toradex_4.9-2.3.x-imx-next
sound/soc/codecs/sgtl5000.c
sound/soc/fsl/imx-sgtl5000.c
This is the 4.9.220 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/common.h
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm/mach-imx/suspend-imx6.S
block/blk-core.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/host/sdhci.c
drivers/net/can/flexcan.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/phy/phy_device.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/tty/serial/imx.c
drivers/usb/dwc3/gadget.c
drivers/usb/host/xhci.c
include/linux/blkdev.h
include/linux/cpu.h
include/linux/platform_data/dma-imx-sdma.h
kernel/cpu.c
net/wireless/util.c
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
sound/soc/fsl/fsl_sai.c
[ Upstream commit 8148d2136002da2e2887caf6a07bbd9c033f14f3 ]
One of the Freescale recommended sequences for power off with external
PMIC is the following:
3. SoC is programming PMIC for power off when standby is asserted.
4. In CCM STOP mode, Standby is asserted, PMIC gates SoC supplies.
See:
http://www.nxp.com/assets/documents/data/en/reference-manuals/IMX6DQRM.pdf
page 5083
This patch implements step 4. of this sequence.
Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de>
(cherry picked from commit 051ee1a1c24058db62f10a177b1271daebbd2ebe)
With the 3.14.28 release of the kernel imx6_stop_mode_poweroff() does not
enter stop mode.
Thus the function does not switch of power but returns.
This seems to be caused by the second processor which has been stopped.
Set the WFI event mask for the stopped processor works around the issue.
(cherry-picked from commit 2acff0eaece38533e85e08431e7ae9f3027c677a)
(cherry picked from commit 894914718e9e563eb601e0090e1ae2ddadf426a9)
After the system has been shutdown with PMIC_ON_REQ and VCC_BATT is supplied
from a battery it will never restart either by RESET or power cycle.
So use the PMIC_STBY_REQ after shutdown to switch off power rails.
arch/arm/mach-imx/pm-imx6.c
drivers/regulator/pfuze100-regulator.c
(cherry-picked from commit c8b186404065c4502b485820ad4a51515924795c)
(cherry-picked from commit ee4c5c4da3b32f65528a2d523ca4bce574dee3c5)
(cherry picked from commit 29ff2389ecf7cb4e30924c80b8d42165cf306936)
Support using PSCI to handle Power stuff.
Use PSCI to differentiate secure/non-secure kernel.
i.MX7 LPSR mode not implemented now.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Anson Huang <Anson.Huang@nxp.com>
For i.mx6q systems the mmdc handshake on channel 0 is kept enabled (while
channel 1 is bypassed). This is ok for lpddr2 systems operating on 1ch-mode,
but not true for 2ch-mode. On this case the handshake needs to be set for
both channels, otherwise a kernel panic or Oops error might be observed
after resuming from suspend.
Signed-off-by: Juan Gutierrez <juan.gutierrez@nxp.com>
i.MX6SLL has new hardware function of bus auto clock gating,
whenerve bus is idle, its clock will be auto gated to save
power, enable this function.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
i.MX6SLL has different DRAM IO offset, and it has no
CAS/RAS/ODT/RESET pin now, correct the DRAM IO offset.
To better support all different i.MX6 SoCs and different
DRAM types, introduce a new column to store the low power
settings for DRAM IO, then suspend asm code no need to check
SoC or DRAM type, just get the DRAM IO's low power
settings from OCRAM pm_info and set to each DRAM IO.
i.MX6SLL LPDDR3 script v1.2 is released, update MMDC
restore settings accordingly.
For MMDC, LPDDR3 type's value is 2b'11, which is
different from DDRC, so correct it.
Add DSM mode support for i.MX6SLL, Mega/Fast mix
can be off now.
There are two states in i.MX6Q cpuidle driver.
state[1]: ARM WFI mode
state[2]: i.MX6Q WAIT mode
Take i.MX6DL as example, think out such a case:
1. CPU0/1 both run at normal mode
2. On CPU0, `sleep 1` is executed. And there are no workload on CPU1.
3. CPU0 first runs into state[2] and 'wfi' instruction. Switched to use
GPT broadcast.
4. CPU1 runs into state[2] and configure CCM to WAIT MODE,
then 'wfi' instruction. Now arm_clk and local timer clock are
shutdown. Switched to use GPT broadcast
5. GPT broadcast timer interrupt comes to GPC/GIC, then CPU0 wakes up.
CPU0 switched to use arm local timer. CPU1 is still sleeping.
