[ Upstream commit 2125801ccce19249708ca3245d48998e70569ab8 ]
clang warns about statically defined DMA masks from the DMA_BIT_MASK
macro with length 64:
arch/arm/mach-iop13xx/setup.c:303:35: error: shift count >= width of type [-Werror,-Wshift-count-overflow]
static u64 iop13xx_adma_dmamask = DMA_BIT_MASK(64);
include/linux/dma-mapping.h:141:54: note: expanded from macro 'DMA_BIT_MASK'
#define DMA_BIT_MASK(n) (((n) == 64) ? ~0ULL : ((1ULL<<(n))-1))
The ones in iop shouldn't really be 64 bit masks, so changing them
to what the driver can support avoids the warning.
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
set_irq_flags is ARM specific with custom flags which have genirq
equivalents. Convert drivers to use the genirq interfaces directly, so we
can kill off set_irq_flags. The translation of flags is as follows:
IRQF_VALID -> !IRQ_NOREQUEST
IRQF_PROBE -> !IRQ_NOPROBE
IRQF_NOAUTOEN -> IRQ_NOAUTOEN
For IRQs managed by an irqdomain, the irqdomain core code handles clearing
and setting IRQ_NOREQUEST already, so there is no need to do this in
.map() functions and we can simply remove the set_irq_flags calls. Some
users also modify IRQ_NOPROBE and this has been maintained although it
is not clear that is really needed. There appears to be a great deal of
blind copy and paste of this code.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Cc: Gregory Clement <gregory.clement@free-electrons.com>
Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Imre Kaloz <kaloz@openwrt.org>
Acked-by: Krzysztof Halasa <khalasa@piap.pl>
Cc: Greg Ungerer <gerg@uclinux.org>
Cc: Roland Stigge <stigge@antcom.de>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Daniel Mack <daniel@zonque.org>
Cc: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Simtec Linux Team <linux@simtec.co.uk>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Cc: linux-omap@vger.kernel.org
Cc: linux-samsung-soc@vger.kernel.org
Tested-by: Kevin Hilman <khilman@linaro.org>
frequency
The SI unit of frequency is Hertz, named after Heinrich Hertz, and is
given the symbol "Hz" to denote this. "hz" is not the unit of frequency,
and is in fact meaningless.
Fix arch/arm to correctly use "Hz", thereby acknowledging Heinrich Hertz'
contribution to the modern world.
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Reviewed-by: Andreas Färber <afaerber@suse.de>
The PCI/MSI irq chip callbacks mask/unmask_msi_irq have been renamed
to pci_msi_mask/unmask_irq to mark them PCI specific. Rename all usage
sites. The conversion helper functions are kept around to avoid
conflicts in next and will be removed after merging into mainline.
Coccinelle assisted conversion. No functional change.
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: x86@kernel.org
Cc: Murali Karicheri <m-karicheri2@ti.com>
Cc: Thierry Reding <thierry.reding@gmail.com>
Cc: Mohit Kumar <mohit.kumar@st.com>
Cc: Simon Horman <horms@verge.net.au>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Yijing Wang <wangyijing@huawei.com>
Rename write_msi_msg() to pci_write_msi_msg() to mark it as PCI
specific.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Yingjoe Chen <yingjoe.chen@mediatek.com>
Clearing obj-y, obj-m, obj-n, obj- in each Makefile is
a useless habit.
They are non-exported variables; therefore they are always empty
whenever descending into each subdirectory.
(Moreorver, obj-y and obj-m are also set to empty at the beginning
of scripts/Makefile.build)
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Peter Foley <pefoley2@pefoley.com>
<mach/memory.h>
The platforms selecting NEED_MACH_MEMORY_H defined the start address of
their physical memory in the respective <mach/memory.h>. With
ARM_PATCH_PHYS_VIRT=y (which is quite common today) this is useless
though because the definition isn't used but determined dynamically.
