git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c changes from Wolfram Sang:
- new drivers for exynos5, bcm kona, and st micro
- bigger overhauls for drivers mxs and rcar
- typical driver bugfixes, cleanups, improvements
- got rid of the superfluous 'driver' member in i2c_client struct This
touches a few drivers in other subsystems. All acked.
* 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (38 commits)
i2c: bcm-kona: fix error return code in bcm_kona_i2c_probe()
i2c: i2c-eg20t: do not print error message in syslog if no ACK received
i2c: bcm-kona: Introduce Broadcom I2C Driver
i2c: cbus-gpio: Fix device tree binding
i2c: wmt: add missing clk_disable_unprepare() on error
i2c: designware: add new ACPI IDs
i2c: i801: Add Device IDs for Intel Wildcat Point-LP PCH
i2c: exynos5: Remove incorrect clk_disable_unprepare
i2c: i2c-st: Add ST I2C controller
i2c: exynos5: add High Speed I2C controller driver
i2c: rcar: fixup rcar type naming
i2c: scmi: remove some bogus NULL checks
i2c: sh_mobile & rcar: Enable the driver on all ARM platforms
i2c: sh_mobile: Convert to clk_prepare/unprepare
i2c: mux: gpio: use reg value for i2c_add_mux_adapter
i2c: mux: gpio: use gpio_set_value_cansleep()
i2c: Include linux/of.h header
i2c: mxs: Fix PIO mode on i.MX23
i2c: mxs: Rework the PIO mode operation
i2c: mxs: distinguish i.MX23 and i.MX28 based I2C controller
Pull ARM SoC fixes from Olof Johansson:
"A first set of batches of fixes for 3.13. The diffstat is large
mostly because we're adding a defconfig for a family that's been
lacking it, and there's some missing clock information added for i.MX
and OMAP.
The at91 new code is around dealing with RTC/RTT reset at boot to fix
possible hangs due to pending wakeup interrupts coming in during early
boot"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits)
ARM: OMAP2+: Fix build for dra7xx without omap4 and 5
ARM: OMAP2+: omap_device: maintain sane runtime pm status around suspend/resume
doc: devicetree: Add bindings documentation for omap-des driver
ARM: dts: doc: Document missing compatible property for omap-sham driver
ARM: OMAP3: Beagle: fix return value check in beagle_opp_init()
ARM: at91: fix hanged boot due to early rtt-interrupt
ARM: at91: fix hanged boot due to early rtc-interrupt
video: exynos_mipi_dsim: Remove unused variable
ARM: highbank: only select errata 764369 if SMP
ARM: sti: only select errata 764369 if SMP
ARM: tegra: init fuse before setting reset handler
ARM: vt8500: add defconfig for v6/v7 chips
ARM: integrator_cp: Set LCD{0,1} enable lines when turning on CLCD
ARM: OMAP: devicetree: fix SPI node compatible property syntax items
pinctrl: single: call pcs_soc->rearm() whenever IRQ mask is changed
ARM: OMAP2+: smsc911x: fix return value check in gpmc_smsc911x_init()
MAINTAINERS: drop discontinued mailing list
ARM: dts: i.MX51: Fix OTG PHY clock
ARM: imx: set up pllv3 POWER and BYPASS sequentially
ARM: imx: pllv3 needs relock in .set_rate() call
Pull ACPI and power management updates from Rafael J Wysocki:
- New power capping framework and the the Intel Running Average Power
Limit (RAPL) driver using it from Srinivas Pandruvada and Jacob Pan.
- Addition of the in-kernel switching feature to the arm_big_little
cpufreq driver from Viresh Kumar and Nicolas Pitre.
- cpufreq support for iMac G5 from Aaro Koskinen.
- Baytrail processors support for intel_pstate from Dirk Brandewie.
- cpufreq support for Midway/ECX-2000 from Mark Langsdorf.
- ARM vexpress/TC2 cpufreq support from Sudeep KarkadaNagesha.
- ACPI power management support for the I2C and SPI bus types from Mika
Westerberg and Lv Zheng.
- cpufreq core fixes and cleanups from Viresh Kumar, Srivatsa S Bhat,
Stratos Karafotis, Xiaoguang Chen, Lan Tianyu.
