path: root/arch/arm/mach-iop13xx
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-09-01[ARM] 5222/1: Allow configuring user:kernel split via KconfigLennert Buytenhek
This patch adds a config option (CONFIG_VMSPLIT_*) to allow choosing between 3:1, 2:2 and 1:3 user:kernel memory splits. Tested-by: Riku Voipio <riku.voipio@iki.fi> Signed-off-by: Lennert Buytenhek <buytenh@marvell.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Eliminate useless includes of asm/mach-types.hRussell King
There are 43 includes of asm/mach-types.h by files that don't reference anything from that file. Remove these unnecessary includes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-03-06[ARM] replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-13Merge branch 'ioat-md-accel-for-linus' of ↵Linus Torvalds
git://lost.foo-projects.org/~dwillia2/git/iop * 'ioat-md-accel-for-linus' of git://lost.foo-projects.org/~dwillia2/git/iop: (28 commits) ioatdma: add the unisys "i/oat" pci vendor/device id ARM: Add drivers/dma to arch/arm/Kconfig iop3xx: surface the iop3xx DMA and AAU units to the iop-adma driver iop13xx: surface the iop13xx adma units to the iop-adma driver dmaengine: driver for the iop32x, iop33x, and iop13xx raid engines md: remove raid5 compute_block and compute_parity5 md: handle_stripe5 - request io processing in raid5_run_ops md: handle_stripe5 - add request/completion logic for async expand ops md: handle_stripe5 - add request/completion logic for async read ops md: handle_stripe5 - add request/completion logic for async check ops md: handle_stripe5 - add request/completion logic for async compute ops md: handle_stripe5 - add request/completion logic for async write ops md: common infrastructure for running operations with raid5_run_ops md: raid5_run_ops - run stripe operations outside sh->lock raid5: replace custom debug PRINTKs with standard pr_debug raid5: refactor handle_stripe5 and handle_stripe6 (v3) async_tx: add the async_tx api xor: make 'xor_blocks' a library routine for use with async_tx dmaengine: make clients responsible for managing channels dmaengine: refactor dmaengine around dma_async_tx_descriptor ...
2007-07-13iop13xx: surface the iop13xx adma units to the iop-adma driverDan Williams
Adds the platform device definitions and the architecture specific support routines (i.e. register initialization and descriptor formats) for the iop-adma driver. Changelog: * added 'descriptor pool size' to the platform data * add base support for buffer sizes larger than 16MB (hw max) * build error fix from Kirill A. Shutemov * rebase for async_tx changes * add interrupt support * do not call platform register macros in driver code * remove unnecessary ARM assembly statement * checkpatch.pl fixes * gpl v2 only correction Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2007-07-12[ARM] 4429/2: iop13xx: expose the 'iop' attribute versions of the tpmi ↵Dan Williams
control registers The tpmi control registers can be accessed on the internal bus via an address with PCI attributes or IOP attributes (i.e. read-only, read-write... etc). The sas driver needs access to the iop-attribute registers for initialization. Changelog: * use ARRAY_SIZE for num_resources, Russell King Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-21Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (22 commits) [ARM] spelling fixes [ARM] at91_adc parenthesis balance [ARM] 4400/1: S3C24XX: Add high-speed MMC device definition [ARM] 4399/2: S3C2443: Fix SMDK2443 nand timings [ARM] 4398/1: S3C2443: Fix watchdog IRQ number [ARM] 4397/1: S3C2443: remove SDI0/1 IRQ ambiguity [ARM] 4396/1: S3C2443: Add missing HCLK clocks [ARM] 4395/1: S3C24XX: add include of <linux/sysdev.h> to relevant machines [ARM] 4388/1: no need for arm/mm mmap range checks for non-mmu [ARM] 4387/1: fix /proc/cpuinfo formatting for pre-ARM7 parts [ARM] ARMv6: add CPU_HAS_ASID configuration [ARM] integrator: fix pci_v3 compile error with DEBUG_LL [ARM] gic: Fix gic cascade irq handling [ARM] Silence OMAP kernel configuration warning [ARM] Update ARM syscalls [ARM] 4384/1: S3C2412/13 SPI registers offset correction [ARM] 4383/1: iop: fix usage of '__init' and 'inline' in iop files [ARM] 4382/1: iop13xx: fix msi support [ARM] Remove Integrator/CP SMP platform support [ARM] 4378/1: KS8695: Serial driver fix ...
