The TWD and SCU configs are selected by default as long as
MSM_SCORPIONMP is false and/or MCT is false. Implementing the
logic this way certainly saves lines in the Kconfig but it
precludes those machines which select MSM_SCORPIONMP or MCT from
participating in the single zImage effort because when those
machines are combined with other SMP capable machines the TWD and
SCU are no longer selected by default.
Push the select out to the machine entries so that we can compile
these machines together and still select the appropriate configs.
Cc: Barry Song <baohua.song@csr.com>
Acked-by: David Brown <davidb@codeaurora.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Acked-by: Pawel Moll <pawel.moll@arm.com>
Cc: Rob Herring <rob.herring@calxeda.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Shiraz Hashim <shiraz.hashim@st.com>
Acked-by: Simon Horman <horms@verge.net.au>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Tony Lindgren <tony@atomide.com>
Acked-by: Viresh Kumar <viresh.linux@gmail.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 into next/cleanup
* 'gic' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64:
irqchip: gic: Perform the gic_secondary_init() call via CPU notifier
irqchip: gic: Call handle_bad_irq() directly
arm: Move chained_irq_(enter|exit) to a generic file
arm: Move the set_handle_irq and handle_arch_irq declarations to asm/irq.h
+ Linux 3.9-rc3
All the calls to gic_secondary_init() pass 0 as the first argument.
Since this function is called on each CPU when starting, it can be done
in a platform-independent way via a CPU notifier registered by the GIC
code.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Tested-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Tested-by: Dinh Nguyen <dinguyen@altera.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: David Brown <davidb@codeaurora.org>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Magnus Damm <magnus.damm@gmail.com>
Now that we have OF based init with CLKSRC_OF, convert smp_twd init
function to use it and covert all callers of
twd_local_timer_of_register.
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Viresh Kumar <viresh.linux@gmail.com>
Cc: John Stultz <johnstul@us.ibm.com>
Cc: linux-omap@vger.kernel.org
Cc: spear-devel@list.st.com
Pull ARM SoC cleanups from Arnd Bergmann:
"A large number of cleanups, all over the platforms. This is dominated
largely by the Samsung platforms (s3c, s5p, exynos) and a few of the
others moving code out of arch/arm into more appropriate subsystems.
The clocksource and irqchip drivers are now abstracted to the point
where platforms that are already cleaned up do not need to even
specify the driver they use, it can all get configured from the device
tree as we do for normal device drivers. The clocksource changes
basically touch every single platform in the process.
We further clean up the use of platform specific header files here,
with the goal of turning more of the platforms over to being
"multiplatform" enabled, which implies that they cannot expose their
headers to architecture independent code any more.
It is expected that no functional changes are part of the cleanup.
The overall reduction in total code lines is mostly the result of
removing broken and obsolete code."
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (133 commits)
ARM: mvebu: correct gated clock documentation
ARM: kirkwood: add missing include for nsa310
ARM: exynos: move exynos4210-combiner to drivers/irqchip
mfd: db8500-prcmu: update resource passing
drivers/db8500-cpufreq: delete dangling include
ARM: at91: remove NEOCORE 926 board
sunxi: Cleanup the reset code and add meaningful registers defines
ARM: S3C24XX: header mach/regs-mem.h local
ARM: S3C24XX: header mach/regs-power.h local
ARM: S3C24XX: header mach/regs-s3c2412-mem.h local
ARM: S3C24XX: Remove plat-s3c24xx directory in arch/arm/
ARM: S3C24XX: transform s3c2443 subirqs into new structure
ARM: S3C24XX: modify s3c2443 irq init to initialize all irqs
ARM: S3C24XX: move s3c2443 irq code to irq.c
ARM: S3C24XX: transform s3c2416 irqs into new structure
ARM: S3C24XX: modify s3c2416 irq init to initialize all irqs
ARM: S3C24XX: move s3c2416 irq init to common irq code
ARM: S3C24XX: Modify s3c_irq_wake to use the hwirq property
ARM: S3C24XX: Move irq syscore-ops to irq-pm
clocksource: always define CLOCKSOURCE_OF_DECLARE
Pull ACPI and power management updates from Rafael Wysocki:
- Rework of the ACPI namespace scanning code from Rafael J. Wysocki
with contributions from Bjorn Helgaas, Jiang Liu, Mika Westerberg,
Toshi Kani, and Yinghai Lu.