- cpufreq drivers updates (mostly fixes and cleanups) from Viresh
Kumar, Aaro Koskinen, Jungseok Lee, Sudeep KarkadaNagesha, Lukasz
Majewski, Manish Badarkhe, Hans-Christian Egtvedt, Evgeny Kapaev.
- intel_pstate updates from Dirk Brandewie and Adrian Huang.
- ACPICA update to version 20130927 includig fixes and cleanups and
some reduction of divergences between the ACPICA code in the kernel
and ACPICA upstream in order to improve the automatic ACPICA patch
generation process. From Bob Moore, Lv Zheng, Tomasz Nowicki, Naresh
Bhat, Bjorn Helgaas, David E Box.
- ACPI IPMI driver fixes and cleanups from Lv Zheng.
- ACPI hotplug fixes and cleanups from Bjorn Helgaas, Toshi Kani, Zhang
Yanfei, Rafael J Wysocki.
- Conversion of the ACPI AC driver to the platform bus type and
multiple driver fixes and cleanups related to ACPI from Zhang Rui.
- ACPI processor driver fixes and cleanups from Hanjun Guo, Jiang Liu,
Bartlomiej Zolnierkiewicz, Mathieu Rhéaume, Rafael J Wysocki.
- Fixes and cleanups and new blacklist entries related to the ACPI
video support from Aaron Lu, Felipe Contreras, Lennart Poettering,
Kirill Tkhai.
- cpuidle core cleanups from Viresh Kumar and Lorenzo Pieralisi.
- cpuidle drivers fixes and cleanups from Daniel Lezcano, Jingoo Han,
Bartlomiej Zolnierkiewicz, Prarit Bhargava.
- devfreq updates from Sachin Kamat, Dan Carpenter, Manish Badarkhe.
- Operation Performance Points (OPP) core updates from Nishanth Menon.
- Runtime power management core fix from Rafael J Wysocki and update
from Ulf Hansson.
- Hibernation fixes from Aaron Lu and Rafael J Wysocki.
- Device suspend/resume lockup detection mechanism from Benoit Goby.
- Removal of unused proc directories created for various ACPI drivers
from Lan Tianyu.
- ACPI LPSS driver fix and new device IDs for the ACPI platform scan
handler from Heikki Krogerus and Jarkko Nikula.
- New ACPI _OSI blacklist entry for Toshiba NB100 from Levente Kurusa.
- Assorted fixes and cleanups related to ACPI from Andy Shevchenko, Al
Stone, Bartlomiej Zolnierkiewicz, Colin Ian King, Dan Carpenter,
Felipe Contreras, Jianguo Wu, Lan Tianyu, Yinghai Lu, Mathias Krause,
Liu Chuansheng.
- Assorted PM fixes and cleanups from Andy Shevchenko, Thierry Reding,
Jean-Christophe Plagniol-Villard.
* tag 'pm+acpi-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (386 commits)
cpufreq: conservative: fix requested_freq reduction issue
ACPI / hotplug: Consolidate deferred execution of ACPI hotplug routines
PM / runtime: Use pm_runtime_put_sync() in __device_release_driver()
ACPI / event: remove unneeded NULL pointer check
Revert "ACPI / video: Ignore BIOS initial backlight value for HP 250 G1"
ACPI / video: Quirk initial backlight level 0
ACPI / video: Fix initial level validity test
intel_pstate: skip the driver if ACPI has power mgmt option
PM / hibernate: Avoid overflow in hibernate_preallocate_memory()
ACPI / hotplug: Do not execute "insert in progress" _OST
ACPI / hotplug: Carry out PCI root eject directly
ACPI / hotplug: Merge device hot-removal routines
ACPI / hotplug: Make acpi_bus_hot_remove_device() internal
ACPI / hotplug: Simplify device ejection routines
ACPI / hotplug: Fix handle_root_bridge_removal()
ACPI / hotplug: Refuse to hot-remove all objects with disabled hotplug
ACPI / scan: Start matching drivers after trying scan handlers
ACPI: Remove acpi_pci_slot_init() headers from internal.h
ACPI / blacklist: fix name of ThinkPad Edge E530
PowerCap: Fix build error with option -Werror=format-security
arch/arm/mach-omap2/opp.c
drivers/Kconfig
drivers/spi/spi.c
Currently, POWER and BYPASS bits are set up in a single write to pllv3
register. This causes problem occasionally from the IPU/HDMI testing.
