path: root/arch/arm/mach-imx
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-09-04genalloc: add name arg to gen_pool_get() and devm_gen_pool_create()Vladimir Zapolskiy
This change modifies gen_pool_get() and devm_gen_pool_create() client interfaces adding one more argument "name" of a gen_pool object. Due to implementation gen_pool_get() is capable to retrieve only one gen_pool associated with a device even if multiple gen_pools are created, fortunately right at the moment it is sufficient for the clients, hence provide NULL as a valid argument on both producer devm_gen_pool_create() and consumer gen_pool_get() sides. Because only one created gen_pool per device is addressable, explicitly add a restriction to devm_gen_pool_create() to create only one gen_pool per device, this implies two possible error codes returned by the function, account it on client side (only misc/sram). This completes client side changes related to genalloc updates. [akpm@linux-foundation.org: gen_pool_get() cleanup] Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Cc: Philipp Zabel <p.zabel@pengutronix.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Cc: Shawn Guo <shawnguo@kernel.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-01Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform updates from Olof Johansson: "New or improved SoC support: - add support for Atmel's SAMA5D2 SoC - add support for Freescale i.MX6UL - improved support for TI's DM814x platform - misc fixes and improvements for RockChip platforms - Marvell MVEBU suspend/resume support A few driver changes that ideally would belong in the drivers branch are also here (acked by appropriate maintainers): - power key input driver for Freescale platforms (svns) - RTC driver updates for Freescale platforms (svns/mxc) - clk fixes for TI DM814/816X + a bunch of other changes for various platforms" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (83 commits) ARM: rockchip: pm: Fix PTR_ERR() argument ARM: imx: mach-imx6ul: Fix allmodconfig build clk: ti: fix for definition movement ARM: uniphier: drop v7_invalidate_l1 call at secondary entry memory: kill off set_irq_flags usage rtc: snvs: select option REGMAP_MMIO ARM: brcmstb: select ARCH_DMA_ADDR_T_64BIT for LPAE ARM: BCM: Enable ARM erratum 798181 for BRCMSTB ARM: OMAP2+: Fix power domain operations regression caused by 81xx ARM: rockchip: enable PMU_GPIOINT_WAKEUP_EN when entering shallow suspend ARM: rockchip: set correct stabilization thresholds in suspend ARM: rockchip: rename osc_switch_to_32k variable ARM: imx6ul: add fec MAC refrence clock and phy fixup init ARM: imx6ul: add fec bits to GPR syscon definition rtc: mxc: add support of device tree dt-binding: document the binding for mxc rtc rtc: mxc: use a second rtc clock ARM: davinci: cp_intc: use IRQCHIP_SKIP_SET_WAKE instead of irq_set_wake callback soc: mediatek: Fix SCPSYS compilation ARM: at91/soc: add basic support for new sama5d2 SoC ...
2015-08-21ARM: imx: mach-imx6ul: Fix allmodconfig buildFabio Estevam
We should call phy_register_fixup_for_uid() only when CONFIG_PHYLIB is built-in, otherwise we get the following link error when building allmodconfig: arch/arm/mach-imx/built-in.o: In function `imx6ul_init_machine': :(.init.text+0xa714): undefined reference to `phy_register_fixup_for_uid' This is the same approach done in mach-imx6q.c and mach-imx6sx.c. Reported-by: Olof Johansson <olof@lixom.net> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-08-06Merge branch 'fixes' into next/cleanupOlof Johansson
* fixes: (28 commits) ARM: ux500: add an SMP enablement type and move cpu nodes ARM: dts: keystone: fix dt bindings to use post div register for mainpll ARM: nomadik: disable UART0 on Nomadik boards ARM: dts: i.MX35: Fix can support. ARM: OMAP2+: hwmod: Fix _wait_target_ready() for hwmods without sysc ARM: dts: add CPU OPP and regulator supply property for exynos4210 ARM: dts: Update video-phy node with syscon phandle for exynos3250 ARM: keystone: dts: rename pcie nodes to help override status ARM: keystone: dts: fix dt bindings for PCIe ARM: pxa: fix dm9000 platform data regression ARM: DRA7: hwmod: fix gpmc hwmod ARM: dts: Correct audio input route & set mic bias for am335x-pepper ARM: OMAP2+: Add HAVE_ARM_SCU for AM43XX MAINTAINERS: digicolor: add dts files ARM: ux500: fix MMC/SD card regression ARM: ux500: define serial port aliases ARM: dts: OMAP5: Add #iommu-cells property to IOMMUs ARM: dts: OMAP4: Add #iommu-cells property to IOMMUs ARM: dts: Fix frequency scaling on Gumstix Pepper ARM: dts: configure regulators for Gumstix Pepper ...