6. No workload on CPU0, CPU0 runs into state[1]. But CCM register
is still not restored to Normal RUN mode. 'wfi' + CCM WAIT will
cause arm_clk and arm core clk.
Now CPU0 stops, which is not correct.
So, need to make sure CCM configured to RUN mode when any cpu exit
state[2].
In this patch,
When CPU exits state[2], it configures CCM to RUN mode.
When all CPUs enters state[2], the last CPU needs to check
whether it's ok to configure CCM to WAIT mode or not.
In imx6q_set_lpm, we only need to unmask GINT when not WAIT_CLOCKED,
so add a check condition.
Enable DSM for i.MX6ULL, UART_UBRC is a read-only
register, writting it will cause external abort,
so skip save/restore for this register.
Signed-off-by: Bai Ping <ping.bai@nxp.com>
Add suspend/resume support for i.MX6ULL.
Add lpddr2 two channel suspend support
- save/restore mmdc io pads for channel 2
- Set mmdc channe 2 on self refresh and auto power saving mode
only if mmdc channel 2 is enabled
- Perform a reset fifo on resume_io when restoring mmdc io pads
Signed-off-by: Adrian Alonso <adrian.alonso@nxp.com>
(cherry picked from commit 2e5982e82edc8fc7de0aebc8894a9f0a41e01965)
Add low power suspend mode support for imx6q lpddr2
Save/restore mmdc iomux pads relevant to dual channel
lpddr2 memory when enter/exit low power suspend mode.
Remove unused macros in suspend-imx6.
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
Signed-off-by: Anson Huang <b20788@freescale.com>
(cherry picked from commit 5ebac6d425b859c51d570489d03684e0c976ef60)
Currently, all i.MX6 config (CONFIG_SOC_IMX6XXX) are enabled, so
build and function are OK for every i.MX6 SOC, however, when only
one SOC config is selected in menu config, for example, users only
needs i.MX6SL, they might deselect all reset SOC configs, then the
build will fail, this is unacceptable.
Signed-off-by: Bai Ping <b51503@freescale.com>
This patch adds suspend/resume with Mega/Fast mix off
support for i.MX6UL-9x9-LPDDR2-EVK board, LPDDR2 has
different MMDC restore flow compared to DDR3.
(cherry picked from commit d5d3915aac04c2a80827d215d703e0f46309ed14)
this patch adds A9-M4 power management, including
below features:
1. busfreq: M4 is registered as a high speed device
of A9, when M4 is running at high speed, busfreq
will NOT enter low bus mode, when M4 is entering
its low power idle, A9 will be able to enter low
bus mode according to its state machine;
2. low power idle: only when M4 is in its low power
idle, busfreq is staying at low bus mode, low
power idle is available for kernel;
3. suspend: when M4 is NOT in its low power idle,
when linux is about to suspend, it will only
force SOC enter WAIT mode, only when M4 is in
its low power idle in TCM, linux suspend can
enter DSM mode. M4 can request/release wakeup
source via MU to A9.
as M4 can NOT switch its clk parent due to glitch MUX,
to handle this case, A9 will help switch M4's clk
parent, the flow is as below:
M4:
1. enter low power idle, send bus use count-- to A9;
2. enter wfi and only wait for MU interrupt;
3. receive A9's clk switch ready message, go into low
power idle;
4. receive interrupt to exit low power idle, send request
to A9 for increase busfreq and M4 freq, enter wfi
5. receive A9 ready message, go out of low power idle.
A9:
1. when receive M4's message of entering low power idle,
wait M4 into wfi, hold M4 in wfi by hardware, gate
M4 clk, then switch M4's clk to OSC, ungate M4 clk,
send ready command to wake up M4 into low power idle;
2. when receive M4's message of exiting low power idle,
M4 clk, then switch M4's clk to origin high clk,
ungate M4 clk, send ready command to wake up M4
to exit low power idle;
arch/arm/mach-imx/busfreq-imx6.c
When resume from DSM with Mega/Fast off, we need to restore
the right QSPI module for M4, so get the qspi index from dtb file.
As M4 is executing on QSPI2 flash, and QSPI is inside Mega/Fast
domain which may lost power in DSM, so we need to do save/restore
of QSPI2 controller to make sure QSPI flash can be accessed before
waking up M4 after exiting from DSM.