Let's follow FSL BSP code to set up POWER bit, relock, and then BYPASS
sequentially.
The pllv3 nees relock not only when powering up but also when rate
changes. The patch creates a helper function clk_pllv3_wait_lock() and
moves the relock code from clk_pllv3_prepare() into there, so that
both .prepare() and .set_rate() hooks of pllv3 can call into the helper
for relocking.
Since relock is only needed when PLL is powered up while clk_set_rate()
could be called before clk is prepared, we need to add a check in
clk_pllv3_wait_lock() to skip the relock if PLL is not powered.
The pllv3 relock time varies in the range of 50us ~ 500us, depending on
the specific PLL type, e.g. 50us for ARM PLL and 450us for Audio/Video
PLL. Let's add a usleep_range() call instead of doing busy wait during
relock.
The clk_enet_ref_table[] is missing a final empty entry as end of list
marker. Also make the existing markers more obvious.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Building a kernel with the following options,
CONFIG_SMP=n
CONFIG_PM=y
CONFIG_SOC_IMX6SL=y
CONFIG_SOC_IMX6Q=n
we will see the build error below.
arch/arm/mach-imx/built-in.o: In function `imx6q_pm_enter':
platform-spi_imx.c:(.text+0x2648): undefined reference to `v7_cpu_resume'
make[1]: *** [vmlinux] Error 1
This is because that v7_cpu_resume() implemented in headsmp.S is also
needed by imx6sl build. Let's build headsmp.S for CONFIG_SOC_IMX6SL as
well.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
The current comment in the code does not make it clear why the double writes
on SRC bit is needed. Let's quote the errata to get it clear. Also, to
ensure there are at least 2 writes happen in the same one 32kHz period,
we actually need 3 writes. Let's add the third one.
There is ~10% possibility that the following emergency restart command
fails to reboot imx6q.
$ echo b > /proc/sysrq-trigger
The IMX restart routine mxc_restart() assumes that it will always run on
primary core, and will call imx_src_prepare_restart() to disable
secondary cores in order to get them come to online in the following
boot. However, the assumption is only true for normal kernel_restart()
case where migrate_to_reboot_cpu() will be called to migrate to primary
core, but not necessarily true for emergency_restart() case. So when
emergency_restart() calls into mxc_restart() on any secondary core,
system will hang immediately once imx_src_prepare_restart() is called
to disabled secondary cores. Since emergency_restart() is defined as a
function that is safe to call in interrupt context, we cannot just call
migrate_to_reboot_cpu() to fix the issue.
Fortunately, we just found that the issue can be fixed at imx6q platform
level. We used to call imx_src_prepare_restart() to disable all
secondary cores before resetting hardware. Otherwise, the secondary
will fail come to online in the reboot. However, we recently found that
after commit 6050d18 (ARM: imx: reset core along with enable/disable
operation) comes to play, we do not need to reset the secondary cores
any more. That said, mxc_restart() now can run on any core to reboot
the system, as long as we remove the imx_src_prepare_restart() call from
mxc_restart().
So let's simply remove imx_src_prepare_restart() call to fix the above
emergency restart failure.
Reported-by: Jiada Wang <jiada_wang@mentor.com>
instead of pll3_usb_otg the parent of can_root clock
should be pll3_60m.
Signed-off-by: Jiada Wang <jiada_wang@mentor.com>
Pull ARM SoC platform changes from Olof Johansson:
"New and updated SoC support. Among the things new for this release
are:
- More support for the AM33xx platforms from TI
- Tegra 124 support, and some updates to older tegra families as well
- imx cleanups and updates across the board
- A rename of Broadcom's Mobile platforms which were introduced as
ARCH_BCM, and turned out to be too broad a name. New name is
ARCH_BCM_MOBILE.
- A whole bunch of updates and fixes for integrator, making the
platform code more modern and switches over to DT-only booting.