- ACPI power resources handling and ACPI device PM update from Rafael
J Wysocki.
- ACPICA update to version 20130117 from Bob Moore and Lv Zheng with
contributions from Aaron Lu, Chao Guan, Jesper Juhl, and Tim Gardner.
- Support for Intel Lynxpoint LPSS from Mika Westerberg.
- cpuidle update from Len Brown including Intel Haswell support, C1
state for intel_idle, removal of global pm_idle.
- cpuidle fixes and cleanups from Daniel Lezcano.
- cpufreq fixes and cleanups from Viresh Kumar and Fabio Baltieri with
contributions from Stratos Karafotis and Rickard Andersson.
- Intel P-states driver for Sandy Bridge processors from Dirk
Brandewie.
- cpufreq driver for Marvell Kirkwood SoCs from Andrew Lunn.
- cpufreq fixes related to ordering issues between acpi-cpufreq and
powernow-k8 from Borislav Petkov and Matthew Garrett.
- cpufreq support for Calxeda Highbank processors from Mark Langsdorf
and Rob Herring.
- cpufreq driver for the Freescale i.MX6Q SoC and cpufreq-cpu0 update
from Shawn Guo.
- cpufreq Exynos fixes and cleanups from Jonghwan Choi, Sachin Kamat,
and Inderpal Singh.
- Support for "lightweight suspend" from Zhang Rui.
- Removal of the deprecated power trace API from Paul Gortmaker.
- Assorted updates from Andreas Fleig, Colin Ian King, Davidlohr Bueso,
Joseph Salisbury, Kees Cook, Li Fei, Nishanth Menon, ShuoX Liu,
Srinivas Pandruvada, Tejun Heo, Thomas Renninger, and Yasuaki
Ishimatsu.
* tag 'pm+acpi-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (267 commits)
PM idle: remove global declaration of pm_idle
unicore32 idle: delete stray pm_idle comment
openrisc idle: delete pm_idle
mn10300 idle: delete pm_idle
microblaze idle: delete pm_idle
m32r idle: delete pm_idle, and other dead idle code
ia64 idle: delete pm_idle
cris idle: delete idle and pm_idle
ARM64 idle: delete pm_idle
ARM idle: delete pm_idle
blackfin idle: delete pm_idle
sparc idle: rename pm_idle to sparc_idle
sh idle: rename global pm_idle to static sh_idle
x86 idle: rename global pm_idle to static x86_idle
APM idle: register apm_cpu_idle via cpuidle
cpufreq / intel_pstate: Add kernel command line option disable intel_pstate.
cpufreq / intel_pstate: Change to disallow module build
tools/power turbostat: display SMI count by default
intel_idle: export both C1 and C1E
ACPI / hotplug: Fix concurrency issues and memory leaks
Pull clock framework update from Michael Turquette:
"The common clock framework changes for 3.9 are almost entirely fixes.
None are dire enough to be Cc'd to stable which may be interpreted to
mean that users of the framework are reaching stability. Lots of new
adoption of this framework is via DeviceTree data and that comes
through the respective architecture and platform trees instead of
through the clk framework tree.
Two new features are improved debugfs output and an improvement to how
DT clocks are initialized by reusing a common method."
* tag 'clk-for-linus' of git://git.linaro.org/people/mturquette/linux: (25 commits)
clk: sunxi: remove stale Makefile entry
clk: vexpress: Use common of_clk_init() function
clk: zynq: Use common of_clk_init() function
clk: vt8500: Use common of_clk_init() function
clk: highbank: Use common of_clk_init() function
clk: sunxi: Use common of_clk_init() function
clk: add common of_clk_init() function
clk: Deduplicate exit code in clk_set_rate
clk: beautify Makefile
clk-divider: fix macros
clk: prima2: enable dt-binding clkdev mapping
clk: mxs: Index is always positive
clk: max77686: Avoid double free at remove time
clk: remove exported function from __init section
clk: vt8500: Add support for WM8750/WM8850 PLL clocks
clk: vt8500: Fix division-by-0 when requested rate=0
clk: vt8500: Fix device clock divisor calculations
clk: vt8500: Fix error in PLL calculations on non-exact match.