So remove the definitions from all <mach/memory.h> and provide the
Kconfig symbol PHYS_OFFSET with the respective defaults in case
ARM_PATCH_PHYS_VIRT isn't enabled.
This allows to drop the dependency of PHYS_OFFSET on !NEED_MACH_MEMORY_H
which prevents compiling an integrator nommu-kernel.
(CONFIG_PAGE_OFFSET which has "default PHYS_OFFSET if !MMU" expanded to
"0x" because CONFIG_PHYS_OFFSET doesn't exist as INTEGRATOR selects
NEED_MACH_MEMORY_H.)
After applying patch:
"ARM: 8078/1: get rid of hardcoded assumptions about kernel stack size"
following build failure happens on iop13xx platform:
In file included from include/linux/srcu.h:33:0,
from include/linux/notifier.h:15,
from include/linux/reboot.h:5,
from arch/arm/mach-iop13xx/include/mach/iop13xx.h:6,
from arch/arm/mach-iop13xx/include/mach/hardware.h:14,
from arch/arm/mach-iop13xx/include/mach/memory.h:4,
from arch/arm/include/asm/memory.h:24,
from arch/arm/include/asm/page.h:163,
from arch/arm/include/asm/thread_info.h:17,
from include/linux/thread_info.h:54,
from include/asm-generic/preempt.h:4,
from arch/arm/include/generated/asm/preempt.h:1,
from include/linux/preempt.h:18,
from include/linux/spinlock.h:50,
from include/linux/seqlock.h:35,
from include/linux/time.h:5,
from include/uapi/linux/timex.h:56,
from include/linux/timex.h:56,
from include/linux/sched.h:19,
from arch/arm/kernel/asm-offsets.c:13:
include/linux/rcupdate.h: In function '__rcu_read_lock':
>> include/linux/rcupdate.h:220:2: error: implicit declaration of function 'preempt_disable' [-Werror=implicit-function-declaration]
preempt_disable();
The problem here is recursive header inclusion which could be avoided by
removing linux/reboot.h from mach/iop13xxx.h.
linux/reboot.h in include/mach/iop13xx.h is needed only for enum reboot_mode,
so header it could be replaced with a enum declaration.
Whatever patch "ARM: 8078/1: get rid of hardcoded assumptions about kernel stack size"
does, I think it's good to avoid unnecessary header inclusion here in any case.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
patch 37ebbcff7837 ("arm: iop13xx: Use sparse irqs for MSI") moved
iop13xx over to sparse IRQ support, but this broke the build for the
msi.c file, which now has to include mach/irqs.h itself.
Link: http://lkml.kernel.org/r/12285212.fBJyVfk69p@wuerfel
No need for a private allocator. The core code handles it
already.
Allocate the non MSI irqs right at boot time via machine_desc->nr_irqs
and let the sparse core handle the MSI space.
Reviewed-by: Grant Likely <grant.likely@linaro.org>
Cc: Dan Williams <dan.j.williams@intel.com>
Link: http://lkml.kernel.org/r/20140507154333.809210026@linutronix.de
While <mach/timex.h> isn't used for multi-platform builds since long it
still is for "normal" builds. As the previous patches fix all sites to
not make use of this per-platform file, it can go now for good also for
platforms that are not (yet) converted to multi-platform.
While at it there are no users of CLOCK_TICK_RATE any more, so also drop
the dummy #define.
Remove support for DMA unmapping from drivers as it is no longer
needed (DMA core code is now handling it).
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Tomasz Figa <t.figa@samsung.com>
Cc: Dave Jiang <dave.jiang@intel.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
[djbw: fix up chan2parent() unused warning in drivers/dma/dw/core.c]
Now that the 8250 debug include can stand alone without requiring
platforms to provide any macros, move it into the debug directory
so it can be directly included. This allows us to get rid of a lot
of debug-macros include files.
Move the definition of the UART register addresses out of the platform
specific header file into the Kconfig files.
Move the definition of the UART register shift out of the platform
Preparing to move the parsing of reboot= to generic kernel code forces
the change in reboot_mode handling to use the enum.
[akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c]
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
There have never been any real users of MEMSET operations since they
have been introduced in January 2007 by commit 7405f74badf4 ("dmaengine:
refactor dmaengine around dma_async_tx_descriptor"). Therefore remove
support for them for now, it can be always brought back when needed.
[sebastian.hesselbarth@gmail.com: fix drivers/dma/mv_xor]
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Acked-by: Dan Williams <djbw@fb.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Olof Johansson <olof@lixom.net>
Cc: Kevin Hilman <khilman@linaro.org>
Several of the ioremap functions use unsigned long in places
resulting in truncation if physical addresses greater than
4G are passed in. Change the types of the functions and the
callers accordingly.
Cc: Krzysztof Halasa <khc@pm.waw.pl>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
git://git.linaro.org/people/shawnguo/linux-2.6 into next/cleanup
From Shawn Guo:
The series cleans up ARCH_HAS_DECOMP_WDOG and arch_decomp_wdog which
are unused on ARM architecure. Samsung has some code setting up wdog
in arch_decomp_wdog(). But since CONFIG_S3C_BOOT_WATCHDOG is defined
nowhere, it will not run. Otherwise, system can not boot at all when
wdog is set up but no one pats it.
* tag 'cleanup-decompwdog-3.9' of git://git.linaro.org/people/shawnguo/linux-2.6:
ARM: samsung: remove unused arch_decomp_wdog() code
ARM: remove unused arch_decomp_wdog()
ARM: decompress: remove unused ARCH_HAS_DECOMP_WDOG
Clockevent cleanup series from Shawn Guo.
Resolved move/change conflict in mach-pxa/time.c due to the sys_timer
cleanup.
* clocksource/cleanup:
clocksource: use clockevents_config_and_register() where possible
ARM: use clockevents_config_and_register() where possible
clockevents: export clockevents_config_and_register for module use
+ sync to Linux 3.8-rc3
arch/arm/mach-pxa/time.c
With ARCH_HAS_DECOMP_WDOG removed from arch/arm/boot/compressed/decompress.c,
all the arch_decomp_wdog() definition at platform level is unneeded.
Remmove it.
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Jason Cooper <jason@lakedaemon.net>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
This is a series from Arnd that fixes a number of compiler warnings
when building defconfigs on ARM.
* late/fixes:
ARM: footbridge: nw_gpio_lock is raw_spin_lock
ARM: mv78xx0: correct addr_map_cfg __initdata annotation
ARM: footbridge: remove RTC_IRQ definition
ARM: soc: dependency warnings for errata
ARM: ks8695: __arch_virt_to_dma type handling
ARM: rpc: check device_register return code in ecard_probe
ARM: davinci: don't mark da850_register_cpufreq as __init
ARM: iop13xx: fix iq81340sc_atux_map_irq prototype
ARM: iop13xx: mark iop13xx_scan_bus as __devinit
ARM: mv78xx0: mark mv78xx0_timer_init as __init_refok
ARM: s3c24xx: fix multiple section mismatch warnings
ARM: at91: unused variable in at91_pm_verify_clocks
ARM: at91: skip at91_io_desc definition for NOMMU
ARM: pxa: work around duplicate definition of GPIO24_SSP1_SFRM
ARM: pxa: remove sharpsl_fatal_check function
ARM: pxa: define palmte2_pxa_keys conditionally
ARM: pxa: Wunused-result warning in viper board file
ARM: shark: fix shark_pci_init return code
Fixed trivial conflicts in arch/arm/mach-at91/setup.c.
The pci map_irq callbacks get a 'const' pci_dev argument, so change the
iop13xx version to use the same prototype as everything else.