- Support for two new Renesas shmobile chipsets. Next up for them is
more work on consolidation instead of introduction of new
non-multiplatform SoCs, we're all looking forward to that!
- Misc cleanups for older Samsung platforms, some Allwinner updates,
etc"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (159 commits)
ARM: bcm281xx: Add ARCH_BCM_MOBILE to bcm config
ARM: bcm_defconfig: Run "make savedefconfig"
ARM: bcm281xx: Add ARCH Timers to config
rename ARCH_BCM to ARCH_BCM_MOBILE (mach-bcm)
ARM: vexpress: Enable platform-specific options in defconfig
ARM: vexpress: Make defconfig work again
ARM: sunxi: remove .init_time hooks
ARM: imx: enable suspend for imx6sl
ARM: imx: ensure dsm_request signal is not asserted when setting LPM
ARM: imx6q: call WB and RBC configuration from imx6q_pm_enter()
ARM: imx6q: move low-power code out of clock driver
ARM: imx: drop extern with function prototypes in common.h
ARM: imx: reset core along with enable/disable operation
ARM: imx: do not return from imx_cpu_die() call
ARM: imx_v6_v7_defconfig: Select CONFIG_PROVE_LOCKING
ARM: imx_v6_v7_defconfig: Enable LEDS_GPIO related options
ARM: mxs_defconfig: Turn off CONFIG_DEBUG_GPIO
ARM: imx: replace imx6q_restart() with mxc_restart()
ARM: mach-imx: mm-imx5: Retrieve iomuxc base address from dt
ARM: mach-imx: mm-imx5: Retrieve tzic base address from dt
Since Operating Performance Points (OPP) functions are specific
to device specific power management, be specific and rename opp.h
to pm_opp.h
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Nishanth Menon <nm@ti.com>
Since Operating Performance Points (OPP) functions are specific to
device specific power management, be specific and rename opp_*
accessors in OPP library with dev_pm_opp_* equivalent.
Affected functions are:
opp_get_voltage
opp_get_freq
opp_get_opp_count
opp_find_freq_exact
opp_find_freq_floor
opp_find_freq_ceil
opp_add
opp_enable
opp_disable
opp_get_notifier
opp_init_cpufreq_table
opp_free_cpufreq_table
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
The imx6sl low power mode implementation inherits imx6q/dl one,
and pm-imx6q.c can just work for imx6sl with some minor updates.
Let's enable imx6sl suspend support by reusing pm-imx6q.c and use
cpu_is_imxXX() to handle the those minor differences between imx6sl
and imx6q/dl.
There is a defect in imx6 LPM design. When SW tries to enter low power
mode with following sequence, the chip will enter low power mode before
A9 CPU execute WFI instruction:
1. Set CCM_CLPCR[1:0] to 2'b00;
2. ARM CPU enters WFI;
3. ARM CPU wakeup from an interrupt event, which is masked by GPC or not
visible to GPC, such as interrupt from local timer;
4. Set CCM_CLPCR[1:0] to 2'b01 or 2'b10;
5. ARM CPU execute WFI.
Before the last step, the chip will enter WAIT mode if CCM_CLPCR[1:0] is
set to 2'b01, or enter STOP mode if CCM_CLPCR[1:0] is set to 2'b10.
The patch implements a recommended workaround for this issue.
1. SW triggers irq #32(IOMUX) to be always pending manually by setting
IOMUX_GPR1_GINT bit;
2. SW should then unmask it in GPC before setting CCM LPM;
3. SW should mask it right after CCM LPM is set (bit0-1 of CCM_CLPCR).
The WB and RBC configuration calls are currently made from
imx6q_set_lpm() for WAIT_CLOCKED and WAIT_UNCLOCKED mode with a simple
state tracking. This becomes unnecessary since we can make the calls
from imx6q_pm_enter() directly now for suspend.
More importantly, the current call of imx6q_enable_wb() from
imx6q_set_lpm() is buggy. The CLPCR register bits configured by
imx6q_enable_wb() will get lost, because imx6q_set_lpm() caches the same
register and write it back at the end of the function. That's why the
imx6dl suspend/resume does not work currently - the wakeup from suspend
triggers a reset on imx6dl.