clk: max77686: Remove unnecessary NULL checking for container_of()
clk: JSON debugfs clock tree summary
Highbank processors depend on the external ECME to perform voltage
management based on a requested frequency. Communication between the
A9 cores and the ECME happens over the pl320 IPC channel.
Signed-off-by: Mark Langsdorf <mark.langsdorf@calxeda.com>
Reviewed-by: Shawn Guo <shawn.guo@linaro.org>
Reviewed-by: Mike Turquette <mturquette@linaro.org>
The pl320 IPC allows for interprocessor communication between the
highbank A9 and the EnergyCore Management Engine. The pl320 implements
a straightforward mailbox protocol.
With commit a0ae0240 (ARM: kernel: add device tree init map function),
the cpu id value may include the cluster id and is no longer 0-3, so we
need to mask it now to get the right hard cpu index.
Use common of_clk_init() function for clocks initialization.
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Tested-by: Rob Herring <rob.herring@calxeda.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
into next/cleanup
From Rob Herring:
Initial irqchip init infrastructure and GIC and VIC clean-ups
This creates irqchip initialization infrastructure from Thomas
Petazzoni. The VIC and GIC irqchip code is moved to drivers/irqchips
and adapted to use the new infrastructure. All DT enabled platforms
using GIC and VIC are converted over to use the new irqchip_init.
* tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux:
irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.h
ARM: picoxcell: use common irqchip_init function
ARM: spear: use common irqchip_init function
irqchip: Move ARM VIC to drivers/irqchip
ARM: samsung: remove unused tick.h
ARM: remove unneeded vic.h includes
ARM: remove mach .handle_irq for VIC users
ARM: VIC: set handle_arch_irq in VIC initialization
ARM: VIC: shrink down vic.h
irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.h
ARM: use common irqchip_init for GIC init
irqchip: Move ARM GIC to drivers/irqchip
ARM: remove mach .handle_irq for GIC users
ARM: GIC: set handle_arch_irq in GIC initialization
ARM: GIC: remove direct use of gic_raise_softirq
ARM: GIC: remove assembly ifdefs from gic.h
ARM: mach-ux500: use SGI0 to wake up the other core
arm: add set_handle_irq() to register the parent IRQ controller handler function
irqchip: add basic infrastructure
irqchip: add to the directories part of the IRQ subsystem in MAINTAINERS
Fixed up massive merge conflicts with the timer cleanup due to adjacent changes:
arch/arm/mach-bcm/board_bcm.c
arch/arm/mach-cns3xxx/cns3420vb.c
arch/arm/mach-ep93xx/adssphere.c
arch/arm/mach-ep93xx/edb93xx.c
arch/arm/mach-ep93xx/gesbc9312.c
arch/arm/mach-ep93xx/micro9.c
arch/arm/mach-ep93xx/simone.c
arch/arm/mach-ep93xx/snappercl15.c
arch/arm/mach-ep93xx/ts72xx.c
arch/arm/mach-ep93xx/vision_ep9307.c
arch/arm/mach-highbank/highbank.c
arch/arm/mach-imx/mach-imx6q.c
arch/arm/mach-msm/board-dt-8960.c
arch/arm/mach-netx/nxdb500.c
arch/arm/mach-netx/nxdkn.c
arch/arm/mach-netx/nxeb500hmi.c
arch/arm/mach-nomadik/board-nhk8815.c
arch/arm/mach-picoxcell/common.c
arch/arm/mach-realview/realview_eb.c
arch/arm/mach-realview/realview_pb1176.c
arch/arm/mach-realview/realview_pb11mp.c
arch/arm/mach-realview/realview_pba8.c
arch/arm/mach-realview/realview_pbx.c
arch/arm/mach-socfpga/socfpga.c
arch/arm/mach-spear13xx/spear1310.c
arch/arm/mach-spear13xx/spear1340.c
arch/arm/mach-spear13xx/spear13xx.c
arch/arm/mach-spear3xx/spear300.c
arch/arm/mach-spear3xx/spear310.c
arch/arm/mach-spear3xx/spear320.c
arch/arm/mach-spear3xx/spear3xx.c
arch/arm/mach-spear6xx/spear6xx.c
arch/arm/mach-tegra/board-dt-tegra20.c
arch/arm/mach-tegra/board-dt-tegra30.c
arch/arm/mach-u300/core.c
arch/arm/mach-ux500/board-mop500.c
arch/arm/mach-ux500/cpu-db8500.c
arch/arm/mach-versatile/versatile_ab.c
arch/arm/mach-versatile/versatile_dt.c
arch/arm/mach-versatile/versatile_pb.c
arch/arm/mach-vexpress/v2m.c
include/asm-generic/vmlinux.lds.h
Clockevent cleanup series from Shawn Guo.