2015-08-05ARM: imx6ul: add fec MAC refrence clock and phy fixup initFugang Duan
Add FEC MAC refrence clock init. Add phy fixup init for i.MX6ul 14x14 evk board that installs KSZ8081 phy. For the phy, there needs extra phy fixup for MII and RMII mode. Signed-off-by: Fugang Duan <b38611@freescale.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-07-28ARM: kill off set_irq_flags usageRob Herring
set_irq_flags is ARM specific with custom flags which have genirq equivalents. Convert drivers to use the genirq interfaces directly, so we can kill off set_irq_flags. The translation of flags is as follows: IRQF_VALID -> !IRQ_NOREQUEST IRQF_PROBE -> !IRQ_NOPROBE IRQF_NOAUTOEN -> IRQ_NOAUTOEN For IRQs managed by an irqdomain, the irqdomain core code handles clearing and setting IRQ_NOREQUEST already, so there is no need to do this in .map() functions and we can simply remove the set_irq_flags calls. Some users also modify IRQ_NOPROBE and this has been maintained although it is not clear that is really needed. There appears to be a great deal of blind copy and paste of this code. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Andrew Lunn <andrew@lunn.ch> Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Cc: Gregory Clement <gregory.clement@free-electrons.com> Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Acked-by: Shawn Guo <shawnguo@kernel.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Imre Kaloz <kaloz@openwrt.org> Acked-by: Krzysztof Halasa <khalasa@piap.pl> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Roland Stigge <stigge@antcom.de> Cc: Tony Lindgren <tony@atomide.com> Cc: Daniel Mack <daniel@zonque.org> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Simtec Linux Team <linux@simtec.co.uk> Cc: Kukjin Kim <kgene@kernel.org> Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: linux-arm-kernel@lists.infradead.org Cc: linux-omap@vger.kernel.org Cc: linux-samsung-soc@vger.kernel.org Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-07-28ARM: appropriate __init annotation for const dataNicolas Pitre
Init data marked const should be annotated with __initconst for correctness and not __initdata. In some cases the array gathering references to that data has to be marked const as well. This fixes LTO builds that otherwise fail with section mismatch errors. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-07-17ARM/imx/epit: Migrate to new 'set-state' interfaceViresh Kumar
Migrate imx driver to the new 'set-state' interface provided by clockevents core, the earlier 'set-mode' interface is marked obsolete now. This also enables us to implement callbacks for new states of clockevent devices, for example: ONESHOT_STOPPED. Also drop 'clockevent_mode': It was caching the last state of the clockevent device. The same behavior can be achieved by using clockevents state helpers. These helpers are only required for oneshot mode as shutdown/resume wouldn't be done twice by the core. Cc: Shawn Guo <shawnguo@kernel.org> Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2015-07-14ARM: imx: add i.mx6ul msl supportFrank Li
i.MX6UL is a new SOC, add MSL support Signed-off-by: Frank Li <Frank.Li@freescale.com> Signed-off-by: Shawn Guo <shawnguo@kernel.org>
2015-07-08ARM: imx6: gpc: always enable PU domain if CONFIG_PM is not setLucas Stach
If CONFIG_PM is not set the PU power domain needs to be enabled always, otherwise there are two failure scenarios which will hang the system if one of the devices in the PU domain is accessed. 1. New DTs (4.1+) drop the "always-on" property from the PU regulator, so if it isn't properly enabled by the GPC code it will be disabled at the end of boot. 2. If the bootloader already disabled the PU domain the GPC explicitly needs to enable it again, even if the kernel doesn't do any power management. This is a bit hypothetical, as it requires to boot a mainline kernel on a downstream bootloader, as no mainline bootloader disables the PM domains. Cc: <stable@vger.kernel.org> # 4.1 Signed-off-by: Lucas Stach <l.stach@pengutronix.de> Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-30genalloc: rename dev_get_gen_pool() to gen_pool_get()Vladimir Zapolskiy