Moves the WB and RBC calls into imx6q_pm_enter() to save the state
tracking and fixes above bug, so that suspend/resume can start working
on imx6dl.
The LPM (Low Power Mode) code that currently sits in imx6q clock driver
will be reused by imx6sl. Let's move it into pm-imx6q.c, so that we
can keep clock driver SoC specific and reuse pm-imx6q.c on imx6sl.
In order to avoid adding another ioremap for CCM block,
imx6q_pm_set_ccm_base() is created to let clock driver set up ccm_base
for pm code.
During the move, the unused CCGR macros get removed.
Since commit 70dc8a4 (checkpatch: warn when using extern with function
prototypes in .h files), we will get checkpatch warning when updating
common.h following the existing convention which has extern for function
prototypes.
Let's change the convention to not use extern with function prototypes
in this header.
From hotplug stress test result, resetting core during enable/disable
operation can improve cpu hotplug stability. So let's set
SRC reset bit in imx_enable_cpu() for the core when its enable bit is
accessed.
When imx_cpu_die() is being called, the cpu should never return from the
call but just in WFI and wait for hardware to take it down. So let's
do cpu_do_idle() repeatly in the call. Doing this help improve the
relibility of hotplug operation.
The imx6q_restart() works fine with normal reboot but will run into
problem with emergency reboot like sysrq-b. In that case, of_iomap()
gets called from interrupt context and hence triggers the BUG_ON in
__get_vm_area_node().
Actually, since commit c1e31d1 (ARM: imx: create
mxc_arch_reset_init_dt() for DT boot), imx6q/dl should try to use
mxc_restart() by calling mxc_arch_reset_init_dt() beforehand, where
things like of_iomap() can be done.
The patch updates mxc_restart() a little bit to get it work for imx6q/dl
and kill imx6q_restart() completely.
Reported-by: Nathan Lynch <nathan_lynch@mentor.com>
As mx53 is a dt-only SoC, we should retrieve the iomuxc base address from the
device tree, instead of using the old MX53_IO_ADDRESS method.
As mx53 is a dt-only SoC, we should retrieve the tzic base address from the
As mx53 is a dt-only SoC, we should retrieve the gpt base address and irq
from the device tree, instead of using the old MX53_IO_ADDRESS method.
The IS_ERR() macro is defined in the linux/err.h header file, so include
it explicitly.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Update imx6q clock initialization and Kconfig for PCIe support.
Signed-off-by: Sean Cross <xobs@kosagi.com>
The i.MX6 has two general-purpose LVDS clocks that can be driven
from a variety of sources. This patch adds a mux and a gate for
both of these clocks.
The mx53_display_revision() declaration in common.h is stale and used
nowhere, so remove it.
The patch enables soc bus infrastructure and adds a function
imx_soc_device_init() to report soc info via soc device interface for
imx6qdl and imx6sl. With the support, user space can get soc related
info by looking at sysfs like below.
$ cat /sys/devices/soc0/machine
Freescale i.MX6 Quad SABRE Smart Device Board
$ cat /sys/devices/soc0/family
Freescale i.MX
$ cat /sys/devices/soc0/soc_id
i.MX6Q
$ cat /sys/devices/soc0/revision
1.2
Add imx6sl support into imx_init_revision_from_anatop(), so that it can
be used to initialize cpu type and revision on imx6sl.
The patch creates a common function imx_init_revision_from_anatop() by
merging imx6q_init_revision() and imx_anatop_get_digprog(), so that any
SoC that encodes revision info in anatop can use it to initialize
revision.
It calls imx_set_soc_revision() to set up soc revision in
imx6q_init_revision(), and replaces all the occurrences of
imx6q_revision() with common helper imx_get_soc_revision().
Similar to what we do for cpu type, the patch adds helper functions
imx_set_soc_revision() and imx_get_soc_revision() to maintain
imx_soc_revision in cpu.c.
This flag is a NOOP since 2.6.35 and can be removed.
This is an update for 3.11 of a patch already sent for 3.10
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Config iomux-gpr1 to select clock source for fec system clock.
Clear gpr1[14], gpr1[18-17] bit to select the fec clock source
from internal anatop PLL.