Resolved move/change conflict in mach-pxa/time.c due to the sys_timer
cleanup.
* clocksource/cleanup:
clocksource: use clockevents_config_and_register() where possible
ARM: use clockevents_config_and_register() where possible
clockevents: export clockevents_config_and_register for module use
+ sync to Linux 3.8-rc3
arch/arm/mach-pxa/time.c
Now that we have GIC moved to drivers/irqchip and all GIC DT init for
platforms using irqchip_init, move gic.h and update the remaining
includes.
Cc: Anton Vorontsov <avorontsov@mvista.com>
Cc: Daniel Walker <dwalker@fifo99.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Convert all GIC DT initialization over to use common irqchip_init
function.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Cc: Dinh Nguyen <dinguyen@altera.com>
Now that the GIC initialization sets up the handle_arch_irq pointer, we
can remove it for all machines and make it static.
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Olof Johansson <olof@lixom.net>
In preparation of moving gic code to drivers/irqchip, remove the direct
platform dependencies on gic_raise_softirq. Move the setup of
smp_cross_call into the gic code and use arch_send_wakeup_ipi_mask
function to trigger wake-up IPIs.
This fixes suspend to RAM adding necessary save and restore of L2 and GIC.
When we fail to power down, we need to clear out the power request.
With commit 384a290 (ARM: gic: use a private mapping for CPU target
interfaces), wake-up IPIs now go to all cores as the gic cpu interface
numbering may not follow core numbering. This broke secondary boot on
highbank since the boot address was already set for all secondary cores,
this caused all cores to boot before the kernel was ready.
Fix this by moving the setting of the jump address to
highbank_boot_secondary instead of highbank_smp_prepare_cpus and
highbank_cpu_die. Also, clear the address when we boot. This prevents
cores from booting before they are actually triggered and is also necessary
to get suspend/resume to work.
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
s/hignbank/highbank/
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/soc
From Kukjin Kim:
Just adding camif gpio setup and clkdev.
* 'next/cam-samsung' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung:
ARM: S3C24XX: Add clkdev entry for camif-upll clock
ARM: SAMSUNG: Add s3c24xx/s3c64xx CAMIF GPIO setup helpers
+ Linux 3.7-rc6
Conflicts due to the 3.7-rc6 sync: arch/arm/mach-highbank/system.c
include/linux/clk-provider.h, resolved as in other branches.
git://sources.calxeda.com/kernel/linux into next/soc
From Rob Herring:
Use common debug_ll_init function and remove the static mapping code
from mach-highbank.
* tag 'highbank-debugll-cleanup' of git://sources.calxeda.com/kernel/linux:
ARM: highbank: use common debug_ll_io_init
ARM: implement debug_ll_io_init()
Remove the platform static mapping code for uart and use the common
debug_ll_io_init function.