Without this patch, building iop13xx_defconfig results in:
arch/arm/mach-iop13xx/iq81340sc.c:63:2: warning: initialization from incompatible pointer type [enabled by default]
arch/arm/mach-iop13xx/iq81340sc.c:63:2: warning: (near initialization for 'iq81340sc_pci.map_irq') [enabled by default]
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Cc: Dan Williams <djbw@fb.com>
pci_scan_root_bus is __devinit, so iop13xx_scan_bus has to be the
same in order to safely call it. This is ok because the function
itself is only called from the hwpci->scan callback.
WARNING: vmlinux.o(.text+0x10138): Section mismatch in reference from the function iop13xx_scan_bus() to the function .devinit.text:pci_scan_root_bus()
The function iop13xx_scan_bus() references
the function __devinit pci_scan_root_bus().
This is often because iop13xx_scan_bus lacks a __devinit
annotation or the annotation of pci_scan_root_bus is wrong.
__iomem annotation cleanup branch from Arnd.
* cleanup/__iomem: (21 commits)
net: seeq: use __iomem pointers for MMIO
video: da8xx-fb: use __iomem pointers for MMIO
scsi: eesox: use __iomem pointers for MMIO
serial: ks8695: use __iomem pointers for MMIO
input: rpcmouse: use __iomem pointers for MMIO
ARM: samsung: use __iomem pointers for MMIO
ARM: spear13xx: use __iomem pointers for MMIO
ARM: sa1100: use __iomem pointers for MMIO
ARM: prima2: use __iomem pointers for MMIO
ARM: nomadik: use __iomem pointers for MMIO
ARM: msm: use __iomem pointers for MMIO
ARM: lpc32xx: use __iomem pointers for MMIO
ARM: ks8695: use __iomem pointers for MMIO
ARM: ixp4xx: use __iomem pointers for MMIO
ARM: iop32x: use __iomem pointers for MMIO
ARM: iop13xx: use __iomem pointers for MMIO
ARM: integrator: use __iomem pointers for MMIO
ARM: imx: use __iomem pointers for MMIO
ARM: ebsa110: use __iomem pointers for MMIO
ARM: at91: use __iomem pointers for MMIO
ARM is moving to stricter checks on readl/write functions,
so we need to use the correct types everywhere.
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Move iop13xx PCI to fixed i/o mapping and remove io.h.
This changes the PCIe bus address to start at 0x10000. Let's hope this
works. If it does not, the alternative would be to revert the value we
write into OIOTVR to zero and set sys->io_offset to 64K.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
iop13xx confuses I/O port numbers with physical addresses, which breaks
legacy ISA I/O access behind PCI bridges and makes it unnecessarily hard
to unify the inb/outb accessors with other platforms. This removes the
special-casing and just puts all I/O ports into a single 128KB virtually
mapped I/O port range starting at port zero.
Most PCI implementations use the standard PCI swizzle function, which
handles the well defined behaviour of PCI-to-PCI bridges which can be
found on cards (eg, four port ethernet cards.)
Rather than having almost every platform specify the standard swizzle
function, make this the default when no swizzle function is supplied.
Therefore, a swizzle function only needs to be provided when there is
something exceptional which needs to be handled.
This gets rid of the swizzle initializer from 47 files, and leaves us
with just two platforms specifying a swizzle function: ARM Integrator
and Chalice CATS.
Acked-by: Krzysztof Hałasa <khc@pm.waw.pl>
Pull "ARM: cleanups of io includes" from Olof Johansson:
"Rob Herring has done a sweeping change cleaning up all of the
mach/io.h includes, moving some of the oft-repeated macros to a common
location and removing a bunch of boiler plate. This is another step
closer to a common zImage for multiple platforms."
Fix up various fairly trivial conflicts (<mach/io.h> removal vs changes
around it, tegra localtimer.o is *still* gone, yadda-yadda).
