The changes introduced in commit
cc22b4c18540e5e8bf55c7d124044f9317527d3c
"ARM: set vga memory base at run-time"
Makes the Integrator/AP freeze completely. I appears that
this is due to the VGA base address being assigned at PCI
init time, while this base is needed earlier than that.
Moving the initialization of the base address to the
.map_io function solves this problem.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
I was intrigued by the fact that the clock stood still on
the Integrator, but it wasn't strange at all, because the
timer was set up all wrong and probably has been for a
while. With this patch the clock starts ticking again:
make the timer periodic (reload), |= on the divisor bit
and load the timer before starting it.
Cc: stable@kernel.org
'consolidate-generic', 'consolidate-smp', 'consolidate-stmp' and 'consolidate-zones' into consolidate
Convert the Integrator/AP 16-bit down-counting clocksource to the
generic clocksource infrastructure.
map_info
The set_vpp() method provided by physmap passes a map_info back to
the platform code, which has little relevance as far as the platform
is concerned (this parameter is completely unused).
Instead, pass the platform_device, which can be used in the pismo
driver to retrieve some important information in a nicer way, instead
of the hack that was in place.
The empty set_vpp function in board-at572d940hf_ek.c is left untouched,
as the board/SoC is scheduled for removal.
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: Philipp Zabel <philipp.zabel@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Acked-by: David Woodhouse <dwmw2@infradead.org>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Replace the sysdev class and struct sys_device used for power
management by the Integrator interrupt-handling code with a
struct syscore_ops object which is simpler.
Consolidate the FPGA IRQ handling code. Integrator/AP and Versatile
have one FPGA-based IRQ handler each. Integrator/CP has three.
Initialize the clock tree early.
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new
interfaces were added which simplify (and optimize) the selection of the
divisor shift/mult constants. Switch over to using this new interface.
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Eric Miao <eric.miao at canonical.com>
Move the platform specific bootmem memory reservations out of
arch/arm/mm/mmu.c into their respective platform files.
Only Integrator/AP has 16-bit timers, so move the support into the
Integrator/AP specific support files.
Rather than using converted base address plus offset, use the register
address itself now that IO_ADDRESS() can cope with these.
This is now what the clocksource/clockevent initialization functions
want, so give them the timer tick rate directly.
Realview doesn't include mach/platform.h in mach/hardware.h, so
make versatile behave in the same way. Also, move the definition
of __io_address() into mach/hardware.h, just like Realview.
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
All kobjects require a dynamically allocated name now. We no longer
need to keep track if the name is statically assigned, we can just
unconditionally free() all kobject names on cleanup.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
set_irq_chipdata -> set_irq_chip_data
get_irq_chipdata -> get_irq_chip_data
do_level_IRQ -> handle_level_irq
do_edge_IRQ -> handle_edge_irq
do_simple_IRQ -> handle_simple_irq
irqdesc -> irq_desc
irqchip -> irq_chip
Patch from David Brownell
ARM genirq cleanups/updates:
- Start switching platforms to newer APIs
* use "irq_chip" name, not "irqchip"
* providing irq_chip.name
- Show irq_chip.name in /proc/interrupts, like on x86.
This update a bit more than half of the ARM code. The irq_chip.name
values were chosen to match docs (if I have them) or be otherwise
obvious ("FPGA", "CPLD", or matching the code).
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Convert all uses of kmalloc followed by memset to use kzalloc instead.
Patch from Nicolas Pitre
This field is redundent since it must be equal to PHYS_OFFSET anyway.
Now that no code uses it anymore, mark it deprecated and remove all
initializations from the tree.
Signed-off-by: Nicolas Pitre <nico@cam.org>
Since the ARM AMBA bus is used on MIPS as well as ARM, we need
to make the bus available for other architectures to use. Move
the AMBA include files from include/asm-arm/hardware/ to
include/linux/amba/
Manual #include fixups for clashes - there may be some unnecessary
I recently picked up my older work to remove unnecessary #includes of
sched.h, starting from a patch by Dave Jones to not include sched.h
from module.h. This reduces the number of indirect includes of sched.h
by ~300. Another ~400 pointless direct includes can be removed after
this disentangling (patch to follow later).
However, quite a few indirect includes need to be fixed up for this.
In order to feed the patches through -mm with as little disturbance as
possible, I've split out the fixes I accumulated up to now (complete for
i386 and x86_64, more archs to follow later) and post them before the real
patch. This way this large part of the patch is kept simple with only
adding #includes, and all hunks are independent of each other. So if any
hunk rejects or gets in the way of other patches, just drop it. My scripts
will pick it up again in the next round.
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
Patch from Deepak Saxena
Integrator map_desc.pfn conversion
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
Remove the pointless machine description macros, favouring C99
initialisers instead.
infrastructure for it.
Let it rip!