Fixes build error due to multiple includes:
In file included from arch/arm/mach-highbank/sysregs.h:23:0,
from arch/arm/mach-highbank/system.c:20:
arch/arm/mach-highbank/core.h:8:91: error: redefinition of 'highbank_lluart_map_io'
In file included from arch/arm/mach-highbank/system.c:19:0:
arch/arm/mach-highbank/core.h:8:91: note: previous definition of 'highbank_lluart_map_io' was here
In some cases, an interrupt can occur and prevent cause failure to enter
wfi. This causes reset to hang. Retrying the wfi should be enough to
prevent reset from hanging.
And initial Calxeda ECX-2000 SOC support. This adds Cortex-A15 peripherals
and machine DT match name.
In preparation for A15 support on ECX-2000, the direct calls to SCU
registers must be conditional. The SCU power mode register is replaced by
a custom register on ECX-2000.
Rather than read the number of cores from the SCU, just hardcode it to 4.
This removes one use of SCU and removes the need for the SCU to be
statically mapped. The cpu initialization will ultimately come from DT.
git://git.linaro.org/people/mszyprowski/linux-dma-mapping
Pull CMA and DMA-mapping updates from Marek Szyprowski:
"This time the pull request is rather small, because the further
redesign patches were not ready on time.
This pull request consists of the patches which extend ARM DMA-mapping
subsystem with support for CPU coherent (ACP) DMA busses. The first
client of the new version is HighBank SATA driver. The second part of
the pull request includes various cleanup for both CMA common code and
ARM DMA-mapping subsystem."
Fix up trivial add-add conflict due to the "dma-coherent" DT property
being added next to the "calxeda,port-phys" property for the Calxeda
AHCI controller.
* 'for-v3.7' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping:
ARM: dma-mapping: Remove unsed var at arm_coherent_iommu_unmap_page
ARM: highbank: add coherent DMA setup
ARM: kill off arch_is_coherent
ARM: add coherent iommu dma ops
ARM: add coherent dma ops
ARM: dma-mapping: Refrain noisy console message
ARM: dma-mapping: Small logical clean up
drivers: dma-contiguous: refactor dma_alloc_from_contiguous()
Some highbank DMA masters can support coherent (ACP) or non-coherent DMA.
This sets up dma_map_ops for masters which are configured for coherent DMA.
* multiplatform/smp_ops:
ARM: consolidate pen_release instead of having per platform definitions
ARM: smp: Make SMP operations mandatory
ARM: SoC: convert spear13xx to SMP operations
ARM: SoC: convert imx6q to SMP operations
ARM: SoC: convert highbank to SMP operations
ARM: SoC: convert shmobile SMP to SMP operations
ARM: SoC: convert ux500 to SMP operations
ARM: SoC: convert MSM to SMP operations
ARM: SoC: convert Exynos4 to SMP operations
ARM: SoC: convert Tegra to SMP operations
ARM: SoC: convert OMAP4 to SMP operations
ARM: SoC: convert VExpress/RealView to SMP operations
ARM: SoC: add per-platform SMP operations
Conflicts due to file moves or removals in:
arch/arm/mach-msm/board-msm8960.c
arch/arm/mach-msm/board-msm8x60.c
arch/arm/mach-tegra/board-harmony.c
arch/arm/mach-tegra/board-trimslice.c
Conflicts due to board file cleanup:
arch/arm/mach-tegra/board-paz00.c
Conflicts due to cpu hotplug addition:
arch/arm/mach-tegra/hotplug.c
Being a module_init call, highbank_pm_init will cause problem with
multi-platform build running on other platforms. Call it from
.init_machine instead.
Reported-by: Shawn Guo <shawn.guo@linaro.org>
This lets us build a multiplatform kernel for experimental purposes.
However, it will not be useful for any real work, because it relies
on a number of useful things to be disabled for now:
* SMP support must be turned off because of conflicting symbols.
Marc Zyngier has proposed a solution by adding a new SOC
operations structure to hold indirect function pointers
for these, but that work is currently stalled
* We turn on SPARSE_IRQ unconditionally, which is not supported
on most platforms. Each of them is currently in a different
state, but most are being worked on.
* A common clock framework is in place since v3.4 but not yet
being used. Work on this is on its way.
* DEBUG_LL for early debugging is currently disabled.