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-20[ARM] spelling fixesSimon Arlott
Spelling fixes in arch/arm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-16[ARM] 4383/1: iop: fix usage of '__init' and 'inline' in iop filesDan Williams
WARNING: arch/arm/mach-iop13xx/built-in.o - Section mismatch: reference to .init.text:iop13xx_pcie_map_irq from .text between 'iop13xx_pci_setup' (at offset 0x7fc) and 'iop13xx_map_pci_memory' While fixing this warning I also recalled Adrian Bunk's recommendation to not use inline in .c files, as 'iop13xx_map_pci_memory' is needlessly inlined. Removing 'inline' uncovered some dead code so that is cleaned up as well. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-16[ARM] 4382/1: iop13xx: fix msi supportDan Williams
updates iop13xx msi support for a msi api change in 2.6.22 rev7: * update for Michael Ellerman's "MSI: arch must connect the irq and the msi_desc" patch Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-11[ARM] iop13xx: msi supportDaniel Wolstenholme
Enable devices to signal interrupts via PCI memory cycles. rev6: * fix enable/disable typo, Michael Ellerman rev5: * fix up ack, enable, and disable for iop13xx_msi_chip rev4: * move smp compile fix to separate patch * use dynamic_irq_init in create_irq() * hookup mask/unmask routines in iop13xx_msi_chip rev3: * change msi.c to use linux/smp.h instead of asm/smp.h * call dynamic_irq_cleanup at destroy_irq time rev2: * destroy_irq did not take the full 128 bits of msi_irq_in_use into account * added missing '&' for calls to test_and_set_bit and clear_bit [ebiederm@xmission.com: review comments/suggestions] [dan.j.williams@intel.com: cleanups/forward port to 2.6-git] Signed-off-by: Daniel Wolstenholme <daniel.e.wolstenholme@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-06Merge branches 'arm-mm', 'at91', 'clkevts', 'imx', 'iop', 'misc', 'netx', ↵Russell King
'ns9xxx', 'omap', 'pxa', 'rpc', 's3c' and 'sa1100' into devel
2007-05-05[ARM] mm 10: allow memory type to be specified with ioremapRussell King
__ioremap() took a set of page table flags (specifically the cacheable and bufferable bits) to control the mapping type. However, with the advent of ARMv6, this is far too limited. Replace the page table flags with a memory type index, so that the desired attributes can be selected from the mem_type table. Finally, to prevent silent miscompilation due to the differing arguments, rename the __ioremap() and __ioremap_pfn() functions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-03[ARM] 4342/2: iop13xx: add resource definitions for the tpmi unitsDan Williams
The tpmi units interface with the SAS controller on iop348. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-04-30[ARM] 4344/1: iop13xx: do not claim both uarts by default on iop342Dan Williams
2007-04-30[ARM] 4343/1: iop13xx: automatically detect the internal bus frequencyDan Williams
2007-04-30[ARM] 4341/1: iop13xx: fix i/o address translationDan Williams
PCI devices were being programmed with an incorrect base address value. This patch moves I/O space into a 16-bit addressable region and corrects the i/o offset. Much thanks to Martin Michlmayr for tracking this issue and testing debug patches. Cc: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-20Merge ARM fixesRussell King
2007-02-20[ARM] Fix iop13xx build errorRussell King
