git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: Consolidate the clkdev header files
ARM: set vga memory base at run-time
ARM: convert PCI defines to variables
ARM: pci: make pcibios_assign_all_busses use pci_has_flag
ARM: remove unnecessary mach/hardware.h includes
pci: move microblaze and powerpc pci flag functions into asm-generic
powerpc: rename ppc_pci_*_flags to pci_*_flags
Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
Convert the incorrectly named PCIMEM_BASE to a variable called vga_base.
This removes the dependency on mach/hardware.h.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Convert PCIBIOS_MIN_IO and PCIBIOS_MIN_MEM to variables to allow
multi-platform builds. This also removes the requirement for a platform to
have a mach/hardware.h.
The default values for i/o and mem are 0x1000 and 0x01000000, respectively.
Per Arnd Bergmann, other values are likely to be incorrect, but this commit
does not try to address that issue.
Convert pcibios_assign_all_busses from a define to inline so platforms can
control this setting.
Not only does this file duplicate <linux/bitops.h> and implement a
well-known antipattern, it is also not used by anything.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
When the CLCD is in anything but RGB888 mode, its outputs are configured
for RGB5551 output. Integrator/CP supports RGB565 via an external
multiplexer, which we configure for RGB5551 or RGB565 based only on the
bits per pixel. So when userspace asks for the RGB555 layout, the mux
remains in RGB565 mode, and we produce incorrect colours. Fix this.
Note that Integrator doesn't support BGR565 mode, but does support
BGR5551.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
This uncouple PHYS_OFFSET from the platform definitions, thereby
facilitating run-time computation of the physical memory offset.
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Magnus Damm <damm@opensource.se>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
Commit 7c63984b86 (ARM: do not define VMALLOC_END relative to PAGE_OFFSET)
changed VMALLOC_END to be an explicit value. Before this, it was
relative to PAGE_OFFSET and therefore converted to unsigned long
as PAGE_OFFSET is an unsigned long. This introduced the following
build warning. Fix this by changing the explicit defines of
VMALLOC_END to be unsigned long.
CC arch/arm/mm/init.o
arch/arm/mm/init.c: In function 'mem_init':
arch/arm/mm/init.c:606: warning: format '%08lx' expects type 'long unsigned int', but argument 12 has type 'unsigned int'
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Acked-by: Uwe Kleine-K <u.kleine-koenig@pengutronix.dee>
Rather than checking the MMU status in every instance of addruart, do it
once in kernel/debug.S, and change the existing addruart macros to
return both physical and virtual addresses. The main debug code can then
select the appropriate address to use.
This will also allow us to retreive the address of a uart for the MMU
state that we're not current in.
Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com>
and Tony Lindgren <tony@atomide.com>, and fix for versatile express from
Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Jason Wang <jason77.wang@gmail.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
VMALLOC_END is supposed to be an absolute value, while PAGE_OFFSET may
vary depending on the selected user:kernel memory split mode through
CONFIG_VMSPLIT_*. In fact, the goal of moving PAGE_OFFSET down is to
accommodate more directly addressed RAM by the kernel below the vmalloc
area, and having VMALLOC_END move along PAGE_OFFSET is rather against
the very reason why PAGE_OFFSET can be moved in the first place.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Signed-off-by: Eric Miao <eric.miao@canonical.com>
The structures for the ICST307 and ICST525 VCO devices are
identical, so merge them together.
Realview doesn't include mach/platform.h in mach/hardware.h, so
make versatile behave in the same way. Also, move the definition
of __io_address() into mach/hardware.h, just like Realview.
Otherwise more complicated uart configuration won't be possible.
We can use r1 for tmp register for both head.S and debug.S.
NOTE: This patch depends on another patch to add the the tmp register
into all debug-macro.S files. That can be done with:
$ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/"
arch/arm/*/include/*/debug-macro.S
Anders Grafström reports that footbridge fails to build after 1c4a4f4.
Fix this by adding the necessary definitions for __pfn_to_bus and
__bus_to_pfn.
Reported-by: Anders Grafström <anders.grafstrom@netinsight.net>
This fixes Integrator builds with highmem enabled; we need to
translate from 'struct page' to a DMA address, and this is not
possible without __pfn_to_bus().
This patch redefines the IO_ADDRESS macro in
include/asm-arm/hardware.h.
OMAP wishes to pass state to the boot loader upon reboot in order to
instruct it whether to wait for USB-based reflashing or not. There is
already a facility to do this via the reboot() syscall, except we ignore
the string passed to machine_restart().
This patch fixes things to pass this string to arch_reset(). This means
that we keep the reboot mode limited to telling the kernel _how_ to
perform the reboot which should be independent of what we request the
boot loader to do.
Macro arguments should be parenthesized to avoid unexpected side
effects.
When ISA_DMA_API is unset, we're not implementing the ISA DMA API,
so there's no point in publishing the prototypes via asm/dma.h, nor
including the machine dependent parts of that API.
This allows us to remove a lot of mach/dma.h files which don't contain
any useful code. Unfortunately though, some platforms put their own
private non-ISA definitions into mach/dma.h, so we leave these behind
and fix the appropriate #include statments.
arch/arm/mach-clps7500/include/mach/memory.h
Let's provide an overridable default instead of having every machine
class define __virt_to_bus and __bus_to_virt to the same thing. What
most platforms are using is bus_addr == phys_addr so such is the default.
One exception is ebsa110 which has no DMA what so ever, so the actual
definition is not important except only for proper compilation. Also
added a comment about the special footbridge bus translation.
Let's also remove comments alluding to set_dma_addr which is not
(and should not) be commonly used.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
People often point to the Integrator/Versatile/Realview
implementations to justify using the consumer name as the sole
selector for clocks.
Eliminate this excuse by changing the Integrator implementation, so
it provides a better example of how it should be done.
FLASH_* and EPROM_* constants are unused, and clash with drivers:
drivers/atm/ambassador.h:257:1: warning: "FLASH_BASE" redefined
drivers/atm/ambassador.h:258:1: warning: "FLASH_SIZE" redefined
drivers/atm/iphase.h:332:1: warning: "EPROM_SIZE" redefined
so remove them.
This patch removes CVS keywords that weren't updated for a long time.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This just leaves include/asm-arm/plat-* to deal with.