* THUMB2_KERNEL does not work with allyesconfig because the
kernel gets too big
[Rob Herring]: Rebased to not be dependent on the mass mach header rename.
As a result, omap2plus, imx, mxs and ux500 are not converted. Highbank,
picoxcell, mvebu, and socfpga are converted.
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Acked-by: Jamie Iles <jamie@jamieiles.com>
Move highbank debug-macro.S over to common debug macro directory.
Also, remove v7 specific movw/movt instructions so this can compile under
v6 mode.
Most platforms don't need mach/gpio.h and it prevents multi-platform
kernel images. Add CONFIG_NEED_MACH_GPIO_H and make platforns select it
if they need gpio.h. This is platforms that define __GPIOLIB_COMPLEX
or have lots of implicit includes pulled in by mach/gpio.h.
at91 and omap have gpio clean-up pending and can drop
CONFIG_NEED_MACH_GPIO_H once that is in.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Convert the highbank platform to use struct smp_operations to provide
its SMP and CPU hotplug operations.
This adds real clock support to Calxeda Highbank SOC using the common
clock infrastructure.
[mturquette@linaro.org: fixed up invalid writes to const struct member]
Linux runs in non-secure mode on highbank, so we need secure monitor calls
to enable and disable the PL310. Rather than invent new smc calls, the same
calling convention used by OMAP is used here.
Pull "ARM: cleanups of io includes" from Olof Johansson:
"Rob Herring has done a sweeping change cleaning up all of the
mach/io.h includes, moving some of the oft-repeated macros to a common
location and removing a bunch of boiler plate. This is another step
closer to a common zImage for multiple platforms."
Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes
around it, tegra localtimer.o is *still* gone, yadda-yadda).
* tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits)
ARM: tegra: Include assembler.h in sleep.S to fix build break
ARM: pxa: use common IOMEM definition
ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol
ARM: __io abuse cleanup
ARM: create a common IOMEM definition
ARM: iop13xx: fix missing declaration of iop13xx_init_early
ARM: fix ioremap/iounmap for !CONFIG_MMU
ARM: kill off __mem_pci
ARM: remove bunch of now unused mach/io.h files
ARM: make mach/io.h include optional
ARM: clps711x: remove unneeded include of mach/io.h
ARM: dove: add explicit include of dove.h to addr-map.c
ARM: at91: add explicit include of hardware.h to uncompressor
ARM: ep93xx: clean-up mach/io.h
ARM: tegra: clean-up mach/io.h
ARM: orion5x: clean-up mach/io.h
ARM: davinci: remove unneeded mach/io.h include
[media] davinci: remove includes of mach/io.h
ARM: OMAP: Remove remaining includes for mach/io.h
ARM: msm: clean-up mach/io.h
Pull more ARM updates from Russell King.
This got a fair number of conflicts with the <asm/system.h> split, but
also with some other sparse-irq and header file include cleanups. They
all looked pretty trivial, though.
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (59 commits)
ARM: fix Kconfig warning for HAVE_BPF_JIT
ARM: 7361/1: provide XIP_VIRT_ADDR for no-MMU builds
ARM: 7349/1: integrator: convert to sparse irqs
ARM: 7259/3: net: JIT compiler for packet filters
ARM: 7334/1: add jump label support
ARM: 7333/2: jump label: detect %c support for ARM
ARM: 7338/1: add support for early console output via semihosting
ARM: use set_current_blocked() and block_sigmask()
ARM: exec: remove redundant set_fs(USER_DS)
ARM: 7332/1: extract out code patch function from kprobes
ARM: 7331/1: extract out insn generation code from ftrace
ARM: 7330/1: ftrace: use canonical Thumb-2 wide instruction format
ARM: 7351/1: ftrace: remove useless memory checks
ARM: 7316/1: kexec: EOI active and mask all interrupts in kexec crash path
ARM: Versatile Express: add NO_IOPORT
ARM: get rid of asm/irq.h in asm/prom.h
ARM: 7319/1: Print debug info for SIGBUS in user faults
ARM: 7318/1: gic: refactor irq_start assignment
ARM: 7317/1: irq: avoid NULL check in for_each_irq_desc loop
ARM: 7315/1: perf: add support for the Cortex-A7 PMU
Pull "ARM: SoC specific updates" from Arnd Bergmann:
"These changes are all specific to an soc family or the code for one
soc. Lots of work for Tegra3 this time, but also a lot of other
platforms. There will be another (smaller) set of soc patches later
in the merge window for stuff that has dependencies on external trees
or that was sent just before the merge window opened.
