Request for comment and commit.
Date: Mon, 4 Jul 2011 15:53:30 +0200
Subject: [PATCH] i.MX25 GPT clock fix: ensure correct the clock source
This patch ensures, that Linux will take the correct clock source (AHB_DIV)
for gpt in the ARM i.MX25 implementation. The currect code depends on the reset
defaults of the CCM_MCR register. So on some boards it could happen that the
UPLL is used for clock source, which results in faulty time behavior in Linux.
In this case all delays or sleeps will will be faktor 1.8 too long.
Signed-off-by: Torsten Mehnert <t.mehnert@eckelmann.de>
It might be not good to use software defined version to identify sdma
device type, when hardware does not define such version. Instead,
soc name is stable enough to define the device type.
The patch uses platform_device_id rather than version number passed
by platform data to identify sdma device type/version.
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Acked-by: Vinod Koul <vinod.koul@intel.com>
The patch removes all the uses of cpu_is_mx(). Instead, it utilizes
platform_device_id to distinguish the esdhc differences among SoCs.
Cc: Wolfram Sang <w.sang@pengutronix.de>
Cc: Chris Ball <cjb@laptop.org>
Acked-by: Chris Ball <cjb@laptop.org>
On the recent i.mx (mx25/50/53), there is a gasket inside fec
controller which needs to be enabled no matter phy works in MII
or RMII mode.
The current code enables the gasket only when phy interface is RMII.
It's broken when the driver works with a MII phy. The patch uses
platform_device_id to distinguish the SoCs that have the gasket and
enables it on these SoCs for both MII and RMII mode.
Reported-by: Troy Kisky <troy.kisky@boundarydevices.com>
The patch removes all the uses of cpu_is_mx1(). Instead, it uses
the .id_table of platform_driver to distinguish the uart device type,
IMX1_UART and IMX21_UART. The IMX21_UART type runs on all i.mx
except i.mx1.
A couple of !cpu_is_mx1 logic gets turned into is_imx21_uart,
as the codes wrapped there are really IMX21 type uart specific.
It also removes macro MX1_UCR3_REF25 and MX1_UCR3_REF30 which are
not used anywhere.
Cc: Alan Cox <alan@linux.intel.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Software defined version number is not stable enough to be used
in device type naming scheme. The patch changes it to use implicit
soc name for spi device type definition. In this way, we can easily
align the naming scheme with device tree binding, which comes later.
It removes fifosize from spi_imx_data and adds devtype there, so that
fifosize can be set in an inline function according to devtype.
Also, cpu_is_mx can be replaced by inline functions checking devtype.
Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Cc: Grant Likely <grant.likely@secretlab.ca>
Signed-off-by: Eric Bénard <eric@eukrea.com>
arch/arm/mach-pxa/clock.c
arch/arm/mach-pxa/clock.h
Use clk_get to acquire the watchdog clock and also avoid hardcoding the clock name.
