The i.MX6ULZ is new SOC of the i.MX6 series. it
is SW compatile with i.MX6ULL, so most of the code
can be reuse from i.MX6ULL. To maximum the SW reuse,
i.MX6ULZ don't have an independent SOC id in anamix.
so a dummy ID is used to identify it.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Previous code don't take care about the i.MX6QP revision update of
new TO. So improve the code to include future TO support for i.MX6QP.
On our i.MX6 SOC, the DIGPROG register is used for represent the
SOC ID and silicon revision. The revision has two part: MAJOR and
MINOR. each is represented in 8 bits in the register.
bits [15:8]: reflect the MAJOR part of the revision;
bits [7:0]: reflect the MINOR part of the revision;
In our linux kernel, the soc revision is represented in 8 bits. MAJOR
part and MINOR each occupy 4 bits.
previous method does NOT take care about the MAJOR part in DIGPROG register.
So reformat the revision read from the HW to compatible the revision format
used in kernel.
When ENET wake up is enabled by wake-on-lan (WOL), the weak 2P5
ldo needs to keep power up even for LPDDR2 due to the ENET_PLL is
feed by the weak 2p5 ldo during DSM. If the weak 2P5 ldo is power
down the ENET module is power off hence it is not able to sense the
WOL interrupt and trigger the system resume.
Signed-off-by: Juan Gutierrez <juan.gutierrez@nxp.com>
For MMDC, LPDDR3 type's value is 2b'11, which is
different from DDRC, so correct it.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
Add DSM mode support for i.MX6SLL, Mega/Fast mix
can be off now.
Enable DSM for i.MX6ULL, UART_UBRC is a read-only
register, writting it will cause external abort,
so skip save/restore for this register.
Wait PU LDO ramp before GPU power on once system resume back on i.mx6qp,
otherwise, GPU resume may hang.
Signed-off-by: Robin Gong <b38343@freescale.com>
(cherry picked from commit 361af86190c160e0ea66e007c61b18a793149b74)
To eliminate the power number, need turn off PU regulator before suspend
since it's turned on always on i.mx6qp.
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
Since i.MX6SX, if USB vbus wake up is enabled, weak 2P5
needs to be on even if the DRAM is LPDDR2, previously, we need
to set stop_mode_config to keep 2P5 on, so enter DSM,
if USB vbus wakeup is enabled, we need to keep weak 2P5 on.
Signed-off-by: Anson Huang <b20788@freescale.com>
(cherry picked from commit 1ca4dffee79055ea95c59e27bab50bc5080310f5)
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Same as i.MX6SX, need to disconnect vddhigh and vddsnvs
in DSM on i.MX6UL, they have same design.
(cherry picked from commit f0c63b894a60512318481cb8a7b0777cdb7c46ab)
per design team's recommendation, in DSM mode,
need to disconnect vddhigh and vddsnvs, add it for i.MX6SX.
i.MX6SX has different bit definition than i.MX6SL about this
bit in PMU_MISC0 register.
(cherry picked from commit ec42012c66961c357a1ed4c31d27f83a1db86611)
STOP_MODE_CONFIG field of PMU_MISC0 register are different
on different i.MX6 SoC, weak2P5 can only be enabled when
STOP_MODE_CONFIG is clear, need to read STOP_MODE_CONFIG
setting before enabling weak2P5, so the register field
must be correct, the definition are as below:
i.MX6Q/DL: bit[12];
i.MX6SL: bit[12:11], but only bit[11] is valid, so use bit[11];
i.MX6SX/UL: bit[11:10].
power mode
the PFD override bit must be set before system entering any low power mode.
Signed-off-by: Bai Ping <b51503@freescale.com>
Add i.MX7D suspend/resume support, including standby
and mem mode support, mega/fast mix off and DDR
retention support.
The i.MX6QP is a different SOC, but internally we treate it as i.MX6Q
Rev_2.0 to maximum the code reusability. The chip silicon number we
read from the ANADIG_DIGPROG is 0x630100. This patch add code to
identify it as i.MX6QP Rev_1.0 when print out the silicon version.
The commond 'cat /sys/devices/soc0/revision' can
show correct soc version information.
"unknow revision" message in imx_print_silicon_rev()
will never work for digprog.
Signed-off-by: Frank Li <Frank.Li@freescale.com>
Add i.MX7D MSL support.
For LPDDR2 platform, no need to enable weak2P5 in DSM mode,
it can be pulled down to save power(~0.65mW).
And per design team's recommendation, we should disconnect
VDDHIGH and SNVS in DSM mode on i.MX6SL.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Add more revision support for the new i.MX6DQ tape-out (TO1.5). This
TO1.5 is the Rev 1.3 as documented in i.MX6DQ data sheet, because TO1.3
and TO1.4 are never revealed.
Signed-off-by: Jason Liu <r64343@freescale.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Add imx6sl support into imx_init_revision_from_anatop(), so that it can
be used to initialize cpu type and revision on imx6sl.
The patch creates a common function imx_init_revision_from_anatop() by
merging imx6q_init_revision() and imx_anatop_get_digprog(), so that any
SoC that encodes revision info in anatop can use it to initialize
revision.
Move anatop related (For USB) from board file to anatop driver
Function imx_anatop_get_digprog() that reads register ANADIG_DIGPROG is
called to identify silicon version. Users might query silicon version
earlier than regmap subsystem is ready. For example, imx6q clock driver
query revision in mx6q_clocks_init(), where regmap is not initialized
yet.
Change imx_anatop_get_digprog() to map anatop block and read
ANADIG_DIGPROG in the native way, so that the function can work at very
early stage.
While at it, let's move imx_print_silicon_rev() back to
imx6q_timer_init() to have the message show up a little earlier.
Fix the following sparse warnings:
arch/arm/mach-imx/anatop.c:56:6: warning: symbol 'imx_anatop_pre_suspend' was not declared. Should it be static?
arch/arm/mach-imx/anatop.c:62:6: warning: symbol 'imx_anatop_post_resume' was not declared. Should it be static?
arch/arm/mach-imx/anatop.c:68:6: warning: symbol 'imx_anatop_usb_chrg_detect_disable' was not declared. Should it be static?
arch/arm/mach-imx/anatop.c:78:5: warning: symbol 'imx_anatop_get_digprog' was not declared. Should it be static?
arch/arm/mach-imx/anatop.c:86:13: warning: symbol 'imx_anatop_init' was not declared. Should it be static?
RBC is to control whether some ANATOP sub modules
can enter lpm mode when SOC is into STOP mode, if
RBC is enabled and PMIC_VSTBY_REQ is set, ANATOP
will have below behaviors:
1. Digital LDOs(CORE, SOC and PU) are bypassed;
2. Analog LDOs(1P1, 2P5, 3P0) are disabled;
As the 2P5 is necessary for DRAM IO pre-drive in
STOP mode, so we need to enable weak 2P5 in STOP
mode when 2P5 LDO is disabled.
For RBC settings, there are some rules as below
due to hardware design:
1. All interrupts must be masked during operating
RBC registers;
2. At least 2 CKIL(32K) cycles is needed after the
RBC setting is changed.
Anatop module have sereval configurations for user
to reduce the power consumption in suspend, provide
suspend/resume interface for further use and enable
fet_odrive to reduce CORE LDO leakage during suspend.
As we have a common anatop file, remove all the operations
of anatop module in other files, use anatop interfaces to
do that.
