are related; one is the physical/bus address, the other is the virtual address. Both need to be kept in step, so rather than having platforms define both, allow them to define a single macro which sets both of these macros appropraitely. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: h720x: Fix irq conversion falloutThomas Gleixner
The conversion missed, that one of the irq functions is called from the init code. Split it out, so the irq number based call works. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-15Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (161 commits) ARM: pxa: fix building issue of missing physmap.h ARM: mmp: PXA910 drive strength FAST using wrong value ARM: mmp: MMP2 drive strength FAST using wrong value ARM: pxa: fix recursive calls in pxa_low_gpio_chip AT91: Support for gsia18s board AT91: Acme Systems FOX Board G20 board files AT91: board-sam9m10g45ek.c: Remove duplicate inclusion of mach/hardware.h ARM: pxa: fix suspend/resume array index miscalculation ARM: pxa: use cpu_has_ipr() consistently in irq.c ARM: pxa: remove unused variable in clock-pxa3xx.c ARM: pxa: fix warning in zeus.c ARM: sa1111: fix typo in sa1111_retrigger_lowirq() ARM mxs: clkdev related compile fixes ARM i.MX mx31_3ds: Fix MC13783 regulator names ARM: plat-stmp3xxx: irq_data conversion. ARM: plat-spear: irq_data conversion. ARM: plat-orion: irq_data conversion. ARM: plat-omap: irq_data conversion. ARM: plat-nomadik: irq_data conversion. ARM: plat-mxc: irq_data conversion. ... Fix up trivial conflict in arch/arm/plat-omap/gpio.c (Lennert Buytenhek's irq_data conversion clashing with some omap irq updates)
2011-01-15ARM: Fix build regression on SA11x0, PXA, and H720x targetsRussell King
Build errors similar this appeared in todays kautobuild for the above targets: In file included from arch/arm/include/asm/pgtable.h:461, from arch/arm/mach-pxa/generic.c:26: include/asm-generic/pgtable.h: In function 'ptep_test_and_clear_young': include/asm-generic/pgtable.h:29: error: dereferencing pointer to incomplete type None of the .c files including asm/pgtable.h with this error is using this header, so simply remove the include. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-13ARM: h720x: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
2010-11-21ARM: 6484/1: fix compile warning in mm/init.cAnand Gadiyar
Commit 7c63984b86 (ARM: do not define VMALLOC_END relative to PAGE_OFFSET) changed VMALLOC_END to be an explicit value. Before this, it was relative to PAGE_OFFSET and therefore converted to unsigned long as PAGE_OFFSET is an unsigned long. This introduced the following build warning. Fix this by changing the explicit defines of VMALLOC_END to be unsigned long. CC arch/arm/mm/init.o arch/arm/mm/init.c: In function 'mem_init': arch/arm/mm/init.c:606: warning: format '%08lx' expects type 'long unsigned int', but argument 12 has type 'unsigned int' Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Acked-by: Uwe Kleine-K <u.kleine-koenig@pengutronix.dee> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-10-01ARM: do not define VMALLOC_END relative to PAGE_OFFSETNicolas Pitre
VMALLOC_END is supposed to be an absolute value, while PAGE_OFFSET may vary depending on the selected user:kernel memory split mode through CONFIG_VMSPLIT_*. In fact, the goal of moving PAGE_OFFSET down is to accommodate more directly addressed RAM by the kernel below the vmalloc area, and having VMALLOC_END move along PAGE_OFFSET is rather against the very reason why PAGE_OFFSET can be moved in the first place. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2010-08-05ARM: 6283/1: Remove useless PCIO_BASE definitionseric miao
Signed-off-by: Eric Miao <eric.miao@canonical.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-26ARM: 6258/1: arm/h720x: fix debug macro compilation failureJeremy Kerr
IO_BASE shoule be IO_VIRT, and IO_START should be IO_PHYS. We also need mach/hardware.h for these definitions. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-24ARM: arch/arm/mach-h720x/common.h: Checkpatch cleanupAndrea Gelmini
arch/arm/mach-h720x/common.h:17: WARNING: space prohibited between function name and open parenthesis '(' arch/arm/mach-h720x/common.h:23: WARNING: space prohibited between function name and open parenthesis '(' Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-03-19[ARM] pass reboot command line to arch_reset()Russell King
OMAP wishes to pass state to the boot loader upon reboot in order to instruct it whether to wait for USB-based reflashing or not. There is already a facility to do this via the reboot() syscall, except we ignore the string passed to machine_restart(). This patch fixes things to pass this string to arch_reset(). This means that we keep the reboot mode limited to telling the kernel _how_ to perform the reboot which should be independent of what we request the boot loader to do. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-08[ARM] fix AT91, davinci, h720x, ks8695, msm, mx2, mx3, netx, omap1, omap2, ↵Russell King