CC arch/arm/mach-iop13xx/setup.o arch/arm/mach-iop13xx/setup.c: In function 'iq8134x_probe_flash_size': arch/arm/mach-iop13xx/setup.c:210: warning: implicit declaration of function 'ioremap' arch/arm/mach-iop13xx/setup.c:210: warning: initialization makes pointer from integer without a cast arch/arm/mach-iop13xx/setup.c:218: warning: implicit declaration of function 'writew' arch/arm/mach-iop13xx/setup.c:222: warning: implicit declaration of function 'readb' arch/arm/mach-iop13xx/setup.c:231: warning: implicit declaration of function 'iounmap' LD .tmp_vmlinux1 arch/arm/mach-iop13xx/built-in.o: In function `iop13xx_platform_init': iq81340mc.c:(.init.text+0x150): undefined reference to `ioremap' iq81340mc.c:(.init.text+0x21c): undefined reference to `writew' iq81340mc.c:(.init.text+0x24c): undefined reference to `writew' iq81340mc.c:(.init.text+0x254): undefined reference to `iounmap' iq81340mc.c:(.init.text+0x2c4): undefined reference to `readb' iq81340mc.c:(.init.text+0x2e8): undefined reference to `readb' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17[ARM] 4187/1: iop: unify time implementation across iop32x, iop33x, and iop13xxDan Williams
* architecture specific details are handled in asm/arch/time.h * ARCH_IOP13XX now selects PLAT_IOP * as suggested by Lennert use ifdef CONFIG_XSCALE to skip the cp_wait on XSC3 Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17[ARM] 4186/1: iop: remove cp6_enable/disable routinesDan Williams
This functionality is replaced by cp6_trap Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4184/1: iop: cp6 access handler (undef_hook)Dan Williams
Enable svc access to cp6 via an undefined instruction hook. Do not enable access for usr code. This patch also makes iop13xx select PLAT_IOP, this requires a small change to drivers/i2c/busses/i2c-iop3xx.c. Per Lennert Buytenhek's note, the cp6 trap routine is moved to arch/arm/plat-iop Per Nicolas Pitre's note, the cp_wait is skipped since the latency to return to the faulting function is longer than cp_wait. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-30[ARM] 4077/1: iop13xx: fix __io() macroDan Williams
Since iop13xx defines the PCI I/O spaces with physical resource addresses the __io macro needs to perform the physical to virtual conversion. I incorrectly assumed that this would be handled by ioremap, but drivers (like e1000) directly dereference the address returned from __io. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-19[ARM] 4022/1: iop13xx: generic irq fixupsDan Williams
* use irq_chip * use handle_level_irq Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-18[ARM] 4056/1: iop13xx: fix resource.end off-by-one in flash setupLennert Buytenhek
The struct resource 'end' field is inclusive, the iop13xx flash setup code got this wrong. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-18[ARM] 4055/1: iop13xx: fix phys_io/io_pg_offst for iq81340mc/scLennert Buytenhek
The phys_io/io_pg_offst machine record variables were being set to bogus values, causing problems when enabling DEBUG_LL. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-07[ARM] 3995/1: iop13xx: add iop13xx supportDan Williams
The iop348 processor integrates an Xscale (XSC3 512KB L2 Cache) core with a Serial Attached SCSI (SAS) controller, multi-ported DDR2 memory controller, 3 Application Direct Memory Access (DMA) controllers, a 133Mhz PCI-X interface, a x8 PCI-Express interface, and other peripherals to form a system-on-a-chip RAID subsystem engine. The iop342 processor replaces the SAS controller with a second Xscale core for dual core embedded applications. The iop341 processor is the single core version of iop342. This patch supports the two Intel customer reference platforms iq81340mc for external storage and iq81340sc for direct attach (HBA) development. The developer's manual is available here: ftp://download.intel.com/design/iio/docs/31503701.pdf Changelog: * removed virtual addresses from resource definitions * cleaned up some unnecessary #include's Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
