path: root/arch/arm/mach-imx/devices
2014-03-05ARM i.MX: remove PWM platform supportSascha Hauer
As the i.MX pwm driver is devicetree only, remove the platform support for this device. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-06-27ARM: imx: prepare for removal of flexcan_platform_dataMarc Kleine-Budde
As there are no imx in-tree users of flexcan_platform_data, this patch removes the possibility to register a flexcan device with platform data. The functionality to swith on/off CAN transceivers is added to DT via regulators in a later patch. Compile time tested with imx_v4_v5_defconfig and imx_v6_v7_defconfig. Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2013-06-03can: flexcan: remove HAVE_CAN_FLEXCAN Kconfig symbolMarc Kleine-Budde
This patch removes the Kconfig symbol HAVE_CAN_FLEXCAN from arch/{arm,powerpc} and allowing compilation unconditionally on all arm and powerpc platforms. This brings a bigger compile time coverage and removes the following dependency warning found by Arnd Bergmann: warning: (SOC_IMX28 && SOC_IMX25 && SOC_IMX35 && IMX_HAVE_PLATFORM_FLEXCAN && SOC_IMX53 && SOC_IMX6Q) selects HAVE_CAN_FLEXCAN which has unmet direct dependencies (NET && CAN && CAN_DEV) Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2013-05-03Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "The major items included in here are: - MCPM, multi-cluster power management, part of the infrastructure required for ARMs big.LITTLE support. - A rework of the ARM KVM code to allow re-use by ARM64. - Error handling cleanups of the IS_ERR_OR_NULL() madness and fixes of that stuff for arch/arm - Preparatory patches for Cortex-M3 support from Uwe Kleine-König. There is also a set of three patches in here from Hugh/Catalin to address freeing of inappropriate page tables on LPAE. You already have these from akpm, but they were already part of my tree at the time he sent them, so unfortunately they'll end up with duplicate commits" * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (77 commits) ARM: EXYNOS: remove unnecessary use of IS_ERR_VALUE() ARM: IMX: remove unnecessary use of IS_ERR_VALUE() ARM: OMAP: use consistent error checking ARM: cleanup: OMAP hwmod error checking ARM: 7709/1: mcpm: Add explicit AFLAGS to support v6/v7 multiplatform kernels ARM: 7700/2: Make cpu_init() notrace ARM: 7702/1: Set the page table freeing ceiling to TASK_SIZE ARM: 7701/1: mm: Allow arch code to control the user page table ceiling ARM: 7703/1: Disable preemption in broadcast_tlb*_a15_erratum() ARM: mcpm: provide an interface to set the SMP ops at run time ARM: mcpm: generic SMP secondary bringup and hotplug support ARM: mcpm_head.S: vlock-based first man election ARM: mcpm: Add baremetal voting mutexes ARM: mcpm: introduce helpers for platform coherency exit/setup ARM: mcpm: introduce the CPU/cluster power API ARM: multi-cluster PM: secondary kernel entry code ARM: cacheflush: add synchronization helpers for mixed cache state accesses ARM: cpu hotplug: remove majority of cache flushing from platforms ARM: smp: flush L1 cache in cpu_die() ARM: tegra: remove tegra specific cpu_disable() ...