Signed-off-by: Fugang Duan <B38611@freescale.com>
There's a pll4_audio_div clock, an extra divider for pll4, missing
in current clock tree, thus add it.
Signed-off-by: Nicolin Chen <b42378@freescale.com>
CLKDEV_LOOKUP selects HAVE_CLK and COMMON_CLK selects CLKDEV_LOOKUP. So
all symbols that select at least two of these symbols can be simplified.
For imx, omap2 and ux500 some rearrangements were necessary before the
simplification.
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Dinh Nguyen <dinguyen@altera.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Pawel Moll <pawel.moll@arm.com>
https://github.com/shesselba/linux-dove into next/cleanup
From Sebastian Hasselbarth:
This is a patch set based on an RFC [1][2] sent earlier to provide
a common arch/arm init for DT clock providers. Currently, the call to
of_clk_init(NULL) to initialize DT clock providers is spread among several
mach-dirs. Since most machs require DT clocks initialized before timers,
no initcall can be used.
By adding of_clk_init(NULL) to arch/arm time_init(), we can remove all
mach-specific .init_time hooks that basically called of_clk_init and
clocksource_of_init.
In contrast to the RFC version, of_clk_init(NULL) is now only called if
no custom .init_time callback is set. This allows some machs to still
call clock init themselves, as not all can be converted now. Therefore,
this patch sets drops conversion of mach-mvebu and mach-zynq. New machs
that were introduced with v3.12-rc1 are also converted, except mach-u300
that requires clocks before irqs.
* 'clk-of-init-v2_for-3.13' of https://github.com/shesselba/linux-dove: (29 commits)
ARM: vt8500: remove custom .init_time hook
ARM: vexpress: remove custom .init_time hook
ARM: tegra: remove custom .init_time hook
ARM: sunxi: remove custom .init_time hook
ARM: sti: remove custom .init_time hook
ARM: socfpga: remove custom .init_time hook
ARM: rockchip: remove custom .init_time hook
ARM: prima2: remove custom .init_time hook
ARM: nspire: remove custom .init_time hook
ARM: nomadik: remove custom .init_time hook
ARM: mxs: remove custom .init_time hook
ARM: kirkwood: remove custom .init_time hook
ARM: imx: remove custom .init_time hook
ARM: highbank: remove custom .init_time hook
ARM: exynos: remove custom .init_time hook
ARM: dove: remove custom .init_time hook
ARM: bcm2835: remove custom .init_time hook
ARM: bcm: provide common arch init for DT clocks
ARM: call of_clk_init from default time_init handler
ARM: vt8500: prepare for arch-wide .init_time callback
This patch moves the at24.h header from include/linux/i2c to
include/linux/platform_data and updates existing support accordingly.
It also fixes the following checkpatch warning:
WARNING: please, no space before tabs
#436: FILE: include/linux/platform_data/at24.h:31:
+ * ^Iu8 *mac_addr = ethernet_pdata->mac_addr;$
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
With arch/arm calling of_clk_init(NULL) from time_init(), we can now
remove custom .init_time hooks.
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Pull ACPI and power management fixes from Rafael Wysocki:
1) Four fixes for cpufreq regressions introduced by the changes that
removed Device Tree parsing for CPU device nodes from cpufreq
drivers from Sudeep KarkadaNagesha.
2) Two fixes for recent cpufreq regressions introduced by changes
related to the preservation of sysfs attributes over system
suspend/resume cycles from Viresh Kumar.
3) Fix for ACPI-based wakeup signaling in the PCI subsystem that
fails to stop PME polling for devices put into the D3cold power
state from Rafael J Wysocki.
4) Fix for bad interactions between cpufreq and udev on systems
supporting intel_pstate where acpi-cpufreq is available as well
from Yinghai Lu.
* tag 'pm+acpi-3.12-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpufreq: return EEXIST instead of EBUSY for second registering
PCI / ACPI / PM: Clear pme_poll for devices in D3cold on wakeup
ARM: shmobile: change dev_id to cpu0 while registering cpu clock
ARM: i.MX: change dev_id to cpu0 while registering cpu clock
cpufreq: imx6q-cpufreq: assign cpu_dev correctly to cpu0 device
cpufreq: cpufreq-cpu0: assign cpu_dev correctly to cpu0 device
cpufreq: unlock correct rwsem while updating policy->cpu
cpufreq: Clear policy->cpus bits in __cpufreq_remove_dev_finish()
Currently all clkdev registration use "cpufreq-cpu0.0" as dev_id
for cpu clock which refers to virtual platform device. It needs to
be "cpu0" instead which is actual cpu0 device id.