The asoc tree added a few devices to the i.mx platform, which conflict
with other devices added in the same place here.
The tegra Makefile conflicts between a number of branches, mostly
because of changes regarding localtimer.c, which was removed in the
end.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fix up some trivial conflicts, including the mentioned Tegra Makefile.
* tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (51 commits)
ARM: EXYNOS: fix cycle count for periodic mode of clock event timers
ARM: EXYNOS: add support JPEG
ARM: EXYNOS: Add DMC1, allow PPMU access for DMC
ARM: SAMSUNG: Correct MIPI-CSIS io memory resource definition
ARM: SAMSUNG: fix __init attribute on regarding s3c_set_platdata()
ARM: SAMSUNG: Add __init attribute to samsung_bl_set()
ARM: S5PV210: Add usb otg phy control
ARM: S3C64XX: Add usb otg phy control
ARM: EXYNOS: Enable l2 configuration through device tree
ARM: EXYNOS: remove useless code to save/restore L2
ARM: EXYNOS: save L2 settings during bootup
ARM: S5P: add L2 early resume code
ARM: EXYNOS: Add support AFTR mode on EXYNOS4210
ARM: mx35: Setup the AIPS registers
ARM: mx5: Use common function for configuring AIPS
ARM: mx3: Setup AIPS registers
ARM: mx3: Let mx31 and mx35 enter in LPM mode in WFI
ARM: defconfig: imx_v6_v7: build in REGULATOR_FIXED_VOLTAGE
ARM: imx: update imx_v6_v7_defconfig
ARM: tegra: Demote EMC clock inconsistency BUG to WARN
arch/arm/mach-tegra/Makefile
arch/arm/mach-vexpress/core.h
The tegra Makefile was changed in four different branches
in the same line. This merge should reduce the amount
of churn.
Add support for the new smp_twd runtime registration interface
to the highbank platforms, and remove the old compile-time support.
The highbank DTS file is updated to match the TWD DT documentation
and fixes the timer trigger (rising edge).
Now that many platforms don't need mach/io.h, remove the unused ones.
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
into for-armsoc
Now that most platforms don't need disable_fiq and arch_ret_to_user
macros, we can remove the empty macros or empty entry-macro.S files.
Acked-by: Ryan Mallon <rmallon@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
next/soc
* 'for-arm-soc' of git://sources.calxeda.com/kernel/linux: (247 commits)
ARM: highbank: remove unused memory.h
ARM: highbank: enable sp804 based sched_clock
ARM: timer-sp: add sched_clock support
Linux 3.3-rc3
pcmcia: fix socket refcount decrementing on each resume
mm: fix UP THP spin_is_locked BUGs
drivers/leds/leds-lm3530.c: fix setting pltfm->als_vmax
mm: compaction: check for overlapping nodes during isolation for migration
nilfs2: avoid overflowing segment numbers in nilfs_ioctl_clean_segments()
ASoC: wm8994: Disable line output discharge prior to ramping VMID
ASoC: wm8994: Fix typo in VMID ramp setting
ALSA: oxygen, virtuoso: fix exchanged L/R volumes of aux and CD inputs
ALSA: usb-audio: add Edirol UM-3G support
checkpatch: Warn on code with 6+ tab indentation
ACPI: remove duplicated lines of merging problems with acpi_processor_add
ALSA: hda - add support for Uniwill ECS M31EI notebook
HID: wiimote: fix invalid power_supply_powers call
ALSA: hda - Fix error handling in patch_ca0132.c
target: Fix unsupported WRITE_SAME sense payload
iscsi: use IP_FREEBIND socket option
memory.h is empty and no longer needed to build, so remove it.
Initialize sched_clock to use the sp804 timer.
