path: root/arch/arm/mach-imx/mach-qong.c
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-15ARM: imx: include hardware.h rather than mach/hardware.hShawn Guo
It moves a bunch of header files included in hardware.h and itself from mach-imx/include/mach to mach-imx, and updates users to include hardware.h rather than mach/hardware.h. The files in mach-imx/devices will need to include "../hardware.h". Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-15ARM: imx: include common.h rather than mach/common.hShawn Guo
Rename mach-imx/include/mach/common.h to mach-imx/common.h and update all users to include common.h rather than mach/common.h. It also removes an unneeded inclusion to common.h in mach-imx/devices/devices.c. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-15ARM: imx: move iomux drivers and headers into mach-imxShawn Guo
The board files in mach-imx are the only users of iomux drivers and headers. Move them into mach-imx from plat-mxc. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-07-23Merge tag 'irq' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc sparse IRQ conversion from Arnd Bergmann: "The I.MX platform is getting converted to use sparse IRQs. We are doing this for all platforms over time, because this is one of the requirements for building a multiplatform kernel, and generally a good idea." * tag 'irq' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: imx: select USE_OF ARM: imx: Fix build error due to missing irqs.h include ARM: imx: enable SPARSE_IRQ for imx platform ARM: fiq: change FIQ_START to a variable tty: serial: imx: remove the use of MXC_INTERNAL_IRQS ARM: imx: remove unneeded mach/irq.h inclusion i2c: imx: remove unneeded mach/irqs.h inclusion ARM: imx: add a legacy irqdomain for mx31ads ARM: imx: add a legacy irqdomain for 3ds_debugboard ARM: imx: pass gpio than irq number into mxc_expio_init ARM: imx: leave irq_base of wm8350_platform_data uninitialized dma: ipu: remove the use of ipu_platform_data ARM: imx: move irq_domain_add_legacy call into avic driver ARM: imx: move irq_domain_add_legacy call into tzic driver gpio/mxc: move irq_domain_add_legacy call into gpio driver ARM: imx: eliminate macro IRQ_GPIOx() ARM: imx: eliminate macro IOMUX_TO_IRQ() ARM: imx: eliminate macro IMX_GPIO_TO_IRQ()
2012-07-06ARM: imx: remove unused pdata from device macrosBenoît Thébaudeau
Many imx device macros have a meaningless pdata. This patch removes those. Cc: Sascha Hauer <kernel@pengutronix.de> Cc: <linux-arm-kernel@lists.infradead.org> Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-07-01ARM: imx: remove unneeded mach/irq.h inclusionShawn Guo
Remove unneeded mach/irq.h inclusion from imx platform code. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
2012-07-01ARM: imx: eliminate macro IOMUX_TO_IRQ()Shawn Guo
This patch changes all the static gpio irq number assigning with IOMUX_TO_IRQ() to run-time assigning with gpio_to_irq call, and in turn eliminates the macro IOMUX_TO_IRQ(). Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
2012-01-05ARM: restart: mxc: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-01Merge branch 'next/devel' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/devel' of git://git.linaro.org/people/arnd/arm-soc: (50 commits) ARM: tegra: update defconfig arm/tegra: Harmony: Configure PMC for low-level interrupts arm/tegra: device tree support for ventana board arm/tegra: add support for ventana pinmuxing arm/tegra: prepare Seaboard pinmux code for derived boards arm/tegra: pinmux: ioremap registers gpio/tegra: Convert to a platform device arm/tegra: Convert pinmux driver to a platform device arm/dt: Tegra: Add pinmux node to tegra20.dtsi arm/tegra: Prep boards for gpio/pinmux conversion to pdevs ARM: mx5: fix clock usage for suspend ARM i.MX entry-macro.S: remove now unused code ARM i.MX boards: use CONFIG_MULTI_IRQ_HANDLER ARM i.MX tzic: add handle_irq function ARM i.MX avic: add handle_irq function ARM: mx25: Add the missing IIM base definition ARM i.MX avic: convert to use generic irq chip mx31moboard: Add poweroff support ARM: mach-qong: Add watchdog support ARM: davinci: AM18x: Add wl1271/wlan support ... Fix up conflicts in: arch/arm/mach-at91/at91sam9g45.c arch/arm/mach-mx5/devices-imx53.h arch/arm/plat-mxc/include/mach/memory.h
2011-10-20Merge branch 'imx/cleanup' into next/cleanupArnd Bergmann
2011-10-17arm/imx: remove mx31_setup_weimcs() from mx31.hShawn Guo
The helper function mx31_setup_weimcs() references IOMEM() and IMX_IO_P2V() but without required header mach/hardware.h included in mx31.h. This will break the build of those mx31 based board file with no direct inclusion of mach/hardware.h, or when indirect inclusion to mach/hardware.h breaks. For example, when the inclusion of mach/hardware.h gets removed from mach/gpio.h, we will see the following compile error. CC arch/arm/mach-imx/mach-pcm037_eet.o In file included from arch/arm/mach-imx/devices-imx31.h:9:0, from arch/arm/mach-imx/mach-pcm037_eet.c:20: arch/arm/plat-mxc/include/mach/mx31.h: In function ‘mx31_setup_weimcs’: arch/arm/plat-mxc/include/mach/mx31.h:129:2: error: implicit declaration of function ‘IOMEM’ arch/arm/plat-mxc/include/mach/mx31.h:129:2: error: implicit declaration of function ‘IMX_IO_P2V’ This patch removes mx31_setup_weimcs() from mx31.h and makes it local to mach-qong.c, which is the only user for this helper. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-09-29Merge branches 'features/assorted', 'features/imx-pata' and ↵Sascha Hauer
'features/imx-multi-irq-v2' into imx-features Conflicts: arch/arm/plat-mxc/avic.c arch/arm/plat-mxc/include/mach/common.h Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-09-26ARM i.MX boards: use CONFIG_MULTI_IRQ_HANDLERSascha Hauer
Also, add handle_irq callbacks to machine descriptors. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-09-20ARM: mach-qong: Add watchdog supportFabio Estevam
Add watchdog support for mach-qong target. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by : Stefano Babic <sbabic@denx.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-08-21ARM: mach-imx: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-06-06gpio/mxc: Change gpio-mxc into an upstanding gpio driverShawn Guo
The patch makes necessary changes on gpio-mxc as below to turn it into an upstanding gpio driver. * Add a list to save all mx2 ports references, so that mx2_gpio_irq_handler can walk through all interrupt status registers * Use readl/writel to replace mach-specific accessors __raw_readl/__raw_writel * Change mxc_gpio_init into mxc_gpio_probe function * Move "struct mxc_gpio_port" into gpio-mxc.c, as it needs not to be public at all, and also make some other cleanup on plat-mxc/include/mach/gpio.h at the same time And the patch then migrates mach-imx and mach-mx5 to the updated driver by adding corresponding platform devices. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-19ARM: imx: move mx3 support to mach-imxUwe Kleine-König
Fixing a few "please, no space before tabs" and "empty line at end of file" warnings on the way. LAKML-Reference: 1299271882-2130-6-git-send-email-u.kleine-koenig@pengutronix.de Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