To be consistent with other genalloc interface namings, rename dev_get_gen_pool() to gen_pool_get(). The original omitted "dev_" prefix is removed, since it points to argument type of the function, and so it does not bring any useful information. [akpm@linux-foundation.org: update arch/arm/mach-socfpga/pm.c] Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Philipp Zabel <p.zabel@pengutronix.de> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Sascha Hauer <kernel@pengutronix.de> Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Mark Brown <broonie@kernel.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Alan Tull <atull@opensource.altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Kevin Hilman <khilman@linaro.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-26Merge tag 'armsoc-soc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform support updates from Kevin Hilman: "Our SoC branch usually contains expanded support for new SoCs and other core platform code. Some highlights from this round: - sunxi: SMP support for A23 SoC - socpga: big-endian support - pxa: conversion to common clock framework - bcm: SMP support for BCM63138 - imx: support new I.MX7D SoC - zte: basic support for ZX296702 SoC" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (134 commits) ARM: zx: Add basic defconfig support for ZX296702 ARM: dts: zx: add an initial zx296702 dts and doc clk: zx: add clock support to zx296702 dt-bindings: Add #defines for ZTE ZX296702 clocks ARM: socfpga: fix build error due to secondary_startup MAINTAINERS: ARM64: EXYNOS: Extend entry for ARM64 DTS ARM: ep93xx: simone: support for SPI-based MMC/SD cards MAINTAINERS: update Shawn's email to use kernel.org one ARM: socfpga: support suspend to ram ARM: socfpga: add CPU_METHOD_OF_DECLARE for Arria 10 ARM: socfpga: use CPU_METHOD_OF_DECLARE for socfpga_cyclone5 ARM: EXYNOS: register power domain driver from core_initcall ARM: EXYNOS: use PS_HOLD based poweroff for all supported SoCs ARM: SAMSUNG: Constify platform_device_id ARM: EXYNOS: Constify irq_domain_ops ARM: EXYNOS: add coupled cpuidle support for Exynos3250 ARM: EXYNOS: add exynos_get_boot_addr() helper ARM: EXYNOS: add exynos_set_boot_addr() helper ARM: EXYNOS: make exynos_core_restart() less verbose ARM: EXYNOS: fix exynos_boot_secondary() return value on timeout ...
2015-06-26Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Kevin Hilman: "A relatively small setup of cleanups this time around, and similar to last time the bulk of it is removal of legacy board support: - OMAP: removal of legacy (non-DT) booting for several platforms - i.MX: remove some legacy board files" * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (36 commits) ARM: fix EFM32 build breakage caused by cpu_resume_arm ARM: 8389/1: Add cpu_resume_arm() for firmwares that resume in ARM state ARM: v7 setup function should invalidate L1 cache mach-omap2: Remove use of deprecated marco, PTR_RET in devices.c ARM: OMAP2+: Remove calls to deprecacted marco,PTR_RET in the files,fb.c and pmu.c ARM: OMAP2+: Constify irq_domain_ops ARM: OMAP2+: use symbolic defines for console loglevels instead of numbers ARM: at91: remove useless Makefile.boot ARM: at91: remove at91rm9200_sdramc.h ARM: at91: remove mach/at91_ramc.h and mach/at91rm9200_mc.h ARM: at91/pm: use the atmel-mc syscon defines pcmcia: at91_cf: Use syscon to configure the MC/smc ARM: at91: declare the at91rm9200 memory controller as a syscon mfd: syscon: Add Atmel MC (Memory Controller) registers definition ARM: at91: drop sam9_smc.c ata: at91: use syscon to configure the smc ARM: ux500: delete static resource defines ARM: ux500: rename ux500_map_io ARM: ux500: look up PRCMU resource from DT ARM: ux500: kill off L2CC static map ...
