This patch adds a config option (CONFIG_VMSPLIT_*) to allow choosing
between 3:1, 2:2 and 1:3 user:kernel memory splits.
Tested-by: Riku Voipio <riku.voipio@iki.fi>
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
There are 43 includes of asm/mach-types.h by files that don't
reference anything from that file. Remove these unnecessary
includes.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc).
Here is a short excerpt of the semantic patch performing
this transformation:
type T2;
expression x;
identifier f,fld;
expression E;
expression E1,E2;
expression e1,e2,e3,y;
statement S;
x =
- kmalloc
+ kzalloc
(E1,E2)
... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\)
- memset((T2)x,0,E1);
expression E1,E2,E3;
- kzalloc(E1 * E2,E3)
+ kcalloc(E1,E2,E3)
[akpm@linux-foundation.org: get kcalloc args the right way around]
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Cc: Bryan Wu <bryan.wu@analog.com>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Dave Airlie <airlied@linux.ie>
Acked-by: Roland Dreier <rolandd@cisco.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Acked-by: Pierre Ossman <drzeus-list@drzeus.cx>
Cc: Jeff Garzik <jeff@garzik.org>
Acked-by: Greg KH <greg@kroah.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
git://lost.foo-projects.org/~dwillia2/git/iop
* 'ioat-md-accel-for-linus' of git://lost.foo-projects.org/~dwillia2/git/iop: (28 commits)
ioatdma: add the unisys "i/oat" pci vendor/device id
ARM: Add drivers/dma to arch/arm/Kconfig
iop3xx: surface the iop3xx DMA and AAU units to the iop-adma driver
iop13xx: surface the iop13xx adma units to the iop-adma driver
dmaengine: driver for the iop32x, iop33x, and iop13xx raid engines
md: remove raid5 compute_block and compute_parity5
md: handle_stripe5 - request io processing in raid5_run_ops
md: handle_stripe5 - add request/completion logic for async expand ops
md: handle_stripe5 - add request/completion logic for async read ops
md: handle_stripe5 - add request/completion logic for async check ops
md: handle_stripe5 - add request/completion logic for async compute ops
md: handle_stripe5 - add request/completion logic for async write ops
md: common infrastructure for running operations with raid5_run_ops
md: raid5_run_ops - run stripe operations outside sh->lock
raid5: replace custom debug PRINTKs with standard pr_debug
raid5: refactor handle_stripe5 and handle_stripe6 (v3)
async_tx: add the async_tx api
xor: make 'xor_blocks' a library routine for use with async_tx
dmaengine: make clients responsible for managing channels
dmaengine: refactor dmaengine around dma_async_tx_descriptor
Adds the platform device definitions and the architecture specific
support routines (i.e. register initialization and descriptor formats) for the
iop-adma driver.
Changelog:
* added 'descriptor pool size' to the platform data
* add base support for buffer sizes larger than 16MB (hw max)
* build error fix from Kirill A. Shutemov
* rebase for async_tx changes
* add interrupt support
* do not call platform register macros in driver code
* remove unnecessary ARM assembly statement
* checkpatch.pl fixes
* gpl v2 only correction
control registers
The tpmi control registers can be accessed on the internal bus via an
address with PCI attributes or IOP attributes (i.e. read-only,
read-write... etc). The sas driver needs access to the iop-attribute
registers for initialization.
Changelog:
* use ARRAY_SIZE for num_resources, Russell King
* master.kernel.org:/home/rmk/linux-2.6-arm: (22 commits)
[ARM] spelling fixes
[ARM] at91_adc parenthesis balance
[ARM] 4400/1: S3C24XX: Add high-speed MMC device definition
[ARM] 4399/2: S3C2443: Fix SMDK2443 nand timings
[ARM] 4398/1: S3C2443: Fix watchdog IRQ number
[ARM] 4397/1: S3C2443: remove SDI0/1 IRQ ambiguity
[ARM] 4396/1: S3C2443: Add missing HCLK clocks
[ARM] 4395/1: S3C24XX: add include of <linux/sysdev.h> to relevant machines
[ARM] 4388/1: no need for arm/mm mmap range checks for non-mmu
[ARM] 4387/1: fix /proc/cpuinfo formatting for pre-ARM7 parts
[ARM] ARMv6: add CPU_HAS_ASID configuration
[ARM] integrator: fix pci_v3 compile error with DEBUG_LL
[ARM] gic: Fix gic cascade irq handling
[ARM] Silence OMAP kernel configuration warning
[ARM] Update ARM syscalls
[ARM] 4384/1: S3C2412/13 SPI registers offset correction
[ARM] 4383/1: iop: fix usage of '__init' and 'inline' in iop files
[ARM] 4382/1: iop13xx: fix msi support
[ARM] Remove Integrator/CP SMP platform support
[ARM] 4378/1: KS8695: Serial driver fix
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
Spelling fixes in arch/arm/.
Signed-off-by: Simon Arlott <simon@fire.lp0.eu>
WARNING: arch/arm/mach-iop13xx/built-in.o - Section mismatch: reference to
.init.text:iop13xx_pcie_map_irq from .text between 'iop13xx_pci_setup' (at
offset 0x7fc) and 'iop13xx_map_pci_memory'
While fixing this warning I also recalled Adrian Bunk's recommendation to
not use inline in .c files, as 'iop13xx_map_pci_memory' is needlessly
inlined.