pxa, s3c arch/arm/mach-at91/at91cap9.c:337: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91rm9200.c:301: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9260.c:351: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9261.c:287: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9263.c:312: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-at91/at91sam9rl.c:304: error: 'NR_AIC_IRQS' undeclared here (not in a function) arch/arm/mach-h720x/h7202-eval.c:38: error: implicit declaration of function 'IRQ_CHAINED_GPIOB' arch/arm/mach-ks8695/devices.c:46: error: 'KS8695_IRQ_WAN_RX_STATUS' undeclared here (not in a function) arch/arm/mach-msm/devices.c:28: error: 'INT_UART1' undeclared here (not in a function) arch/arm/mach-mx2/devices.c:233: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-mx3/devices.c:128: error: 'MXC_GPIO_IRQ_START' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:140: error: 'INT_730_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:165: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap1/mcbsp.c:200: error: 'INT_McBSP1RX' undeclared here (not in a function) arch/arm/mach-omap2/board-apollon.c:286: error: implicit declaration of function 'omap_set_gpio_direction' arch/arm/mach-omap2/mcbsp.c:154: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-omap2/mcbsp.c:181: error: 'INT_24XX_MCBSP1_IRQ_RX' undeclared here (not in a function) arch/arm/mach-pxa/e350.c:36: error: 'IRQ_BOARD_START' undeclared here (not in a function) arch/arm/plat-s3c/dev-i2c0.c:32: error: 'IRQ_IIC' undeclared here (not in a function) ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-30[ARM] Ensure that both MAX_DMA_ADDRESS and ISA_DMA_THRESHOLD are definedRussell King
Both of these symbols should be defined by a platform, or neither should be defined. Ensure that all platforms conform. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-30[ARM] Add a common typesafe __io implementationRussell King
As Al did for Versatile in 2ad4f86b60b649fd7428265c08d73a3bd360c81b, add a typesafe __io implementation for platforms to use. Convert platforms to use this new simple typesafe implementation. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] Rename ISA mach/dma.h header to mach/isa-dma.hRussell King
This avoids confusion with platform specific DMA implementations in mach/dma.h Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] fix constant values of MAX_DMA_ADDRESSRussell King
Since 8d5796d2ec6b5a4e7a52861144e63af438d6f8f7, we have allowed PAGE_OFFSET to be configurable, so a constant virtual address for MAX_DMA_ADDRESS is buggy. It should be defined in terms of PAGE_OFFSET rather than a constant virtual address. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-29[ARM] move MAX_DMA_ADDRESS to mach/memory.hRussell King
Move the definition of MAX_DMA_ADDRESS from mach/dma.h to mach/memory.h, thereby placing it along side its relative, ISA_DMA_THRESHOLD. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] h720x: avoid polluting the kernel's namespaceRussell King
Avoid unnecessarily pollution of the kernel's namespace by avoiding mach/hardware.h in mach/io.h. Include this header file where necessary. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-28[ARM] remove a common set of __virt_to_bus definitionsNicolas Pitre
Let's provide an overridable default instead of having every machine class define __virt_to_bus and __bus_to_virt to the same thing. What most platforms are using is bus_addr == phys_addr so such is the default. One exception is ebsa110 which has no DMA what so ever, so the actual definition is not important except only for proper compilation. Also added a comment about the special footbridge bus translation. Let's also remove comments alluding to set_dma_addr which is not (and should not) be commonly used. Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-11-13[ARM] cdb89712,clps7500,h720x: avoid namespace clash for FLASH_* constantsRussell King
2008-10-09Merge branch 'pxa-all' into develRussell King
Conflicts: arch/arm/mach-pxa/Kconfig arch/arm/mach-pxa/corgi.c arch/arm/mach-pxa/include/mach/hardware.h arch/arm/mach-pxa/spitz.c
2008-10-09[ARM] 5298/1: Drop desc_handle_irq()Dmitry Baryshkov
desc_handle_irq() was declared as obsolete since long ago. Replace it with generic_handle_irq() Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-03-06[ARM] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] Fix timer damage from d3d74453c34f8fd87674a8cf5b8a327c68f22e99Russell King
Move the xtime write mode seqlock into timer_tick(), so it only surrounds the call to do_timer(). This avoids a deadlock in update_process_times() ... hrtimer_get_softirq_time() which tries to get a read mode seqlock on xtime, thereby preventing booting. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-20[ARM] spelling fixesSimon Arlott
Spelling fixes in arch/arm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[ARM] 2999/1: Replace map_desc.physical with map_desc.pfn: H720xDeepak Saxena
Patch from Deepak Saxena H720x map_desc.pfn conversion Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-08[SERIAL] Use an enum for serial8250 platform device IDsRussell King
Rather than hard-coding the platform device IDs, enumerate them. We don't particularly care about the actual ID we get, just as long as they're unique. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-04[ARM] Wrap calls to descriptor handlersRussell King
This is part of Thomas Gleixner's generic IRQ patch, which converts ARM to use the generic IRQ subsystem. Here, we wrap calls to desc->handler() in an inline function, desc_handle_irq(). This reduces the size of Thomas' patch since the changes become more localised. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-03[PATCH] ARM: Remove machine description macrosRussell King
Remove the pointless machine description macros, favouring C99 initialisers instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