2013-05-02Merge branch 'cleanup' into for-linusRussell King
Conflicts: arch/arm/plat-omap/dmtimer.c
2013-05-02ARM: IMX: remove unnecessary use of IS_ERR_VALUE()Russell King
device_register() returns -ve values for errors, and zero for success. There's no need to obfuscate the code with IS_ERR_VALUE(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-04-09ARM i.MX53: remove platform ahci supportSascha Hauer
The i.MX53 ahci platform support is unused in mainline. To demotivate people using it just remove it from the tree. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-01-29Merge tag 'imx-cleanup-3.9' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup From Shawn Guo: IMX cleanup for 3.9: * Remove lluart.c by using debug_ll_io_init() * Remove mach-mx51_3ds board support * Remove imx50 support which has been BROKEN for cycles * Other trival cleanups * tag 'imx-cleanup-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: imx: Remove mx508 support ARM: imx: Remove mach-mx51_3ds board ARM: imx: use debug_ll_io_init() for imx6q ARM: imx: remove unused imx6q_clock_map_io() ARM: mach-imx: Kconfig: Do not select Babbage for MACH_IMX51_DT Signed-off-by: Olof Johansson <olof@lixom.net> Change/delete conflicts due to some of the previous sweeping cleanups in: arch/arm/mach-imx/mach-mx50_rdp.c arch/arm/mach-imx/mach-mx51_3ds.c
2013-01-29ARM: imx: Remove mx508 supportFabio Estevam
Only mx508 based board is mach-mx50_rdp and it has been marked as BROKEN for several releases. mx508 currently lacks clock support. In case someone needs to add mx508 support back, then the recommended approach is to use device tree. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2013-01-24Merge tag 'fixes-for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Here's a long-pending fixes pull request for arm-soc (I didn't send one in the -rc4 cycle). The larger deltas are from: - A fixup of error paths in the mvsdio driver - Header file move for a driver that hadn't been properly converted to multiplatform on i.MX, which was causing build failures when included - Device tree updates for at91 dealing mostly with their new pinctrl setup merged in 3.8 and mistakes in those initial configs The rest are the normal mix of small fixes all over the place; sunxi, omap, imx, mvebu, etc, etc." * tag 'fixes-for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits) mfd: vexpress-sysreg: Don't skip initialization on probe ARM: vexpress: Enable A7 cores in V2P-CA15_A7's Device Tree ARM: vexpress: extend the MPIDR range used for pen release check ARM: at91/dts: correct comment in at91sam9x5.dtsi for mii ARM: at91/at91_dt_defconfig: add at91sam9n12 SoC to DT defconfig ARM: at91/at91_dt_defconfig: remove memory specification to cmdline ARM: at91/dts: add macb mii pinctrl config for kizbox ARM: at91: rm9200: remake the BGA as default version ARM: at91: fix gpios on i2c-gpio for RM9200 DT ARM: at91/at91sam9x5 DTS: add SCK USART pins ARM: at91/at91sam9x5 DTS: correct wrong PIO BANK values on u(s)arts ARM: at91/at91-pinctrl documentation: fix typo and add some details ARM: kirkwood: fix missing #interrupt-cells property mmc: mvsdio: use devm_ API to simplify/correct error paths. clk: mvebu/clk-cpu.c: fix memory leakage ARM: OMAP2+: omap4-panda: add UART2 muxing for WiLink shared transport ARM: OMAP2+: DT node Timer iteration fix ARM: OMAP2+: Fix section warning for omap_init_ocp2scp() ARM: OMAP2+: fix build break for omapdrm ARM: OMAP2: Fix missing omap2xxx_clkt_vps_late_init function calls ...
2013-01-18usb: gadget: fsl-mxc-udc: replace cpu_is_xxx() with platform_device_idPeter Chen
As mach/hardware.h is deleted, we need to use platform_device_id to differentiate SoCs. Besides, one cpu_is_mx35 is useless as it has already used pdata to differentiate runtime Meanwhile we update the platform code accordingly. Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-01-14ARM: imx: platform-imx-fb: modifies platform device nameGwenhael Goavec-Merou
Framebuffer platform device is now identified by a device id (imx1-fb or imx21-fb) instead of by driver name (imx-fb). Signed-off-by: Gwenhael Goavec-Merou <gwenhael.goavec-merou@armadeus.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-12-17ARM: imx: Move platform-mx2-emma to arch/arm/mach-imx/devicesFabio Estevam
Move platform-mx2-emma to arch/arm/mach-imx/devices and fix the following build error: make[2]: *** No rule to make target `arch/arm/mach-imx/devices/platform-mx2-emma.o', needed by `arch/arm/mach-imx/devices/built-in.o'. Stop. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-11-16ARM : i.MX27 : split code for allocation of ressources of camera and eMMAGaëtan Carlier
This is to prepare addition of m2m-emmapp driver otherwise IMX_HAVE_PLATFORM_MX2_CAMERA must be declared even if only Post-Processor is needed. IMX_HAVE_PLATFORM_MX2_EMMA define has been added. Changes since v1: - Add "select IMX_HAVE_PLATFORM_MX2_EMMA" for MACH_IMX27_VISSTRIM_M10 platform due to pending patch in linux-media tree that will call imx27_add_mx2_emmaprp(). Signed-off-by: Gaëtan Carlier <gcembed@gmail.com> Acked-by: Javier Martin <javier.martin@vista-silicon.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-11-16Merge remote-tracking branch 'arm-soc/imx/multiplatform' into xSascha Hauer