* tag 'cleanup2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (29 commits)
ARM: tegra: Include assembler.h in sleep.S to fix build break
ARM: pxa: use common IOMEM definition
ARM: dma-mapping: convert ARCH_HAS_DMA_SET_COHERENT_MASK to kconfig symbol
ARM: __io abuse cleanup
ARM: create a common IOMEM definition
ARM: iop13xx: fix missing declaration of iop13xx_init_early
ARM: fix ioremap/iounmap for !CONFIG_MMU
ARM: kill off __mem_pci
ARM: remove bunch of now unused mach/io.h files
ARM: make mach/io.h include optional
ARM: clps711x: remove unneeded include of mach/io.h
ARM: dove: add explicit include of dove.h to addr-map.c
ARM: at91: add explicit include of hardware.h to uncompressor
ARM: ep93xx: clean-up mach/io.h
ARM: tegra: clean-up mach/io.h
ARM: orion5x: clean-up mach/io.h
ARM: davinci: remove unneeded mach/io.h include
[media] davinci: remove includes of mach/io.h
ARM: OMAP: Remove remaining includes for mach/io.h
ARM: msm: clean-up mach/io.h
Pull #1 ARM updates from Russell King:
"This one covers stuff which Arnd is waiting for me to push, as this is
shared between both our trees and probably other trees elsewhere.
Essentially, this contains:
- AMBA primecell device initializer updates - mostly shrinking the
size of the device declarations in platform code to something more
reasonable.
- Getting rid of the NO_IRQ crap from AMBA primecell stuff.
- Nicolas' idle cleanups. This in combination with the restart
cleanups from the last merge window results in a great many
mach/system.h files being deleted."
Yay: ~80 files, ~2000 lines deleted.
* 'for-armsoc' of git://git.linaro.org/people/rmk/linux-arm: (60 commits)
ARM: remove disable_fiq and arch_ret_to_user macros
ARM: make entry-macro.S depend on !MULTI_IRQ_HANDLER
ARM: rpc: make default fiq handler run-time installed
ARM: make arch_ret_to_user macro optional
ARM: amba: samsung: use common amba device initializers
ARM: amba: spear: use common amba device initializers
ARM: amba: nomadik: use common amba device initializers
ARM: amba: u300: use common amba device initializers
ARM: amba: lpc32xx: use common amba device initializers
ARM: amba: netx: use common amba device initializers
ARM: amba: bcmring: use common amba device initializers
ARM: amba: ep93xx: use common amba device initializers
ARM: amba: omap2: use common amba device initializers
ARM: amba: integrator: use common amba device initializers
ARM: amba: realview: get rid of private platform amba_device initializer
ARM: amba: versatile: get rid of private platform amba_device initializer
ARM: amba: vexpress: get rid of private platform amba_device initializer
ARM: amba: provide common initializers for static amba devices
ARM: amba: make use of -1 IRQs warn
ARM: amba: u300: get rid of NO_IRQ initializers
Commit 1dfe34ae794c13 (ARM: iop13xx: use runtime ioremap hook) missed
a declaration of iop13xx_init_early resulting in a build error.
__mem_pci is only used to enable readl/writel and friends. Just condition
this on readl being defined and remove all the __mem_pci defines.
Cc: Nicolas Pitre <nico@fluxnic.net>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Colin Cross <ccross@android.com>
Cc: Stephen Warren <swarren@nvidia.com>
These variables are just needed in pci.c and io.c, so move them out of
io.h in preparation to remove io.h.
Convert iop13xx platforms to use run-time ioremap hook instead of the
compile time hook. The custom ioremap is still needed for 64-bit address
handling.
Tell the PCI core about host bridge address translation so it can take
care of bus-to-resource conversion for us.
CC: Russell King <linux@arm.linux.org.uk>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
into for-armsoc
Now that most platforms don't need disable_fiq and arch_ret_to_user
macros, we can remove the empty macros or empty entry-macro.S files.
Acked-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Ryan Mallon <rmallon@gmail.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
When this is the only content remaining in mach/system.h then the
whole file is removed.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-and-tested-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: David Brown <davidb@codeaurora.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (80 commits)
x86/PCI: Expand the x86_msi_ops to have a restore MSIs.