2015-06-12Merge branch 'for-arm-soc' of ↵Kevin Hilman
http://ftp.arm.linux.org.uk/pub/armlinux/kernel/git-cur/linux-2.6-arm into next/cleanup * 'for-arm-soc' of http://ftp.arm.linux.org.uk/pub/armlinux/kernel/git-cur/linux-2.6-arm: ARM: fix EFM32 build breakage caused by cpu_resume_arm ARM: 8389/1: Add cpu_resume_arm() for firmwares that resume in ARM state ARM: v7 setup function should invalidate L1 cache
2015-06-10Merge tag 'imx-soc-4.2' of ↵Kevin Hilman
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/soc The i.MX SoC updates for 4.2: - Add new SoC i.MX7D support, which integrates two Cortex-A7 and one Cortex-M4 cores. - Support suspend from IRAM on i.MX53, so that DDR pins can be set to high impedance for more power saving during suspend. - Move i.MX clock drivers from arch/arm/mach-imx to drivers/clk/imx. - Move i.MX GPT timer driver from arch/arm/mach-imx into drivers/clocksource. - A couple of clock driver update for VF610 and i.MX6Q. - A few random code correction and improvement. * tag 'imx-soc-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (44 commits) ARM: imx: imx7d requires anatop clocksource: timer-imx-gpt: remove include of <asm/mach/time.h> ARM: imx: move timer driver into drivers/clocksource ARM: imx: remove platform headers from timer driver ARM: imx: provide gpt device specific irq functions ARM: imx: get rid of variable timer_base ARM: imx: define gpt register offset per device type ARM: imx: move clock event variables into imx_timer ARM: imx: set up .set_next_event hook via imx_gpt_data ARM: imx: setup tctl register in device specific function ARM: imx: initialize gpt device type for DT boot ARM: imx: define an enum for gpt timer device type ARM: imx: move timer resources into a structure ARM: imx: use relaxed IO accessor in timer driver ARM: imx: make imx51/3 suspend optional ARM: clk-imx6q: refine sata's parent ARM: imx: clk-v610: Add clock for I2C2 and I2C3 ARM: mach-imx: iomux-imx31: Use DECLARE_BITMAP ARM: imx: add imx7d clk tree support ARM: clk: imx: update pllv3 to support imx7 ... Conflicts: arch/arm/mach-imx/Kconfig
2015-06-03ARM: imx: imx7d requires anatopArnd Bergmann
Like i.MX6, the i.MX7 code calls into the anatop driver, which fails if that is disabled: arch/arm/mach-imx/built-in.o: In function `imx7d_init_machine': arch/arm/mach-imx/mach-imx7d.c:24: undefined reference to `imx_anatop_init' arch/arm/mach-imx/built-in.o: In function `imx7d_init_irq': arch/arm/mach-imx/mach-imx7d.c:29: undefined reference to `imx_init_revision_from_anatop' This patch ensures that for an imx7-only build, we still get anatop built-in, matching what we do for imx6. We also need to select HAVE_IMX_MMDC, as that is needed by the anatop code. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: move timer driver into drivers/clocksourceShawn Guo
After the cleanup on imx timer driver, now it's ready to be moved into drivers/clocksource/. Let's do it. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2015-06-03ARM: imx: remove platform headers from timer driverShawn Guo
With the cleanup done before, the platform specific headers now can be removed. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: provide gpt device specific irq functionsShawn Guo
It splits irq enable/disable/acknowledge operations into device specific functions as the hooks in imx_gpt_data, so that we can save the use of timer_is_xxx() and cpu_is_xxx() checking in these irq functions. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: get rid of variable timer_baseShawn Guo
We now have pointer to imx_timer structure available where timer base address is needed, so we can just kill global timer_base by using imxtm->base instead. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: define gpt register offset per device typeShawn Guo
It defines offset of gpt registers TSTAT, TCN and TCMP per device type in imx_gpt_data, so that these registers can be accessed in an way without timer_is_v2() checking. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: move clock event variables into imx_timerShawn Guo
Since we now have imx_timer structure, it makes more sense to move those clock event related variables into the structure, so that we can save some global variables. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: set up .set_next_event hook via imx_gpt_dataShawn Guo
Set up .set_next_event hook via imx_gpt_data, so that we can save the use of timer_is_v2(). Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: setup tctl register in device specific functionShawn Guo
It creates a gpt device speicific data structure and adds function hook gpt_setup_tctl in there to set up gpt TCTL register. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: initialize gpt device type for DT bootShawn Guo
Use different initialization function in CLOCKSOURCE_OF_DECLARE() to initialize gpt device type for DT boot. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: define an enum for gpt timer device typeShawn Guo
