As the DDR/IO and MMDC setting are different on LPDDR2 and DDR3,
we used cpu type to decide how to do these settings in suspend
before which is NOT flexible, take i.MX6SL for example, although
it has LPDDR2 on EVK board, but users can also use DDR3 on other
boards, so it is better to read the DDR type from MMDC then decide
how to do related settings.
Signed-off-by: Anson Huang <b20788@freescale.com>
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Add more revision support for the new i.MX6DQ tape-out (TO1.5). This
TO1.5 is the Rev 1.3 as documented in i.MX6DQ data sheet, because TO1.3
and TO1.4 are never revealed.
Signed-off-by: Jason Liu <r64343@freescale.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Add basic suppport for i.MX6 SoloX SoC.
[shawn.guo: cherry-pick commit d9654dceb315 from upstream]
The imx6sl low power mode implementation inherits imx6q/dl one,
and pm-imx6q.c can just work for imx6sl with some minor updates.
Let's enable imx6sl suspend support by reusing pm-imx6q.c and use
cpu_is_imxXX() to handle the those minor differences between imx6sl
and imx6q/dl.
The patch enables soc bus infrastructure and adds a function
imx_soc_device_init() to report soc info via soc device interface for
imx6qdl and imx6sl. With the support, user space can get soc related
info by looking at sysfs like below.
$ cat /sys/devices/soc0/machine
Freescale i.MX6 Quad SABRE Smart Device Board
$ cat /sys/devices/soc0/family
Freescale i.MX
$ cat /sys/devices/soc0/soc_id
i.MX6Q
$ cat /sys/devices/soc0/revision
1.2
The i.MX6 DualLite/Solo is another i.MX6 family SoC, which is highly
compatible with i.MX6 Quad/Dual. And that's why we choose to support
it using imx6q code with cpu_is_imx6dl() check when necessary.
Only mx508 based board is mach-mx50_rdp and it has been marked as BROKEN
for several releases.
mx508 currently lacks clock support.
In case someone needs to add mx508 support back, then the recommended approach
is to use device tree.
It moves a bunch of header files included in hardware.h and itself
from mach-imx/include/mach to mach-imx, and updates users to include
hardware.h rather than mach/hardware.h. The files in mach-imx/devices
will need to include "../hardware.h".