Signed-off-by: Allen Xu <b45815@freescale.com>
This patch adds suspend/resume with Mega/Fast mix off support
for i.MX6SX LPDDR2, tested on i.MX6SX-14x14-LPDDR2-ARM2 board.
Enable the M/F funtion support on i.MX6SX. The M4 M/F off
support is not added at present, will be enabled after the M4
funtion is ready.
i.MX6SX has same design as i.MX6SL which has bypass
pmic ready signal, as we do NOT enable this function,
so need to bypass it during suspend/resume.
Add M/F mix support on i.MX6UL.
This patch adds busfreq support for i.MX7D SDB
board with DDR3 memory, 3 setpoints supported:
HIGH: DRAM CLK = 533MHz, AXI = 332MHz, AHB = 135MHz;
AUDIO: DRAM CLK = 100MHz; AXI = 24MHz, AHB = 24MHz;
LOW: DRAM CLK = 24MHz; AXI = 24MHz, AHB = 24MHz;
add necessary io memory mapping used by power management.
Add basic pm suspend/resume support for i.MX6UL.
Pull ARM SoC platform updates from Arnd Bergmann:
"These are updates for platform specific code on 32-bit ARM machines,
essentially anything that can not (yet) be expressed using DT files.
Noteworthy changes include:
- We get support for running in big-endian mode on two platforms:
sunxi (Allwinner) and s3c24xx (old Samsung).
- The recently added Uniphier platform now uses standard PSCI methods
for SMP booting and we remove support for old bootloader versions
that did not support it yet.
- In sunxi, we gain support for the "Nextthing GR8" SoC, which is a
close relative of the Allwinner A13 and R8 chips.
- PXA completes its move over to the generic dmaengine framework and
removes its old private API
- mach-bcm gains support for BCM47189/BCM53573, their first ARM SoC
with integrated 802.11ac wireless networking"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (54 commits)
ARM: imx legacy: pca100: move peripheral initialization to .init_late
ARM: imx legacy: mx27ads: move peripheral initialization to .init_late
ARM: imx legacy: mx21ads: move peripheral initialization to .init_late
ARM: imx legacy: pcm043: move peripheral initialization to .init_late
ARM: imx legacy: mx35-3ds: move peripheral initialization to .init_late
ARM: imx legacy: mx27-3ds: move peripheral initialization to .init_late
ARM: imx legacy: imx27-visstrim-m10: move peripheral initialization to .init_late
ARM: imx legacy: vpr200: move peripheral initialization to .init_late
ARM: imx legacy: mx31moboard: move peripheral initialization to .init_late
ARM: imx legacy: armadillo5x0: move peripheral initialization to .init_late
ARM: imx legacy: qong: move peripheral initialization to .init_late
ARM: imx legacy: mx31-3ds: move peripheral initialization to .init_late
ARM: imx legacy: pcm037: move peripheral initialization to .init_late
ARM: imx legacy: mx31lilly: move peripheral initialization to .init_late
ARM: imx legacy: mx31ads: move peripheral initialization to .init_late
ARM: imx legacy: mx31lite: move peripheral initialization to .init_late
ARM: imx legacy: kzm: move peripheral initialization to .init_late
MAINTAINERS: update list of Oxnas maintainers
ARM: orion5x: remove extraneous NO_IRQ
ARM: orion: simplify orion_ge00_switch_init
i.MX6SX has bypass PMIC ready function, as this function
is normally NOT enabled on the board design, so we need
to bypass the PMIC ready pin check during DSM mode resume
flow, otherwise, the internal DSM resume logic will be
waiting for this signal to be ready forever and cause
resume fail.
Fixes: ff843d621bfc ("ARM: imx: add suspend support for i.mx6sx")
Cc: <stable@vger.kernel.org>
Tested-by: Peter Chen <peter.chen@nxp.com>
Let's rename the function imx6q_set_int_mem_clk_lpm()
to imx6_set_int_mem_clk_lpm() since it's actually
common for all i.MX6 SoCs.
There is a missing BM_CLPCR_BYP_MMDC_CH0_LPM_HS setting for imx6ul,
without it, the "standby" mode can't work well, the system can't be
resumed.
With this commit, the "standby" mode works well.
