Remove linux/mm.h inclusion from netdevice.h -- it's unused (I've checked manually).
To prevent mm.h inclusion via other channels also extract "enum dma_data_direction"
definition into separate header. This tiny piece is what gluing netdevice.h with mm.h
via "netdevice.h => dmaengine.h => dma-mapping.h => scatterlist.h => mm.h".
Removal of mm.h from scatterlist.h was tried and was found not feasible
on most archs, so the link was cutoff earlier.
Hope people are OK with tiny include file.
Note, that mm_types.h is still dragged in, but it is a separate story.
No drivers currently implement these operation types, so they can be
deleted.
include/linux/dmaengine.h
[ Based on an original patch by Yuri Tikhonov ]
This adds support for doing asynchronous GF multiplication by adding
two additional functions to the async_tx API:
async_gen_syndrome() does simultaneous XOR and Galois field
multiplication of sources.
async_syndrome_val() validates the given source buffers against known P
and Q values.
When a request is made to run async_pq against more than the hardware
maximum number of supported sources we need to reuse the previous
generated P and Q values as sources into the next operation. Care must
be taken to remove Q from P' and P from Q'. For example to perform a 5
source pq op with hardware that only supports 4 sources at a time the
following approach is taken:
p, q = PQ(src0, src1, src2, src3, COEF({01}, {02}, {04}, {08}))
p', q' = PQ(p, q, q, src4, COEF({00}, {01}, {00}, {10}))
p' = p + q + q + src4 = p + src4
q' = {00}*p + {01}*q + {00}*q + {10}*src4 = q + {10}*src4
Note: 4 is the minimum acceptable maxpq otherwise we punt to
synchronous-software path.
The DMA_PREP_CONTINUE flag indicates to the driver to reuse p and q as
sources (in the above manner) and fill the remaining slots up to maxpq
with the new sources/coefficients.
Note1: Some devices have native support for P+Q continuation and can skip
this extra work. Devices with this capability can advertise it with
dma_set_maxpq. It is up to each driver how to handle the
DMA_PREP_CONTINUE flag.
Note2: The api supports disabling the generation of P when generating Q,
this is ignored by the synchronous path but is implemented by some dma
devices to save unnecessary writes. In this case the continuation
algorithm is simplified to only reuse Q as a source.
Cc: David Woodhouse <David.Woodhouse@intel.com>
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
Reviewed-by: Andre Noll <maan@systemlinux.org>
Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
'zero_sum' does not properly describe the operation of generating parity
and checking that it validates against an existing buffer. Change the
name of the operation to 'val' (for 'validate'). This is in
anticipation of the p+q case where it is a requirement to identify the
target parity buffers separately from the source buffers, because the
target parity buffers will not have corresponding pq coefficients.
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)
Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com>
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Adds the platform device definitions and the architecture specific
support routines (i.e. register initialization and descriptor formats) for the
iop-adma driver.
Changelog:
* added 'descriptor pool size' to the platform data
* add base support for buffer sizes larger than 16MB (hw max)
* build error fix from Kirill A. Shutemov
* rebase for async_tx changes
* add interrupt support
* do not call platform register macros in driver code
* remove unnecessary ARM assembly statement
* checkpatch.pl fixes
* gpl v2 only correction
CC arch/arm/mach-iop13xx/setup.o
arch/arm/mach-iop13xx/setup.c: In function 'iq8134x_probe_flash_size':
arch/arm/mach-iop13xx/setup.c:210: warning: implicit declaration of function 'ioremap'
arch/arm/mach-iop13xx/setup.c:210: warning: initialization makes pointer from integer without a cast
arch/arm/mach-iop13xx/setup.c:218: warning: implicit declaration of function 'writew'
arch/arm/mach-iop13xx/setup.c:222: warning: implicit declaration of function 'readb'
arch/arm/mach-iop13xx/setup.c:231: warning: implicit declaration of function 'iounmap'
LD .tmp_vmlinux1
arch/arm/mach-iop13xx/built-in.o: In function `iop13xx_platform_init':
iq81340mc.c:(.init.text+0x150): undefined reference to `ioremap'
iq81340mc.c:(.init.text+0x21c): undefined reference to `writew'
iq81340mc.c:(.init.text+0x24c): undefined reference to `writew'
iq81340mc.c:(.init.text+0x254): undefined reference to `iounmap'
iq81340mc.c:(.init.text+0x2c4): undefined reference to `readb'
iq81340mc.c:(.init.text+0x2e8): undefined reference to `readb'
The struct resource 'end' field is inclusive, the iop13xx flash
setup code got this wrong.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
The iop348 processor integrates an Xscale (XSC3 512KB L2 Cache) core with a
Serial Attached SCSI (SAS) controller, multi-ported DDR2 memory
controller, 3 Application Direct Memory Access (DMA) controllers, a 133Mhz
PCI-X interface, a x8 PCI-Express interface, and other peripherals to form
a system-on-a-chip RAID subsystem engine.
The iop342 processor replaces the SAS controller with a second Xscale core
for dual core embedded applications.
The iop341 processor is the single core version of iop342.
This patch supports the two Intel customer reference platforms iq81340mc
for external storage and iq81340sc for direct attach (HBA) development.
The developer's manual is available here:
ftp://download.intel.com/design/iio/docs/31503701.pdf
Changelog:
* removed virtual addresses from resource definitions
* cleaned up some unnecessary #include's