This patch changes the dev_id from "cpufreq-cpu0.0" to "cpu0".
Reported-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Signed-off-by: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com>
Commit cdc58d602d2e657602a90c190cbf745886c95977 "cpufreq: imx6q-cpufreq:
remove device tree parsing for cpu nodes" assumed the pdev->dev is set to
cpu0 device in the platform code. But it actually points to the virtual
cpufreq-cpu0 platform device which is not present in the device tree.
Most of the information needed by cpufreq is stored in cpu0 DT node.
So cpu_dev must point to cpu0 device.
This patch fixes the wrong assignment to cpu_dev.
The L2 cache controller(PL310) version on the i.MX6D/Q is r3p1-50rel0
The L2 cache controller(PL310) version on the i.MX6DL/SOLO/SL is r3p2
But according to ARM PL310 errata: 752271
ID: 752271: Double linefill feature can cause data corruption
Fault Status: Present in: r3p0, r3p1, r3p1-50rel0. Fixed in r3p2
Workaround: The only workaround to this erratum is to disable the
double linefill feature. This is the default behavior.
without this patch, you will meet the following error when run the
memtester application at: http://pyropus.ca/software/memtester/
FAILURE: 0x00100000 != 0x00200000 at offset 0x01365664.
FAILURE: 0x00100000 != 0x00200000 at offset 0x01365668.
FAILURE: 0x00100000 != 0x00200000 at offset 0x0136566c.
FAILURE: 0x00100000 != 0x00200000 at offset 0x01365670.
FAILURE: 0x00100000 != 0x00200000 at offset 0x01365674.
FAILURE: 0x00100000 != 0x00200000 at offset 0x01365678.
Signed-off-by: Jason Liu <r64343@freescale.com>
Since commit beb2d1c1ba (ARM i.MX5: Add S/PDIF clocks), the following clock
error appears on mx51:
TrustZone Interrupt Controller (TZIC) initialized
i.MX51 clk 180: register failed with -17
i.MX5 clk 180: register failed with -17
sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
CPU identified as i.MX51, silicon rev 3.0
Clock 180 corresponds to 'spdif1_podf' and this clock is getting registered
twice.
Fix it, by properly registering the 'spdif1_pred' clock, which should not
reference 'spdif1_podf'.
The clk_init_data.flags of clk-fixup-mux is left there without
initialization. It may hold some random data and cause clock framework
interpret the clock in an unexpected way. At least on imx6sl, the
following division by zero error with sched_clock is seen because of it.
Division by zero in kernel.
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.11.0-rc3+ #19
Backtrace:
[<80011af0>] (dump_backtrace+0x0/0x10c) from [<80011c90>] (show_stack+0x18/0x1c)
r6:3b9aca00 r5:00000020 r4:00000000 r3:00000000
[<80011c78>] (show_stack+0x0/0x1c) from [<8055e02c>] (dump_stack+0x78/0x94)
[<8055dfb4>] (dump_stack+0x0/0x94) from [<80011924>] (__div0+0x18/0x20)
[<8001190c>] (__div0+0x0/0x20) from [<8026c408>] (Ldiv0_64+0x8/0x18)
[<8006330c>] (clocks_calc_mult_shift+0x0/0xf8) from [<8072f604>] (setup_sched_clock+0x88/0x1f0)
[<8072f57c>] (setup_sched_clock+0x0/0x1f0) from [<8071ad48>] (mxc_timer_init+0xe8/0x17c)
[<8071ac60>] (mxc_timer_init+0x0/0x17c) from [<807290b0>] (imx6sl_clocks_init+0x1db8/0x1dc0)
r8:807a9ca4 r7:00000000 r6:80777564 r5:8100c1f4 r4:c0820000
[<807272f8>] (imx6sl_clocks_init+0x0/0x1dc0) from [<807420ac>] (of_clk_init+0x40/0x6c)
[<8074206c>] (of_clk_init+0x0/0x6c) from [<807290cc>] (imx6sl_timer_init+0x14/0x18)
r5:807a8e80 r4:ffffffff
[<807290b8>] (imx6sl_timer_init+0x0/0x18) from [<80716e1c>] (time_init+0x24/0x34)
[<80716df8>] (time_init+0x0/0x34) from [<80713738>] (start_kernel+0x1b0/0x310)
[<80713588>] (start_kernel+0x0/0x310) from [<80008074>] (0x80008074)
r7:80770b08 r6:80754cd4 r5:8076c8c4 r4:10c53c7d
sched_clock: 32 bits at 0 Hz, resolution 0ns, wraps every 0ms
Fix the bug by initializing init.flags as zero.