Define an enum for gpt timer device type in include/soc/imx/timer.h to tell the gpt block differences among SoCs. Update non-DT users (clock drivers) to pass the device type. As we now have include/soc/imx/timer.h, the declaration of mxc_timer_init() is moved into there as the best fit. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: move timer resources into a structureShawn Guo
Instead of passing around as individual argument, let's move timer resources like irq and clocks together with base address into a data structure, and pass pointer of the structure as argument to simplify the function call interface. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: use relaxed IO accessor in timer driverShawn Guo
Replace the __raw_readl/__raw_writel with readl_relaxed/writel_relaxed which is endian-safe, as a step of moving the driver code into folder drivers/clocksource. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: make imx51/3 suspend optionalArnd Bergmann
A recent change to the imx53 power management caused a build regression when CONFIG_SOC_IMX53 is disabled: mach-imx/built-in.o:(.init.rodata+0x60): undefined reference to `imx53_suspend' mach-imx/built-in.o:(.init.rodata+0x64): undefined reference to `imx53_suspend_sz' This avoids the problem by compiling the code in question conditionally on the presence of CONFIG_SOC_IMX53. For consistency, I'm also changing the same thing for CONFIG_SOC_IMX51. An additional benefit of this approach is reduced code size for kernels that only include support for one of the two SoCs. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: 1579c7b9fe01 ("ARM: imx53: Set DDR pins to high impedance when in suspend to RAM.") Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: mach-imx: iomux-imx31: Use DECLARE_BITMAPJoe Perches
Use the generic mechanism to declare a bitmap instead of unsigned long. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx53: Set DDR pins to high impedance when in suspend to RAM.Martin Fuzzey
In order to save power the DDR pins should be put into high impedance when in suspend to RAM. This requires manually requesting self refresh (rather than using the automatic mode implemented by the CCM / ESDCTL), followed by reconfiguring the IOMUXC. Of course the code to do this cannot itself run from DDR so the code is copied to and executed from internal memory. In my tests using a custom i.MX53 board with LPDDR2 RAM this reduced the suspend power consumption from 200mW to 60mW. Signed-off-by: Martin Fuzzey <mfuzzey@parkeon.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: add msl support for imx7dAnson Huang
Add i.MX7D MSL support. Signed-off-by: Anson Huang <b20788@freescale.com> Signed-off-by: Frank Li <Frank.Li@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: mmdc: Include "common.h" header fileFabio Estevam
Include the "common.h" header file to fix the following sparse warning: arch/arm/mach-imx/mmdc.c:66:5: warning: symbol 'imx_mmdc_get_ddr_type' was not declared. Should it be static? Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: Correct the comments in time.cShenwei Wang
The comments were corrected as the following to reflect the real situation of Freescale MXC timer IP block. There are totally 4 version of the timer on Freescale i.MX SoCs. Signed-off-by: Shenwei Wang <shenwei.wang@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: Remove the duplicated function declarationShenwei Wang
Removed the duplicated function declaration of mxc_timer_init which was already declared in drivers/clk/imx/clk.h. Signed-off-by: Shenwei Wang <shenwei.wang@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: Constify irq_domain_opsKrzysztof Kozlowski
The irq_domain_ops are not modified by the driver and the irqdomain core code accepts pointer to a const data. Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx6: initialize CCM_CLPCR_LPM into RUN mode earlierShawn Guo
Commit 4631960d26da ("ARM: imx6: set initial power mode in pm function") moves imx6_set_lpm() from clock init function into imx6_pm_common_init(). This causes a hang when cpuidle support is enabled. The reason for that is ARM core clock is shut down unexpectedly by WAIT mode. It happens with the following call stack: cpuidle_register_governor() cpuidle_switch_governor() cpuidle_uninstall_idle_handler() synchronize_sched() wait_rcu_gp() wait_for_completion() When wait_for_completion() is called as above, all cores are idle/WFI. Hence, the reset value of CCM_CLPCR_LPM - WAIT mode, will trigger a hardware shutdown of the ARM core clock. To fix the regression, we need to ensure that CCM_CLPCR_LPM is initialized into RUN mode earlier than cpuidle governor registration, which is a postcore_initcall. This patch creates function imx6_pm_ccm_init() to map CCM block and initialize CCM_CLPCR_LPM into RUN mode, and have the function called from machine .init_irq hook, which should be early enough. Reported-by: Kevin Hilman <khilman@kernel.org> Fixes: 8fb76a07e2cb ("ARM: imx6: set initial power mode in pm function") Tested-by: Kevin Hilman <khilman@linaro.org> Tested-by: Tyler Baker <tyler.baker@linaro.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: move clock drivers into drivers/clkShawn Guo
