path: root/arch/arm/mach-integrator/leds.c
2010-04-29ARM: Fix Versatile&Integrator includes to behave in the same way as RealviewRussell King
Realview doesn't include mach/platform.h in mach/hardware.h, so make versatile behave in the same way. Also, move the definition of __io_address() into mach/hardware.h, just like Realview. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-18[PATCH] ARM SMP: Add basic support Integrator/CP platformRussell King
Add basic SMP support for the Integrator/CP platform. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-05-03[PATCH] ARM: Clean up commenting/spacing for IntegratorRussell King
Signed-off-by: Russell King <rmk@arm.linux.org.uk>