Pull slave-dmaengine updates from Vinod Koul:
"This pull brings:
- Andy's DW driver updates
- Guennadi's sh driver updates
- Pl08x driver fixes from Tomasz & Alban
- Improvements to mmp_pdma by Daniel
- TI EDMA fixes by Joel
- New drivers:
- Hisilicon k3dma driver
- Renesas rcar dma driver
- New API for publishing slave driver capablities
- Various fixes across the subsystem by Andy, Jingoo, Sachin etc..."
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (94 commits)
dma: edma: Remove limits on number of slots
dma: edma: Leave linked to Null slot instead of DUMMY slot
dma: edma: Find missed events and issue them
ARM: edma: Add function to manually trigger an EDMA channel
dma: edma: Write out and handle MAX_NR_SG at a given time
dma: edma: Setup parameters to DMA MAX_NR_SG at a time
dmaengine: pl330: use dma_set_max_seg_size to set the sg limit
dmaengine: dma_slave_caps: remove sg entries
dma: replace devm_request_and_ioremap by devm_ioremap_resource
dma: ste_dma40: Fix potential null pointer dereference
dma: ste_dma40: Remove duplicate const
dma: imx-dma: Remove redundant NULL check
dma: dmagengine: fix function names in comments
dma: add driver for R-Car HPB-DMAC
dma: k3dma: use devm_ioremap_resource() instead of devm_request_and_ioremap()
dma: imx-sdma: Staticize sdma_driver_data structures
pch_dma: Add MODULE_DEVICE_TABLE
dmaengine: PL08x: Add cyclic transfer support
dmaengine: PL08x: Fix reading the byte count in cctl
dmaengine: PL08x: Add support for different maximum transfer size
Pull clock framework changes from Michael Turquette:
"The common clk framework changes for 3.12 are dominated by clock
driver patches, both new drivers and fixes to existing. A high
percentage of these are for Samsung platforms like Exynos. Core
framework fixes and some new features like automagical clock
re-parenting round out the patches"
* tag 'clk-for-linus-3.12' of git://git.linaro.org/people/mturquette/linux: (102 commits)
clk: only call get_parent if there is one
clk: samsung: exynos5250: Simplify registration of PLL rate tables
clk: samsung: exynos4: Register PLL rate tables for Exynos4x12
clk: samsung: exynos4: Register PLL rate tables for Exynos4210
clk: samsung: exynos4: Reorder registration of mout_vpllsrc
clk: samsung: pll: Add support for rate configuration of PLL46xx
clk: samsung: pll: Use new registration method for PLL46xx
clk: samsung: pll: Add support for rate configuration of PLL45xx
clk: samsung: pll: Use new registration method for PLL45xx
clk: samsung: exynos4: Rename exynos4_plls to exynos4x12_plls
clk: samsung: exynos4: Remove checks for DT node
clk: samsung: exynos4: Remove unused static clkdev aliases
clk: samsung: Modify _get_rate() helper to use __clk_lookup()
clk: samsung: exynos4: Use separate aliases for cpufreq related clocks
clocksource: samsung_pwm_timer: Get clock from device tree
ARM: dts: exynos4: Specify PWM clocks in PWM node
pwm: samsung: Update DT bindings documentation to cover clocks
clk: Move symbol export to proper location
clk: fix new_parent dereference before null check
clk: wm831x: Initialise wm831x pointer on init