Signed-off-by: Peter Chen <peter.chen@nxp.com>
Cc: Anson Huang <anson.huang@nxp.com>
Fixes: ee4a5f838c84 ("ARM: imx: add suspend/resume support for i.mx6ul")
The wrong pointer is passed to the ioumap function in the cleanup path
Signed-off-by: Jean-Christophe Dubois <jcd@tribudubois.net>
Reviewed-by: Lucas Stach <l.stach@pengutronix.de>
This patch adds suspend function for i.MX6UL, it supports
"standby" and "mem" mode, for "standby" mode, SoC will
enter STOP mode only, while for "mem" mode, SoC will
enter STOP mode and DDR IO will be set to low power
mode.
As i.MX6UL contains a "Cortex-A7" ARM core which has no
PL310, so we need to avoid any PL310 operations during
suspend/resume, also, we need to flush Cortex-A7's inernal
L2 cache before suspend.
This change modifies gen_pool_get() and devm_gen_pool_create() client
interfaces adding one more argument "name" of a gen_pool object.
Due to implementation gen_pool_get() is capable to retrieve only one
gen_pool associated with a device even if multiple gen_pools are created,
fortunately right at the moment it is sufficient for the clients, hence
provide NULL as a valid argument on both producer devm_gen_pool_create()
and consumer gen_pool_get() sides.
Because only one created gen_pool per device is addressable, explicitly
add a restriction to devm_gen_pool_create() to create only one gen_pool
per device, this implies two possible error codes returned by the
function, account it on client side (only misc/sram). This completes
client side changes related to genalloc updates.
[akpm@linux-foundation.org: gen_pool_get() cleanup]
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
Cc: Philipp Zabel <p.zabel@pengutronix.de>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
To be consistent with other genalloc interface namings, rename
dev_get_gen_pool() to gen_pool_get(). The original omitted "dev_" prefix
is removed, since it points to argument type of the function, and so it
does not bring any useful information.
[akpm@linux-foundation.org: update arch/arm/mach-socfpga/pm.c]
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Mark Brown <broonie@kernel.org>
Cc: Alan Tull <atull@opensource.altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Kevin Hilman <khilman@linaro.org>
Commit 4631960d26da ("ARM: imx6: set initial power mode in pm function")
moves imx6_set_lpm() from clock init function into
imx6_pm_common_init(). This causes a hang when cpuidle support is
enabled. The reason for that is ARM core clock is shut down
unexpectedly by WAIT mode. It happens with the following call stack:
cpuidle_register_governor()
cpuidle_switch_governor()
cpuidle_uninstall_idle_handler()
synchronize_sched()
wait_rcu_gp()
wait_for_completion()
When wait_for_completion() is called as above, all cores are idle/WFI.
Hence, the reset value of CCM_CLPCR_LPM - WAIT mode, will trigger a
hardware shutdown of the ARM core clock.
To fix the regression, we need to ensure that CCM_CLPCR_LPM is
initialized into RUN mode earlier than cpuidle governor registration,
which is a postcore_initcall. This patch creates function
imx6_pm_ccm_init() to map CCM block and initialize CCM_CLPCR_LPM into
RUN mode, and have the function called from machine .init_irq hook,
which should be early enough.
Reported-by: Kevin Hilman <khilman@kernel.org>
Fixes: 8fb76a07e2cb ("ARM: imx6: set initial power mode in pm function")
Tested-by: Kevin Hilman <khilman@linaro.org>
Tested-by: Tyler Baker <tyler.baker@linaro.org>
We are about to move imx6 clock driver into drivers/clk, so let's get
imx6 pm code map CCM block on its own rather than relying on clock
driver to do the mapping.
Rather than setting initial low-power mode in every single i.MX6 clock
initialization function, we should really do that in pm code. Let's
move imx6q_set_lpm(WAIT_CLOCKED) call into imx6_pm_common_init().
While at it, let's rename the function to imx6_set_lpm() since it's
actually common for all i.MX6 SoCs.
IMX6 has been (ab)using the gic_arch_extn to provide
wakeup from suspend, and it makes a lot of sense to convert
this code to use stacked domains instead.
This patch does just this, updating the DT files to actually
reflect what the HW provides.
BIG FAT WARNING: because the DTs were so far lying by not
exposing the fact that the GPC block is actually the first
interrupt controller in the chain, kernels with this patch
applied wont have any suspend-resume facility when booted
with old DTs, and old kernels with updated DTs won't even boot.