Removing 'inline' uncovered some dead code so that is cleaned up as well.
updates iop13xx msi support for a msi api change in 2.6.22
rev7:
* update for Michael Ellerman's "MSI: arch must connect the irq and the
msi_desc" patch
Enable devices to signal interrupts via PCI memory cycles.
rev6:
* fix enable/disable typo, Michael Ellerman
rev5:
* fix up ack, enable, and disable for iop13xx_msi_chip
rev4:
* move smp compile fix to separate patch
* use dynamic_irq_init in create_irq()
* hookup mask/unmask routines in iop13xx_msi_chip
rev3:
* change msi.c to use linux/smp.h instead of asm/smp.h
* call dynamic_irq_cleanup at destroy_irq time
rev2:
* destroy_irq did not take the full 128 bits of msi_irq_in_use into account
* added missing '&' for calls to test_and_set_bit and clear_bit
[ebiederm@xmission.com: review comments/suggestions]
[dan.j.williams@intel.com: cleanups/forward port to 2.6-git]
Signed-off-by: Daniel Wolstenholme <daniel.e.wolstenholme@intel.com>
Acked-by: Eric W. Biederman <ebiederm@xmission.com>
'ns9xxx', 'omap', 'pxa', 'rpc', 's3c' and 'sa1100' into devel
__ioremap() took a set of page table flags (specifically the cacheable
and bufferable bits) to control the mapping type. However, with
the advent of ARMv6, this is far too limited.
Replace the page table flags with a memory type index, so that the
desired attributes can be selected from the mem_type table.
Finally, to prevent silent miscompilation due to the differing
arguments, rename the __ioremap() and __ioremap_pfn() functions.
The tpmi units interface with the SAS controller on iop348.
PCI devices were being programmed with an incorrect base address value.
This patch moves I/O space into a 16-bit addressable region and corrects
the i/o offset.
Much thanks to Martin Michlmayr for tracking this issue and testing
debug patches.
Cc: Martin Michlmayr <tbm@cyrius.com>
CC arch/arm/mach-iop13xx/setup.o
arch/arm/mach-iop13xx/setup.c: In function 'iq8134x_probe_flash_size':
arch/arm/mach-iop13xx/setup.c:210: warning: implicit declaration of function 'ioremap'
arch/arm/mach-iop13xx/setup.c:210: warning: initialization makes pointer from integer without a cast
arch/arm/mach-iop13xx/setup.c:218: warning: implicit declaration of function 'writew'
arch/arm/mach-iop13xx/setup.c:222: warning: implicit declaration of function 'readb'
arch/arm/mach-iop13xx/setup.c:231: warning: implicit declaration of function 'iounmap'
LD .tmp_vmlinux1
arch/arm/mach-iop13xx/built-in.o: In function `iop13xx_platform_init':
iq81340mc.c:(.init.text+0x150): undefined reference to `ioremap'
iq81340mc.c:(.init.text+0x21c): undefined reference to `writew'
iq81340mc.c:(.init.text+0x24c): undefined reference to `writew'
iq81340mc.c:(.init.text+0x254): undefined reference to `iounmap'
iq81340mc.c:(.init.text+0x2c4): undefined reference to `readb'
iq81340mc.c:(.init.text+0x2e8): undefined reference to `readb'
* architecture specific details are handled in asm/arch/time.h
* ARCH_IOP13XX now selects PLAT_IOP
* as suggested by Lennert use ifdef CONFIG_XSCALE to skip the cp_wait on
XSC3
This functionality is replaced by cp6_trap
Enable svc access to cp6 via an undefined instruction hook. Do not enable
access for usr code.
This patch also makes iop13xx select PLAT_IOP, this requires a small change
to drivers/i2c/busses/i2c-iop3xx.c.
Per Lennert Buytenhek's note, the cp6 trap routine is moved to arch/arm/plat-iop
Per Nicolas Pitre's note, the cp_wait is skipped since the latency to
return to the faulting function is longer than cp_wait.
Since iop13xx defines the PCI I/O spaces with physical resource addresses
the __io macro needs to perform the physical to virtual conversion. I
incorrectly assumed that this would be handled by ioremap, but drivers
(like e1000) directly dereference the address returned from __io.
* use irq_chip
* use handle_level_irq
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
The struct resource 'end' field is inclusive, the iop13xx flash
setup code got this wrong.
The phys_io/io_pg_offst machine record variables were being set
to bogus values, causing problems when enabling DEBUG_LL.
The iop348 processor integrates an Xscale (XSC3 512KB L2 Cache) core with a
Serial Attached SCSI (SAS) controller, multi-ported DDR2 memory
controller, 3 Application Direct Memory Access (DMA) controllers, a 133Mhz
PCI-X interface, a x8 PCI-Express interface, and other peripherals to form
a system-on-a-chip RAID subsystem engine.
The iop342 processor replaces the SAS controller with a second Xscale core
for dual core embedded applications.
The iop341 processor is the single core version of iop342.
This patch supports the two Intel customer reference platforms iq81340mc
for external storage and iq81340sc for direct attach (HBA) development.
The developer's manual is available here:
ftp://download.intel.com/design/iio/docs/31503701.pdf
Changelog:
* removed virtual addresses from resource definitions
* cleaned up some unnecessary #include's
