path: root/arch/arm/mach-imx/mx1ads.c
2009-05-07[ARM] remove arch-imxSascha Hauer
arch-imx is superseeded by the MXC architecture support. This patch removes arch/arm/mach-imx from the kernel. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-28[ARM] mx1ads: make mmc platform data available for modulesSascha Hauer
Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Acked-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2008-07-05IMX UART: remove statically initialized tablesSascha Hauer
This patch removes the statically initialized tables from the i.MX serial driver and makes the driver fully dependent on the information provided by the platform_device. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2007-09-24arm: i.MX/MX1 SDHC implements SD cards read-only switch read-backPavel Pisa
The patch enables to define MMC host get_ro() method through platform data. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2006-05-07[ARM] 3501/1: i.MX: fix lowlevel debug macrosSascha Hauer
Patch from Sascha Hauer This patch fixes the addruart macro to work with both mmu enabled and disabled. Signed-off-by: Sascha Hauer <s.hauer@pengutonix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-04[ARM] 3490/1: i.MX: move uart resources to board filesSascha Hauer
Patch from Sascha Hauer This patch moves the i.MX uart resources and the gpio pin setup to the board files. This allows the boards to decide how many internal uarts are connected to the outside world and whether they use rts/cts or not. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-02[ARM] 3446/1: i.MX: MMC/SD SDHC controller registration for i.MX/MX1 MX1ADS ↵Pavel Pisa
board Patch from Pavel Pisa From: Stefano Fedrigo <aleph@develer.com> This adds to the MX1ADS platform the needed code to detect insertion/removal of an MMC/SD card. Tested on a v1.1 board. Signed-off-by: Stefano Fedrigo <aleph@develer.com> Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-05[SERIAL] Remove unnecessary serial.h includeRussell King
imx.c does not use anything from serial.h, so remove it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-05[ARM] 3231/1: mx1ads board support cleanupSascha Hauer
Patch from Sascha Hauer - remove unnecessary mappings - rename mx1ads_device to cs89x0_device, because that's what it is - fix io/irq resource for cs89x0 device Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[ARM] 3000/1: Replace map_desc.physical with map_desc.pfn: iMXDeepak Saxena
Patch from Deepak Saxena iMX map_desc.pfn conversion Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-04[ARM] 2950/1: i.MX gpio setup functionSascha Hauer
Patch from Sascha Hauer Current implementation of imx_gpio_mode does not allow to configure all alternate routing possibilities of the i.MX. With this patch every bit in the gpio setup registers has a corresponding bit in the gpio_mode parameter, so every routing should be possible now. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-03[PATCH] ARM: Remove machine description macrosRussell King
Remove the pointless machine description macros, favouring C99 initialisers instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