Tested-by: Stefan Agner <stefan@agner.ch>
Acked-by: Stefan Agner <stefan@agner.ch>
This patch introduces an independent cpuidle driver for
i.MX6SX, and supports arm power off in idle, totally
3 levels of cpuidle are supported as below:
1. ARM WFI;
2. SOC in WAIT mode;
3. SOC in WAIT mode + ARM power off.
ARM power off can save at least 5mW power.
This patch also replaces imx6q_enable_rbc with imx6_enable_rbc.
Now we support DSM in OCRAM for all i.MX6 SoCs,
the resume entry point is set in asm code of
suspend-imx6.S, so no need to set the resume
entry point for SRC in pre-suspend flow.
Pull ARM SoC platform changes from Arnd Bergmann:
"New and updated SoC support, notable changes include:
- bcm:
brcmstb SMP support
initial iproc/cygnus support
- exynos:
Exynos4415 SoC support
PMU and suspend support for Exynos5420
PMU support for Exynos3250
pm related maintenance
- imx:
new LS1021A SoC support
vybrid 610 global timer support
- integrator:
convert to using multiplatform configuration
- mediatek:
earlyprintk support for mt8127/mt8135
- meson:
meson8 soc and l2 cache controller support
- mvebu:
Armada 38x CPU hotplug support
drop support for prerelease Armada 375 Z1 stepping
extended suspend support, now works on Armada 370/XP
- omap:
hwmod related maintenance
prcm cleanup
- pxa:
initial pxa27x DT handling
- rockchip:
SMP support for rk3288
add cpu frequency scaling support
- shmobile:
r8a7740 power domain support
various small restart, timer, pci apmu changes
- sunxi:
Allwinner A80 (sun9i) earlyprintk support
- ux500:
Overall, a significant chunk of changes, coming mostly from the usual
suspects: omap, shmobile, samsung and mvebu, all of which already
contain a lot of platform specific code in arch/arm"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (187 commits)
ARM: mvebu: use the cpufreq-dt platform_data for independent clocks
soc: integrator: Add terminating entry for integrator_cm_match
ARM: mvebu: add SDRAM controller description for Armada XP
ARM: mvebu: adjust mbus controller description on Armada 370/XP
ARM: mvebu: add suspend/resume DT information for Armada XP GP
ARM: mvebu: synchronize secondary CPU clocks on resume
ARM: mvebu: make sure MMU is disabled in armada_370_xp_cpu_resume
ARM: mvebu: Armada XP GP specific suspend/resume code
ARM: mvebu: reserve the first 10 KB of each memory bank for suspend/resume
ARM: mvebu: implement suspend/resume support for Armada XP
clk: mvebu: add suspend/resume for gatable clocks
bus: mvebu-mbus: provide a mechanism to save SDRAM window configuration
bus: mvebu-mbus: suspend/resume support
clocksource: time-armada-370-xp: add suspend/resume support
irqchip: armada-370-xp: Add suspend/resume support
ARM: add lolevel debug support for asm9260
ARM: add mach-asm9260
ARM: EXYNOS: use u8 for val[] in struct exynos_pmu_conf
power: reset: imx-snvs-poweroff: add power off driver for i.mx6
ARM: imx: temporarily remove CONFIG_SOC_FSL from LS1021A
The imx6 PM code seems to be quite creative in its use of irq_data,
using something that is very much a hardware interrupt number where
we expect a virtual one. Yes, it worked so far, but that's only
luck, and it will definitely explode in 3.19.
Fix it by using a pair of helper functions that deal with the
actual hardware.
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
As the DDR/IO and MMDC setting are different on LPDDR2 and DDR3,
we used cpu type to decide how to do these settings in suspend
before which is NOT flexible, take i.MX6SL for example, although
it has LPDDR2 on EVK board, but users can also use DDR3 on other
boards, so it is better to read the DDR type from MMDC then decide
how to do related settings.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Add standby mode support for suspend, to enter standby mode:
echo standby > /sys/power/state;
Use UART or RTC alarm to wake up system, when system enters
standby mode, SOC will enter STOP mode with ARM core kept
power on and 24M XTAL on.
According to hardware design, mem bit must be clear before
entering DSM mode, as ARM core will be power gated in DSM mode.
