The code for irq priorisation support doesn't have any in-tree users and
the Kconfig description does wrong promises because nowadays irq
handlers are called with irqs disabled, so no high prioritized irq can
interrupt a lower prioritized handler.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
The only mach/irqs.h user outside arch/arm/mach-imx is
sound/soc/fsl/imx-pcm-fiq.c, which refers to mxc_set_irq_fiq().
Move the declaration into include/linux/platform_data/asoc-imx-ssi.h,
so that we can remove mach/irqs.h includsion from imx-pcm-fiq.c.
Inside arch/arm/mach-imx, the only users to mach/irqs.h are avic.c
and tzic.c for referring to macro FIQ_START. Let's move the macro
into irq-common.h and get rid of mach/irqs.h completely.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: alsa-devel@alsa-project.org
It's really unnecessary to have plat-mxc, and let's merge it into
mach-imx. It's pretty much just a bunch of file renaming and
Kconfig/Makefile merge.
To make the change less invasive, we keep using Kconfig symbol
CONFIG_ARCH_MXC for mach-imx sub-architecture.