PCI: Increase resource array mask bit size in pcim_iomap_regions()
PCI: DEVICE_COUNT_RESOURCE should be equal to PCI_NUM_RESOURCES
PCI: pci_ids: add device ids for STA2X11 device (aka ConneXT)
PNP: work around Dell 1536/1546 BIOS MMCONFIG bug that breaks USB
x86/PCI: amd: factor out MMCONFIG discovery
PCI: Enable ATS at the device state restore
PCI: msi: fix imbalanced refcount of msi irq sysfs objects
PCI: kconfig: English typo in pci/pcie/Kconfig
PCI/PM/Runtime: make PCI traces quieter
PCI: remove pci_create_bus()
xtensa/PCI: convert to pci_scan_root_bus() for correct root bus resources
x86/PCI: convert to pci_create_root_bus() and pci_scan_root_bus()
x86/PCI: use pci_scan_bus() instead of pci_scan_bus_parented()
x86/PCI: read Broadcom CNB20LE host bridge info before PCI scan
sparc32, leon/PCI: convert to pci_scan_root_bus() for correct root bus resources
sparc/PCI: convert to pci_create_root_bus()
sh/PCI: convert to pci_scan_root_bus() for correct root bus resources
powerpc/PCI: convert to pci_create_root_bus()
powerpc/PCI: split PHB part out of pcibios_map_io_space()
Fix up conflicts in drivers/pci/msi.c and include/linux/pci_regs.h due
to the same patches being applied in other branches.
Convert from pci_scan_bus() to pci_scan_root_bus() and remove root bus
resource fixups. This fixes the problem of "early" and "header" quirks
seeing incorrect root bus resources.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
arch/arm/mach-exynos/cpu.c
The changes to arch/arm/mach-exynos/cpu.c were moved to
mach-exynos/common.c.
Remove the now empty arch_reset() from all the mach/system.h includes,
and remove its callsite. Remove arm_machine_restart() as this function
no longer does anything useful.
For samsung platforms, remove the include of mach/system-reset.h and
plat/system-reset.h from their respective mach/system.h headers as these
just define their arch_reset functions. As a result, the s3c2410 and
plat-samsung system-reset.h files are no longer referenced, so remove
these files entirely.
Hook these platforms restart code into the new restart hook rather
than using arch_reset().
Acked-by: Lennert Buytenhek <buytenh@wantstofly.org>
These files all make use of one of the EXPORT_SYMBOL variants
or the THIS_MODULE macro. So they will need <linux/export.h>
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits)
ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET
ARM: gic, local timers: use the request_percpu_irq() interface
ARM: gic: consolidate PPI handling
ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H
ARM: mach-s5p64x0: remove mach/memory.h
ARM: mach-s3c64xx: remove mach/memory.h
ARM: plat-mxc: remove mach/memory.h
ARM: mach-prima2: remove mach/memory.h
ARM: mach-zynq: remove mach/memory.h
ARM: mach-bcmring: remove mach/memory.h
ARM: mach-davinci: remove mach/memory.h
ARM: mach-pxa: remove mach/memory.h
ARM: mach-ixp4xx: remove mach/memory.h
ARM: mach-h720x: remove mach/memory.h
ARM: mach-vt8500: remove mach/memory.h
ARM: mach-s5pc100: remove mach/memory.h
ARM: mach-tegra: remove mach/memory.h
ARM: plat-tcc: remove mach/memory.h
ARM: mach-mmp: remove mach/memory.h
ARM: mach-cns3xxx: remove mach/memory.h
Fix up mostly pretty trivial conflicts in:
- arch/arm/Kconfig
- arch/arm/include/asm/localtimer.h
- arch/arm/kernel/Makefile
- arch/arm/mach-shmobile/board-ap4evb.c
- arch/arm/mach-u300/core.c
- arch/arm/mm/dma-mapping.c
- arch/arm/mm/proc-v7.S
- arch/arm/plat-omap/Kconfig
largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP ->
CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and
addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
