path: root/arch/arm/mach-imx/avic.c
2016-06-21ARM: i.MX: Fix FIQ interrupt handling for TZICAlexander Shiyan
IRQ number should be translated from VIRQ to HWIRQ for TZIC. As a solution for this issue, move existing translation code from AVIC to common place. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2016-02-02ARM: imx: use endian-safe readl/readw/writel/writewJohannes Berg
Instead of __raw_*, define imx_* to *_relaxed and use those. Using imx_* was requested by Arnd because *_relaxed tends to indicate that the code was carefully reviewed to not require any synchronisation and otherwise be safe, which isn't the case here with the automatic conversion. The conversion itself was done using the following spatch (since that automatically adjusts the coding style unlike a simple search&replace). @@ expression E1, E2; @@ -__raw_writel(E1, E2) +imx_writel(E1, E2) @@ expression E1, E2; @@ -__raw_writew(E1, E2) +imx_writew(E1, E2) @@ expression E1; @@ -__raw_readl(E1) +imx_readl(E1) @@ expression E1; @@ -__raw_readw(E1) +imx_readw(E1) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2014-09-03ARM: imx: avic: Convert to handle_domain_irqMarc Zyngier
Use the new handle_domain_irq method to handle interrupts. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Shawn Guo <shawn.guo@freescale.com> Link: https://lkml.kernel.org/r/1409047421-27649-23-git-send-email-marc.zyngier@arm.com Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2014-05-12ARM: i.MX: Setup IRQ handler from IRQ driverAlexander Shiyan
This patch moves IRQ handler setup to the its corresponded IRQ driver (AVIC, TZIC). Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2013-12-09ARM: imx: drop support for irq priorisationUwe Kleine-König
The code for irq priorisation support doesn't have any in-tree users and the Kconfig description does wrong promises because nowadays irq handlers are called with irqs disabled, so no high prioritized irq can interrupt a lower prioritized handler. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-05-02Merge tag 'cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanup from Olof Johansson: "Here is a collection of cleanup patches. Among the pieces that stand out are: - The deletion of h720x platforms - Split of at91 non-dt platforms to their own Kconfig file to keep them separate - General cleanups and refactoring of i.MX and MXS platforms - Some restructuring of clock tables for OMAP - Convertion of PMC driver for Tegra to dt-only - Some renames of sunxi -> sun4i (Allwinner A10) - ... plus a bunch of other stuff that I haven't mentioned" * tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits) ARM: i.MX: remove unused ARCH_* configs ARM i.MX53: remove platform ahci support ARM: sunxi: Rework the restart code irqchip: sunxi: Rename sunxi to sun4i irqchip: sunxi: Make use of the IRQCHIP_DECLARE macro clocksource: sunxi: Rename sunxi to sun4i clocksource: sunxi: make use of CLKSRC_OF clocksource: sunxi: Cleanup the timer code ARM: at91: remove trailing semicolon from macros ARM: at91/setup: fix trivial typos ARM: EXYNOS: remove "config EXYNOS_DEV_DRM" ARM: EXYNOS: change the name of USB ohci header ARM: SAMSUNG: Remove unnecessary code for dma ARM: S3C24XX: Remove unused GPIO drive strength register definitions ARM: OMAP4+: PM: Restore CPU power state to ON with clockdomain force wakeup method ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2412 ARM: S3C24XX: Removed unneeded dependency on CPU_S3C2410 ARM: S3C24XX: Removed unneeded dependency on ARCH_S3C24XX for boards ARM: SAMSUNG: Fix typo "CONFIG_SAMSUNG_DEV_RTC" ARM: S5P64X0: Fix typo "CONFIG_S5P64X0_SETUP_SDHCI" ...
2013-04-02ARM: imx: avic: Move avic_saved_mask_reg under CONFIG_PMFabio Estevam
When building a kernel with CONFIG_PM undefined, the following warning happens: arch/arm/mach-imx/avic.c:57:12: warning: 'avic_saved_mask_reg' defined but not used [-Wunused-variable] Move avic_saved_mask_reg definition inside the '#ifdef CONFIG_PM' block to avoid the warning. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-04-01ARM: mach-imx: avic: Staticize *avic_baseFabio Estevam
Fix the following sparse warning: arch/arm/mach-imx/avic.c:54:14: warning: symbol 'avic_base' was not declared. Should it be static? Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-10-15ARM: imx: remove header file mach/irqs.hShawn Guo
The only mach/irqs.h user outside arch/arm/mach-imx is sound/soc/fsl/imx-pcm-fiq.c, which refers to mxc_set_irq_fiq(). Move the declaration into include/linux/platform_data/asoc-imx-ssi.h, so that we can remove mach/irqs.h includsion from imx-pcm-fiq.c. Inside arch/arm/mach-imx, the only users to mach/irqs.h are avic.c and tzic.c for referring to macro FIQ_START. Let's move the macro into irq-common.h and get rid of mach/irqs.h completely. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: alsa-devel@alsa-project.org
2012-10-15ARM: imx: include hardware.h rather than mach/hardware.hShawn Guo
It moves a bunch of header files included in hardware.h and itself from mach-imx/include/mach to mach-imx, and updates users to include hardware.h rather than mach/hardware.h. The files in mach-imx/devices will need to include "../hardware.h". Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-15ARM: imx: include common.h rather than mach/common.hShawn Guo
Rename mach-imx/include/mach/common.h to mach-imx/common.h and update all users to include common.h rather than mach/common.h. It also removes an unneeded inclusion to common.h in mach-imx/devices/devices.c. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-15ARM: imx: merge plat-mxc into mach-imxShawn Guo
It's really unnecessary to have plat-mxc, and let's merge it into mach-imx. It's pretty much just a bunch of file renaming and Kconfig/Makefile merge. To make the change less invasive, we keep using Kconfig symbol CONFIG_ARCH_MXC for mach-imx sub-architecture. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
