Use the more common pr_warn.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
The platform_data header usb-ehci-mxc.h has a lot of stuff used by only
IMX platform code. They shouldn't be really in this header but a IMX
platform local header. Create ehci.h and move these stuff into it.
This patch moves IRQ handler setup to the its corresponded IRQ
driver (AVIC, TZIC).
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
It moves a bunch of header files included in hardware.h and itself
from mach-imx/include/mach to mach-imx, and updates users to include
hardware.h rather than mach/hardware.h. The files in mach-imx/devices
will need to include "../hardware.h".
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Rename mach-imx/include/mach/ulpi.h to mach-imx/ulpi.h, and update
users to include ulpi.h rather than mach/ulpi.h.
Rename mach-imx/include/mach/common.h to mach-imx/common.h and update
all users to include common.h rather than mach/common.h.
It also removes an unneeded inclusion to common.h in
mach-imx/devices/devices.c.
The board files in mach-imx are the only users of iomux drivers and
headers. Move them into mach-imx from plat-mxc.
The headers that are only used by board files do not necessarily
need to be in plat-mxc/include/mach. Move them to the same place
as those board files.
ARM is moving to stricter checks on readl/write functions,
so we need to use the correct types everywhere.
This found a bug in mach-armadillo5x0.c, where we attempt mmio
on the MXC_CCM_RCSR address that is currently defined to 0xc
and consequently causes an illegal address access.
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Shawn Guo <shawn.guo@linaro.org>
Remove unneeded mach/irq.h inclusion from imx platform code.
Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
This patch changes all the static gpio irq number assigning with
IOMUX_TO_IRQ() to run-time assigning with gpio_to_irq call, and
in turn eliminates the macro IOMUX_TO_IRQ().
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Fix smsc911x driver probe by adding a fixed dummy regulator.
Hook these platforms restart code into the new restart hook rather
than using arch_reset().
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
* 'for-next' of git://git.infradead.org/users/sameo/mfd-2.6: (80 commits)
mfd: Fix missing abx500 header file updates
mfd: Add missing <linux/io.h> include to intel_msic
x86, mrst: add platform support for MSIC MFD driver
mfd: Expose TurnOnStatus in ab8500 sysfs
mfd: Remove support for early drop ab8500 chip
mfd: Add support for ab8500 v3.3
mfd: Add ab8500 interrupt disable hook
mfd: Convert db8500-prcmu panic() into pr_crit()
mfd: Refactor db8500-prcmu request_clock() function
mfd: Rename db8500-prcmu init function
mfd: Fix db5500-prcmu defines
mfd: db8500-prcmu voltage domain consumers additions
mfd: db8500-prcmu reset code retrieval
mfd: db8500-prcmu tweak for modem wakeup
mfd: Add db8500-pcmu watchdog accessor functions for watchdog
mfd: hwacc power state db8500-prcmu accessor
mfd: Add db8500-prcmu accessors for PLL and SGA clock
mfd: Move to the new db500 PRCMU API
mfd: Create a common interface for dbx500 PRCMU drivers
mfd: Initialize DB8500 PRCMU regs
Fix up trivial conflicts in
arch/arm/mach-imx/mach-mx31moboard.c
arch/arm/mach-omap2/board-omap3beagle.c
arch/arm/mach-u300/include/mach/irqs.h
drivers/mfd/wm831x-spi.c
* 'next/devel' of git://git.linaro.org/people/arnd/arm-soc: (50 commits)
ARM: tegra: update defconfig
arm/tegra: Harmony: Configure PMC for low-level interrupts
arm/tegra: device tree support for ventana board
arm/tegra: add support for ventana pinmuxing
arm/tegra: prepare Seaboard pinmux code for derived boards
arm/tegra: pinmux: ioremap registers
gpio/tegra: Convert to a platform device
arm/tegra: Convert pinmux driver to a platform device
arm/dt: Tegra: Add pinmux node to tegra20.dtsi
arm/tegra: Prep boards for gpio/pinmux conversion to pdevs
ARM: mx5: fix clock usage for suspend
ARM i.MX entry-macro.S: remove now unused code
ARM i.MX boards: use CONFIG_MULTI_IRQ_HANDLER
ARM i.MX tzic: add handle_irq function
ARM i.MX avic: add handle_irq function
ARM: mx25: Add the missing IIM base definition
ARM i.MX avic: convert to use generic irq chip
mx31moboard: Add poweroff support
ARM: mach-qong: Add watchdog support
ARM: davinci: AM18x: Add wl1271/wlan support
Fix up conflicts in:
arch/arm/mach-at91/at91sam9g45.c
arch/arm/mach-mx5/devices-imx53.h
arch/arm/plat-mxc/include/mach/memory.h
To get the definition of core_param() they need this header.
Signed-off-by: Philippe Rétornaz <philippe.retornaz@epfl.ch>
Also, add handle_irq callbacks to machine descriptors.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
The patch makes necessary changes on gpio-mxc as below to turn it
into an upstanding gpio driver.
* Add a list to save all mx2 ports references, so that
mx2_gpio_irq_handler can walk through all interrupt status
registers
* Use readl/writel to replace mach-specific accessors
__raw_readl/__raw_writel
* Change mxc_gpio_init into mxc_gpio_probe function
* Move "struct mxc_gpio_port" into gpio-mxc.c, as it needs not to
be public at all, and also make some other cleanup on
plat-mxc/include/mach/gpio.h at the same time
And the patch then migrates mach-imx and mach-mx5 to the updated
driver by adding corresponding platform devices.
Acked-by: Olof Johansson <olof@lixom.net>
Fixing a few "please, no space before tabs" and "empty line at end of
file" warnings on the way.
LAKML-Reference: 1299271882-2130-6-git-send-email-u.kleine-koenig@pengutronix.de