After the cleanup on clock drivers, they are now ready to be moved into drivers/clk. Let's move them into drivers/clk/imx folder. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Stephen Boyd <sboyd@codeaurora.org>
2015-06-03ARM: imx: remove inclusions of platform headersShawn Guo
With the cleanup done before, we now can simply define base address and irq as needed in clock driver, to get those platform header inclusions removed. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: add clk-pllv1 type supportShawn Guo
Instead of calling cpu_is_xxx() in clk-pllv1 driver, let's add clk-pllv1 type support to handle the difference/quirk in particular SoC designs. Doing so will help get clk-pllv1 driver ready for being moved out of arch/arm/mach-imx folder. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx6: do not use cpu_is_xxx() in clock driverShawn Guo
As we're about to move clock drivers out of arch/arm/mach-imx, cpu_is_xxx() shouldn't be used any more. Let's avoid the call by looking at the device tree machine compatible string to determine which SoC the clock driver is running on. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx6: let pm code map CCM block on its ownShawn Guo
We are about to move imx6 clock driver into drivers/clk, so let's get imx6 pm code map CCM block on its own rather than relying on clock driver to do the mapping. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx6: set initial power mode in pm functionShawn Guo
Rather than setting initial low-power mode in every single i.MX6 clock initialization function, we should really do that in pm code. Let's move imx6q_set_lpm(WAIT_CLOCKED) call into imx6_pm_common_init(). While at it, let's rename the function to imx6_set_lpm() since it's actually common for all i.MX6 SoCs. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx5: let pm code map CCM block on its ownShawn Guo
We are about to move imx5 clock driver into drivers/clk, so let's get imx5 pm code map CCM block on its own rather than relying on clock driver to do the mapping. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: move revision definitions and declarations into a headerShawn Guo
The revision definitions and declarations are widely used by clock drivers. As a step of moving clock drivers out of arch/arm/mach-imx, let's create header include/soc/imx/revision.h to accommodate them. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: use dynamic mapping for CCMShawn Guo
Replace the static mapping of CCM block in clock drivers with dynamic mapping. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-03ARM: imx: use dynamic mapping for timerShawn Guo
Pass physical address of timer block to mxc_timer_init() call, which in turn does dynamic mapping within the function. Thus, we can avoid using static mapping in clock drivers. Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2015-06-01Merge tag 'imx-cleanup-4.2' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/cleanup Merge "The i.MX cleanup for 4.2" from Shawn Guo: - Remove eukrea_mbimxsd35 non-DT board files - Remove .owner field from gpc platform driver * tag 'imx-cleanup-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: ARM: imx: gpc: Remove .owner field ARM: imx: Remove eukrea_mbimxsd35 non-dt support
2015-06-01ARM: v7 setup function should invalidate L1 cacheRussell King
All ARMv5 and older CPUs invalidate their caches in the early assembly setup function, prior to enabling the MMU. This is because the L1 cache should not contain any data relevant to the execution of the kernel at this point; all data should have been flushed out to memory. This requirement should also be true for ARMv6 and ARMv7 CPUs - indeed, these typically do not search their caches when caching is disabled (as it needs to be when the MMU is disabled) so this change should be safe. ARMv7 allows there to be CPUs which search their caches while caching is disabled, and it's permitted that the cache is uninitialised at boot; for these, the architecture reference manual requires that an implementation specific code sequence is used immediately after reset to ensure that the cache is placed into a sane state. Such functionality is definitely outside the remit of the Linux kernel, and must be done by the SoC's firmware before _any_ CPU gets to the Linux kernel. Changing the data cache clean+invalidate to a mere invalidate allows us to get rid of a lot of platform specific hacks around this issue for their secondary CPU bringup paths - some of which were buggy. Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Heiko Stuebner <heiko@sntech.de> Tested-by: Dinh Nguyen <dinguyen@opensource.altera.com> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Tested-by: Thierry Reding <treding@nvidia.com> Acked-by: Thierry Reding <treding@nvidia.com> Tested-by: Geert Uytterhoeven <geert+renesas@glider.be> Tested-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Wei Xu <xuwei5@hisilicon.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