2012-10-15ARM: imx: call mxc_device_init() in soc specific functionShawn Guo
mxc_device_init() is a core_initcall function used to register devices for mxc_aips_bus and mxc_ahb_bus, which are needed by gpio and dma device registration. Instead of being a core_initcall function, we have it called in soc specific initialization function before gpio and dma devices get registered, so that it will not be called for other platforms when we enable multi-platform support for imx. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-10-15ARM: imx: include hardware.h rather than mach/hardware.hShawn Guo
It moves a bunch of header files included in hardware.h and itself from mach-imx/include/mach to mach-imx, and updates users to include hardware.h rather than mach/hardware.h. The files in mach-imx/devices will need to include "../hardware.h". Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-15video: imxfb: remove cpu_is_xxx by using platform_device_idShawn Guo
It changes the driver to use platform_device_id rather than cpu_is_xxx to determine the controller type, and updates the platform code accordingly. As the result, mach/hardware.h inclusion gets removed from the driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: linux-fbdev@vger.kernel.org
2012-10-15mmc: mxcmmc: remove cpu_is_xxx by using platform_device_idShawn Guo
It changes the driver to use platform_device_id rather than cpu_is_xxx to determine the controller type, and updates the platform code accordingly. As the result, mach/hardware.h inclusion gets removed from the driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Chris Ball <cjb@laptop.org> Tested-by: Javier Martin <javier.martin@vista-silicon.com> Cc: linux-mmc@vger.kernel.org
2012-10-15media: mx2_camera: remove cpu_is_xxx by using platform_device_idShawn Guo
It changes the driver to use platform_device_id rather than cpu_is_xxx to determine the controller type, and updates the platform code accordingly. As the result, mach/hardware.h inclusion gets removed from the driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Tested-by: Javier Martin <javier.martin@vista-silicon.com> Cc: linux-media@vger.kernel.org
2012-10-15dma: imx-dma: remove cpu_is_xxx by using platform_device_idShawn Guo
It changes the driver to use platform_device_id rather than cpu_is_xxx to determine the controller type, and updates the platform code accordingly. As the result, mach/hardware.h inclusion gets removed from the driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Javier Martin <javier.martin@vista-silicon.com> Cc: Vinod Koul <vinod.koul@linux.intel.com>
2012-10-15dma: imx-dma: retrieve MEM and IRQ from resourcesShawn Guo
Retrieve MEM and IRQ from resources rather than directly using the value by including machine header. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Vinod Koul <vinod.koul@linux.intel.com>
2012-10-15rtc: mxc_rtc: remove cpu_is_xxx by using platform_device_idShawn Guo
It changes the driver to use platform_device_id rather than cpu_is_xxx to determine the controller type, and updates the platform code accordingly. As the result, mach/hardware.h inclusion gets removed from the driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: rtc-linux@googlegroups.com
2012-10-15mtd: mxc_nand: remove cpu_is_xxx by using platform_device_idShawn Guo
It changes the driver to use platform_device_id rather than cpu_is_xxx to determine the controller type, and updates the platform code accordingly. As the result, mach/hardware.h inclusion gets removed from the driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: linux-mtd@lists.infradead.org
2012-10-15i2c: imx: remove cpu_is_xxx by using platform_device_idShawn Guo
This is some amount of work left/forgot from device tree conversion. Instead of checking cpu_is_xxx to determine the controller type, the driver should use platform_device_id, which should match the device tree compatible string. The patch changes the driver to use platform_device_id rather than cpu_is_xxx to determine the controller type/version. It also updates the platform code and device tree source accordingly. As the result, mach/hardware.h inclusion gets removed from the driver. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Wolfram Sang <w.sang@pengutronix.de> Cc: linux-i2c@vger.kernel.org
2012-10-15ARM: imx: include common.h rather than mach/common.hShawn Guo
Rename mach-imx/include/mach/common.h to mach-imx/common.h and update all users to include common.h rather than mach/common.h. It also removes an unneeded inclusion to common.h in mach-imx/devices/devices.c. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-15ARM: imx: move platform device code into mach-imxShawn Guo
It moves platform device code from plat-mxc into mach-imx. Along with that, header devices-common.h gets moved from plat-mxc/include/mach/ into mach-imx/devices/. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
